dtgbot - Domoticz TeleGram BOT
Mrblomme
Re: dtgbot - Domoticz TeleGram BOT
Post by Mrblomme »
jvdz wrote: Saturday 02 January 2021 11:30 Did you also check the contents of dtg.log.errors as I expect the lua script has errors?
Hmm it seems like there are a few errors...
/usr/bin/lua5.2: error loading module 'ssl.core' from file '/usr/local/lib/lua/5.2/ssl.so':
libssl.so.1.0.0: cannot open shared object file: No such file or directory
stack traceback:
[C]: in ?
[C]: in function 'require'
/usr/local/share/lua/5.2/ssl.lua:7: in main chunk
/usr/local/share/lua/5.2/ssl/https.lua:10: in main chunk
/home/pi/dtgbot/dtgbot.lua:132: in main chunk
[C]: in ?
stack traceback:
[C]: in ?
[C]: in ?
stack traceback:
[C]: in ?
[C]: in ?
stack traceback:
[C]: in ?
[C]: in ?
jvdz
Domoticz version: 4.107
Post by jvdz »
Ah ok ...you haven't installed lua-socket, so try installing that with:
sudo apt install lua-socket
Jos
Mrblomme
Post by Mrblomme »
updated lua
pi@Domoticz:~ $ sudo apt install lua-socket
Reading package lists... Done
Building dependency tree
Reading state information... Done
lua-socket is already the newest version (3.0~rc1+git+ac3201d-4).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
stack traceback:
        [C]: in ?
        [C]: in ?
stack traceback:
        [C]: in ?
        [C]: in ?
stack traceback:
        [C]: in ?
        [C]: in ?
stack traceback:
        [C]: in ?
        [C]: in ?
jvdz
Post by jvdz »
I guess you also installed the "old" version as defined in the Wiki to "/usr/local/lib/lua/5.2/"?
Could you remove that version as it seems to use that.
Mrblomme
Post by Mrblomme »
jvdz wrote: Saturday 02 January 2021 13:34 I guess you also installed the "old" version as defined in the Wiki to "/usr/local/lib/lua/5.2/"?
Cant seem to remove it (using sudo rm) but is denied...
This is harder than I thought.....
Mrblomme
Post by Mrblomme »
Mrblomme wrote: Saturday 02 January 2021 13:43
I've removed the folder and installed it back but same errors..
jvdz
Post by jvdz »
Your shouldn't be getting this error anymore:
from file '/usr/local/lib/lua/5.2/ssl.so'. ?
Mrblomme
Post by Mrblomme »
jvdz wrote: Saturday 02 January 2021 18:25 Your shouldn't be getting this error anymore:
Still getting the next errors.
When I go to /usr/local/lib/lua/5.2/ the file ssl.so is there and in the map socket there's the file ssl.core.
stack traceback:
[C]: in ?
[C]: in ?
stack traceback:
[C]: in ?
[C]: in ?
jvdz
Post by jvdz »
I thought you had removed these files you installed manually: '/usr/local/lib/lua/5.2/ssl.so' ?
It seems they are still there?
There have been several others that reported this issue in the past and they have been able to solve it, have a look to see if that helps you:
search.php?keywords=libssl.so.1.0.0&t=7279&sf=msgonly
Mrblomme
Post by Mrblomme »
jvdz wrote: Sunday 03 January 2021 11:01 I thought you had removed these files you installed manually: '/usr/local/lib/lua/5.2/ssl.so' ?
My bad.. thought the file was corrupted so removed it and installed a fresh copy.. :roll:
Should I also delete the ssl.core?
/usr/bin/lua5.2: /usr/local/share/lua/5.2/ssl.lua:7: module 'ssl.core' not found:
no field package.preload['ssl.core']
no file '/usr/local/share/lua/5.2/ssl/core.lua'
no file '/usr/local/share/lua/5.2/ssl/core/init.lua'
no file '/usr/local/lib/lua/5.2/ssl/core.lua'
no file '/usr/local/lib/lua/5.2/ssl/core/init.lua'
no file '/usr/share/lua/5.2/ssl/core.lua'
no file '/usr/share/lua/5.2/ssl/core/init.lua'
no file './ssl/core.lua'
no file '/usr/local/lib/lua/5.2/ssl/core.so'
no file '/usr/lib/arm-linux-gnueabihf/lua/5.2/ssl/core.so'
no file '/usr/lib/lua/5.2/ssl/core.so'
no file '/usr/local/lib/lua/5.2/loadall.so'
no file './ssl/core.so'
no file '/usr/local/lib/lua/5.2/ssl.so'
no file '/usr/lib/arm-linux-gnueabihf/lua/5.2/ssl.so'
no file '/usr/lib/lua/5.2/ssl.so'
no file './ssl.so'
stack traceback:
[C]: in ?
