homebridge-edomoticz Plugin
- TheRamon
- Domoticz version: BETA
Re: eDomoticz Homebridge-Plugin
Coolio! Any thoughts on when to release this update? I mean we could always add more sensors with time.
- Marci
- Domoticz version: 3.8153
At the moment the issue is that unsupported switch types get forced into being an On/Off switch on the first MQTT update of that device - essentially we just need to make sure that every switch type possible is supported. Sensors are covered in the empty 'else' so shouldn't cause any problems (for now).
I'll check it all out tonight when I get home and report back...
- TheRamon
Whoops! Wanted to look into that issue. Completely forgot. It is because I had changed the if condition of 'getServices'. With the old statement the 'Fan' type switches would never show up as fan, but as a Switch. Not because of the word "Fan" not appearing in the name, but because the default of 'Sensor' (else clause) is also a 'Switch'.
Details in GitHub.
I have fixed the issue and am creating a pull request now.
Details in GitHub.
- Marci
There were still some devices being broken - have just applied some ugly workarounds for now - feel free to improve if you’re able, but, that all seems to be working now without destroying any of my plethora of sensors
Excellent work fella! As it stands, we’re definitely at ReleaseCandidate stage... https://github.com/PatchworkBoy/homebri ... /issues/29
EDIT: just noticed, the refactoring has improved/reduced memory usage also... *applause*
Will give it some thorough testing between now and the weekend and see if anything unexpected crops up... then we can think about Release!
For reference, just so you’ve an idea of my “test” setup, here’s a full sweep of all accessories from Homebridge:
- Spoiler: show
- devices.txt
- (120.17 KiB) Downloaded 73 times
- TheRamon
My goodie, that's a vast list you have there.
Good to hear memory usage has improved. We should probably remove the logging of MQTT messages too, easy win there.
So basically, anyone that wants to help testing this is free to try:
Clone the repo in your node_modules directory that contains the plugin. (usually /usr/lib/node_modules or /usr/local/lib/node_modules/)
$ git clone -b mqtt-integration https://github.com/PatchworkBoy/homebridge-eDomoticz.git
- Marci
(and refer to last post at https://github.com/PatchworkBoy/homebri ... /issues/29 for setting up MQTT in Domoticz etc)
- deejc
- Domoticz version: 3.5641
followed all the instructions and i get below error and my Home app doesn't update in real time
i notice that the git clone command has a capital D in eDomoticz but my usual plugin node folder is all lower case
8/10/2016, 8:38:58 PM] ====================
[8/10/2016, 8:38:58 PM] ERROR LOADING PLUGIN homebridge-eDomoticz:
[8/10/2016, 8:38:58 PM] Error: Cannot find module 'request'
at Function.Module._resolveFilename (module.js:440:15)
at Function.Module._load (module.js:388:25)
at Module.require (module.js:468:17)
at require (internal/module.js:20:19)
at Object.<anonymous> (/usr/local/lib/node_modules/homebridge-eDomoticz/index.js:43:15)
at Module._compile (module.js:541:32)
at Object.Module._extensions..js (module.js:550:10)
at Module.load (module.js:458:32)
at tryModuleLoad (module.js:417:12)
at Function.Module._load (module.js:409:3)
[8/10/2016, 8:38:58 PM] ====================
[8/10/2016, 8:39:00 PM] Loaded plugin: homebridge-edomoticz
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
- Marci
2 options...
Copy contents of new folder over old folder, delete new folder... assuming you're in your node_modules folder:
OR...
Remove old folder from your node_modules folder:
Then navigate into your homebridge-eDomoticz folder and run...
...and it should then pull in the dependencies. Once done, restart homebridge.
sudo cp -R homebridge-eDomoticz/* homebridge-edomoticz/
sudo rm -rf homebridge-eDomoticz
sudo rm -rf homebridge-edomoticz/
sudo npm install
- deejc
won't start at all now.
8/10/2016, 8:50:28 PM] Loaded plugin: homebridge-eDomoticz
[8/10/2016, 8:50:28 PM] Registering accessory 'homebridge-edomoticz.eDomoticz'
[8/10/2016, 8:50:28 PM] Registering platform 'homebridge-edomoticz.eDomoticz'
[8/10/2016, 8:50:28 PM] ---
[8/10/2016, 8:50:30 PM] Loaded plugin: homebridge-edomoticz
/usr/local/lib/node_modules/homebridge/lib/api.js:76
throw new Error("Attempting to register an accessory '" + fullName + "' which has already been registered!");
Error: Attempting to register an accessory 'homebridge-edomoticz.eDomoticz' which has already been registered!
at API.registerAccessory (/usr/local/lib/node_modules/homebridge/lib/api.js:76:11)
at Plugin.module.exports [as initializer] (/usr/local/lib/node_modules/homebridge-edomoticz/index.js:67:16)
at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:130:14)
at Array.forEach (native)
at Server._loadPlugins (/usr/local/lib/node_modules/homebridge/lib/server.js:108:22)
at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:43:24)
at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:26:16)
at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
error: Forever detected script exited with code: 1
- Marci
See edits above - you still have 2x plugin folders, therefore all devices duplicate, which breaks the unique-device-name rule.
- deejc
got it, will remove it
I was on travel...Marci wrote: Do the following:
cd / sudo find ./ -name homebridge-edomoticz
...and copy/paste the output.
Here it is
./root/.npm/registry.npmjs.org/homebridge-edomoticz
./root/.npm/homebridge-edomoticz
./usr/local/lib/node_modules/homebridge-edomoticz
- Marci
Once it hits Release and I package it into npmjs it'll be back to 'usual' all-lowercase name.deejc wrote:got it, will remove it
- Marci
Did you delete contents of persist folder, or just the accessories folder? Need to empty both.chrispazz wrote:Also deleting accessory files and repairing is doing the same result...
Could it be the new version still not working good?
Ty
- deejc
ok everything is back up and running, although I'm not seeing the mqtt messages in the plugin log, i am running domo in docker so i reconfigured the docker to open port 1883 etc
I just did both again but the result is again the same.Marci wrote:Did you delete contents of persist folder, or just the accessories folder? Need to empty both.chrispazz wrote:Also deleting accessory files and repairing is doing the same result...
Ty
Is there any way to debug this?
- Marci
Check with an MQTT iPhone app or other MQTT client to make sure Domoticz is sending output. Presume you've added the hardware MQTT over LAN device in Domoticz?deejc wrote:ok everything is back up and running, although I'm not seeing the mqtt messages in the plugin log, i am running domo in docker so i reconfigured the docker to open port 1883 etc
- Marci
Not easily, no. Leave it with me.chrispazz wrote: I just did both again but the result is again the same.
- Marci
@chrispazz - what HomeKit app are you using, and what version of iOS?
I am using standard home app with iOS 10 beta 4
