How to install Domoticz on a Synology NAS
monfiston
Re: How to install Domoticz on a Synology NAS
Post by monfiston »
Hello
I installed on my nas synology ds115j, the Domoticz Stable version "V4.10717 for DSM 6.2"
it works perfectly, for the use I make of it:
recovery of my solar panel production with a "Téléinfo 1 USB counter" module
However, I would like to send the information to the site bdpv.com
I found a script in "json"
#! / Bin / bash
pr = $ (curl -s "http://127.0.0.1:8080/json.htm?type=devices&rid=902" | jq -r .result []. "Data" | cut -d '' -f1 | tr -d '.')
prod = "$ pr" "0"
echo "We produced from the start:" $ prod
url = "http://www.bdpv.fr//webservice/majProd/ ... ndex=$prod"
echo $ url
ret = $ (curl -s "$ url")
https://easydomoticz.com/forum/viewtopi ... =10&t=7929
How do I install json?
monfiston
Post by monfiston »
Hello
I have been using domoticz for 2 months now on my nas synology ds115j
it works well with the version "V4.10717 for DSM 6.2"
last night I uninstalled this version to upgrade to V4.10717 for DSM 6.2 with Python
the installation is going well, but domoticz refuses to launch, when I click on launch, 2 minutes after the service is on stop !!!
do you have a solution?
jumbotroll
Post by jumbotroll »
monfiston wrote: Wednesday 04 March 2020 9:23 Hello
Did you install the Python 3 package before you installed the domoticz package ?
You have to install this package first or domoticz don't run!
https://global.download.synology.com/do ... mber=24922
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
monfiston
Post by monfiston »
perfect, thank you very much, it works again now
maybe you can help me again?
I want to send my electricity production (see message above), to the site https://www.bdpv.fr/fr/
I found a tutorial on the internet, but it is for a rasberry
and I block on the 1st line:
- having installed jq: sudo apt-get install jq
can you help me, or do you have another way to export my production data?
monfiston
Post by monfiston »
Hello
since yesterday, I have this message which appears in domoticz
I clicked on the link to update it, but the update looks like it won't start
Annotation 2020-03-23 101013.jpg (12.3 KiB) Viewed 5346 times
domotics is installed on my nas synology ds115j
monfiston wrote: Monday 23 March 2020 10:13 since yesterday, I have this message which appears in domoticz. I clicked on the link to update it, but the update looks like it won't start
This button has no function with domoticz on a Synology NAS. You will have to wait until @jumbotroll prepared a package (if at all possible for the ds115j)
You can get rid of the message by unmarking
Software Updates:
Check for Updates (Not working on windows systems)
in tab
[setup][settings][system]
dressie
Domoticz version: V2020.2
Post by dressie »
monfiston wrote: Monday 23 March 2020 10:13 Hello
You can't update within Domoticz on a Synology. You will have to download the new version from http://www.jadahl.com/
monfiston
Post by monfiston »
thank
jumbotroll
I am working with stable 2020.1 (11804) for Synology.
First packages for non python support is already uploaded.
Jadahl
Jumbotroll
dressie
Post by dressie »
jumbotroll wrote: Monday 23 March 2020 12:01 I am working with stable 2020.1 (11804) for Synology.
Jadahl
Thanks! I really appriciate your work! Is the "Python" version coming too?
Edit: I checked it again, it was there. It's installed and running! Thanks!
alkempter
Domoticz version: 2022.2
Post by alkempter »
dressie wrote: Monday 23 March 2020 10:42
Thanks a lot for the information and to Jadahl for the fast delivery of the new code level!
I also had to note that the upgrade button does not work.
I already downloaded the new package for my NAS (Phython version).
Is there a sound description of a safe way how to install it and still keep all what you implemented before?
Synology HyperBackup does not offer to make a backup of Domoticz. How should I make a backup of settings, database and LUA scripts? Will the new package install on top of the old one and do a migration or do I have to uninstall the old version first?
Thank you a lot in advance!
Best regards
Al
edit: solved, new Domoticz level up and running (minor problem, see below).
smukec
Post by smukec »
Any known troubles after upgrade?
FlatBread
Post by FlatBread »
Just installed the new version (domoticz_cedarview-6.2_2020.1.11804-8.spk) on my DS412+ but Domoticz stops everytime after 25 seconds...
Tried to reboot and re-install, but same problem. Unable to rollback to previous version, so I'm now stuck with a version that doesn't work...
Any ideas?
alkempter
Post by alkempter »
succeeded in installing the new level 2020.1 on my DS414j (comcerto2k-6.2_2020.1.11804-8 with Python).
