Aurora theme
blauwebuis
Domoticz version: current
Re: Aurora theme
Post by blauwebuis »
I've accepted a pull request that should enable camera's everywhere again.
rkarolek
Re: Aurora theme
Post by rkarolek »
hi
in my system i have some devices THB, on aurora theme T and H displayed small size font in upper right corner device's "bricks".
there are any way to chose which data are display in centre, or atleast increase size of fonts?
ty in advance for any help
blauwebuis
Re: Aurora theme
@rkarolek Yes, there is an option in settings to place the temperature in the middle.
dervogt
Re: Aurora theme
Post by dervogt »
HI, just updated to the most recent release, both Domoticz (Beta) and AUrora. SInce the update, my switch page is no longer showing ALL switches from all Rooms. Only a handful of switches is diaplayed on the switches page, but when switching the Filter in the upperright corner to a different room, the "lost"devices show up again on the specific room. But when the filter is set to All only 17 Items are displayed.
Any idea how to fix that?
dervogt
Re: Aurora theme
Post by dervogt »
ok
dervogt wrote: Wednesday 23 January 2019 15:27 HI, just updated to the most recent release, both Domoticz (Beta) and AUrora. SInce the update, my switch page is no longer showing ALL switches from all Rooms. Only a handful of switches is diaplayed on the switches page, but when switching the Filter in the upperright corner to a different room, the "lost"devices show up again on the specific room. But when the filter is set to All only 17 Items are displayed.
I found my solution here inthe Forum, it seems to have been a locked up cache and old file on the server...
THis was my solution:
https://www.domoticz.com/forum/viewtopi ... de#p184112
espenln
Re: Aurora theme
Post by espenln »
I have some problems with my switches page on Aurora theme. See screenshot. It happened suddenly some weeks ago. Right now I'm on v4.10430 Beta, but I can't remember which version I had when the problem first appeared. The problem is independent on which browser I use or if I'm on a Windows PC, phone or tablet. It looks okay on other themes than Aurora. The other pages also looks okay.Image
Sent fra min SM-T819 via Tapatalk
blauwebuis
Re: Aurora theme
This has been fixed.
bvlet
Re: Aurora theme
Post by bvlet »
Good morning,
In the first post in this thread I see that you also merged the setpoints of the thermostat with the switch.
Can you tell me how to do this? I managed to merge the setpoints by naming them xxx - yyy, but for the switch this doesn't work...
Thank you!
dpui7736
Domoticz version: 4.9700
Re: Aurora theme
Post by dpui7736 »
With the last update, I can't see camera preview on dashboard.
Enviado desde mi ONEPLUS A5010 mediante Tapatalk
splinter
Re: Aurora theme
Post by splinter »
Hi..
I know "this has been fixed", but maybe you could help me anyway. I have this problem with the switches view. I git pulled the latest version of aurora theme into my styles directory. Reset the theme, but it still looks like this:
Screenshot 2019-04-15 at 15.24.57.png (289.78 KiB) Viewed 126556 times
The developer console shows this error repeatedly:
Screenshot 2019-04-18 at 13.50.55.png (37.68 KiB) Viewed 126494 times
Is there anything I forgot to do to fix it? Thanks in advance for the help
Strange "git reset --hard origin/master" fixed it.. but my previous "git pulls" said "Already up to date" until today
regards,
Splinter
Cisco765
Re: Aurora theme
Post by Cisco765 »
i've installed the theme but when I try to group more switch the icon for the activation disappear (see attachment). What can I do? I've tried a lot of configuration. Thanks
Schermata 2019-05-05 alle 19.23.58.png (32.58 KiB) Viewed 126336 times
blauwebuis
Re: Aurora theme
@cisco765: I don't know. Try mixing in a sensor? Or merge less devices?
Overall I will be supporting this theme much less. I have moved on to using the Mozilla Gateway. It's improving rapidly, and is very user friendly.
https://iot.mozilla.org/
Tolubey
Re: Aurora theme
Post by Tolubey »
rkarolek wrote: Thursday 17 January 2019 16:07 hi
I join the question. how can I adjust the display in the center and large font?
blauwebuis
Re: Aurora theme
@Cisco765: There is a limit to how many items you can group. Please read the documentation.
@Tolubey: you could add custom CSS in the theme settings?
imdos
Domoticz version: 2023.2
Re: Aurora theme
Post by imdos »
I'm using this theme/skin for some time now; but I experience two strange things.
The first is the CPU usage on my rPi3 stays above 1.2 while one of my browsers is on the domoticz page. Is there some way to disable this?
Secondly; I have never seen the configuration menu although I'm on the latest beta's.
Making use of: Raspbian(SSD), dz Beta, Woonveilig, Z-Wave(alarm+multi-sensor), RFLink(blinds), P1, Yeelight, Xiaomi temp sensors, Tasmota(SonoFF, Blitzwolf SHP2, Shelly1)
Zamjoke
Domoticz version: 2021.3
Re: Aurora theme
Post by Zamjoke »
Hi all
First of all thanks for providing tis theme, I absolutely love it , however ( yes I'm here for more than praises 😁)
Can anyone please help with the following issue.
Everything is fine on PC (Windows) however on my mobile when on portrait mode and trying to set the temperature on the Dahboard, only half of the pop-up screen is visible and so cannot adjust and set . (Only if I turn the phone to Landscape)
I have tried: •setting center Pop-up in theme settings
•played around wit the mobile_phoney.css (have no idea what I was doing just trying to use some logic, obviously not much here 🙄) anyways..pictures bellow, thanks in advance.
Sjonnie2017
Domoticz version: Latest ß
Re: Aurora theme
Post by Sjonnie2017 »
Thanks Blauwebuis for all your effort. I just discovered your theme today and it is positively mind blowing!
I will follow this thread for any updates that you may produce.
Kudos!!
Greetz,
Sjonnie
YouLess Energy meter
Jochem
Domoticz version: 4.10181
Re: Aurora theme
Post by Jochem »
When I try to use a custom background image, I put this image background.jpg in the style map.... when I put in acttheme/background.jpg I see the image appear... but when I click on the save button te image disappear..
Is there a solution to solve this??
Raspberry P3, RF-Link FW version 48, lots of KAKU switches, Sonos connected, LG TV switching, a lot of weather switches.
Gertschi
Re: Aurora theme
Post by Gertschi »
I reinstalled my RPI3 with domoticz and the aurora theme. At this time I don´t get the preview of the cameras on the dashboard, but the stream works fine. Also the preview of a textutility doesn´t work and the background picture isn´t visible anymore.
I can´t go back to a previous version. But it all worked on the previous installation.
My Domotitcz V4.11799 runs on a RPI 3 with buster.
Are there problems with the theme or on the new domoticz installation and what could I do to get it work again?
blauwebuis
Re: Aurora theme
@gertschi I am no longer supporting this theme. If there are community pull requests I will add those, but that's the limit.
I've personally switched to using the Mozilla WebThings Gateway. It's so much nicer.
