Page 25 of 49
Re: Dashticz - Module - Garbage collector
Posted: Thursday 15 March 2018 19:58
by Aussi
EdwinK wrote: Wednesday 14 March 2018 22:48 You change those in CONFIG.js
Really ? Cause I don't see any of those codes in my CONFIG.js ? :( :roll:
Not even from other blocks which are visible on the dashticz interface
Posted: Friday 23 March 2018 16:37
by Alphons
Is it possible to use the Wastebin Module from the MagicMirror project? Looks very simple en customizable.
Posted: Tuesday 24 April 2018 22:29
by robgeerts
Aussi wrote: Thursday 15 March 2018 19:58
Could you reply with the contents of your CONFIG.js?
Or take a look at CONFIG_DEFAULT.js
Posted: Thursday 03 May 2018 19:09
by Venzent
Is er een werkende voor Almere, krijg ze met de bekende geen info terug.
Posted: Thursday 03 May 2018 19:35
by Venzent
Venzent wrote: Thursday 03 May 2018 19:09 Is er een werkende voor Almere, krijg ze met de bekende geen info terug.
Heb hem al, de "almere" werkt gewoon, bleek alleen niet snel genoeg te reageren.
Posted: Tuesday 08 May 2018 17:28
by Vomera
Hi!
I was wondering if Maastricht also will be supported.
I searched for the website they are using.
They use:
https://www.rd4info.nl/NSI/Burger/Aspx/ ... neral.aspx
How can i or the developer implement this in the garbage collector ? :)
Edit: Not needed anymore, checked the garbage js file and i saw rd4 is supported
Posted: Sunday 13 May 2018 10:08
by Vomera
Does someone know why the garbage text is darker then the rest of the buttons ?
It looks like the "button" is disabled
Posted: Monday 14 May 2018 18:21
by aiolos
Vomera wrote: Sunday 13 May 2018 10:08 Does someone know why the garbage text is darker then the rest of the buttons ?
The text for the bins is given in the color of the bins, so for the grey bin, it's grey. You can change this with the following part in config.js:
config['garbage'] = {
    gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
    pmd: {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
    rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
    papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
    kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
    brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
    black: {kliko: 'black', code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
    kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},
You can change the #xxyyzz codes above to whatever you like, and you can lookup a color with for example a hex color picker (https://www.google.com/search?q=hex+color+picker)
Posted: Tuesday 15 May 2018 11:27
by Vomera
:oops: :roll: what it that simple :lol: i didnt look at the hex of the colors. i changed it and now i have the right colors haha thank you very much!!!
Posted: Tuesday 12 June 2018 9:52
by wmmudde
Hello guys,
The garbage calendar and the other calendars are not working anymore since today.
Any suggestions?
Wesley
Posted: Thursday 14 June 2018 12:12
by robgeerts
Working over here...
Do you get any errors in console-window (F12 on Windows) ?
Posted: Sunday 01 July 2018 21:43
by jdemas
Hi Rob,
RD4 has renamed the BEST to BEST-tas , and isn't showing anymore :o ,
it will probbely because of the - in between. maybe the the best way is to trim of afther 4characters.
regards Jeffrey
Posted: Monday 02 July 2018 15:24
by jdemas
or the problem is that 2 things will be collected on 1 day
regards Jeffrey
Posted: Sunday 08 July 2018 16:03
by mvveelen
I got lost in the thread. I had the HVC working in the old version of Dashticz and can't see how to get it working in the latest version. The settings won't save, so I have to add it manually to the CONFIG.js, but how ? Anyone who can help me out?
Edit: nevermind, I figured it out, using the wiki.
Posted: Monday 13 August 2018 14:01
by Derik
Dear All.
Perhaps someone that have just a simple ical format for garbage in "betuwe"?
Like the dash only for my WAF perhaps better a calendar message....
Posted: Saturday 25 August 2018 11:15
by peet3kabo
Rob, is it possible to implement the Omrin afvalkalender?
