zwavejs2mqtt
MikeyMan
Re: zwavejs2mqtt
Post by MikeyMan »
I keep getting intermittent errors:
2023-04-24 09_52_11-Thuis en nog 5 andere pagina's - Profiel 1 - Microsoft​ Edge.png
2023-04-24 09_52_11-Thuis en nog 5 andere pagina's - Profiel 1 - Microsoft​ Edge.png (6.52 KiB) Viewed 1362 times
The node works fine in ZwaveJS.
I cannot see how to try and fix this. It's not always the same node...
Domoticz log says:
2023-04-24 09:54:05.418 Error: MQTT Zwave: Switch not found!? (zwavejs2mqtt_0xc928871b_15-38-1-currentValue/Buitenverlichting voorkant)
MikeyMan
Re: zwavejs2mqtt
Post by MikeyMan »
Tried setting this node through MQTT, with NodeRed. And thats working fine.
MikeyMan
Re: zwavejs2mqtt
Post by MikeyMan »
Removed all the devices having to do with this switch. And somehow re-added it. The process for that isn't too straightforward to be honest.
And somehow now the naming is different than before.
From NodeID_15* to the actual name of the device. But that could be a setting. Might be the reason for the failures?
It's working now, lets see how long it lasts.
MikeyMan
Re: zwavejs2mqtt
Post by MikeyMan »
Luckily this same node is causing issues now. And the previous didn't work anymore. How to trigger it to autodetect again?
MikeyMan
Re: zwavejs2mqtt
Post by MikeyMan »
Awfully quiet in this topic...?
Any others with this issue?
viewtopic.php?t=40389
Devices failing sometimes. Only option is to manually delete all messages from the broker.
lupo2a
Re: zwavejs2mqtt - solved
Post by lupo2a »
Moved to zwaveJS-ui.
I have a Fibaro door sensor and multiple Fibaro blind shutter. Blind shutter works fine but domoticz dosn't create a device for Fibaro door sensor
I can see the device on zwaveJS-ui and the messages when it detects an opening/closing of the door.
Any help?
Just installed everything from scratch on a raspberry pi 4.
Bot stable and beta version of Domoticz
UPDATE
included a new device and everything is working fine
Last edited by lupo2a on Wednesday 20 September 2023 11:50, edited 1 time in total.
Raspberry PI 4
Domoticz: V2023.2
- Aeotec Gen5 EU
- Neo CoolCam Door Detector and plug
- FIBARO FGWPE Wall Plug
- 6 FIBARO System FGRM222 Roller Shutter Controller 2
- Kodi SamnsungTV Yamaha plugin
- pluginn manager
- Netatmo
Derik
Re: zwavejs2mqtt
Post by Derik »
Hi I use zwave in Docker.
Only cannot ad a node with the webui..
I use: Aeotec Gen5 Z-Wave USB Z-Stick
When i lear directly on the stick, the node is dead..
Is there a special way to learn new nodes?
All te othes nodes came from openzwave settings, and still working fine
