How to install Domoticz on a Synology NAS
- Domoticz version: 2025.1
Re: How to install Domoticz on a Synology NAS
i cant find a package for a Synology DS1019+ on your page is there plans for to make it ?
i want to buy a Synology DS1019+
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
Release: 11
Codename: bullseye
- jumbotroll
Hi.
DS1019+ use arch-apollolake same as DS918+
My download pages is now updated with DS1019+
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
I have the same NAS. Unfortunally the link gives a 404Ingmar wrote: ↑Tuesday 08 January 2019 12:19Ok thank you! So i should really get a new NAS if i understand correctly :pjumbotroll wrote: ↑Tuesday 08 January 2019 10:31DS212j use arch-88F6281 and use very old gcc version and old toolchain from synology.Ingmar wrote: ↑Monday 07 January 2019 23:27 Hi Jumbotroll,
I have a DS212j with DSM 6.2 but on your site I don't see my DS212j in the list of Domoticz version 4.9, is my NAS too old now or can you do some magic?
I'm currently running Domoticz 3.5 so thought it is time for an updateI have to say that this version is running very stable for a few years now, really great. Your work is much appreciated!
I have stopped building new domoticz versions for arch-88F6281.
The latest build for DS212j (DSM6.2) is domoticz_88f6281-6.2_3.0.9483-7.spk
Download here:
http://www.jadahl.com/domoticz_beta_6.2 ... 9483-7.spk
- waaren
Can you check this page ( all available packages ) ?
managed to get the repo from where I can see Mydomo. Now I get the message the NodeJSv4 is needed. but there is no nodes v4 support from my ds212J. Any workaround?
- Domoticz version: 2024.4
As there are no more pre-compiled packages anymore for my DS212+, I like to compile Domoticz myself to benefit from recent added support for Xiaomi/Aqara devices. Currently I can't use my wireless Aqara switches.
My question is whether it's possible to cross-compile for 'Marvell Kirkwood 88F6282' on a MAcBook or do I have to compile it on the NAS (DS212+) following https://www.domoticz.com/wiki/Synology# ... z_yourself?
The website of Jumbotroll mentions it is not compiled anymore because the linux kernel and gcc version from synology is to old and do not support std=C++11
Does this mean it is not possible anymore or do I have to change code too much? Or as said above is new HW the only option?I have stopped build domoticz for NAS that use arch-88f6281/82 because the linux kernel and gcc version from synology is to old and do not support std=C++11.
Running V2024.4 on RPi3B+ & development/HEAD on RPi4B
- jumbotroll
If it was a simple way to build new version, I would do it..Huupke wrote: ↑Monday 21 October 2019 11:01 As there are no more pre-compiled packages anymore for my DS212+, I like to compile Domoticz myself to benefit from recent added support for Xiaomi/Aqara devices. Currently I can't use my wireless Aqara switches.
The website of Jumbotroll mentions it is not compiled anymore because the linux kernel and gcc version from synology is to old and do not support std=C++11Does this mean it is not possible anymore or do I have to change code too much? Or as said above is new HW the only option?I have stopped build domoticz for NAS that use arch-88f6281/82 because the linux kernel and gcc version from synology is to old and do not support std=C++11.
The problem is if you want to compile native or crosscompile, you need the toolchain from synology and it's to old and not compatible to build latest versions of OpenZwave or Domoticz.
Jumbotroll
Jumbotroll
Thanks, I'll move to a RPi3B+ since a new NAS (i.e. DS218+) is too expensive for only being able to run latest Domoticz.
I am now a bit lost and need some help. Newbie with Domoticz.