There is an app available from them, maybe to get the info you need? App called "Omrin Afval"
Otherwise it's only a PDF that you get and then I will try to implement it as an Ical into Dashicz but have to figure out how that goes,
Posted: Thursday 06 September 2018 21:22
by amauryverschooren
Hello Rob, i can't get my garbage list to work. I did eveything that was said in the forum but i won't work. can you have a look at my Config?
regards Amaury
Posted: Thursday 06 September 2018 21:55
by HansieNL
amauryverschooren wrote: Thursday 06 September 2018 21:22 Hello Rob, i can't get my garbage list to work. I did eveything that was said in the forum but i won't work. can you have a look at my Config?
regards Amaury
Dear Amaury,
Maybe you can post your config.js as code. You can do that by selecting </>
Posted: Thursday 06 September 2018 21:59
HansieNL wrote: Thursday 06 September 2018 21:55
regards Amaury
Dear Amaury,
Here you go.
var config = {}
config['language'] = 'nl_NL'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SE
config['domoticz_ip'] = 'http://192.168.0.185:8080';
config['app_title'] = 'Dashboard';
config['domoticz_refresh'] = '0.1';
config['default_news_url'] = '';
config['news_scroll_after'] = '7';
config['standby_after'] = 0;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'slide';
config['standard_graph'] = 'hours';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = 0;
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 'XXX';
config['gm_zoomlevel'] = '8';
config['gm_latitude'] = 'XXX';
config['gm_longitude'] = 'XXX';
config['wu_api'] = '40e147012dd3f272';
config['wu_city'] = 'Rapenberg';
config['wu_name'] = 'in Bazel';
config['wu_country'] = 'BE';
config['idx_moonpicture'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 'd065b50c667940208f2bb2931f77e315';
config['garbage_company'] = 0;
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = 0;
config['garbage_street'] = 0;
config['garbage_housenumber'] = 0;
config['garbage_maxitems'] = 0;
config['garbage_width'] = 0;
config['selector_instead_of_buttons'] = 0;
config['auto_positioning'] = 0;
config['use_favorites'] = 1;
config['last_update'] = 0;
config['hide_topbar'] = 0;
config['hide_seconds'] = 1;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
var trashcan = {}
trashcan.ophaalkalender = { trashapp: 'ophaalkalender', width:6,street:'kerkstraat',zipcode:'9150', country:'BE' }
var trashnames = {}
trashnames['Rest'] = 'Restafval';
trashnames['Gft'] = 'GFT';
trashnames['Pmd'] = 'Plastic';
var trashcolors = {}
trashcolors['Gft'] = 'Lime';
trashcolors['Pmd'] = 'Orange';
var _HOST_ZIGGO_HORIZON = ''; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND = 'xxxxxxxxx';
var _WEATHER_CITY = 'Kruibeke';
var _WEATHER_CITYNAME = ''; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY = 'BE';
var _USE_AUTO_POSITIONING = false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES = false; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK = false; //do not show the seconds in the clock
var _NEWS_RSSFEED = 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT = false;
var _USE_BEAUFORT = false; //Bft instead of m/s
var _TRANSLATE_SPEED = false; //windspeed, north northwest instead of NNW
var _STANDBY_AFTER_MINUTES = false; //enter amount of minutes like: 5 (5 minutes)
var _SCROLL_NEWS_AFTER = 7000; //milliseconds, so 7000 is 7 seconds
var _SHOW_LASTUPDATE = true;
var _LASTUPDATE_FORMAT = 'DD-MM-YY HH:mm';
var _SCREENSLIDER_EFFECT = 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip'
// Online Radio Stream Plugin, Note: you must enable plugin in column section 'streamplayer'
var _STREAMPLAYER_TRACKS = [
{"track":1,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
{"track":2,"name":"Radio 538","file":"http://vip-icecast.538.lw.triple-it.nl/RADIO538_MP3"},
