Re: dtgbot - Domoticz TeleGram BOT
Posted: Thursday 09 September 2021 1:13
dtgbot is rarely reliable in my experience.
Open source Home Automation System
https://forum.domoticz.com/
/usr/bin/lua5.2: error loading module 'ssl.core' from file '/usr/local/lib/lua/5.2/ssl.so':
libssl.so.1.0.0: cannot open shared object file: No such file or directory
stack traceback:
[C]: in ?
[C]: in function 'require'
/usr/local/share/lua/5.2/ssl.lua:7: in main chunk
/usr/local/share/lua/5.2/ssl/https.lua:10: in main chunk
/home/pi/dtgbot/dtgbot.lua:132: in main chunk
[C]: in ?
Marcello1970 wrote: Thursday 28 February 2019 12:34
Edit the sources.listadd the next line:Code: Select all
sudo nano /etc/apt/sources.list
this linkthis linkCode: Select all
deb http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
Save it with CTRL + X , Y
and then:Then the bot works!Code: Select all
sudo apt-get update sudo apt-get install libssl1.0.0
Thanks to:
https://diyprojects.io/domoticz-install ... HfCKOhKgdW
pi@raspberrypi2:~ $ apt list libssl*
Listing... Done
libssl-dev/oldstable,now 1.1.1d-0+deb10u7 armhf [installed]
libssl-doc/oldstable 1.1.1d-0+deb10u7 all
libssl-ocaml-dev/oldstable 0.5.5-1 armhf
libssl-ocaml/oldstable 0.5.5-1 armhf
libssl-utils-clojure/oldstable 0.8.3-2 all
libssl1.0-dev/oldstable 1.0.2q-2 armhf
libssl1.0.2/oldstable,now 1.0.2q-2 armhf [installed,automatic]
libssl1.1-dbgsym/oldstable 1.1.1d-0+deb10u6+rpt1 armhf
libssl1.1/oldstable,now 1.1.1d-0+deb10u7 armhf [installed]
pi@raspberrypi2:~ $
wget http://ftp.nl.debian.org/debian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u8_armhf.deb
sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u8_armhf.deb
sudo rebootThanks a lot, it works great nowhoeby wrote: Monday 20 December 2021 18:22 I had the same problem last month.
Solved it with this
You are trying to get something out of the jessie archive. But that doesn't exist anymore. Therefor the error.
wget http://ftp.nl.debian.org/debian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u8_armhf.deb sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u8_armhf.deb sudo reboot
Via the Menu in Telegramjvdz wrote: Monday 20 December 2021 23:19 How are you trying to switch this switch? Via a bash or LUA script using a JSON call to domoticz or the MENU?
can you show me an example. pleasejvdz wrote: Tuesday 21 December 2021 9:08 As this requires a JSON call with the extra password field, can only see this working via a Bash or LUA command files that performs that action and the command yourself in the dtgmenu.cfg.
#!/bin/sh
curl 'https://yourdomoticzip:port/json.htm?type=command¶m=switchlight&idx=IDX-oftheSwitch&switchcmd=On&passcode=YOUR_SWITCH_PASSWORD_AS_SET_IN_SETTINGS'
static_dtgmenu_submenus = {
["pSwitch"] = {whitelist="",showdevstatus="n",Menuwidth=3,
buttons={
["pswitchon"] = {whitelist=""},
["pswitchoff"] = {whitelist=""},
satanasinc wrote: Tuesday 13 March 2018 16:53 Hi!
First of all excuse my bad english. I do my best.
Ive got a RPi working with the telegram bot and domoticz control but my instalation is very old running ver rapsbian wheezy. So i do a fresh install in a new SD with raspbian stretch and the domoticz telegram bot control dont works.
I cant find where is the problem because dont recive answer from domoticz but the notification works perfect.
The /var/tmp/dtb.log apears to be correct...
2018-03-13 14:52:01 - DomoticzIP: 127.0.0.1
2018-03-13 14:52:01 - DomoticzPort: 8080
2018-03-13 14:52:01 - BotHomePath: /home/pi/dtgbot/
2018-03-13 14:52:01 - TempFileDir: /var/tmp/
2018-03-13 14:52:01 - BotLuaScriptPath: /home/pi/dtgbot/lua/
2018-03-13 14:52:01 - BotBashScriptPath: /home/pi/dtgbot/bash/
2018-03-13 14:52:01 - TelegramBotToken: 524####64:AAFZUOtHs_tvJ_F6c06GYpkt6$$$$$$$$$$$$
2018-03-13 14:52:01 - TelegramBotOffset: TelegramBotOffset
2018-03-13 14:52:01 - -----------------------------------------
2018-03-13 14:52:01 - Starting Telegram api Bot message handler
In /var/tmp/dtb.log.error i got this...
Illegal instruction
My /etc/profile.d/DomoticzData.sh#I can't get the next line to work during start-up so have gone to 127 instead
#export DomoticzIP=$(hostname -I|sed 's/[ ]*$//')
export DomoticzIP="127.0.0.1"
export DomoticzPort="8080"
export TempFileDir="/var/tmp/"
export BotHomePath="/home/pi/dtgbot/"
export BotBashScriptPath=$BotHomePath"bash/"
export BotLuaScriptPath=$BotHomePath"lua/"
export BotLuaLog=$TempFileDir"dtb.log"
export TelegramChatId='34####63#
export TelegramBotToken="524####64:AAFZUOtHs_tvJ_F6c06GYpkt6$$$$$$$$$$$$"
export TelegramBotOffset="TelegramBotOffset"
export EmailTo="alt$$$$$[email protected]"
I have started the installation a couple of times wthout luck following the domoticz wiki.
Any idea? What can i do to make it work?
Thanx in advance for your help.
The link on the similar issue isn't working anymore, any idea where the link was transfered to?jvdz wrote: Tuesday 13 March 2018 18:36 The issue seems to lie in these lines so guess the best bet will be an issue with the require files:Could the issue be similar to issues reported like this one?: http://www.domoticz.com/forum/viewtopic ... on#p171940Code: Select all
-- Load necessary Lua libraries http = require "socket.http"; socket = require "socket"; https = require "ssl.https"; JSON = require "JSON"; function file_exists(name) local f=io.open(name,"r") if f~=nil then io.close(f) return true else return false end end -- Load the configuration file this file contains the list of commands -- used to define the external files with the command function to load. local config="" if (file_exists(BotHomePath.."dtgbot-user.cfg")) then config = assert(loadfile(BotHomePath.."dtgbot-user.cfg"))(); print_to_log ("Using DTGBOT config file:"..BotHomePath.."dtgbot-user.cfg") else config = assert(loadfile(BotHomePath.."dtgbot.cfg"))(); print_to_log ("Using DTGBOT config file:"..BotHomePath.."dtgbot.cfg") end
Jos
2021-12-22 18:49:21 - -----------------------------------------
2021-12-22 18:49:21 - Starting Telegram api Bot message handler
Illegal instruction
