Python Plugin: MqttMapper
FlyingDomotic
- Domoticz version: 2020.2
Re: Python Plugin: MqttMapper
"Error: Mapper: Can't find device key wican/amperae/SOC" just means that there's no MqttMapper device with that key. IT probably has been deleted...
Just restart plug-in to get the device recreated.
rron
Thank you for the reply,
I rebooted the system but still the same.You mean the code in the mqtt.json?
"amperae State of Charge": {
"topic": "wican/amperae/SOC",
"type": "243", "subtype": "6", "switchtype": "0",
"mapping": {"item": "", "multiplier": 0.1}/code]Rpi4, Docker, z-wave, zigbee, espeasy, smartevse
FlyingDomotic
Would it be possible to get part of Domoticz's log related to start of MqttMapper plugin?
rron
This is the only part I see. I am using docker.
[ 2026-01-11 16:12:08.121 Error: Mapper: Can't find device key wican/amperae/HV_CAPACITY
2026-01-11 16:12:13.079 Error: Mapper: Can't find device key wican/amperae/SOC
2026-01-11 16:12:13.179 Error: Mapper: Can't find device key wican/amperae/HV_CAPACITY
2026-01-11 16:12:18.153 Error: Mapper: Can't find device key wican/amperae/SOC
2026-01-11 16:12:18.203 Error: Mapper: Can't find device key wican/amperae/HV_CAPACITY /code]Rpi4, Docker, z-wave, zigbee, espeasy, smartevse
FlyingDomotic
The interesting part start with:
and ends with:
Would it be also possible to (temporarily) allow device creation, as this could be a good reason to not create devices successfully?
/home/pi/domoticz/plugins/MqttMapper/xxxx.json is a version 1.0 fileCode: Select all
MqttClient::__init__-
rron
This is what I have in the MqttMapper
- Schermafdruk van 2026-01-11 16-35-36.png (7.43 KiB) Viewed 10325 times
FlyingDomotic
I wasn't sufficiently clear
Would it be possible to extract part of Domoticz.log concerning MqttMapper between line containing " /home/pi/domoticz/plugins/MqttMapper/MqttMapper.json is a version 1.0 file" and "MqttClient::__init__"?
In addition, if you find any "device creation impossible" in domoticz log, please enable device creation.
rron
I am trying to find my domoticz logging. According to my docker-compose.yml it should be in opt/domoticz/userdata/domoticz.log but there is nothing.
FlyingDomotic
You found it, you even copy (part of) it in this message:
rron wrote: Sunday 11 January 2026 16:13Code: Select all
2026-01-11 16:12:08.121 Error: Mapper: Can't find device key wican/amperae/HV_CAPACITY 2026-01-11 16:12:13.079 Error: Mapper: Can't find device key wican/amperae/SOC 2026-01-11 16:12:13.179 Error: Mapper: Can't find device key wican/amperae/HV_CAPACITY 2026-01-11 16:12:18.153 Error: Mapper: Can't find device key wican/amperae/SOC 2026-01-11 16:12:18.203 Error: Mapper: Can't find device key wican/amperae/HV_CAPACITY
rron
Ok i try to find the part you mentioned
FlyingDomotic
If too complicated, please send me the full log by Private Message.
FlyingDomotic
Done: [https://github.com/domoticz/domoticz/issues/6506}NvBgm wrote: Sunday 11 January 2026 12:00 Oh, would you mind doing that for me? My English isn't the best, and I'm not very familiar with this subject. Anyway, thanks so much for this, and I hope it's possible later.
rron
I will send you the startup log when I am loading my car again. Only than I will see the fault.
FlyingDomotic
I got an answer:FlyingDomotic wrote: Monday 12 January 2026 22:29 Done: [https://github.com/domoticz/domoticz/issues/6506}
We are using the mosquito library which i trust
Even if this may seems a bit raw, I should admit that this is the right answer for someone very busy managing a large project like Domoticz.
On my own, I tried to see if something changed in Domoticz on MQTT area. I checked for differences between V2020.2 and 2025.2 and ... nothing changed last 5 years in (this part of) C code. We can safely exclude side effect of a recent Domoticz code change.
That's said, we should investigate a bit on sender side.
So, if I correctly understood, you're using P1 monitor from "https://www.p1-monitor.nl/".
It may be interesting to have used version number, and (part of) parameters related to MQTT (probably its version, if you can get it). I don't known P1 monitor, so I can't tell you how to do that, but I guess some Dutch users here can provide help.
