Page 22 of 28
Re: Python Plugin : Broadlink
Posted: Monday 07 February 2022 11:56
by kollemt
192.168.178.*
Posted: Monday 07 February 2022 12:02
by zak45
ok, you need also 127.0.0.*
Posted: Monday 07 February 2022 12:16
by kollemt
Added and rebooted
Same problem Failed to load plugin.py
Posted: Monday 07 February 2022 12:32
by zak45
ok, normal, but now the installation sould be ok and you should be able to see log file, hope no more error HTTP 401.
please confirm.
After, another test you can do:
disable hardware IDX 16 (woonkamer)
add another 'Broadlink with Kodi remote' hardware ( non existing IP address and non used Listener Port )
add another 'Broadlink with Kodi remote' hardware ( with same data as woonkamer )
lets see what happend ....
Posted: Monday 07 February 2022 12:34
by zak45
Hummm... just a warning... if you do that on your production system, hope you have a backup... we don't know what could happened !!!!
Posted: Monday 07 February 2022 12:45
by zak45
and if still ptoblem, maybe check the 'rights' on your Broadlink folder.
My advice will be to put 777 ( in recursive way ).
Posted: Monday 07 February 2022 14:10
by zak45
ok, after some reboot and deep testing, have been able to see this error on my windows system:
2022-02-07 13:45:28.560 Error: rm2: (Broadlink) failed to load 'plugin.py', Python Path used was 'C:\Program Files (x86)\Domoticz\plugins\Broadlink\;C:\Program Files (x86)\Python37-32\python37.zip;C:\Program Files (x86)\Python37-32\Lib\;C:\Program Files (x86)\Python37-32\DLLs\;C:\Program Files (x86)\Domoticz;C:\Program Files (x86)\Python37-32;C:\Program Files (x86)\Python37-32\lib\site-packages'.
2022-02-07 13:45:28.560 Error: rm2: Module Import failed, exception: 'InternalError'
2022-02-07 13:45:28.560 Error: rm2: Error Line details not available.
2022-02-07 13:45:28.560 Error: rm2: Exception traceback:
2022-02-07 13:45:28.560 Error: rm2: ----> Line 168 in 'C:\Program Files (x86)\Domoticz\plugins\Broadlink\plugin.py'
2022-02-07 13:45:28.560 Error: rm2: ----> Line 622 in 'C:\Program Files (x86)\Python37-32\lib\site-packages\broadlink\__init__.py'
2022-02-07 13:45:28.561 Error: rm2: ----> Line 229 in 'C:\Program Files (x86)\Python37-32\lib\site-packages\broadlink\__init__.py'
2022-02-07 13:45:28.561 Error: rm2: ----> Line 233 in 'C:\Program Files (x86)\Python37-32\lib\site-packages\broadlink\__init__.py'
2022-02-07 13:45:28.561 Error: rm2: ----> Line 15 in 'C:\Program Files (x86)\Python37-32\lib\site-packages\cryptography\hazmat\backends\__init__.py'
2022-02-07 13:45:28.561 Error: rm2: ----> Line 7 in 'C:\Program Files (x86)\Python37-32\lib\site-packages\cryptography\hazmat\backends\openssl\__init__.py'
2022-02-07 13:45:28.561 Error: rm2: ----> Line 75 in 'C:\Program Files (x86)\Python37-32\lib\site-packages\cryptography\hazmat\backends\openssl\backend.py'
2022-02-07 13:45:28.561 Error: rm2: ----> Line 203 in 'C:\Program Files (x86)\Python37-32\lib\site-packages\cryptography\hazmat\bindings\openssl\binding.py'
2022-02-07 13:45:28.561 Error: rm2: ----> Line 152 in 'C:\Program Files (x86)\Python37-32\lib\site-packages\cryptography\hazmat\bindings\openssl\binding.py'
2022-02-07 13:45:28.561 Error: rm2: ----> Line 135 in 'C:\Program Files (x86)\Python37-32\lib\site-packages\cryptography\hazmat\bindings\openssl\binding.py'
2022-02-07 13:45:28.561 Error: rm2: ----> Line 121 in 'C:\Program Files (x86)\Python37-32\lib\site-packages\cryptography\hazmat\bindings\openssl\binding.py'
2022-02-07 13:45:28.561 Error: rm2: ----> Line 79 in 'C:\Program Files (x86)\Python37-32\lib\site-packages\cryptography\hazmat\bindings\openssl\binding.py'
2022-02-07 13:45:39.715 Error: rm3: Traceback (most recent call last):
2022-02-07 13:45:39.715 File "C:\Program Files (x86)\Python37-32\lib\site-packages\broadlink\__init__.py", line 369, in send_packet
2022-02-07 13:45:39.715 response = cs.recvfrom(2048)
2022-02-07 13:45:39.715 socket.timeout: timed out
2022-02-07 13:45:39.715 During handling of the above exception, another exception occurred:
this is my test system:
Version: 2021.1 (build 13954)
Build Hash: 43ee2af49
Compile Date: 2021-12-23 23:07:32
dzVents Version: 3.1.8
Python Version: 3.7.5 (tags/v3.7.5:5c02a39a0b, Oct 14 2019, 23:09:19) [MSC v.1916 32 bit (Intel)]
OS : windows 10
Have tried the same on another one (production), no error until now.