{"track":3,"name":"Arrow Classic Rock","file":"http://www.garnierstreamingmedia.com/as ... stream=205"},
{"track":4,"name":"Radio Veronica","file":"http://live.icecast.kpnstreaming.nl/sky ... GSTR09.mp3"},
{"track":5,"name":"Q-music","file":"http://live.icecast.kpnstreaming.nl/omr ... bantHq.m3u"},
var buttons = {}
buttons.webcam1 = { width:6, isimage:true, refresh:5000, image: 'http://sensored/image.jpg', url: 'http://sensored/image.jpg' }
buttons.webcam2 = { width:6, isimage:true, refresh:5000, image: 'sensored' }
buttons.buienradar = {width:4, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=sensored', url: 'http://www.weeronline.nl/Europa/Nederland/Dordrecht/sensored'}
buttons.nzbget = {width:12, icon: 'fa-download', title: 'NZBget', url: 'http://sensored:6789'}
buttons.log = {key:'log', width:12, icon:'fa-microchip', title: 'Domoticz Log', log:true, level: 2}
//CUSTOM POSITIONING:
//defining wich blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
var blocks = {}
//Groepen & Scenes
//Schakelaars
//Overige
blocks[6] = {}
blocks[6]['width'] = 6;
blocks[6]['title'] = 'Temp. Kamer Amaury:'
blocks[6]['switch'] = true;
blocks[7] = {}
blocks[7]['width'] = 6;
blocks[7]['title'] = 'Temp. Kamer Valerie:'
blocks[7]['switch'] = true;
blocks[8] = {}
blocks[8]['width'] = 6;
blocks[8]['title'] = 'Temp. Woonkamer:'
blocks[8]['switch'] = true;
//Titels
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Temperatuur sensors';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['title'] = 'Scenes';
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['type'] = 'blocktitle';
blocks['blocktitle_3']['title'] = 'Schakelaars';
blocks['blocktitle_4'] = {}
blocks['blocktitle_4']['type'] = 'blocktitle';
blocks['blocktitle_4']['title'] = 'Weer';
blocks['blocktitle_5'] = {}
blocks['blocktitle_5']['type'] = 'blocktitle';
blocks['blocktitle_5']['title'] = 'Radio';
// Kolommen
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['clock','sunrise', 'currentweather_big']
columns[1]['width'] = 2;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1','6','7','8','blocktitle_2']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['blocktitle_3','1','2','5','blocktitle_4','weather']
columns[3]['width'] = 5;
columns[4] = {}
columns[4]['blocks'] = ['currentweather_big']
columns[4]['width'] = 6;
columns[5] = {}
columns[5]['blocks'] = [buttons.buienradar, buttons.radio, buttons.nunl]
columns[5]['width'] = 6;
columns[6] = {}
columns[6]['blocks'] = [trashcan.ophaalkalender]
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg9.jpg';
screens[1]['background_night'] = 'bg12.jpg';
screens[2] = {}
screens[2]['background'] = 'bg9.jpg';
screens[2]['background_night'] = 'bg12.jpg';
screens[2]['columns'] = [4,5,6]
Posted: Thursday 06 September 2018 22:27
by HansieNL
amauryverschooren wrote: Thursday 06 September 2018 21:59
regards Amaury
Dear Amaury,
Here you go.
var config = {}
config['wu_api'] = 'xzxzzxz';
config['spot_clientid'] = 'xzxzx';
var trashcan = {}
trashcan.ophaalkalender = { trashapp: 'zxx', width:6,street:'zxzx',zxzx:'zxzx', country:'BE' }
var trashnames = {}
var _HOST_ZIGGO_HORIZON = ''; //e.g. http://192.168.zx/domoticz/switch_horizon.php';
var buttons = {}
var blocks = {}
//Groepen & Scenes
//Schakelaars
//Overige
blocks[6] = {}
blocks[7] = {}
blocks[8] = {}
//Titels
// Kolommen
var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
columns[4] = {}
columns[5] = {}
columns[6] = {}
var screens = {}
screens[1] = {}
screens[2] = {}
These variables are empty
You can take a look at the wiki https://www.domoticz.com/wiki/Dashticz_ ... _Collector how to do that.
I don't know what version of Dashticz you are using, because variables all have changed. Now it's a mix of very old and new in your config.js.
TIP: Remove personal info from your config.js if you post on a forum.
