Re: Domoticz App
Posted: Wednesday 08 April 2020 20:58
The Github says it's not available on Apple's AppStore yet because it is still beta... But the site links to the App on Appstore...
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
I have same problem. I had to remove the app then install it again. But when I activated security setup it crashed again. Now I reinstalled it without activate security it works.vgr2 wrote: Wednesday 08 April 2020 18:47 Latest App Version is not working on my iOS 13.4.1.
App is starting and shutting down directly….
hmmmm do you use http with a valid certificate??DewGew wrote: Wednesday 08 April 2020 21:01I have same problem. I had to remove the app then install it again. But when I activated security setup it crashed again. Now I reinstalled it without activate security it works.vgr2 wrote: Wednesday 08 April 2020 18:47 Latest App Version is not working on my iOS 13.4.1.
Good oneFearNaBoinne wrote: Wednesday 08 April 2020 20:58 The Github says it's not available on Apple's AppStore yet because it is still beta... But the site links to the App on Appstore...![]()
Yes i have a valid certificategaladril wrote: Thursday 09 April 2020 20:21hmmmm do you use http with a valid certificate??DewGew wrote: Wednesday 08 April 2020 21:01I have same problem. I had to remove the app then install it again. But when I activated security setup it crashed again. Now I reinstalled it without activate security it works.vgr2 wrote: Wednesday 08 April 2020 18:47 Latest App Version is not working on my iOS 13.4.1.
Can you maybe make screenshots of what you mean? with security setup etc?
Fixed the issue on beta.. is going to be in the next releasegaladril wrote: Saturday 11 April 2020 23:14Created an issue to keep track
https://github.com/domoticz/domoticz-xamarin/issues/22
The new version is available in the App Store.. this should be fixedDewGew wrote: Thursday 09 April 2020 22:28Yes i have a valid certificategaladril wrote: Thursday 09 April 2020 20:21hmmmm do you use http with a valid certificate??DewGew wrote: Wednesday 08 April 2020 21:01
There is an issue with your connection settings.darrepac wrote: Wednesday 15 April 2020 10:02 I put server information, not so sure what to put if http or https but I tried both (http was better working)
Then, at the next page, there is "check your parameters" (well it is in french for me so that could differ slightly)
I press the button and I got "not possible to get switches"
Yesgaladril wrote: Thursday 16 April 2020 8:12 And your using an account in Domoticz that has enough rights to see devices right?
I've submitted a new beta with some fixes on the local/remote detecting method.
What iOS version do you use?solidum90 wrote: Sunday 26 April 2020 14:40 Hello, I’ve a problem since last weeks updates Borghi on Apple store app (I’ve bought pay version) and beta version.
The search button on top right doesn’t work, the search box does not appear.
Thanks for your work!![]()