In addition, version of broker used by Domoticz is also useful. A quick way to get it is "mosquitto -h", reading first line which is something like "mosquitto version x.y.z".
It could be also helping to get the view of other tools of these messages.
On machine running mosquitto, you can run:
and give us few received messages (or error messages)mosquitto_sub -h localhost -t p1monitor/watermeter/day/watermeter_consumption_liter
You may also install MqttExplorer (https://mqtt-explorer.com/), and give us content of "p1monitor/watermeter/day/watermeter_consumption_liter" topic (or error messages if any).
Idea behind these requests is to determine where error could be (bad settings, bad message, ...)
rron
This is the part from the mapper logging. I will try this tomorrow when I loading my car.
domoticz | 2026-01-17 12:10:43.256 Mapper: Debug logging mask set to: PYTHON PLUGIN
domoticz | 2026-01-17 12:10:43.258 Mapper: /opt/domoticz/userdata/plugins/MqttMapper/MqttMapper.json is a version 1.0 file
domoticz | 2026-01-17 12:10:43.443 Mapper: pluginV1::__init__
domoticz | 2026-01-17 12:10:43.444 Mapper: 'HardwareID': '48'
domoticz | 2026-01-17 12:10:43.444 Mapper: 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/'
domoticz | 2026-01-17 12:10:43.444 Mapper: 'StartupFolder': '/opt/domoticz/'
domoticz | 2026-01-17 12:10:43.445 Mapper: 'UserDataFolder': '/opt/domoticz/userdata/'
domoticz | 2026-01-17 12:10:43.445 Mapper: 'Database': '/opt/domoticz/userdata/domoticz.db'
domoticz | 2026-01-17 12:10:43.445 Mapper: 'Language': 'nl'
domoticz | 2026-01-17 12:10:43.445 Mapper: 'Version': '25.12.9-1'
domoticz | 2026-01-17 12:10:43.446 Mapper: 'Author': 'Flying Domotic'
domoticz | 2026-01-17 12:10:43.446 Mapper: 'Name': 'Mapper'
domoticz | 2026-01-17 12:10:43.446 Mapper: 'Address': '192.168.178.50'
domoticz | 2026-01-17 12:10:43.446 Mapper: 'Port': '1883'
domoticz | 2026-01-17 12:10:43.447 Mapper: 'Key': 'MqttMapper'
domoticz | 2026-01-17 12:10:43.447 Mapper: 'Mode1': 'MqttMapper.json'
domoticz | 2026-01-17 12:10:43.447 Mapper: 'Mode6': 'Normal'
domoticz | 2026-01-17 12:10:43.447 Mapper: 'DomoticzVersion': '2025.2 (build 16836)'
domoticz | 2026-01-17 12:10:43.447 Mapper: 'DomoticzHash': '3b8a9cf2f'
domoticz | 2026-01-17 12:10:43.447 Mapper: 'DomoticzBuildTime': '2025-10-26 10:11:08'
domoticz | 2026-01-17 12:10:43.448 Mapper: Device count: 7
domoticz | 2026-01-17 12:10:43.448 Mapper: Device: 1 - ID: 867, Name: 'charge current', nValue: 15, sValue: '15.3'
domoticz | 2026-01-17 12:10:43.448 Mapper: Device: 2 - ID: 868, Name: 'max current', nValue: 16, sValue: '16.0'
domoticz | 2026-01-17 12:10:43.448 Mapper: Device: 3 - ID: 901, Name: 'evenergy charged', nValue: 30044, sValue: '30044.0'
domoticz | 2026-01-17 12:10:43.448 Mapper: Device: 4 - ID: 870, Name: 'evtotalenergy charged', nValue: 1002, sValue: '1002.479'
domoticz | 2026-01-17 12:10:43.448 Mapper: Device: 5 - ID: 871, Name: 'SmartEVSE state', nValue: 0, sValue: 'Ready to Charge'
domoticz | 2026-01-17 12:10:43.449 Mapper: Device: 6 - ID: 872, Name: 'SmartEVSE error', nValue: 0, sValue: '0'
domoticz | 2026-01-17 12:10:43.449 Mapper: Device: 7 - ID: 873, Name: 'charge current override', nValue: 0, sValue: '0.0'
domoticz | 2026-01-17 12:10:43.449 Mapper: Creating device amperae State of Charge
domoticz | 2026-01-17 12:10:43.450 Mapper: Creating device amperae Hv Capacity
domoticz | 2026-01-17 12:10:43.450 Mapper: MqttClient::__init__
domoticz | 2026-01-17 12:10:43.452 Mapper: Heartbeat interval set to: 3.
