Blockly examples
StanHD
Re: RE: Re: Blockly examples
Post by StanHD »
tozzke wrote:Sunset/rise have to be linked into the Time-blockly
I think the "and" should be an "or" due to the 00:00 end of day within Domoticz. Image
Python:- Broadlink RM2, Sonos
tozzke
Domoticz version: Stable
Post by tozzke »
true, I was too focussed on the correct position of the blocks :)
tjabas
Post by tjabas »
Hi!
i have made a blocky like this:[img]
[/img]
it contols my bathroom fan, it works good but i can see in the log that it send an off command every minute when it goes below 49%
i dont know if it matters if the rfx sends an off command every minute, but it sure doesnt need to do that, how can i make the blocky so the rfx sends just one or a couple of off commands after the moisture % goes below 49%?
another stupid question is, is it called blocky or blockly?
PeGe
Domoticz version: V3.6328
Post by PeGe »
To avoid that unnecessary load, just include an AND in your condition, checking if 'Toalett fläkt' = On.
Like this:
if 'Toalett nere' < 49 AND 'Toalett fläkt' = On
/P-G
tjabas
Post by tjabas »
ofcourse , why didnt i think of that :)
i have fixed it now and im going to test it.
thanks.
AimoPaukku
Post by AimoPaukku »
Hi...
How can i create this IF event?
IF it is cold outside(<10c I have virtual weatherstation) and any door(i can do doors or package) is left open for a 5min or more. Ignore if less.
Then I want a message (can do this part)
tozzke
Post by tozzke »
AimoPaukku wrote:Hi...
I'd say that this should do the trick:
Change my 'TESTknop1 = On' into your 'temp < 10', my 'TESTknop2 = On' into your 'Doors = Open', my 'var TESTlamp1' into a variable to your liking, my switch 'TESTlamp1' into a dummy switch to your liking, my 'TESTknop1 = Off' into your 'Doors = Closed', my 'Write to log "WARNING!!!!! DOORS OPEN!!!!"' into your notification and my 10 seconds into your desired time in seconds.
The dummy switch 'TESTlamp1' is necessary because of the fact that Domoticz/Blockly won't allow you to change the very variable which you also use in the if-statement.
the log:
2017-04-01 01:03:33.339 User: Admin initiated a switch command (123/TESTknop1/On)
2017-04-01 01:03:33.340 (TESTknop1) Lighting 2 (TESTknop1)
2017-04-01 01:03:35.427 User: Admin initiated a switch command (124/TESTknop2/On)
2017-04-01 01:03:35.457 EventSystem: Event triggered: TEST - 1-4-2017 - AimoPaukku Domoticz forum Blockly samples_1
2017-04-01 01:03:35.460 var TESTlamp1 = 1
2017-04-01 01:03:35.460 var TESTlamp1 = 2 after 10 seconds
2017-04-01 01:03:35.428 (TESTknop2) Lighting 2 (TESTknop2)
2017-04-01 01:03:35.746 (TESTlamp1) Lighting 1 (TESTlamp1)
2017-04-01 01:03:39.447 User: Admin initiated a switch command (124/TESTknop2/Off)
2017-04-01 01:03:39.478 EventSystem: Event triggered: TEST - 1-4-2017 - AimoPaukku Domoticz forum Blockly samples_3
2017-04-01 01:03:39.480 var TESTlamp1 = 0
2017-04-01 01:03:39.448 (TESTknop2) Lighting 2 (TESTknop2)
2017-04-01 01:03:39.775 (TESTlamp1) Lighting 1 (TESTlamp1)
2017-04-01 01:03:46.743 Set UserVariable TESTlamp1 = 2
2017-04-01 01:03:50.066 User: Admin initiated a switch command (124/TESTknop2/On)
2017-04-01 01:03:50.095 EventSystem: Event triggered: TEST - 1-4-2017 - AimoPaukku Domoticz forum Blockly samples_2
2017-04-01 01:03:50.097 WARNING!!!!! DOORS OPEN!!!!