Just installed it via manual install in the package center. Domoticz now shows as version 2020.1.11804-8 but still shows the pop-up "A new version of Domoticz is available..."
edit: this is gone now (restarted the NAS, Domoticz and the PC during the night)
Apart from that, the only problem I noticed are messages like:
2020-03-24 22:40:11.055 Error: OpenZWave: Unhandled Meter type: Electric - Pulses, class: 0x32 (METER), NodeID: 3 (0x03), Index: 3, Instance: 1
2020-03-24 22:40:12.592 Error: OpenZWave: Unhandled Meter type: Electric - Pulses, class: 0x32 (METER), NodeID: 3 (0x03), Index: 3, Instance: 1
2020-03-24 22:40:12.592 Error: OpenZWave: Value_Changed: Tried adding value, not succeeded!. Node: 3 (0x03), CommandClass: METER, Label: Electric - Pulses, Instance: 1, Index: 3
Removing the node and adding it again did not help.
The device is a Devolo Smart Metering Plug and in Node Management shows as
"Devolo home Control Smart Metering Plug MT02792+"
Seems to function OK, though. :)
Best regards
Al
Last edited by alkempter on Wednesday 25 March 2020 12:04, edited 1 time in total.
FlatBread
Post by FlatBread »
Still not working for me. I tried to install the Python version, but then Domoticz doesn't start at all. So back to the non Python version, that starts, but stops everytime after 25 seconds.
Here are the last lines from my logfile, this is what happens everytime when I try to start Domoticz:
2020-03-25 08:01:47.725 Error: Domoticz(pid:10151, tid:10179('EvoHome')) received fatal signal 6 (Aborted)
2020-03-25 08:01:47.725 Error: siginfo address=0x27a7, address=0x7f1128dda907
2020-03-25 08:01:47.737 Error: Failed to start gdb, will use backtrace() for printing stack frame
2020-03-25 08:01:47.738 Error: #0 /usr/local/domoticz/bin/domoticz() [0x565040]
2020-03-25 08:01:47.738 Error: #1 /usr/local/domoticz/bin/domoticz() [0x565d4d]
2020-03-25 08:01:47.738 Error: #2 /lib/libpthread.so.0 : + 0x101c0 [0x7f112a2dc1c0]
2020-03-25 08:01:47.738 Error: #3 /lib/libc.so.6 : gsignal + 0x37 [0x7f1128dda907]
2020-03-25 08:01:47.738 Error: #4 /lib/libc.so.6 : abort + 0x16a [0x7f1128ddbcda]
2020-03-25 08:01:47.738 Error: #5 /usr/local/domoticz/bin/domoticz : __gnu_cxx::__verbose_terminate_handler() + 0xbf [0xbfc859]
2020-03-25 08:01:47.739 Error: #6 /usr/local/domoticz/bin/domoticz : __cxxabiv1::__terminate(void (*)()) + 0x3 [0xbc776a]
2020-03-25 08:01:47.739 Error: #7 /usr/local/domoticz/bin/domoticz : __cxxabiv1::__unexpected(void (*)()) + 0 [0xbc77a0]
2020-03-25 08:01:47.739 Error: #8 /usr/local/domoticz/bin/domoticz : std::thread::_M_start_thread(std::shared_ptr<std::thread::_Impl_base>) + 0 [0xbf4e18]
2020-03-25 08:01:47.739 Error: #9 /lib/libpthread.so.0 : + 0x72c4 [0x7f112a2d32c4]
2020-03-25 08:01:47.739 Error: #10 /lib/libc.so.6 : clone + 0x6d [0x7f1128e9110d]
teo1966
Domoticz version: 2025.1
Post by teo1966 »
hello whits version of python need we python 3 or python 2.7 whit 2020.1.11804-8 ?
i have now on DS916+ v4.11781 whit python 2.7 must i remove 2.7 and install python 3 or not remove python 2.7 and install python 3 ?
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
teo1966 wrote: Wednesday 25 March 2020 11:55 hello whits version of python need we python 3 or python 2.7 whit 2020.1.11804-8 ?
Not remove 2.7
alkempter
Post by alkempter »
I have Python 3 and Python Module installed and it is working well.
Best regards
Al
PieterS
Domoticz version: 2024.7
Post by PieterS »
@alkempter is a bit quicker..
I have Python 3 and Python Module installed and it is working well on my Synology DS718+ for at least 2 days. :D
Synology with Domoticz build (V2024.7) in Docker
FlatBread
Post by FlatBread »
I also tried the beta version, but same problem here.
Is there a way to go back to the previous version without losing all the data (devices, history, settings)?