domoticz | 2026-01-17 12:10:43.502 Mapper: MqttClient::onConnect
domoticz | 2026-01-17 12:10:43.502 Mapper: MqttClient::onConnect connect to 192.168.178.50:1883, ID=Domoticz_MqttMapper_48_1768648243
domoticz | 2026-01-17 12:10:43.554 Mapper: onMQTTConnected
domoticz | 2026-01-17 12:10:43.554 Mapper: getTopics: '{'SmartEVSE-5572/EVEnergyCharged', 'wican/amperae/HV_CAPACITY', 'SmartEVSE-5572/ChargeCntOverride', 'SmartEVSE-5572/Error', 'SmartEVSE-5572/State', 'wican/amperae/SOC', 'SmartEVSE-5572/ChargeCurrent', 'SmartEVSE-5572/EVTotalEnergyCed', 'SmartEVSE-5572/MaxCurrent'}'
domoticz | 2026-01-17 12:10:43.555 Mapper: MqttClient::Subscribe to [{'Topic': 'SmartEVSE-5572/EVEnergyCharged', 'QoS': 0}, {'Topic': 'wican/aae/HV_CAPACITY', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/ChargeCurrentOverride', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/Error', 'QoS': 0}, {'Topic': rtEVSE-5572/State', 'QoS': 0}, {'Topic': 'wican/amperae/SOC', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/ChargeCurrent', 'QoS': 0}, {'Topic': 'SmartEV572/EVTotalEnergyCharged', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/MaxCurrent', 'QoS': 0}]
domoticz | 2026-01-17 12:10:43.605 Mapper: onMQTTSubscribed
domoticz | 2026-01-17 12:10:43.609 Mapper: onMQTTPublish found SmartEVSE-5572/EVEnergyCharged, Device 'evenergy charged', message '30044'
domoticz | 2026-01-17 12:10:43.610 Mapper: Setting evenergy charged to 30044/30044.0
domoticz | 2026-01-17 12:10:43.621 Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrentOverride, Device 'charge current override', message
domoticz | 2026-01-17 12:10:43.621 Mapper: Setting charge current override to 0/0.0
domoticz | 2026-01-17 12:10:43.628 Mapper: onMQTTPublish found SmartEVSE-5572/Error, Device 'SmartEVSE error', message 'None'
domoticz | 2026-01-17 12:10:43.629 Mapper: testValue="None" (str), readValue="None" (str)
domoticz | 2026-01-17 12:10:43.629 Mapper: testValue="No Power Available" (str), readValue="None" (str)
domoticz | 2026-01-17 12:10:43.629 Mapper: testValue="Communication Error" (str), readValue="None" (str)
domoticz | 2026-01-17 12:10:43.630 Mapper: testValue="Temperature High" (str), readValue="None" (str)
domoticz | 2026-01-17 12:10:43.630 Mapper: testValue="EV Meter Comm Error" (str), readValue="None" (str)
domoticz | 2026-01-17 12:10:43.630 Mapper: testValue="RCM Tripped" (str), readValue="None" (str)
domoticz | 2026-01-17 12:10:43.630 Mapper: testValue="Waiting for Solar" (str), readValue="None" (str)
domoticz | 2026-01-17 12:10:43.630 Mapper: testValue="Test IO" (str), readValue="None" (str)
domoticz | 2026-01-17 12:10:43.630 Mapper: testValue="Flash Error" (str), readValue="None" (str)
domoticz | 2026-01-17 12:10:43.630 Mapper: testValue="**Unknown**" (str), readValue="None" (str)
domoticz | 2026-01-17 12:10:43.630 Mapper: Setting SmartEVSE error to 0/0
domoticz | 2026-01-17 12:10:43.638 Mapper: onMQTTPublish found SmartEVSE-5572/State, Device 'SmartEVSE state', message 'Ready to Charge'
domoticz | 2026-01-17 12:10:43.639 Mapper: Setting SmartEVSE state to >Ready to Charge<
domoticz | 2026-01-17 12:10:43.644 Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrent, Device 'charge current', message '153'
domoticz | 2026-01-17 12:10:43.644 Mapper: Setting charge current to 15/15.3
domoticz | 2026-01-17 12:10:43.649 Mapper: onMQTTPublish found SmartEVSE-5572/MaxCurrent, Device 'max current', message '160'
domoticz | 2026-01-17 12:10:43.649 Mapper: Setting max current to 16/16.0Rpi4, Docker, z-wave, zigbee, espeasy, smartevse
FlyingDomotic
As of now, I don't see anything strange in this log.