My current setup is following:
Synology 216j NAS
admin@xxxNAS:~$ uname -m
armv7l
admin@xxxNAS:~$ cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 1 (v7l)
BogoMIPS : 2131.55
Features : swp half thumb fastmult vfp edsp neon vfpv3 tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x4
CPU part : 0xc09
CPU revision : 1
processor : 1
BogoMIPS : 2125.00
CPU architecture: 7
CPU variant : 0x4
CPU part : 0xc09
CPU revision : 1
Hardware : Marvell Armada 380/381/382/383/384/385/388 (Device Tree)
Revision : 0000
Serial : 0000000000000000
admin@xxxNAS:~$
admin@xxxNAS:~$ more /etc.defaults/VERSION
majorversion="6"
minorversion="2"
productversion="6.2.2"
buildphase="GM"
buildnumber="24922"
smallfixnumber="4"
packing="official"
packing_id="18"
builddate="2019/10/30"
buildtime="05:23:02"
admin@xxxNAS:~$
What I would like to do is first to connect my Mitsubishi LN-25 air conditioner to Domoticz. I already installed Domoticz v4.0.10717-8 stable release then downloaded and upgraded Domoticz v4.0.11487-8. Now after the upgrade, I am in the nasty situation. Synology Control panel is showing that Beta release is running, but if I check the Domoticz logs, Stable release is the one has started. What I have done wrong?
I have also installed python 3.5.1 succesfully, but for some reason I am not able to get it working. Based on this post https://www.domoticz.com/wiki/Using_Python_plugins I should see something like this, which is not happening.
PluginSystem: Started, Python version ‘3 .xx ‘in the log.
Python is installed:
root@xxxNAS:/volume1/@appstore/domoticz/var/plugins/domoticz-python-melcloud# python3 -V
Python 3.5.1
Executing rights should be ok:
root@xxxNAS:/volume1/@appstore/domoticz/var/plugins/domoticz-python-melcloud# ll
total 40
drwxr-xr-x 3 root root 4096 Nov 22 20:24 .
drwxr-xr-x 3 domoticz root 4096 Nov 22 20:24 ..
drwxr-xr-x 8 root root 4096 Nov 22 20:24 .git
-rwxr-xr-x 1 root root 24308 Nov 22 20:24 plugin.py
-rw-r--r-- 1 root root 27 Nov 22 20:24 README.md
Highly appreciate if someone could help me with this!
Synology 216j NAS
armv7l
processor : 0
BogoMIPS : 2131.55
CPU architecture: 7
CPU variant : 0x4
CPU part : 0xc09
CPU revision : 1
processor : 1
BogoMIPS : 2125.00
CPU architecture: 7
CPU variant : 0x4
CPU part : 0xc09
CPU revision : 1
Revision : 0000
admin@xxxNAS:~$
majorversion="6"
minorversion="2"
buildphase="GM"
buildnumber="24922"
smallfixnumber="4"
packing="official"
packing_id="18"
admin@xxxNAS:~$
Python 3.5.1
total 40
Hold on, you can ignore this request. All of the sudden Domosticz version is showing demo version and I was able to get Melcoud also working.opex wrote: ↑Saturday 23 November 2019 11:06 Hi,
Synology 216j NAS
armv7l
processor : 0
BogoMIPS : 2131.55
CPU architecture: 7
CPU variant : 0x4
CPU part : 0xc09
CPU revision : 1
processor : 1
BogoMIPS : 2125.00
CPU architecture: 7
CPU variant : 0x4
CPU part : 0xc09
CPU revision : 1
Revision : 0000
admin@xxxNAS:~$
majorversion="6"
minorversion="2"
buildphase="GM"
buildnumber="24922"
smallfixnumber="4"
packing="official"
packing_id="18"
admin@xxxNAS:~$
Python 3.5.1
total 40
On the other hand, any hints or tips are still more tan welcome.
My second step is to add room and outside temperature sensors. I have been thinking wifi and BLE based sensors. Very simple question. If I use wifi sensors, I don't need any extra hardware right? Or do I still need somekind of gateway? Can I find plug and play wifi sensors, I try to avoid arduino type of things.
For BLE sensors somekind of bluetooth gateway is needed. Is normal bluetooth adapter enough, which I just plug into Synology USB port.
- Domoticz version: 4.0.1154
First of all thank you for your work Jumbotroll
I wanna add some sonoff product which need some plugins from https://github.com/gerardwr/Sonoff-Domoticz
But i can not find the correct folder in my NAS directories.
With SSH i can find the Domoticz folder but can not find the plugins subdirectory and have no permission to create it but i am not sure it is a good idea to create subfolders.
