Page 23 of 32
Re: Domoboard - General Discussions
Posted: Wednesday 01 February 2017 9:07
by squandor
Awst6000 wrote:squandor wrote:Hi,
...if anyone has any idea's they are always welcome...
Unfortunately I'm not a coder. But I hope you guys take the time needed and work something out that works intuitive.
Yep this will be an big change for the system so this time where not rushing anything
Posted: Tuesday 07 February 2017 8:59
by possible
I just installed domoboard and it is working perfectly.
I do have 2 questions:
1. I have a RGBWW Milgiht led tube. This one is a switch, dimmer and RGBWW adjustable.
How can i add this in domoboard together? I only can add 1 section. Dimmer, switch or RGB and not all together?
2. How does the weatherunderground works on the dashboard? I have set the following settings:
[general_settings]
[[wunderground]]
api = xxxxxxxxxxxxxxxx
Dashboard:
[dashboard]
[[display_components]]
components = top_tiles, switches, domoticz_temp_charts, wunderground[condition], wunderground[forecast]
and the information:
[[wunderground]]
[[[forecast]]]
location = Amsterdam, NL
[[[condition]]]
It results in:
[2017-02-07 14:18:07,483] ERROR in app: Exception on /api [POST]
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1982, in wsgi_app
response = self.full_dispatch_request()
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1614, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1517, in handle_user_exception
reraise(exc_type, exc_value, tb)
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1612, in full_dispatch_request
rv = self.dispatch_request()
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1598, in dispatch_request
return self.view_functions[rule.endpoint](**req.view_args)
File "/usr/local/lib/python2.7/dist-packages/Flask_Auth-0.85-py2.7.egg/flaskext/auth/auth.py", line 186, in decorator
return func(*args, **kwargs)
File "/home/pi/domoboard/modules/api.py", line 43, in gateway
result = call(request.args)
File "/home/pi/domoboard/plugins/wunderground.py", line 59, in getData
_language = config['general_settings']['wunderground']['language']
KeyError: 'language'
Posted: Tuesday 07 February 2017 15:55
by squandor
possible wrote:Hi,
[general_settings]
[[wunderground]]
Dashboard:
[dashboard]
[[wunderground]]
[[[forecast]]]
[[[condition]]]
It results in:
Hi there,
It seems that you mist 1 argument in the general_settings config.
If you add the following argument under the [wunderground] section it should work:
Posted: Tuesday 07 February 2017 15:56
by squandor
Just created an feature to add autologon functionality to domoboard.
If you get the latest develop update you can add autologon to the domoboard section in general settings and add True or False like this:
[[domoboard]]
time = False # True/False: show time in top bar
date = False # True/False: show date in top bar
autologon = False # True/False: enable autologon
Posted: Tuesday 07 February 2017 17:57
by dutchdevil83
squandor wrote:Just created an feature to add autologon functionality to domoboard.
[[domoboard]]
Thank you for this!
Posted: Tuesday 07 February 2017 18:12
by possible
squandor wrote:possible wrote:Hi,
Hi there,
I think i already had it:
[general_settings]
[[server]]
url = 192.168.0.1:8080 # IP-address of Domoticz backend
flask_url = 192.168.0.1:8081 # Please note: this is the internal IP-address including port of the Domoboard server
user = username # Username for Domoticz (if required)
password = password # Password for Domoticz (if required)
secret_key = xxxxxxxxxxxxx # A random secret key used for Python authentication. Change to anything random.
[[wunderground]]
api_key = xxxxxxxxxxxxxxx
[[users]]
username = password # Add users for Domoboard here. In this case login with username "username" and password "password"
[[domoboard]]
language = "en" # Change this to display date/time in local language and format
google_maps_api_key = X # Google Maps Embed API key
This is the my config file. Is this oke? I stil have the same error
Posted: Tuesday 07 February 2017 18:14
by dutchdevil83
possible wrote:squandor wrote:possible wrote:Hi,
Hi there,
[general_settings]
[[server]]
[[wunderground]]
[[users]]
[[domoboard]]
You need to add the language in the Wunderground settings. The other setting is for local settings for the date/time bar at top of the page
Posted: Tuesday 07 February 2017 18:29
by possible
[general_settings]
[[server]]
[[wunderground]]
[[users]]
[[domoboard]]
Thanks.. I have it working now!
