Page 22 of 30
Re: dtgbot - Domoticz TeleGram BOT
Posted: Saturday 02 January 2021 13:04
by Mrblomme
jvdz wrote: Saturday 02 January 2021 11:30
Did you also check the contents of dtg.log.errors as I expect the lua script has errors?
Hmm it seems like there are a few errors...
/usr/bin/lua5.2: error loading module 'ssl.core' from file '/usr/local/lib/lua/5.2/ssl.so':
libssl.so.1.0.0: cannot open shared object file: No such file or directory
stack traceback:
[C]: in ?
[C]: in function 'require'
/usr/local/share/lua/5.2/ssl.lua:7: in main chunk
/usr/local/share/lua/5.2/ssl/https.lua:10: in main chunk
/home/pi/dtgbot/dtgbot.lua:132: in main chunk
[C]: in ?
stack traceback:
[C]: in ?
[C]: in ?
stack traceback:
[C]: in ?
[C]: in ?
stack traceback:
[C]: in ?
[C]: in ?
Posted: Saturday 02 January 2021 13:11
by jvdz
Ah ok ...you haven't installed lua-socket, so try installing that with:
sudo apt install lua-socket
Jos
Posted: Saturday 02 January 2021 13:32
by Mrblomme
updated lua
pi@Domoticz:~ $ sudo apt install lua-socket
Reading package lists... Done
Building dependency tree
Reading state information... Done
lua-socket is already the newest version (3.0~rc1+git+ac3201d-4).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
stack traceback:
[C]: in ?
[C]: in ?
stack traceback:
[C]: in ?
[C]: in ?
stack traceback:
[C]: in ?
[C]: in ?
stack traceback:
[C]: in ?
[C]: in ?
Posted: Saturday 02 January 2021 13:34
by jvdz
I guess you also installed the "old" version as defined in the Wiki to "/usr/local/lib/lua/5.2/"?
Could you remove that version as it seems to use that.
Posted: Saturday 02 January 2021 13:43
by Mrblomme
jvdz wrote: Saturday 02 January 2021 13:34
Cant seem to remove it (using sudo rm) but is denied...
This is harder than I thought.....
Posted: Saturday 02 January 2021 18:14
by Mrblomme
Mrblomme wrote: Saturday 02 January 2021 13:43
I've removed the folder and installed it back but same errors..
Posted: Saturday 02 January 2021 18:25
by jvdz
Your shouldn't be getting this error anymore:
from file '/usr/local/lib/lua/5.2/ssl.so'. ?
Posted: Sunday 03 January 2021 10:47
by Mrblomme
jvdz wrote: Saturday 02 January 2021 18:25
Still getting the next errors.
When I go to /usr/local/lib/lua/5.2/ the file ssl.so is there and in the map socket there's the file ssl.core.
stack traceback:
[C]: in ?
[C]: in ?
stack traceback:
[C]: in ?
[C]: in ?
Posted: Sunday 03 January 2021 11:01
by jvdz
I thought you had removed these files you installed manually: '/usr/local/lib/lua/5.2/ssl.so' ?
It seems they are still there?
There have been several others that reported this issue in the past and they have been able to solve it, have a look to see if that helps you:
search.php?keywords=libssl.so.1.0.0&t=7279&sf=msgonly
Posted: Sunday 03 January 2021 11:11
by Mrblomme
jvdz wrote: Sunday 03 January 2021 11:01
My bad.. thought the file was corrupted so removed it and installed a fresh copy..
Should I also delete the ssl.core?
/usr/bin/lua5.2: /usr/local/share/lua/5.2/ssl.lua:7: module 'ssl.core' not found:
no field package.preload['ssl.core']
no file '/usr/local/share/lua/5.2/ssl/core.lua'
no file '/usr/local/share/lua/5.2/ssl/core/init.lua'
no file '/usr/local/lib/lua/5.2/ssl/core.lua'
no file '/usr/local/lib/lua/5.2/ssl/core/init.lua'
no file '/usr/share/lua/5.2/ssl/core.lua'
no file '/usr/share/lua/5.2/ssl/core/init.lua'
no file './ssl/core.lua'
no file '/usr/local/lib/lua/5.2/ssl/core.so'
no file '/usr/lib/arm-linux-gnueabihf/lua/5.2/ssl/core.so'
no file '/usr/lib/lua/5.2/ssl/core.so'
no file '/usr/local/lib/lua/5.2/loadall.so'
no file './ssl/core.so'
no file '/usr/local/lib/lua/5.2/ssl.so'
no file '/usr/lib/arm-linux-gnueabihf/lua/5.2/ssl.so'
no file '/usr/lib/lua/5.2/ssl.so'
no file './ssl.so'
stack traceback:
[C]: in ?
