[MyDomoAtHome] Support thread
epierre
Re: [MyDomoAtHome] Support thread
Post by epierre »
@doler the nodejs is restarted with children's holidays free time for me ;-)
This is on another thread: viewtopic.php?f=21&t=8951&p=76176#p76176
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
Evelen
Domoticz version: 2.4538
Post by Evelen »
Just installed MyDomoAtHome, but can't start it?
help
epierre
Post by epierre »
@Eleven what gives:
sudo /etc/init.d/MyDomoAtHome.sh status
also do you see a running starman process ?
also try (as mentioned above):
Try to find and kill ALL mdah fork processes, by using following cmd ex.
sudo kill -9 `ps -ef |grep tarman |awk '{print $2}'`
then remove pid file:
sudo rm /var/run/MyDomoAtHome.pid
Evelen
Post by Evelen »
epierre wrote:@Eleven what gives:
*reboot*
(I'm not that great with linux)
epierre
Post by epierre »
@Doler I've tested on my PI B running Wheezy the script is fine on start/stop from my last commit on github, waiting from your infos on that.
epierre
Post by epierre »
@Evelen there is a quote and a backquote that is why you had terminating issues:
what gives you:
ps -ef |grep tarman
if no starman is running, try starting start2.sh to see if installation is successful or not
Evelen
Post by Evelen »
epierre wrote:@Evelen there is a quote and a backquote that is why you had terminating issues:
what gives you:
ps -ef |grep tarman
This is what I got
epierre
Post by epierre »
@Evelen, do you have a MyDomoAtHome in the domoticz directory ? start2.sh is in this directory
Evelen
Post by Evelen »
epierre wrote:@Evelen, do you have a MyDomoAtHome in the domoticz directory ? start2.sh is in this directory
yes it is.
used the wiki install guide.
PS: I run this on a virtual VMware ESXi server, and I have a backup for before i installed MyDomoAtHome
let me know whether you think I should try from the start again. (and how)
epierre
Post by epierre »
@Evelen well... how to say... this is weird.
normally a "git pull" should bring back some files but maybe the issue is elsewhere
try this, then try run-once.sh and then start2.sh again to see if this fixes this error which is fatal (you're the first to have it congratulations ;-)
Evelen
Post by Evelen »
heh :P
did not work
This is btw my config changes:
MyDomoAtHome.sh:
APP_DIR="/home/flemmingss/domoticz/"
config.yml:
domo_path: "http://localhost:8080"
epierre
Post by epierre »
@Evelen much better yet for missing files have been added.
edit start2.sh to match your /home/flemmingss/ and start it again
Doler
Post by Doler »
epierre wrote:@Doler I've tested on my PI B running Wheezy the script is fine on start/stop from my last commit on github, waiting from your infos on that.
Sorry, I've been occupied by some urgent family business. Gave it a short try on both my working version after git pull and a version after an update. I couldn't get it to work on both. If time permits I'll try a clean, new install tomorrow (still on Wheezie).
Mark: Domoticz Beta on Raspberry Pi 4 running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - MySensors - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (plugin) - Zwave-js-ui - dzVents - Nodered
Evelen
Post by Evelen »
epierre wrote:@Evelen much better yet for missing files have been added.
got this now
epierre
Post by epierre »
@Evelen ok we advance, can you run ./update-mdah.sh there a missing lib
Doler
Post by Doler »
Sorry, I've been occupied by some urgent family business. Gave it a short try on both my working version after git pull and a version after an update. I couldn't get it to work on both. If time permits I'll try a clean, new install tomorrow (still on Wheezy).
Ok, did a clean install (on Wheezy) following the wiki and everything is fine. Next is install on Jessie once I got that up and running, will be continued...
Thanks for the help so far, Mark
Evelen
Post by Evelen »
epierre wrote:@Evelen ok we advance, can you run ./update-mdah.sh there a missing lib
Hi.
Results:
Doler
Post by Doler »
Installing on Jessie gives a problem. Output of run-once.sh (second time install so most is up-to-date):
pi@raspberrypi:~/domoticz/MyDomoAtHome $ sh ./run-once.sh
Will update packages list first...
Now getting the needed software...
Now getting getting and installing dependencies...
Reading package lists... Done
Building dependency tree
Reading state information... Done
libdancer-perl is already the newest version.
libdancer2-perl is already the newest version.
libfile-slurp-perl is already the newest version.
liblwp-protocol-psgi-perl is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Note, selecting 'perl' instead of 'libtime-piece-perl'
libcrypt-ssleay-perl is already the newest version.
libdatetime-format-strptime-perl is already the newest version.
libdatetime-perl is already the newest version.
libjson-perl is already the newest version.
libplack-perl is already the newest version.
starman is already the newest version.
libdbd-sqlite3-perl is already the newest version.
libdbi-perl is already the newest version.
sqlite3 is already the newest version.
libaudio-mpd-perl is already the newest version.
libnet-upnp-perl is already the newest version.
libpoe-component-client-mpd-perl is already the newest version.
sudo: cpanm: command not found
Now installing the service
The installation stops with 'cpanm: command not found' which imho means that the plackserver cannot be installed. Any suggestion how to solve this?
Thanks, Mark
epierre
Post by epierre »
looks we had this issue on another VM try... no clue why...
Doler
Post by Doler »
epierre wrote:looks we had this issue on another VM try... no clue why...
Hmm...
If I do "dpkg -l | grep cpan" I get " libcpan-meta-perl (Perl module to access CPAN distributions meta data)" as a result. So there is something available? Could it be that the path is not correct? "echo $PATH" gives "/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games", maybe there is something missing?
Thanks, Mark