this is the version:
Version: 2020.2 (build 13065)
Build Hash: e31c70c24
Compile Date: 2021-03-11 09:49:29
dzVents Version: 3.1.6
Python Version: 3.7.6 (tags/v3.7.6:43364a7ae0, Dec 18 2019, 23:46:00) [MSC v.1916 32 bit (Intel)]
OS: windows 10
I had also put debug mode to 'All' on both.
On production, when restart the plugin, never receive error , but on test always:
2022-02-07 13:55:04.290 Error: (FindModule) Domoticz/DomoticzEx modules not found in interpreter.
2022-02-07 13:55:04.291 Error: (FindModule) Domoticz/DomoticzEx modules not found in interpreter.
see this topic:
viewtopic.php?t=37043
this happend during the onStop() call:
2022-02-07 13:58:00.899 rm2: onDisconnect called for connection BROWebServer
2022-02-07 13:58:00.899 rm2: Server Connections:
2022-02-07 13:58:00.900 rm2: onStop called
2022-02-07 13:58:00.898 Status: rm2: Stop directive received.
2022-02-07 13:58:00.934 Status: rm2: Exiting work loop.
2022-02-07 13:58:00.916 Error: (FindModule) Domoticz/DomoticzEx modules not found in interpreter.
2022-02-07 13:58:01.014 rm2: Worker thread started.
2022-02-07 13:58:01.345 rm2: Debug logging mask set to: PYTHON
2022-02-07 13:58:01.345 rm2: 'HardwareID':'10'
2022-02-07 13:58:01.345 rm2: 'HomeFolder':'C:\Program Files (x86)\Domoticz\plugins\Broadlink\'
2022-02-07 13:58:01.345 rm2: 'StartupFolder':'C:\Program Files (x86)\Domoticz\'
2022-02-07 13:58:01.346 rm2: 'UserDataFolder':'C:\Program Files (x86)\Domoticz\'
2022-02-07 13:58:01.346 rm2: 'Database':'C:\Program Files (x86)\Domoticz\domoticz.db'
2022-02-07 13:58:01.346 rm2: 'Language':'en'
2022-02-07 13:58:01.346 rm2: 'Version':'1.6.3'
2022-02-07 13:58:01.347 rm2: 'Author':'zak45'
2022-02-07 13:58:01.347 rm2: 'Name':'rm2'
2022-02-07 13:58:01.347 rm2: 'Address':'192.168.1.17'
2022-02-07 13:58:01.347 rm2: 'Port':'8080'
2022-02-07 13:58:01.347 rm2: 'Key':'Broadlink'
2022-02-07 13:58:01.347 rm2: 'Mode1':'b4430dda260b'
2022-02-07 13:58:01.347 rm2: 'Mode2':'C:/Program Files (x86)/Domoticz/plugins/Broadlink/ini/'
2022-02-07 13:58:01.347 rm2: 'Mode3':'RM2'
2022-02-07 13:58:01.347 rm2: 'Mode4':'192.168.1.33'
2022-02-07 13:58:01.347 rm2: 'Mode5':'9000'
2022-02-07 13:58:01.347 rm2: 'Mode6':'2'
2022-02-07 13:58:01.347 rm2: 'DomoticzVersion':'2021.1 (build 13954)'
2022-02-07 13:58:01.347 rm2: 'DomoticzHash':'43ee2af49'
2022-02-07 13:58:01.347 rm2: 'DomoticzBuildTime':'2021-12-23 23:07:32'
2022-02-07 13:58:01.347 rm2: Device count: 3
2022-02-07 13:58:01.347 rm2: Device: 1 - ID: 58, Name: 'rm2 - RM2-Status', nValue: 1, sValue: 'On'
2022-02-07 13:58:01.347 rm2: Device ID: '58'
2022-02-07 13:58:01.347 rm2: Device Name: 'rm2 - RM2-Status'
2022-02-07 13:58:01.347 rm2: Device nValue: 1
2022-02-07 13:58:01.347 rm2: Device sValue: 'On'
2022-02-07 13:58:01.347 rm2: Device LastLevel: 0
