Page 24 of 49
Re: Dashticz - Module - Garbage collector
Posted: Tuesday 13 February 2018 9:25
by EdwinK
It looks like they changed something in the background of the site.
Posted: Tuesday 13 February 2018 10:19
by michaelm86
Hi Guys,
Does anybody know if there is a bug or issue with the garbage module? it worked before but after the redeploy of my domoticz it seems that te connection with rova afvalkalaneder is gone. I'm using the beta installation with apache as webserver for dashticz.
Posted: Thursday 15 February 2018 12:34
by naitsirhc
2 questions:
Is it possible to get the data from an Owncloud server on a synology. It's also usefull for another calendar functions, in my opinion
if not:
is it possible to integrate:
http://www.awb-emsland.de/index.php?ID=408
Wohnort Twist
Strasse Bussardweg
Hausnummer 5
Posted: Friday 16 February 2018 10:09
by robgeerts
Indeed, for some reason mijnafvalwijzer is offline at the moment...
Posted: Friday 16 February 2018 16:57
by EdwinK
robgeerts wrote: Friday 16 February 2018 10:09 Indeed, for some reason mijnafvalwijzer is offline at the moment...
Good thing we still have the old fashioned paper 'afvalwijzer' or I would have completely forgotten to put out my trash :)
Posted: Friday 16 February 2018 23:57
by yfands
Rob,
mijnafvalwijzer.nl if you go to the site and type your postal code and house number it works, and also I get email notification Also Domoticz with a lua script is working. But I cant get Dashticz to work. As stated earlier in the bugs section by me, the Dashticz beta version from November 2017 is also not working anymore no changes made since November, and it worked then !!. Did something change at the mijnafvalwijzer website and Dashticz cant communicate any more?
Frank
Posted: Saturday 17 February 2018 9:43
by EdwinK
I'm no programmer, but this is what I found at https://community.home-assistant.io/t/g ... t/34631/14
It seems that the problem is at json.afvalwijzer.nl. Try to enter the following url with your postal code and housenumber:
http://json.mijnafvalwijzer.nl/?method= ... langs=nl&2
I receive the following error at the moment:
Op dit moment is het erg druk. Probeert u het later nog eens. Onze excuses voor het ongemak.
Posted: Saturday 17 February 2018 12:41
by yfands
I have send an email to the developer from the mijnafvalwijzer.nl website.
I'll guess we just have to wait.
Frank
Posted: Monday 19 February 2018 10:00
by yfands
I've received an answer from the developer, addcomgroup, in short, stop using our api it's not for you and will not help you..
So we have to come up with another solution to retrieve the data.
The answer from the mijnafvalwijzer developer: (English translation below.)
Beste Frank,
De API die jij gebruikt is bedoeld voor onze apps en voor de aangesloten gemeenten.
Dit houdt in dat deze API niet gericht is op particulieren en dat wij ook geen ondersteuning bieden voor particulieren.
Ons verzoek is ook om zo snel mogelijk te stoppen met het gebruik van deze API.
Helaas kan ik je niet verder helpen.
Regards,
Met vriendelijke groet,
Robby Peele
Project Manager
ADDCOM GROUP
Translated,
Dear Frank,
The API you use is meant for our apps and for the affiliated municipalities.
This means that this API is not aimed at private individuals and that we do not offer support for private individuals.
Our request is also to stop using this API as soon as possible.
Unfortunately, I can not help you further.
Posted: Monday 19 February 2018 15:02
by RobertK
He's not a developer but a project manager who probably doesn't know the technical details either.
It's not about the API but about the json URL, which are two different things in my opinion.
The API indeed returns output that is probably understood by the dedicated apps only, like: {"afvalDate":"1515066896","contentDate":"1518771995","iconsDate":"1484849588"}
In the meantime, the json URL of 'mijnafvalwijzer' seems to be working as before and returns useful json again.
(Tested and indeed my dashboard shows the info correctly today).
Posted: Monday 19 February 2018 19:13
by EdwinK
Seems to be working again. :)
Posted: Wednesday 21 February 2018 13:59
by wmmudde
pkrabben wrote: Monday 31 July 2017 15:05 ik heb je een pm gestuurd
wmmudde wrote:
pkrabben wrote:Hi All
The recycle manager is working only I can't get the block wider then 4.
I tried
blocks['trashcan.recyclemanager'] = {}
blocks['trashcan.recyclemanager']['width'] = 12;
but for some reason it stays width 4 do you have any clue?
pkrabben, hoe heb jij deze werkend gekregen in Almere?
Hij zegt bij mij continu "undefined"
welke gebruik jij?
Ik heb die settings gebruikt maar die werken niet, doe ik iets fout?
is er al een andere setup?
Posted: Wednesday 21 February 2018 14:00
by wmmudde
Beste,
Wie heeft dit werkend in Almere of kan mij hiermee helpen?
wordt gewaardeerd!
Posted: Thursday 22 February 2018 8:50
by aiolos
Good to hear MijnAfvalwijzer is working again. However, this problem can come up again, sooner or later, and maybe forever. Since it is also running through the dashticz.nl domain, there is a chance this gets blocked. They cannot easily block it (Ithink) when dashticz does the request to MijnAfvalwijzer itself (the apps and other websites also need the access). So it might be worth to at least give the option to let it run from Dashticz itself again.
Posted: Sunday 25 February 2018 14:18
by jjnj
robgeerts wrote: Sunday 01 October 2017 12:52
jjnj wrote: Sunday 17 September 2017 11:59 I'm still having issues with the module saying "Loading''
My config:
config['garbage_company'] = 'afvalwijzer';
config['garbage_zipcode'] = '170Xxx';
config['garbage_street'] = 0;
config['garbage_housenumber'] = '1';
I'm now running the latest beta
Whats your full zipcode?
1704TW
Posted: Thursday 01 March 2018 14:41
by hmartijns
Another request: I hope you can add the folowing url https://hellendoornafvalkalender.2go-mobile.com/
Posted: Wednesday 14 March 2018 22:20
by Aussi
Could some one please post the necessary codes to make the Garbage collector visible as a block on the Dashticz interface.
Sadly engouh I cant get it via the edit mode because the PHP is not working within domoticz environment..
For now I have this as code in CONFIG.js:
config['garbage_company'] = 'MijnAfvalwijzer';
config['garbage_zipcode'] = 'XXXX';
config['garbage_housenumber'] = '25';
But that doesnt seem to do the trick. It dont even see a block with info
Posted: Wednesday 14 March 2018 22:31
by EdwinK
You need to add 'garbage' to the column where you want it to display.
Example:
columns[3] = {}
columns[3]['blocks'] = ['flipclock',calendars.combined,buttons.moon,185,201,'garbage']
columns[3]['width'] = 4;
Posted: Wednesday 14 March 2018 22:37
by Aussi
EdwinK wrote: Wednesday 14 March 2018 22:31 You need to add 'garbage' to the column where you want it to display.
Example:
columns[3] = {}
Alright sounds good. In which file can I find/add/edit those codes :D?
I saw something like this mentioned on the forum but I cant find it in any file on my RPi
Posted: Wednesday 14 March 2018 22:48
by EdwinK
You change those in CONFIG.js