Mrblomme
Post by Mrblomme »
Got rid of all LUA folders and now it's working perfectly!
Thanks for the help and patience Jos!
usky73
Domoticz version: 2021.1
Post by usky73 »
Dear all
I am trying to control domoticz by using Telegram.
I am using already the telegram API for notification.
I have followed the wiki page instrictions : https://www.domoticz.com/wiki/Remote_Co ... legram_Bot
But I am facing an issue.
The dtb.log.error files is showing an issue with ssl.core library.
pi@domo:/var/tmp $ cat dtb.log.errors
I found on this long thread a person that solved the issue by removing the lua folder in /usr/local/lib & /usr/local/shared & installed the LUA lib
I have tested that but I have the same message remaining...
Please help !
Welsyntoffie
Post by Welsyntoffie »
I think this a dtgbot problem.
When I send the command "systemstatus" I get the responses I im looking for, but then I get another reply that I do not want to see.
How do I stop Recieved Message 3...
Send Command...
Pieter, [27.07.21 15:49]
systemstatus
Recieved Message 1
Arduino_Home, [27.07.21 15:49]
Please wait, gathering data...
Recieved Message 2
-CPU temperature: 36.9°C
-CPU Usage: 9.09 %
-Memory Usage: 39.03 %
-UpTime: 15.24 h
-Domoticz update available! (version 13191)
Recieved Message 3 (Don't want this)
[In reply to Pieter]
t_name":"Pieter","type":"private"},"date":1627393779,"text":"-CPU temperature: 36.9\u00b0C\n-CPU Usage: 9.09 %\n-Memory Usage: 39.03 %\n-UpTime: 15.24 h\n-Domoticz update available! (version 13191)"}}
Welsyntoffie
usky73 wrote: Tuesday 25 May 2021 18:39 Dear all
Please help !
Check this post viewtopic.php?p=208229#p208229
This worked for me 100%
jvdz
Post by jvdz »
Welsyntoffie wrote: Tuesday 27 July 2021 16:41 I think this a dtgbot problem.
Have you made changes to the bash file systemstatus.sh in directory dtgbot/bash ?
You can also check the file SystemStatus.txt in the defined $TempFileDir in the setup file to see what the text was at the time the Telegram was send.
Welsyntoffie
jvdz wrote: Tuesday 27 July 2021 19:13 Have you made changes to the bash file systemstatus.sh in directory dtgbot/bash ?
I only changed the rid in systemstatus.sh.
Even before I changed the id's I received the 3rd message, for that reason I thought is was because it could not find the id's
temperature.sh is Unmodified and also gives me a 3rd unwanted message
The text file is normal, there is nothing else inside the text file...
-CPU temperature: 37°C
-CPU Usage: 8.06 %
-Memory Usage: 35.06 %
-UpTime: 19.67 h
Welsyntoffie
I am having difficulty getting an image on here so made a post on reddit...
https://www.reddit.com/r/Domoticz/comme ... _telegram/
jvdz
Post by jvdz »
Well it looks like a part of the response from the CURL command if send in a reply, but don't understand why that would happen.
As you can see in the BASH file: It sends the content of the text file with a curl command to your TelegramID.
Welsyntoffie
jvdz wrote: Tuesday 27 July 2021 20:49 Well it looks like a part of the response from the CURL command if send in a reply, but don't understand why that would happen.
Yes, both the first responses is as what I would expect.
If you look at this manual/info https://www.domoticz.com/wiki/Telegram_ ... ctionality then that person never receives his responses as a reply but rather as a new message. I followed all the instruction from the wiki except for installing the CLI part of telegram.
I was thinking that their might be some debug switch that is On that also sends the raw string to see the full CURL but can not find anything ragarding that.
Welsyntoffie
So I removed the last line (72) in the BASH file that sends the message. As expected I do not get any message except for the one saying gathering data...
Removing that line aswell (11) then I get a message Reply done. and nothing alse. Only 1 message
Adding line 72 back then I get the extra garbage message after the correct message.
