Page 22 of 25
Re: Easiest way to migrate Openzwave to ZWave-JS-UI
Posted: Sunday 21 January 2024 7:51
by gizmocuz
tiga wrote: Saturday 20 January 2024 20:23 just did a fresh install on a fresh pi and:
pi@raspberrypi:~ $ ls /dev/serial/by-id
ls: cannot access '/dev/serial/by-id': No such file or directory
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=debian
what am i doing wrong?
Maybe this will work? Still it's strange.
https://ubuntu-mate.community/t/ls-cann ... tory/26867
When you unplug the USB device, then plug it back and issue
dmesg
do you see it being added? Or is there a error?
Posted: Thursday 25 January 2024 20:59
by rfvdboom
I guess that a bookworm issue. See this page
https://www.thushanfernando.com/posts/2 ... ial-by-id/
Posted: Thursday 08 February 2024 16:23
by tiga
Lol...this gets more complicated by the minute.
Posted: Friday 09 February 2024 19:16
by MJHDiepman
I also got the "ls: cannot access '/dev/serial/by-id': No such file or directory" error and managed to resolve it.
To be honest I found it quite tricky. My old setup was Domoticz with OpenZwave , running happily on
- an ancient Raspberry Pi 2011.12 Model B v1.0
- an Aeotec Zwave stick 5
Since the latest version of Domoticz no longer supports this old Raspberry Pi hardware I decided to upgrade to a Raspberry Pi 4 and move to ZWave-JS-UI. I followed the installation instructions and with a bit of tinkering and a powered USB hub (as mentioned here https://www.domoticz.com/forum/viewtopic.php?t=29013) I got MQTT and ZwaveJS-UI to work, but never got any devices in Domoticz.
Turns out the Aeotec Zwave stick 5 is not compatible with the Raspberry Pi 4. It draws too much power when you plug it in and the Raspberry Pi rejects & disables it: https://github.com/raspberrypi/linux/issues/3027.
Older Raspberry Pi models are more forgiving. I switched to an older Raspberry Pi 3 Model B and everything works like a charm
Posted: Friday 09 February 2024 19:42
by Quax1507
I jave a similar setup with RPi 4 and Z-Stick 5.
You have to use an USB hub between RPi and Stick.
I use this one https://www.amazon.de/dp/B00L2442H0?ref ... b_ap_share
Posted: Friday 16 February 2024 19:51
by tiga
ok....still one big mess with the migrate.
can you guys give me an advise on what OS i must install that will give me the most chance of succes??
looks like a good foundation will help a lot
(i use a pi 4)
thanks!
Posted: Saturday 17 February 2024 11:42
If you work with docker containers you can can use a recent OS version. Please invest time to understand the concept of Docker containers.
Posted: Saturday 09 March 2024 20:47
by tiga
ok...finaly got the whole migrating-thing figured out.
using a spare pi 4 and a spare new aeotec zwave stick 5.connected some spare switches and everything works fine...
but then i plug in my other aeotec stick 5(this is the one i need to migrate, and couple of years old) with all my 60 or so devices, all went wrong...
the stick went blinking super fast in yellow or stoped blinking at all....
ls /dev/serial/by-id gives no device anymore.
what can be the reason?
stick works perfect on my old pi 2
Posted: Saturday 09 March 2024 20:51
Old zwavel Stick 5 has issues on an RPi4. Use a 2.0 USB hub to fix it.
Posted: Saturday 09 March 2024 20:53
by tiga
i have a usb 2.0 hub connected,like i said all works fine with my newer stick 5
Posted: Saturday 09 March 2024 22:13
by elzorrovega
I been there fighting with Aotec Gen 5+, RPi4b & Bullseye.
Have you verified this post.
https://www.domoticz.com/forum/viewtopic.php?t=40536
Regards,
ElZorrovega
Posted: Saturday 09 March 2024 22:21
by tiga
yes i have replaced the contend....thanks for the tip
but that is not th issue...i have a working setup but when i replace the stick with the other older one things get strange and not working anymore.fast blinking or no power to stick(not blinking at all)
Posted: Sunday 10 March 2024 5:59
by elzorrovega
Silly question!
Does your usb hub have own power supply?
I also have a more recent Aeotec Gen5+ which is recognised by RPi4 but when I tried the old one, no sign of life.
There is a post in RPi forum where basically their gurus tell you that Aeotec does not meet USB specifications …..
My current setup has self powered usb hub.
Posted: Sunday 10 March 2024 11:51
by tiga
No.the hub has no own power supply.
Posted: Sunday 10 March 2024 19:57
by elzorrovega
This is my current setup.
RPi4b
Domoticz Z-Wave Controller is Z-Stick Gen5+ Chip Type ZW0501 Ver 4.54.
Even with new Power Supply - iUniker with output 5,1V 4A 20,4W - controller is not seen when connected directly to RPi4b USB 2.0 ports.
Connected controller to an D-Link USB 2.0 Hub with own power supply and everyone seems to be happy.
Posted: Friday 05 April 2024 18:44
by tiga
Took the effort to migratie all my devices from the old stick to the new one.everything works ok now.this new setup is super stable
Posted: Saturday 06 April 2024 13:08
by elzorrovega
Hello Tiga. Good to hear that new dongle works!
I recently bought a new Aeotec stick and I used EOM tool to transfer settings from old to new. I did not have the time to try the new stick which appears to be visible on RPi4.
Curiosity, what kind of Z-Wave stick do you use and are you now connected directly to USB 2 on the RPi4?
Posted: Saturday 27 April 2024 16:56
by cr1cr1
I've been using Domoticz since 2016 - running on a RPi4.
I was trying to keep OpenZWave in my Domoticz config, 50 hardware devices and I don't feel like wanting to migrate manually to Zwave-JS.
What are the latest best practices?
In the latest 2024.4 update I've lost a lot of zwave features: not sure why but all my scenes with Zwave Fibaro roller devices do not work anymore.
I'm really asking myself if I should move to another plaform such as Home Assistant as I've lost a lot in the past (Android App with its subscription model, zwave...)
Also an alternative could be to resintall all in a container on my Synology server.
What migration path have you taken?
PS: why something that worked so fine became a hell of complexity?
Posted: Saturday 27 April 2024 18:39
by akamming
cr1cr1 wrote: Saturday 27 April 2024 16:56 Hi,
Moving to ha Will not solve your issue. Home assistant has the same issue. Openzwave is no longer supported. So if you want to move to ha you also have to migratie to zwave-js-ui
Posted: Friday 31 May 2024 11:10
by brugje
Hallo,
I have up and running on windows the .exe file version zwave-js-ui-v9.12.0-win. Now there is an update to version zwave-js-ui-v9.13.1-win. What is needed to update. Only replace the .exe file with the new one?
Jan
