Cheap chinese z-wave products
LouiS22
Re: Cheap chinese z-wave products
Post by LouiS22 »
gielie wrote: Monday 13 November 2017 9:35
bink wrote: Friday 10 November 2017 21:07
geezerrr wrote: Tuesday 17 October 2017 13:28 Yes I have! Working very well! One remark it’s a a+++ freezer. Max usage 170watt
Did you need to do anything special to get the energy readings? I currently only get watt, but no kwh data seems to be logged. Tried to get it working by enabling "polling" and changing parameter "6. Configure power report: " to 1 but that doesn't seem to make a difference...
I have the same problem with my neo power plugs, when i exclude/include them again it is back but only a few days. They have been working correctly for months. Maybe this is the downside of cheap chinese plugs.
You have to set parameter 1 (send meter report) to Enable.
gielie
Domoticz version: latest β
Post by gielie »
LouiS22 wrote: Monday 13 November 2017 9:46 You have to set parameter 1 (send meter report) to Enable.
Of Course this is enabled but still no output.
I have various plugs from neo with different application versions 3.93 and 3.70, is there a way to update the versions?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
LouiS22
Post by LouiS22 »
Here's my config: http://ibb.co/hRWv5w
LouiS22
Post by LouiS22 »
gielie wrote: Monday 13 November 2017 11:10
Hm... I have two Neo plugs, both are 3.70. To my knowledge, there's no way to upgrade it by yourself :(
bink
Post by bink »
LouiS22 wrote: Monday 13 November 2017 9:31 With which device? :) Neo? (Sorry, lost between lines)
Yes, NEO Coolcam
bink
Post by bink »
LouiS22 wrote: Monday 13 November 2017 11:21
Mine are application version 3.94. Only paramater I found different with your config is the update interval. I now changed it to 30 as well. Lets see if that makes a difference. Do you have polling enabled or disabled?
LouiS22
Post by LouiS22 »
bink wrote: Monday 13 November 2017 17:18
Disabled!
havnegata
Domoticz version: V4.10162
Post by havnegata »
LouiS22 wrote: Monday 13 November 2017 11:21 Hm... I have two Neo plugs, both are 3.70. To my knowledge, there's no way to upgrade it by yourself :(
Disabled!
Can you tell why you have polling disabled?
lost
Post by lost »
havnegata wrote: Tuesday 14 November 2017 8:28 Can you tell why you have polling disabled?
Modules usually have parameters to tune their info reporting (% of a value change etc...), thus enabling pooling should be for (old?) modules that does not have such parameters. Otherwise it's an added load on the z-wave network to mostly get values with no significant change.
To sum-up: It's not recommended for most setups.
On my side only one z-wave module is pooled every 30s: A Siren that is also battery backed (to avoid false positives on power outages as my RPI+modem are also battery backed).
As my z-wave network also manage an alarm function, If Siren can't be pooled 2 times (thus 1mn) I consider this may be a z-wave jamming by some clever burglar having studied my system and notifications are sent.
LouiS22
Post by LouiS22 »
Disabled!
Polling is not needed when the device sends regular reports. The socket sends new data within the configured period (for example 30 seconds).
havnegata
Post by havnegata »
LouiS22 wrote: Disabled!
Probably impossible to answer this, but would you say there are specific devices that need polling? I've only learned to avoid polling of battery powered devices.
krizzz
Post by krizzz »
I would like to add domotica possibilities to my washing machine. Who dares to put a neo coolcam plug on there washing machine?
blacksn0w
Post by blacksn0w »
I'm using one of them at my dish washing machine and it's working flawlessly within Domoticz, now I can see directly when the machine have finished its work and tell my wife that she can clear it :D
There are some significant spikes, but the plug should be able to handle up to 3kW, so no problem at all.
krizzz
Post by krizzz »
blacksn0w wrote:I'm using one of them at my dish washing machine and it's working flawlessly within Domoticz, now I can see directly when the machine have finished its work and tell my wife that she can clear it :D
Thanks!! Good input. Since the plugs are specified for max 2.000 watts on there website this is probably continious use and not peaks. Because yours Can manage!
My washing machine is rated on 2.200 watts so therefore my question and looking to your stats i am probably good.
How does your machine work btw, 2x cyclus of heating every time?
N1co
Post by N1co »
LouiS22 wrote: Saturday 01 July 2017 8:10 Just a quick feedback.
Arrived yesterday: https://www.aliexpress.com/item/Z-wave- ... 0.0.QIDx6w
As I initially suspected, this is Heiman's smoke sensor - and it really is, detected as Smart Sensor HS1SA. The package is a pain white box with only chinese manual included, but you can find a detailed english version at z-wave alliance database. There's not much to configure, only wake-up time :) The inclusion a bit tricky: there's a small hole on the side of the device, you have to put a thin nail or something similar to it, an push it three times. Did a test, it's a noisy beep-beep-beep :D
Does it have battery percentage feedback?
LouiS22
Post by LouiS22 »
N1co wrote: Thursday 23 November 2017 21:12
Yes.
sincze
Domoticz version: 2024.4
Post by sincze »
Any suggestions for a working with Domoticz Zwave DIMMER ? Instead of the € 50+ Fibaro ones?
Power measurement in addition would be nice, but not mandatory :D
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Eyedon
Domoticz version: 3.8153
Post by Eyedon »
Recently I bought @AliExpress a few Z-wave smoke sensors which were recognized as "Heiman Smart Smoke Sensor HS1SA-Z". I did connect 8 of these smoke sensors. Unfortunately at the line of "Alarm Type: Smoke 1 (0x01)" I can see
  • 4 devices give a small green triangle with Event: 0x01 (1)
and
  • 4 devices give a red triangle with Event: 0xFE (254)
I tried to reconnect the ones with the red sign, but there's no change of state of the "Alarm Type: Smoke 1 (0x01) ", the red ones, stay red.
Anyone suggestions?
stefanwo
Post by stefanwo »
Hi, i hope anybody here could help me please.
Anybody have a tipp for me where to order the the NEO Coolcam NAS - SC01ZE (the light switch, which were mentioned here before) in Europe?
I ordered 2 in china, one at gearbest with the only shipping option Belgium Post and it doesnt arrive since 6 weeks now.
The second one were ordered at tomtop with dhl ecommerce asia, it arives in germany but dhl wasnt able to deliver it, only one delivery attempt and no information that they try to. Now it has been sended back to china. :(
But i would love to give them a try, the price is great and because of the switch-hole i cant use a normal switch with the fibaro relais.
Thanks in advance for your help!
PS: I appologize for my bad english. Hope you can understand what i try to say.
Eugene
Post by Eugene »
stefanwo wrote: Friday 01 December 2017 18:10 Hi, i hope anybody here could help me please.
the delivery from china to EU is very slow. i would not even worry about my item being lost earlier than 8weeks. I ordered couple of coolcam switches on sale on aliexpress on 11.11 last year, and they arrived last week. I hope you got your item too.
