Page 23 of 23
Re: zwavejs2mqtt
Posted: Monday 24 April 2023 9:53
by MikeyMan
I keep getting intermittent errors:
- 2023-04-24 09_52_11-Thuis en nog 5 andere pagina's - Profiel 1 - Microsoft​ Edge.png (6.52 KiB) Viewed 1383 times
The node works fine in ZwaveJS.
I cannot see how to try and fix this. It's not always the same node...
Domoticz log says:
2023-04-24 09:54:05.418 Error: MQTT Zwave: Switch not found!? (zwavejs2mqtt_0xc928871b_15-38-1-currentValue/Buitenverlichting voorkant)
Re: zwavejs2mqtt
Posted: Monday 24 April 2023 11:57
by MikeyMan
Tried setting this node through MQTT, with NodeRed. And thats working fine.
Re: zwavejs2mqtt
Posted: Monday 01 May 2023 8:53
by MikeyMan
Removed all the devices having to do with this switch. And somehow re-added it. The process for that isn't too straightforward to be honest.
And somehow now the naming is different than before.
From NodeID_15* to the actual name of the device. But that could be a setting. Might be the reason for the failures?
It's working now, lets see how long it lasts.
Re: zwavejs2mqtt
Posted: Saturday 13 May 2023 18:30
by MikeyMan
Luckily this same node is causing issues now. And the previous didn't work anymore. How to trigger it to autodetect again?
Re: zwavejs2mqtt
Posted: Monday 10 July 2023 15:05
by MikeyMan
Awfully quiet in this topic...?
Any others with this issue?
viewtopic.php?t=40389
Devices failing sometimes. Only option is to manually delete all messages from the broker.
Re: zwavejs2mqtt - solved
Posted: Tuesday 19 September 2023 17:17
by lupo2a
Moved to zwaveJS-ui.
I have a Fibaro door sensor and multiple Fibaro blind shutter. Blind shutter works fine but domoticz dosn't create a device for Fibaro door sensor
I can see the device on zwaveJS-ui and the messages when it detects an opening/closing of the door.
Any help?
Just installed everything from scratch on a raspberry pi 4.
Bot stable and beta version of Domoticz
UPDATE
included a new device and everything is working fine
Re: zwavejs2mqtt
Posted: Tuesday 19 September 2023 19:37
by Derik
Hi I use zwave in Docker.
Only cannot ad a node with the webui..
I use: Aeotec Gen5 Z-Wave USB Z-Stick
When i lear directly on the stick, the node is dead..
Is there a special way to learn new nodes?
All te othes nodes came from openzwave settings, and still working fine
