13.4galadril wrote: Tuesday 28 April 2020 11:16What iOS version do you use?solidum90 wrote: Sunday 26 April 2020 14:40 Hello, I’ve a problem since last weeks updates Borghi on Apple store app (I’ve bought pay version) and beta version.
The search button on top right doesn’t work, the search box does not appear.
Thanks for your work!![]()
Domoticz App
- solidum90
- Domoticz version: Debian
Re: Domoticz App
schulpr
Re: Domoticz App
Hi, I'm on iOS 13.4.1 with the premium app. I can't use geofencing properly. Connecting a switch isn't possible and I can only use the numeric keyboard to give a name to the zone.
Re: Domoticz App
I already posted here something https://www.domoticz.com/forum/viewtopi ... 28&t=32455
Because I didn't see this forum.
I must be doing something wrong. Wherever I tap on my screen in de iOS app, I can't get any graphic displayed
I'm also not able to tap the search and get it working. Am I doing something wrong?
I have the paid app.
- galadril
- Domoticz version: latest
Re: Domoticz App
Thanks ill take a lookschulpr wrote: Wednesday 29 April 2020 12:02 Hi, I'm on iOS 13.4.1 with the premium app. I can't use geofencing properly. Connecting a switch isn't possible and I can only use the numeric keyboard to give a name to the zone.
- galadril
Re: Domoticz App
You can't click on Any temperature device to see graphs...?ajseesink wrote: Thursday 30 April 2020 21:46 I already posted here something https://www.domoticz.com/forum/viewtopi ... 28&t=32455
Re: Domoticz App
Correct. Whereever I click, it's a no-go. not on temp, not on power no graphs show up. It's like hitting a button but nothing happens.galadril wrote: Friday 01 May 2020 15:48You can't click on Any temperature device to see graphs...?ajseesink wrote: Thursday 30 April 2020 21:46 I already posted here something https://www.domoticz.com/forum/viewtopi ... 28&t=32455
Would love to add a video to show it to you, but it looks like videos cant be added to posts.
Andre
dheuts
Re: Domoticz App
Good to know I'm not the only one with this problem.
Thanks for the New app, Looking good. But Since the New App I have a problem on my iphone. I can turn switches on and off, but when I click the glass, nothing happens. Search is not opende. Also when I hold a device, nothing happens. I expected extra options like log.
Tried with the demo server, same problems. Also Tried to remove and reinstall a coupe of times. Even Tried the Newest version on Testflight.... Still the same problems.
Any idea how to fix this?
Raspberry Pi 4 With Domoticz - RFXCom - Tuya Wifi LED lights - Chuango Alarm - Zwave+ - Zigbee2MQTT - Anna Thermostat - Broadlink IR, P1 - Eufy Robo Vacuum - Worx Robo Mower
pragma
Re: Domoticz App
Hi, After a first - pleasant - experience I decided to upgrade to the paid version, only to see that the app crashes whenever I start it. It shows for a second my switches and then the screen goes back to the main screen. Any suggestions?
- FearNaBoinne
- Domoticz version: 2021.1
Re: Domoticz App
Everything is working on mine (there's a few improvements that could be made, but that will always be the case, obviously), so it's not a systemic issue.
Have you tried removing and reinstalling? I've had issues with apps in the past that were resolved that way... Could be a corrupt setting file or something.
RasPi, Raspbian , Domoticz v2021.1, Z-Wave Stick, RFLink, RFXtrx433e, Hue, Tuya (Tasmota/Mosquitto with Discovery), ESP(easy), MySensors.org, OTGW
doh
Re: Domoticz App
I've just moved back to iPhone from Android and sad to see that the Domoticz app crashes at startup (on both iPhone and iPad). I did get it to start once, put in my server details, which it verified, and it just crashes every time I start it now.
Any way to fix this? I need my Domoticz back!
- FearNaBoinne
Re: Domoticz App
What version of iOS? Is your server using an official signed cert or a self-signed cert? Have you tried removing and reinstalling the app?doh wrote: Tuesday 23 June 2020 14:03 I've just moved back to iPhone from Android and sad to see that the Domoticz app crashes at startup (on both iPhone and iPad). I did get it to start once, put in my server details, which it verified, and it just crashes every time I start it now.
It works on mine (iPad Pro and iPhone 8 Plus), just as a reference point...
doh
Re: Domoticz App
Using latest iOS (13.5.1)FearNaBoinne wrote: Tuesday 23 June 2020 15:11What version of iOS? Is your server using an official signed cert or a self-signed cert? Have you tried removing and reinstalling the app?doh wrote: Tuesday 23 June 2020 14:03 I've just moved back to iPhone from Android and sad to see that the Domoticz app crashes at startup (on both iPhone and iPad). I did get it to start once, put in my server details, which it verified, and it just crashes every time I start it now.
My Domoticz setup uses a public cert provided by LetsEncrypt. I've removed and re-installed, and this time didn't enter the local server setup - only the remote - and the same thing - crashes every time
I've also just tried again, using local connection only, which uses HTTP only - same end result - crashes every time!
- FearNaBoinne
Re: Domoticz App
I would recommend opening an issue on GitHUB for this, so the developer actually sees it and can work with you to resolve the issue. This is NOT an official support channel for the app, so you'll never know when Galadril sees your issue here...doh wrote: Tuesday 23 June 2020 17:05Using latest iOS (13.5.1)FearNaBoinne wrote: Tuesday 23 June 2020 15:11What version of iOS? Is your server using an official signed cert or a self-signed cert? Have you tried removing and reinstalling the app?doh wrote: Tuesday 23 June 2020 14:03 I've just moved back to iPhone from Android and sad to see that the Domoticz app crashes at startup (on both iPhone and iPad). I did get it to start once, put in my server details, which it verified, and it just crashes every time I start it now.
- DewGew
- Domoticz version: V4.10618
Re: Domoticz App
I dont get any notifications. I have checked my phone settings. We I test i settings/mobile devices it works but not from any of my dzvents scripts or in device notifications. Any suggestions?
- DewGew
Re: Domoticz App
I found the isssue. Google cloud message was inactive in settingsDewGew wrote: Wednesday 01 July 2020 20:01 I dont get any notifications. I have checked my phone settings. We I test i settings/mobile devices it works but not from any of my dzvents scripts or in device notifications. Any suggestions?
Geitje
Re: Domoticz App
On my father's Iphone I constantly get an "OK" popup when Domoticz is getting a notification, even when notifications are off. See below. How can we turn this off? It's an Iphone 8, iOS 13.5.1, newest version Domoticz app.
- Spoiler: show
Zwave, Zigate, RFlink etc.
kozmix
- Domoticz version: 2020.2
Re: Domoticz App
Has this been resolved? I'm having the same issue and can't seem to find out what I'm doing wrong.
tpetruzzellis
Re: Domoticz App
Greetings:
looks like a great Domoticz for IOS.
Nowhere can I find out how to setup the application, i.e how to fill in the settings on the app to make it work.
Please direct me to how to "fill-in-the-blanks" to setup the app.
Tom
Tom
- FearNaBoinne
Re: Domoticz App
It's been a while for me, and I do not have the app handy ATM, but as far as I can remember it was really really really straightforward... And I mean REALLY straightforward...
Literally like putting in the server name or IP on the server line, enter your credentials on the user and password lines and done...
kozmix
Re: Domoticz App
Indeed very straightforward. Open the Settings menu via the three dots in the upper-right corner, go to "Server connection settings" and fill in the details.
