Dashticz - Module - Garbage collector Topic is solved
aiolos
Domoticz version: stable
Re: Dashticz - Module - Garbage collector
Post by aiolos »
EdwinK wrote: Wednesday 17 January 2018 10:29 Looks there is something more happening.
As seen on https://www.mijnafvalwijzer.nl/nl/3161LH/27/ today is 'grof vuil' and on Friday we have 'rest'. But on dashticz it shows all the dates as 'rest'. Only 'gft' is changing colors in the text.
Part of config.js
That makes sense. 'Grof' and 'Grijs' both resolve to a grey bin. A while ago someone also asked for a similar change in this behaviour and I think we have to refactor this a bit (and maybe even give the option to add some config options for this). Some of the requests are a bit conflicting, since bin colours and their type of garbage differ per region.
Contributor to Dashticz
More on my Github profile
EdwinK
Post by EdwinK »
Off course.. Didn't even see that. Maybe I can fix this myself for now with just another color bin for one of them.
maceddy
Domoticz version: 12723
Post by maceddy »
Thanks, I cannot get it to work though..
config['garbage_company'] = 'area';
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = '1234XX';
config['garbage_street'] = 'Streetname;
config['garbage_housenumber'] = '83';
config['garbage_maxitems'] = '3';
config['garbage_width'] = '5';
config['garbage'] = {
gft: {kliko: 'green', code: '#375b23', name: 'GFT'},
pmd: {kliko: 'orange', code: '#db5518', name: 'PMD'},
rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval'},
papier: {kliko: 'blue', code: '#153477', name: 'Papier'},
kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval'},
brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin'},
black: {kliko: 'black', code: '#000000', name: 'Zwart'},
config['garbage_use_names'] = true;
config['garbage_use_colors'] = true;
It just gives 'Loading' next to the Kliko icon... Have I done something wrong? Also tried without Streetname and few other options.
aiolos wrote: Tuesday 16 January 2018 0:44
maceddy wrote: Saturday 13 January 2018 21:16 Any chance you will implement 'Area Reiniging'?
</ snip>
Both these garbage collection calendars are added. See this PR
The garbage company configuration is:
and
config['garbage_company'] = 'almere';
aiolos
Post by aiolos »
maceddy wrote: Wednesday 17 January 2018 20:58 Thanks, I cannot get it to work though..
</ snip>
and
Can you send me your postalcode/housenumber (can also be your neighbours ;)) by PM, there might be a new type of garbage in there which I haven't seen yet and on which it is failing.
Edit: A fix for the waste api is available in a PR. There is also some preparation in it for a configurable mapping of the colours of the bin. More about that later, not sure about the solution yet, and I don't want people to have to update their config every time.
Zoekm
Post by Zoekm »
Zoekm wrote: Friday 08 December 2017 13:10 Just recently installed Dashticz and I like it very much, great work! Yesterday was the first time the garbage ("Restafval") pickupdate passed by and I noticed that on the day of pickup of "Restafval", in my case Thursdays ("donderdag"), the block already shows the next pickup days/dates and garbage type, so on Thursday I see the next weeks messages and later. Yesterday, Thursday, they came to pickup "Restafval", but the Dashticz shows "GFT":"Thursday". For me this is confusing, is it possible that the first line displays the garbage type until that day has passed? Is there a configuration setting for this?
Updated Dahticz and now using iCal, same issue pops up again, see picture. At the day of pick-up (18th of January) it does not show what will be picked up.
2018-01-18 afval.jpg (3.57 KiB) Viewed 4778 times
aiolos
Post by aiolos »
Zoekm wrote: Thursday 18 January 2018 10:54
What iCal calendar do you use? I tried this with my own google calendar (as iCal link) and there the appointment for today shows up (no matter if it is a full-day appointment or just for an hour). It can be that the source only delivers the appointments in the future, which can mean that on the day itself, it is already disappeared. But that's just a guess.
maceddy
Post by maceddy »
aiolos wrote: Wednesday 17 January 2018 21:09
It's working now! Is there anything to do about the days and date in American notation? It says 'monday' and 1/29/2018...
Sorry, I'm a Pietje Precies haha!!
aiolos
Post by aiolos »
maceddy wrote: Thursday 18 January 2018 20:48
You can use
config['calendarlanguage'] = 'nl_NL';
to get it in Dutch.
Regdul
Domoticz version: 3.8153
Post by Regdul »
aiolos wrote: Tuesday 16 January 2018 23:58
Regdul wrote: Sunday 14 January 2018 23:36 is there any change to add "de friese meren' garbage calendar? same as maceddy, i cant get it to work. there is an option for Ical
https://dfm.afvalalert.nl/#
thanks!
In this PR the support for this garbage calendar is added.
Configuration:
config['garbage_company'] = 'afvalalert';
It is very likely this company also works for other regions than 'De Friese Meren'
EdwinK wrote: Tuesday 16 January 2018 18:25 Is it right that the colors of the trashbin's dont change anymore?