Let's see what'll happen when charging car.
rron
I will let you know tomorrow
rron
This is the logging when I am charging. I don’t see much difference in the logging.
| 2026-01-18 12:19:12.158 dzVents: Debug: - Domoticz: start
domoticz | 2026-01-18 12:19:12.201 Mapper: Debug logging mask set to: PYTHON PLUGIN
domoticz | 2026-01-18 12:19:12.202 Mapper: /opt/domoticz/userdata/plugins/MqttMapper/MqttMapper.json is a version 1.0 file
domoticz | 2026-01-18 12:19:12.383 Mapper: pluginV1::__init__
domoticz | 2026-01-18 12:19:12.384 Mapper: 'HardwareID': '48'
domoticz | 2026-01-18 12:19:12.385 Mapper: 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/'
domoticz | 2026-01-18 12:19:12.386 Mapper: 'StartupFolder': '/opt/domoticz/'
domoticz | 2026-01-18 12:19:12.386 Mapper: 'UserDataFolder': '/opt/domoticz/userdata/'
domoticz | 2026-01-18 12:19:12.387 Mapper: 'Database': '/opt/domoticz/userdata/domoticz.db'
domoticz | 2026-01-18 12:19:12.388 Mapper: 'Language': 'nl'
domoticz | 2026-01-18 12:19:12.389 Mapper: 'Version': '25.12.9-1'
domoticz | 2026-01-18 12:19:12.391 Mapper: 'Author': 'Flying Domotic'
domoticz | 2026-01-18 12:19:12.391 Mapper: 'Name': 'Mapper'
domoticz | 2026-01-18 12:19:12.392 Mapper: 'Address': '192.168.178.50'
domoticz | 2026-01-18 12:19:12.392 Mapper: 'Port': '1883'
domoticz | 2026-01-18 12:19:12.394 Mapper: 'Key': 'MqttMapper'
domoticz | 2026-01-18 12:19:12.394 Mapper: 'Mode1': 'MqttMapper.json'
domoticz | 2026-01-18 12:19:12.396 Mapper: 'Mode6': 'Normal'
domoticz | 2026-01-18 12:19:12.397 Mapper: 'DomoticzVersion': '2025.2 (build 16836)'
domoticz | 2026-01-18 12:19:12.399 Mapper: 'DomoticzHash': '3b8a9cf2f'
domoticz | 2026-01-18 12:19:12.400 Mapper: 'DomoticzBuildTime': '2025-10-26 10:11:08'
domoticz | 2026-01-18 12:19:12.401 Mapper: Device count: 7
domoticz | 2026-01-18 12:19:12.401 Mapper: Device: 1 - ID: 867, Name: 'charge current', nValue: 16, sValue: '15.9'
domoticz | 2026-01-18 12:19:12.401 Mapper: Device: 2 - ID: 868, Name: 'max current', nValue: 16, sValue: '16.0'
domoticz | 2026-01-18 12:19:12.402 Mapper: Device: 3 - ID: 901, Name: 'evenergy charged', nValue: 3974, sValue: '3974.0'
domoticz | 2026-01-18 12:19:12.403 Mapper: Device: 4 - ID: 870, Name: 'evtotalenergy charged', nValue: 1006, sValue: '1006.453'
domoticz | 2026-01-18 12:19:12.403 Mapper: Device: 5 - ID: 871, Name: 'SmartEVSE state', nValue: 0, sValue: 'Charging'
domoticz | 2026-01-18 12:19:12.404 Mapper: Device: 6 - ID: 872, Name: 'SmartEVSE error', nValue: 0, sValue: '0'
domoticz | 2026-01-18 12:19:12.404 Mapper: Device: 7 - ID: 873, Name: 'charge current override', nValue: 0, sValue: '0.0'
domoticz | 2026-01-18 12:19:12.407 Mapper: Creating device amperae State of Charge
domoticz | 2026-01-18 12:19:12.409 Mapper: Creating device amperae Hv Capacity
domoticz | 2026-01-18 12:19:12.409 Mapper: MqttClient::__init__
domoticz | 2026-01-18 12:19:12.411 Mapper: Heartbeat interval set to: 3.