2022-02-07 13:58:01.347 rm2: Device: 2 - ID: 59, Name: 'rm2 - IR Commands', nValue: 0, sValue: 'Off'
2022-02-07 13:58:01.347 rm2: Device ID: '59'
2022-02-07 13:58:01.347 rm2: Device Name: 'rm2 - IR Commands'
2022-02-07 13:58:01.347 rm2: Device nValue: 0
2022-02-07 13:58:01.347 rm2: Device sValue: 'Off'
2022-02-07 13:58:01.348 rm2: Device LastLevel: 10
2022-02-07 13:58:01.348 rm2: Device: 3 - ID: 60, Name: 'rm2 - RF Commands', nValue: 0, sValue: 'Off'
2022-02-07 13:58:01.348 rm2: Device ID: '60'
2022-02-07 13:58:01.348 rm2: Device Name: 'rm2 - RF Commands'
2022-02-07 13:58:01.348 rm2: Device nValue: 0
2022-02-07 13:58:01.348 rm2: Device sValue: 'Off'
2022-02-07 13:58:01.348 rm2: Device LastLevel: 50
2022-02-07 13:58:01.349 rm2: lang file : C:\Program Files (x86)\Domoticz\plugins\Broadlink\lng/en_en.lng
2022-02-07 13:58:01.349 rm2: Language loaded for : en
2022-02-07 13:58:01.013 Status: rm2: Stopping threads.
2022-02-07 13:58:01.013 Status: rm2: Stopped.
2022-02-07 13:58:01.014 Status: rm2: Entering work loop.
2022-02-07 13:58:01.014 Status: rm2: Started.
2022-02-07 13:58:01.344 Status: rm2: Initialized version 1.6.3, author 'zak45'
2022-02-07 13:58:02.357 rm2: Listen on BROWebServer - Port: 9000
2022-02-07 13:58:02.357 rm2: Hardware ID: 10
2022-02-07 13:58:02.357 rm2: 'HardwareID':'10'
2022-02-07 13:58:02.357 rm2: 'HomeFolder':'C:\Program Files (x86)\Domoticz\plugins\Broadlink\'
2022-02-07 13:58:02.357 rm2: 'StartupFolder':'C:\Program Files (x86)\Domoticz\'
2022-02-07 13:58:02.358 rm2: 'UserDataFolder':'C:\Program Files (x86)\Domoticz\'
2022-02-07 13:58:02.358 rm2: 'Database':'C:\Program Files (x86)\Domoticz\domoticz.db'
2022-02-07 13:58:02.358 rm2: 'Language':'en'
2022-02-07 13:58:02.359 rm2: 'Version':'1.6.3'
2022-02-07 13:58:02.359 rm2: 'Author':'zak45'
2022-02-07 13:58:02.359 rm2: 'Name':'rm2'
2022-02-07 13:58:02.359 rm2: 'Address':'192.168.1.17'
2022-02-07 13:58:02.359 rm2: 'Port':'8080'
2022-02-07 13:58:02.359 rm2: 'Key':'Broadlink'
2022-02-07 13:58:02.360 rm2: 'Mode1':'b4430dda260b'
2022-02-07 13:58:02.360 rm2: 'Mode2':'C:/Program Files (x86)/Domoticz/plugins/Broadlink/ini/'
2022-02-07 13:58:02.360 rm2: 'Mode3':'RM2'
2022-02-07 13:58:02.360 rm2: 'Mode4':'192.168.1.33'
2022-02-07 13:58:02.360 rm2: 'Mode5':'9000'
2022-02-07 13:58:02.360 rm2: 'Mode6':'2'
2022-02-07 13:58:02.360 rm2: 'DomoticzVersion':'2021.1 (build 13954)'
2022-02-07 13:58:02.360 rm2: 'DomoticzHash':'43ee2af49'
2022-02-07 13:58:02.360 rm2: 'DomoticzBuildTime':'2021-12-23 23:07:32'
2022-02-07 13:58:02.360 rm2: Device count: 3
2022-02-07 13:58:02.360 rm2: Device: 1 - ID: 58, Name: 'rm2 - RM2-Status', nValue: 1, sValue: 'On'
2022-02-07 13:58:02.360 rm2: Device ID: '58'
2022-02-07 13:58:02.360 rm2: Device Name: 'rm2 - RM2-Status'
2022-02-07 13:58:02.361 rm2: Device nValue: 1