2017-04-01 01:03:50.067 (TESTknop2) Lighting 2 (TESTknop2)
2017-04-01 01:03:50.371 (TESTlamp1) Lighting 1 (TESTlamp1)
2017-04-01 01:03:50.761 Set UserVariable TESTlamp1 = 0
2017-04-01 01:04:20.292 User: Admin initiated a switch command (124/TESTknop2/Off)
2017-04-01 01:04:20.293 (TESTknop2) Lighting 2 (TESTknop2)
2017-04-01 01:04:21.116 User: Admin initiated a switch command (123/TESTknop1/Off)
2017-04-01 01:04:21.117 (TESTknop1) Lighting 2 (TESTknop1)
PS: in lua it would be easier :p
In lua you can put the time condition in the if instead of in the output
anno
Domoticz version: all
Post by anno »
this is working only not all the time. for example this evening the tuin lights didn't turn off after 5 min. Why?
blocky 1 tuin2.jpg (326.63 KiB) Viewed 6036 times
long time domiticz user, running 8 domoticz installations on vm's nuc i3. And espeay hosting more than 30.
Nautilus
Post by Nautilus »
anno wrote:this is working only not all the time. for example this evening the tuin lights didn't turn off after 5 min. Why?
Depending of the lamp type, I've noticed "Off AFTER 5" works sometimes a lot better than "On FOR 5". It possibly has something to do with the states that are available for the lamp type. Basic On/Off works (maybe) well also with "On FOR XX" whereas dimming / RGB etc. bulbs need to use "Off AFTER XX"?
So I would change the first command to just "On" and then add a second command to each condition with "Off AFTER 5" :)
anno
Post by anno »
Thanks you, i will try it
tozzke
Post by tozzke »
'On for x minutes' means that after the set time, it goes back to the previous setting.
If the light is already on (or rather... not off) it turns the light on again but after 5 minutes it goes to the previous state which was already on.
So probably the time the light didn't go off, it was already on when a sensor detected motion.
So you'll have to add the condition 'and Tuinverlichting = Off' to all if's or use the suggestion made by Nautilus
videodrome
Post by videodrome »
I made this script to bring the nest thermostat to 18 degrees when the window is opened.
the script works fine (open url"http://192.168.1.xxx:8080/json.htm?type ... &svalue=18")
How can run the script when the window is left open for more than five minutes? When x is open for more than 5 minutes, do....
Caribou
Post by Caribou »
I'm a newbie with domoticz and beginning to play with events.
Could you please tell me what am I missing with this blocky scenario:
My goal is to receive an email alert when a motion is detected between specific hours (next I will try to improve it, by receving only an email for the first motion of each day).
StanHD
Post by StanHD »
Caribou wrote:Hi,
If you only have an "If" but not an "Else If" then you should use the block without the blue "gear" symbol. ;)
videodrome
videodrome wrote:I made this script to bring the nest thermostat to 18 degrees when the window is opened.
anyone could help me?
four2six
Post by four2six »
quick idea: have a virtual switch, turn that switch on when the window opens and make it turn off after 5 minutes. when it turns off, open the url.
videodrome
four2six wrote:quick idea: have a virtual switch, turn that switch on when the window opens and make it turn off after 5 minutes. when it turns off, open the url.
Thanx for the idea: now it works. The nest thermostat will be set to 18 degrees if the door remains open for at least 5 minutes, otherwise it will remain at the set temperature. "Finestra"is the virtual sensor
four2six
Post by four2six »
better than what i said, well done :-)
Letalis
Post by Letalis »
Tried to find a solution. But when I use blocky to lower my blind and notify me it sends multiple notifications.. I got like a notification every one minute or so.
Can you get blocky to only send notification once?
four2six
Post by four2six »
can you post the blockly?