domoticz | 2026-01-18 12:19:12.462 Mapper: MqttClient::onConnect
domoticz | 2026-01-18 12:19:12.462 Mapper: MqttClient::onConnect connect to 192.168.178.50:1883, ID=Domoticz_MqttMapper_48_1768735152
domoticz | 2026-01-18 12:19:12.513 Mapper: onMQTTConnected
domoticz | 2026-01-18 12:19:12.513 Mapper: getTopics: '{'SmartEVSE-5572/EVTotalEnergyCharged', 'SmartEVSE-5572/State', 'SmartEVSE-5572/MaxCurrent', 'SmartEVSE-5572/ChargeCurrentOverride', 'wican/amperae/HV_CAPACITY', 'SmartEVSE-5572/EVEnergyCharged', 'wican/amperae/SOC', 'SmartEVSE-5572/ChargeCurrent', 'SmartEVSE-5572/Error'}'
domoticz | 2026-01-18 12:19:12.514 Mapper: MqttClient::Subscribe to [{'Topic': 'SmartEVSE-5572/EVTotalEnergyCharged', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/State', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/MaxCurrent', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/ChargeCurrentOverride', 'QoS': 0}, {'Topic': 'wican/amperae/HV_CAPACITY', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/EVEnergyCharged', 'QoS': 0}, {'Topic': 'wican/amperae/SOC', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/ChargeCurrent', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/Error', 'QoS': 0}]
domoticz | 2026-01-18 12:19:12.564 Mapper: onMQTTSubscribed
domoticz | 2026-01-18 12:19:12.568 Mapper: onMQTTPublish found SmartEVSE-5572/State, Device 'SmartEVSE state', message 'Charging'
domoticz | 2026-01-18 12:19:12.569 Mapper: Setting SmartEVSE state to >Charging<
domoticz | 2026-01-18 12:19:12.574 Mapper: onMQTTPublish found SmartEVSE-5572/MaxCurrent, Device 'max current', message '160'
domoticz | 2026-01-18 12:19:12.575 Mapper: Setting max current to 16/16.0
domoticz | 2026-01-18 12:19:12.579 Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrentOverride, Device 'charge current override', message '0'
domoticz | 2026-01-18 12:19:12.579 Mapper: Setting charge current override to 0/0.0
domoticz | 2026-01-18 12:19:12.585 Mapper: onMQTTPublish found SmartEVSE-5572/EVEnergyCharged, Device 'evenergy charged', message '4019'
domoticz | 2026-01-18 12:19:12.587 Mapper: Setting evenergy charged to 4019/4019.0
domoticz | 2026-01-18 12:19:12.599 Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrent, Device 'charge current', message '159'
domoticz | 2026-01-18 12:19:12.601 Mapper: Setting charge current to 16/15.9
domoticz | 2026-01-18 12:19:12.610 Mapper: onMQTTPublish found SmartEVSE-5572/Error, Device 'SmartEVSE error', message 'None'
domoticz | 2026-01-18 12:19:12.611 Mapper: testValue="None" (str), readValue="None" (str)
domoticz | 2026-01-18 12:19:12.612 Mapper: testValue="No Power Available" (str), readValue="None" (str)
domoticz | 2026-01-18 12:19:12.612 Mapper: testValue="Communication Error" (str), readValue="None" (str)
domoticz | 2026-01-18 12:19:12.613 Mapper: testValue="Temperature High" (str), readValue="None" (str)
domoticz | 2026-01-18 12:19:12.613 Mapper: testValue="EV Meter Comm Error" (str), readValue="None" (str)
domoticz | 2026-01-18 12:19:12.614 Mapper: testValue="RCM Tripped" (str), readValue="None" (str)
domoticz | 2026-01-18 12:19:12.614 Mapper: testValue="Waiting for Solar" (str), readValue="None" (str)
domoticz | 2026-01-18 12:19:12.615 Mapper: testValue="Test IO" (str), readValue="None" (str)
domoticz | 2026-01-18 12:19:12.615 Mapper: testValue="Flash Error" (str), readValue="None" (str)
domoticz | 2026-01-18 12:19:12.616 Mapper: testValue="**Unknown**" (str), readValue="None" (str)
domoticz | 2026-01-18 12:19:12.617 Mapper: Setting SmartEVSE error to 0/0Rpi4, Docker, z-wave, zigbee, espeasy, smartevse
FlyingDomotic
I may be wrong, but reading this log, everything is running well, isn't it?
rron
No it doesn’t appear in domoticz.
