homebridge-edomoticz Plugin
Marci
Domoticz version: 3.8153
Re: eDomoticz Homebridge-Plugin
Post by Marci »
TheRamon wrote:Heya,
I have just created a pull request on mqtt-integration.
This is basically the first proof of concept that MQTT integration works. I have messed about with a lot of files, hope you don't mind Marci.
Also split up the platform and accessory since they were in one file.
Merged! SUPERB job d00d - loving it. Have replied over on the github issue - https://github.com/PatchworkBoy/homebri ... -238362470 - have also just made a few changes - pulled out the custom services & characteristics etc as some were getting missed. Figured may as well as they were the only bits left not to abstract out into their own lib...!
On an aside - are you seeing many SIGPIPE kills of homebridge after doing all this? Mefinx it’s not handling MQTT dropping occasionally and reconnecting. Nothing you’ve done - mine started doing this on the odd occasion as soon as I added mqtt.js and started consuming domoticz/out
chrispazz
Post by chrispazz »
I have added an X10 Motion Sensor and I set type as Motion sensors.
In domoticz it appears as "Lighting 1, X10, Motion sensor".
In homebridge I can't see it as motion sensor, I see it as normal switch.
Where am I wrong?
Ty
Marci
Post by Marci »
See first post, q & a's... need JSON output for the device to be able to investigate. And... is homebridge-eDomoticz fully up to date?
If json output lists swType as 8, then i'd suggest you need to update the plugin.
chrispazz
Post by chrispazz »
This?
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 60.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 3,
"HardwareName" : "X10",
"HardwareType" : "Mochad CM15Pro/CM19A bridge with LAN interface",
"HardwareTypeVal" : 37,
"HaveDimmer" : false,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "65",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2016-08-08 22:43:30",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 0,
"Name" : "Sensore Movimento",
"Notifications" : "false",
"PlanID" : "2",
"PlanIDs" : [ 2, 3, 4 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : 0,
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "X10",
"SwitchType" : "Motion Sensor",
"SwitchTypeVal" : 8,
"Timers" : "false",
"Type" : "Lighting 1",
"TypeImg" : "motion",
"Unit" : 5,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "3"
Marci
Post by Marci »
Yep, switchtypeval is 8, so update plugin to latest and restart homebridge then try again.
chrispazz
Post by chrispazz »
Ok...I have to understand how to update.....I will try now
chrispazz
Post by chrispazz »
I issued npm update and the current homebridge running is 0.3.4
Is it latest version?
Ty
Marci
Post by Marci »
Yep, but it's the plugin you need to update, not homebridge itself.
chrispazz
Post by chrispazz »
Yes I just discovered... :)
I just updated but the problem is still there so I am not sure if I updated correctly.
Is there a way to check if I am running latest version?
Thanks Marci
Marci
Post by Marci »
Find the plugin directory, version is on top line of index.js, or in package.json, or in changelog.
Did you npm update, or sudo npm update -g? And did you restart homebridge after updating the plugin (and waited a minute or two for it to load and redetect accessories).
chrispazz
Post by chrispazz »
sudo npm update -g homebridge-edomoticz
Is there a way to debug what is it doing?
From the main log I see that it start correctly and works but I cannot understand why it is not getting the motion sensor correctly
I am almost sure that it is updated to last version....
Marci
Post by Marci »
Only thing left is to...
sudo rm -rf ~/.homebridge/persist/*
...then restart homebridge & re-pair your bridge within your HomeKit app.
Marci
Post by Marci »
Use...
sudo npm ls -g homebridge-edomoticz
...to get version of globally installed modules.
chrispazz
Post by chrispazz »
/usr/local/lib
└── [email protected]
Marci
Post by Marci »
Yup, that's latest.
chrispazz
Post by chrispazz »
Also deleting accessory files and repairing is doing the same result...
Could it be the new version still not working good?
Ty
TheRamon
Post by TheRamon »
Thanks Marci! Not seeing any SIGPIPEs, on the other side I don't have much devices either.. AND I'm running on Mac for testing. Did not try on my RPI yet. Did you try another broker? I'm using mosquitto myself.
Marci
Post by Marci »
Nah, just Mosquitto - trying to stick to the tools preinstalled with the Domoticz SD image to keep things as simple as possible.
chrispazz wrote:Also deleting accessory files and repairing is doing the same result...
Nope. Current version is stable.
Do the following:
cd /
sudo find ./ -name homebridge-edomoticz
...and copy/paste the output.
TheRamon
Post by TheRamon »
Righto, understood. Have just created another pull request. Blinds, smoke sensors and dimmers are now supported through MQTT aswell.
Marci
Post by Marci »
Merged! 8-)