It does with my config (which is pretty standard for development) For various garbage companies and addresses I saw different colours of bins.
thanks a lot!
snadderr
Post by snadderr »
i'm trying to change some display names in the garbage module. This is working fine for almost all types of garbage, but i can't change the "luiers" name. It's not showing at all in the module when i enable the "use names" config. When i set the "use names" config to false, Luier is showing.
I'm using the "mijnafvalwijzer" service. When i open the url (http://dashticz.nl/afval/?service=mijna ... er&zipcode...) manually, i get the following output:
[{"date":"2018-01-05","title":"tuinafval"},{"date":"2018-01-05","title":"restafval"},{"date":"2018-01-05","title":"luiers"},{"date":"2018-01-05","title":"keukenafval"},{"date":"2018-01-12","title":"luiers"},{"date":"2018-01-12","title":"pmd"},
How do i change the "luier" name in the Dashticz garbage module? This is not working:
luiers: {kliko: 'green', code: '#375b23', name: 'LUIERS'},
For example, if i want to change "restafval" to "RESTAFVAL" i need to configure this:
rest: {kliko: 'green', code: '#375b23', name: 'RESTAFVAL'},
In the service URL i see also restafval (instead of rest), so i think luiers is also a different name, but i can't see where the match is made.
PeJeWe
Domoticz version: Latest
Post by PeJeWe »
My kliko icon stay's grey.
CONFIG.js
//AFVAL PROGRAMMA
    gft: {kliko: 'green', code: '#98fb98', name: 'GFT'},
    pmd: {kliko: 'orange', code: '#faa500', name: 'Plastic'},
    papier: {kliko: 'blue', code: '#0198E1', name: 'Papier'},
config['garbage_icon_use_colors'] = true;
the files are in the garbage map are
etc.
Buzzje
Post by Buzzje »
How would I had the Den Haag calendar (e.g. http://huisvuilkalender.denhaag.nl/ical ... 0000517306)? Seems that the result (https://wedevise.nl/dashticz/ical/demo/ ... 0000517306) comes up empty?
naitsirhc
Post by naitsirhc »
I own a Synology which has Owncloud installed. I managed to get an Ical file from the "garbagewebsite" and imported it to my Owncloud calendar. I can create a link. (http://10.0.0.149/owncloud/remote.php/d ... /personal/)
Is it possible to import data by the garbage module from my Owncloud? I have to say that my Synology is protected by password.
Kind regards
Und Tschjuß
marcel19
Post by marcel19 »
is it possible to get my city on this?
https://www.gad.nl/ophaalschema.aspx
rbeech
Post by rbeech »
I got google ical working, thanks for previous help. However, my events have disappeared.
I think repeating events don't seem to be captured after the first event?
Martinvdm
Post by Martinvdm »
DvD wrote: Saturday 27 May 2017 17:39 Is it possible to add reinis to the garbage collector ? thnx in advance
http://www.reinis.nl/postcodecheck/
Daniel
Did you ever got this working? I want to use Reinis also.
gielie
Domoticz version: latest β
Post by gielie »
mijnafvalwijzer is not working anymore, i read something about adding an ical link, how do i change that?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
Jendemen
Post by Jendemen »
I installed Dashticz this week and want to use the garbage info.
Read throught all 23 pages of this forum, came across multiple problems with screen stays on 'loading', implemented the suggestions but.....
Also my screen just shows 'loading'. I removed everything in the CONFIG.js to prevent that something else is causing the problem.
Hope anyone has suggestions?
This is my config|:|
var config = {}
config['domoticz_ip'] = 'http://192.xx.xx.xx:8080';
config['domoticz_refresh'] = '50';
config['dashticz_refresh'] = '600';
config['garbage_company'] = 'mijnafvalwijzer';
config['garbage_zipcode'] = '4822RL';
config['garbage_housenumber'] = '15';
var columns = {};
columns['bar'] = {};
columns['bar']['blocks'] = ['logo','miniclock','settings'];
columns[1] = {};
columns[1]['blocks'] = ['garbage'];
columns[1]['width'] = 12;
var screens = {};
screens[1] = {};
screens[1]['background'] = 'bg2.jpg';
screens[1]['columns'] = [1];
RobertK
Post by RobertK »
It's likely not a problem in the scripts, but rather an issue with mijnafvalwijzer itself (I have the same 'Loading...' issue myself
as well for the last 2 days).
Trying to load the json url in a plain browser does not return anything useful either.
Using the DEMO postalcode+number from the mijnafvalwijzer website and putting it into the json URL:
http://json.mijnafvalwijzer.nl/?method= ... oevoeging=
returns:
Op dit moment is het erg druk. Probeert u het later nog eens. Onze excuses voor het ongemak.
renerene
Post by renerene »
MijnAfvalwijzer is not working anymore. Noticed it some days ago.
GIT PULL tells me I got the latest Dashticz. The website works OK
Her is my config.js:
config['garbage_zipcode'] = 'xxxxyy';
config['garbage_street'] = '<name>';
config['garbage_housenumber'] = '30';
config['garbage_maxitems'] = '2';