Do you have an answer for my led tubes?
Posted: Tuesday 07 February 2017 20:54
by GuyTreepbush
will give that a try this weekend
Posted: Friday 10 February 2017 7:14
by possible
Hi All,
I tried to install domoboard on a friend of my his Raspberry Pi. When i trie to load the example config, it fails with:
File "server.py", line 4, in <module>
from flaskext.auth import Auth, AuthUser, login_required, logout
ImportError: No module named auth
I installed it but i cannot get it started. Does anyone know what the problem might be?
Posted: Friday 10 February 2017 9:46
by squandor
Does he has Jessie-light installed?
It seems that there is an difference between the full and light version
Posted: Friday 10 February 2017 13:50
by possible
Yeah..
he installed the pixel (full) version.. I needed to upgrade the auth package.. Once this was done.. It is working fine now.
Posted: Friday 10 February 2017 22:18
by squandor
Great to hear
Posted: Sunday 12 February 2017 19:22
by 58djarviss
I 've installed in a few minutes Domoboard (very easy, thanks for that) and it's look very nice. Just have some issues with my Foscam IP Camera to get live streaming, anyway I'll check later.
I would like to ask for a feature which could be nice : auto rotation between the different menu of the navbar. I have an android tablet on the wall and use Imperihome. It's a great tool but the GUI is a bit old and my tablet is a bit old and have some difficulties to run imperihome.
But I like the "rotation" feature between pages in Imerihome. The same would be really appreciated in Domoboard.
Thanks for the job
Posted: Monday 13 February 2017 9:53
by possible
1 more question.
Is there a way to autostart the python server.py script without using the commandline?
When i want to reboot my system it would be nice if domoboard starts automatically.
Posted: Monday 13 February 2017 11:22
by squandor
possible wrote:1 more question.
it was mentioned before in this topic, i still need to automate this on my server to but there is an systemd example somewhere in this topic
Posted: Monday 13 February 2017 12:13
by possible
Aaah yeah I found it! Thanks! normally I use supervisor but systemd is also working fine
Posted: Thursday 16 February 2017 10:42
by ztorm
Hello!
I really love the domoboard! Been playing with it for a while now. Everything works fine, but there is one thing that I can't fix. I have three dimmers (two Hue lamps and a Fibaro dimmer 2). In domoticz they are shown as dimmers with a slider.
- Schermafbeelding 2017-02-16 om 10.27.45.png (105.65 KiB) Viewed 2328 times
When I add them to the domoboard the Hue lamps (IDX 16/17) do work, but the Fibaro dimmer (IDX 1) doesn't. I get an empty square. When I add the dimmer as switch it does work (only on/off, no dimming).
- Schermafbeelding 2017-02-16 om 10.27.31.png (8.53 KiB) Viewed 2328 times
I saw in the devices table of domoticz that the subtype of the Hue lamps is AC and light/switch for the Fibaro dimmer. I thought that that could be an issue. So I added a dummy switch and set the type to dimmer (IDX 29). Then I've added the dummy dimmer to domoboard and guess what: a slider
- Schermafbeelding 2017-02-16 om 10.28.15.png (48.96 KiB) Viewed 2328 times
Does anyone have an idea of how I can get the Fibaro dimmer in domoboard?
Posted: Friday 17 February 2017 17:36
by squandor
ztorm wrote:Hello!
Hi ztorm,
Hmm that's an unusual behaviour. did you get an error in you're console.log when domoboard tries to init an dimmer on zithoek?
It looks like it should work but if there are no errors its a little bit difficult to debug it
Posted: Saturday 18 February 2017 13:44
by GuyTreepbush
In internet explorer or chrome this seems to work. Unfortunatly on IOS it still asks for a password each time.
