DewGew
Domoticz version: V4.10618
Re: machinon theme
Post by DewGew »
EdwinK wrote: Monday 25 March 2019 22:09 I like this theme, but it looks a bit too compact, even with the dashboard setting to normal.
For example:
What can I do to change this so the information on tiles can be read?
Wich browser do you use? Seems like You have cache problems clear cache including app-cache.
EdwinK
Re: machinon theme
Post by EdwinK »
DewGew wrote: Tuesday 26 March 2019 7:29
For example:
Using Chrome on Mac. Already did some cache clearing.
Hobbybob
Re: machinon theme
Post by Hobbybob »
Hobbybob wrote: Thursday 07 March 2019 18:54 I also have the problem with the labels overlapping the values. It happens on the dashboard and also on the other tabs. The Switches-tab is okay though.
I am running the 1.6.0 version of Machinon (a git pull also stated I was up-to-date), and I use Domoticz Stable (4.9700). I also cleared my cache and opened it in a private browsing-tab to prevent any old stuff from interfering. I attached a screenshot.
Is there anything else I can provide to help?
Anything that can be done about this? It looks like it is persistent... Cleared cache and app-cache and opened it in a private browsing-tab...
credenty
Re: machinon theme
Post by credenty »
Good Morning,
To say that this thema is great, I love it.
I have an old iPad 2 mounted on the wall, this iPad has a resolution of 1024x768, in this iPad I can not see this thema correctly nor does it appear the possibility of modifying it. Indicate that only happens on the iPad 2, I have tested several computers and without problems, they all work perfectly, so I understand that it must be a limitation of the iPad 2. I have deleted the cache, I have tested with several browsers, I have reviewed that the cokis are active.
https://support.apple.com/kb/SP622?loca ... cale=en_US
Thank you very much and greetings.
EdddieN
Domoticz version: 4.9700
Re: machinon theme
Post by EdddieN »
Do you get the same on chrome?
11101101 - www.machinon.com
credenty
Re: machinon theme
Post by credenty »
EdddieN wrote: Saturday 30 March 2019 10:05 Do you get the same on chrome?
The chrome I can not install on the iPad 2, since it has IOS 9. But on other devices it goes correctly.
credenty
Re: machinon theme
Post by credenty »
EdddieN
Re: machinon theme
Post by EdddieN »
I would try with any other browsers you could load. It is going to be a bit tough to debug for anyone without an iPad 2. From the image it looks like some JS is not loading correctly... but I’m not expert
DewGew
Re: machinon theme
Post by DewGew »
New version released. Get machinon theme v1.6.9 at https://github.com/EdddieN/machinon-domoticz_theme
lamptah
Re: machinon theme
Post by lamptah »
Very nice theme! One issue so far, using latest version v1.6.9.
I have a switch that is tied to a motion sensor. As a result, for the standard 30 days the log shows ~12,800 entries. Using the standard theme, the log and graphs are displayed properly after a ~5s lag before the data shows. Using machinon theme, the webpage freezes and no data is being displayed for about 3 minutes until it actually shows the log data.
How come rendering the same data in log display takes 3 minutes in machinon theme and 5 seconds in default theme? Any way to improve that?
Thanks very much for this very nice theme! :D
EdwinK
Re: machinon theme
Post by EdwinK »
Looking much better now. Only thing now is:
Schermafbeelding 2019-04-07 om 09.02.16.png (24.94 KiB) Viewed 5308 times
Btw.. Is this not needed anymore:
Copy settings.html in templates folder to
sudo cp ~/domoticz/www/styles/machinon/templates/Settings.html ~/domoticz/www/templates/
DewGew
Re: machinon theme
Post by DewGew »
EdwinK wrote: Sunday 07 April 2019 9:03 Looking much better now. Only thing now is:
No need to copy this file anymore. You can delete it from templates folder if you have latest version
quirk
Re: machinon theme
Post by quirk »
It's fixed in the beta branch :)
EdwinK
Re: machinon theme
Post by EdwinK »
Great. Going to get the new beta ;)
Still is there, even after clearing cache and appcache internals
DewGew
Re: machinon theme
Post by DewGew »
EdwinK wrote: Wednesday 10 April 2019 10:38 Great. Going to get the new beta ;)
Rezise your window you will see its responsive.
DewGew
Re: machinon theme
Post by DewGew »
Try out latest beta with camera preview on dashboard:
To use it:
  • You need to attach a switch to your camera (create a switch then in Settings/Camera, add the switch to the camera)
  • Add the switch to the dashboard
Hobbybob
Re: machinon theme
Post by Hobbybob »
DewGew wrote: Wednesday 24 April 2019 7:30 Try out latest beta with camera preview on dashboard:
To use it:
That looks really good! My compliments!
EdddieN
Re: machinon theme
Post by EdddieN »
felix63
Domoticz version: 2020.1
Re: machinon theme
Post by felix63 »
Just installed the beta. When changing settings I get: Unable to create or update theme settings uservariable, Try to reset the theme
But I don't know how to reset the theme! Any pointers?
EdwinK
Re: machinon theme
Post by EdwinK »
It's in settings/settings/theme/
then scroll down that page. There will be a button tht says 'reset'.