Posted: Sunday 03 January 2021 18:28
by Mrblomme
Got rid of all LUA folders and now it's working perfectly!
Thanks for the help and patience Jos!
Posted: Tuesday 25 May 2021 18:39
by usky73
Dear all
I am trying to control domoticz by using Telegram.
I am using already the telegram API for notification.
I have followed the wiki page instrictions :
https://www.domoticz.com/wiki/Remote_Co ... legram_Bot
But I am facing an issue.
The dtb.log.error files is showing an issue with ssl.core library.
pi@domo:/var/tmp $ cat dtb.log.errors
I found on this long thread a person that solved the issue by removing the lua folder in /usr/local/lib & /usr/local/shared & installed the LUA lib
I have tested that but I have the same message remaining...
Please help !
Posted: Tuesday 27 July 2021 16:41
by Welsyntoffie
I think this a dtgbot problem.
When I send the command "systemstatus" I get the responses I im looking for, but then I get another reply that I do not want to see.
How do I stop Recieved Message 3...
Send Command...
Pieter, [27.07.21 15:49]
systemstatus
Recieved Message 1
Arduino_Home, [27.07.21 15:49]
Please wait, gathering data...
Recieved Message 2
-CPU temperature: 36.9°C
-CPU Usage: 9.09 %
-Memory Usage: 39.03 %
-UpTime: 15.24 h
-Domoticz update available! (version 13191)
Recieved Message 3 (Don't want this)
[In reply to Pieter]
t_name":"Pieter","type":"private"},"date":1627393779,"text":"-CPU temperature: 36.9\u00b0C\n-CPU Usage: 9.09 %\n-Memory Usage: 39.03 %\n-UpTime: 15.24 h\n-Domoticz update available! (version 13191)"}}
Posted: Tuesday 27 July 2021 16:54
by Welsyntoffie
usky73 wrote: Tuesday 25 May 2021 18:39
Dear all
Please help !
Check this post
viewtopic.php?p=208229#p208229
This worked for me 100%
Posted: Tuesday 27 July 2021 19:13
by jvdz
Welsyntoffie wrote: Tuesday 27 July 2021 16:41
Have you made changes to the bash file systemstatus.sh in directory dtgbot/bash ?
You can also check the file
SystemStatus.txt in the defined $TempFileDir in the setup file to see what the text was at the time the Telegram was send.
Posted: Tuesday 27 July 2021 20:38
by Welsyntoffie
jvdz wrote: Tuesday 27 July 2021 19:13
I only changed the rid in systemstatus.sh.
Even before I changed the id's I received the 3rd message, for that reason I thought is was because it could not find the id's
temperature.sh is Unmodified and also gives me a 3rd unwanted message
The text file is normal, there is nothing else inside the text file...
-CPU temperature: 37°C
-CPU Usage: 8.06 %
-Memory Usage: 35.06 %
-UpTime: 19.67 h
Posted: Tuesday 27 July 2021 20:43
by Welsyntoffie
I am having difficulty getting an image on here so made a post on reddit...
https://www.reddit.com/r/Domoticz/comme ... _telegram/
Posted: Tuesday 27 July 2021 20:49
by jvdz
Well it looks like a part of the response from the CURL command if send in a reply, but don't understand why that would happen.
As you can see in the BASH file: It sends the content of the text file with a curl command to your TelegramID.
Posted: Tuesday 27 July 2021 21:20
by Welsyntoffie
jvdz wrote: Tuesday 27 July 2021 20:49
Yes, both the first responses is as what I would expect.
If you look at this manual/info
https://www.domoticz.com/wiki/Telegram_ ... ctionality then that person never receives his responses as a reply but rather as a new message. I followed all the instruction from the wiki except for installing the CLI part of telegram.
I was thinking that their might be some debug switch that is On that also sends the raw string to see the full CURL but can not find anything ragarding that.
Posted: Tuesday 27 July 2021 21:38
by Welsyntoffie
So I removed the last line (72) in the BASH file that sends the message. As expected I do not get any message except for the one saying gathering data...
Removing that line aswell (11) then I get a message Reply done. and nothing alse. Only 1 message
Adding line 72 back then I get the extra garbage message after the correct message.