Can you help me how to install this plugin?
- jumbotroll
Did you install the Python version of domoticz?Clau wrote: ↑Monday 09 December 2019 9:18 First of all thank you for your work Jumbotroll
Python 3 package from synology is required if you choose domoticz with python plugin support.
The plugins folder is located in /usr/local/domoticz/var/plugins on synology!
Jumbotroll
Jumbotroll
Thanks for fast answare
Yes of course, python runs on my nas
I've found the correct directory but to work with my device i should run a sonoff "server" on my network too. The idea was to integrate all work in my nas so i was hapy to find your domoticz under synology. But i can not figure how can i run sonoff https://github.com/mdopp/simple-sonoff-server on it.
So now i keep reading mayba find something.
I do not have raspberry and can't buy new devices, i can do some automated thing with my sonof products but not everyting. IFTTT is a joke withoute "and switches" so a home automation program can be the correct solution.
I've installed domoticz about a year ago, had it running but never really got the time to really use it.
I wanted to pick it up again, installed a new version (latest stable version fot the ds918+).
The problem I now have is that the Hardware page is completly empty.
I see no option to include new hardware.
I've plugged in the usb zwave controller that worked before, but nothing shows.
Same goed for devices.
The rest seems to be ok.
Any ideas?
the log seems ok ...
Any ideas?
2020-02-18 09:13:36.450 Status: Domoticz V4.10717 (c)2012-2019 GizMoCuz
2020-02-18 09:13:36.473 Status: Build Hash: b38b49e-modified, Date: 2019-05-09 13:04:08
2020-02-18 09:13:36.473 Status: Startup Path: /usr/local/domoticz/
2020-02-18 09:13:37.797 Sunrise: 07:51:00 SunSet: 17:58:00
2020-02-18 09:13:37.797 Day length: 10:07:00 Sun at south: 12:55:00
2020-02-18 09:13:37.797 Civil twilight start: 07:16:00 Civil twilight end: 18:33:00
2020-02-18 09:13:37.797 Nautical twilight start: 06:37:00 Nautical twilight end: 19:13:00
2020-02-18 09:13:37.797 Astronomical twilight start: 05:57:00 Astronomical twilight end: 19:52:00
2020-02-18 09:13:37.908 Active notification Subsystems: (0/13)
2020-02-18 09:13:38.330 Starting shared server on: :::6144
2020-02-18 09:13:38.044 Status: WebServer(HTTP) started on address: :: with port 8084
2020-02-18 09:13:38.329 Status: WebServer(SSL) started on address: :: with port 8443
2020-02-18 09:13:38.330 Status: TCPServer: shared server started...
2020-02-18 09:13:38.331 Status: RxQueue: queue worker started...
2020-02-18 09:13:40.333 Status: EventSystem: reset all events...
2020-02-18 09:13:40.333 Status: EventSystem: reset all device statuses...
2020-02-18 09:13:40.379 Status: EventSystem: Started
2020-02-18 09:13:40.379 Status: EventSystem: Queue thread started...
2020-02-18 09:17:34.419 Active notification Subsystems: (0/13)
2020-02-18 09:17:44.892 Active notification Subsystems: (0/13)
- waaren
Did you try clearing cache and appcache (different things ?)
Hello all,
has anyone been able to use a "Z-Wave.Me UZB Z-Wave Plus USB stick" on a synology ?
It's this product : https://z-wave.me/products/uzb/
I have been using this on Synology DS218 for the last 2 years. Works great.dooblem wrote: ↑Saturday 22 February 2020 13:29 Hello all,
- Domoticz version: 2020.2
How savvy are you with a soldering iron and Arduino IDE?Clau wrote: ↑Monday 09 December 2019 21:32 Thanks for fast answare
Because you can skip the whole Sonoff server if you just flash your Sonoff devices with EspEasy or Tasmota. When you use one of those firmware's in combination with Domoticz, anything is possible. (I use EspEasy on 10+ Sonoff devices)
Greetz,
·´¯`·.¸¸.·´¯`·. ( Creaky ) .·´¯`·.¸¸.·´¯ `·
