Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Madgeni
Re: Controlicz - Easy Domoticz to Alexa Integration
so, I *might* be able to incorporate it into the Alexa skill. I wrote a skill for myself to control Kodi ages ago, but might be able to do something to wire it into Controlicz via Domoticz...
As Controlicz (for Alexa) is stable (i think?) - then I might get started on this.
sach
That would be awesome dude
markk
@Madgenie
Could the Kodi skill also be available for those of us still using the native manual Alexa/Domoticz method you built?
hayman
- Domoticz version: 3.8153
yes i'm using kodi as well
Bluelightcrew
- Domoticz version: 3.6708
Kodi skill would be awesome! I youse your controlicz skill and a trick to control kodi with alexa. I have some dummy switchs,that i put in the floorplan,they start some json links for kodi. So i can start,stop,...
here a examplefor stop: xxx.xxx.xxx.xx:8080/jsonrpc?request={%22jsonrpc%22:%20%222.0%22,%20%22method%22:%20%22Player.Stop%22,%20%22params%22:%20{%20%22playerid%22:%201%20},%20%22id%22:%201}
- michaldobrotka
Hi @madgeni,
since 4th of December controlicz skill is not working properly (at least for me).
At this day all my devices were off, so I checked the forum and found a post about same problem.
I re enabled the skill restarted router and domoticz and it was fine. But after a while (hour or so) I checked alexa app and devices were off again. I tried to use some command and on second try worked. From that day this problem is still here. I come home all is of. I re enable skill every day and is working. But after hour i have to repeat command 2, 3 or even more time until it works. By switching answer is always "OK", by asking on temperature reading is "not responding".
Can you help me? Its diving me mad.
Domoticz on Raspi 3 and slave on ZeroW (running only with Broadlink plugin), Serial Mysensors GW on Arduino nano, Broadlink RM2, Rehau CO2 USB Stick, RF link 433 MHz, 2x Amazon Echo Dot (Controlicz), ESP2866 witk Espeasy, Sonoff
gbCambridge
Re: Easy Domoticz to Alexa Integration
So, if I am reading this right, I have to register a domain name to use this feature? If that is correct, can you point me to an easy/cheap way of arranging this?Madgeni wrote: Thursday 13 July 2017 10:34 Your Domoticz needs to be accessible via the internet - i would suggest implementing ssl https://www.domoticz.com/wiki/Native_HT ... SL_support
Then in the Controlicz site you just need to provide:
domoticz IP/dns name
port no:
domoticz Username
domoticz password
Madgeni
i use noip - it's free, you just have to remember to re-authorise it each month (they send you an email)
freijn
- Domoticz version: Stable
it's beginning to look alot like christmas
https://www.youtube.com/watch?v=5neDBnLUMZM
I do wish everybody a very happy and Controlicz Xmas !
Madgeni
that's brilliant! Merry Christmas
Madgeni
sure, it's here - I think the documentation is incomplete - but code completemarkk wrote: Thursday 07 December 2017 13:57 @Madgenie
https://github.com/madgeni/Alexa_Kodi
Madgeni
status should now be fixedsach wrote: Tuesday 05 December 2017 22:15 Cool! I will give it a go.
I just noticed something else and thought I would check if it's just for me. When checking lights via the app, there is a message saying device is unresponsive. I'm guessing it's trying to get the status of the device as I'm still able to switch on/off/dim but the status in the first instance is always off.
sach
Indeed it is for the lights now. however thermostats and temp sensors are now broken.Madgeni wrote: Monday 11 December 2017 10:30status should now be fixedsach wrote: Tuesday 05 December 2017 22:15 Cool! I will give it a go.
I just noticed something else and thought I would check if it's just for me. When checking lights via the app, there is a message saying device is unresponsive. I'm guessing it's trying to get the status of the device as I'm still able to switch on/off/dim but the status in the first instance is always off.![]()
I'm at work right now so not able to test if they still work with Alexa, but will try tonight.
Madgeni
oh ffs. looking now!
Madgeni
fixed
sach
Indeed it is!
Good job sir!
Good job sir!
Madgeni
watch as it breaks something else..
Chakkie
I've just had a thought. It will be nice if Alexa can report all the temperature sensor at once when I ask Alexa, give me the temperature of all temperature sensors. This may not be possible or too challenging
Madgeni
hi - it's not currently available via Alexa i'm afraid (i mean the functionality doesn't exist within Alexa for me to use)