2022-02-07 13:58:02.361 rm2: Device sValue: 'On'
2022-02-07 13:58:02.361 rm2: Device LastLevel: 0
2022-02-07 13:58:02.361 rm2: Device: 2 - ID: 59, Name: 'rm2 - IR Commands', nValue: 0, sValue: 'Off'
2022-02-07 13:58:02.361 rm2: Device ID: '59'
2022-02-07 13:58:02.361 rm2: Device Name: 'rm2 - IR Commands'
2022-02-07 13:58:02.361 rm2: Device nValue: 0
2022-02-07 13:58:02.361 rm2: Device sValue: 'Off'
2022-02-07 13:58:02.361 rm2: Device LastLevel: 10
2022-02-07 13:58:02.361 rm2: Device: 3 - ID: 60, Name: 'rm2 - RF Commands', nValue: 0, sValue: 'Off'
2022-02-07 13:58:02.361 rm2: Device ID: '60'
2022-02-07 13:58:02.361 rm2: Device Name: 'rm2 - RF Commands'
2022-02-07 13:58:02.361 rm2: Device LastLevel: 50
2022-02-07 13:58:02.362 rm2: ini file read....C:/Program Files (x86)/Domoticz/plugins/Broadlink/ini/remote/Broadlink-10-001.ini
2022-02-07 13:58:02.362 rm2: Custom Commands: 0,
2022-02-07 13:58:02.364 rm2: Update 0:'Off' (rm2 - IR Commands)
2022-02-07 13:58:02.368 rm2: Update 0:'Off' (rm2 - RF Commands)
2022-02-07 13:58:02.368 rm2: Plugin Device count start on : 9
2022-02-07 13:58:02.371 rm2: Command line file updated: C:\Program Files (x86)\Domoticz\plugins\Broadlink\log/10RM2.txt
2022-02-07 13:58:02.371 rm2: Connecting to: 192.168.1.33 : b4430dda260b
2022-02-07 13:58:02.640 rm2: Connected to Broadlink device: 192.168.1.33 RM2
2022-02-07 13:58:02.646 rm2: Admin html file created: C:\Program Files (x86)\Domoticz\www/templates/Broadlink-RM2-10.html
2022-02-07 13:58:02.646 rm2: command to execute : "C:\Program Files (x86)\Domoticz\plugins\Broadlink\scr/dombr.cmd" "C:\Program Files (x86)\Domoticz\plugins\Broadlink\Dombroadlink.py" "192.168.1.17;8080;b4430dda260b;C:/Program Files (x86)/Domoticz/plugins/Broadlink/ini/;RM2;192.168.1.33;9000;2;10;C:\Program Files (x86)\Domoticz\plugins\Broadlink\;9;en;remotePlugin" no
2022-02-07 13:58:03.738 rm2: Connected successfully to 127.0.0.1:54332
2022-02-07 13:58:03.738 rm2: onMessage called for connection: 127.0.0.1:54332
2022-02-07 13:58:03.738 rm2: We bypass URL check
2022-02-07 13:58:03.738 rm2: data:b'{"status":{"step":"remotePlugin","msg":"RemotePlugin OK","code":"0"}}'
2022-02-07 13:58:03.738 rm2: {"status":{"step":"remotePlugin","msg":"RemotePlugin OK","code":"0"}}
2022-02-07 13:58:03.739 rm2: processing data : {"status":{"step":"remotePlugin","msg":"RemotePlugin OK","code":"0"}}
2022-02-07 13:58:03.739 rm2: data process OK
2022-02-07 13:58:03.800 rm2: onDisconnect called for connection 127.0.0.1:54332
2022-02-07 13:58:03.800 rm2: Server Connections:
2022-02-07 13:58:03.801 rm2: --> 127.0.0.1:54332'.
2022-02-07 13:58:05.796 rm2: Connected successfully to 127.0.0.1:54340
2022-02-07 13:58:05.796 rm2: onMessage called for connection: 127.0.0.1:54340
2022-02-07 13:58:05.797 rm2: We bypass URL check
2022-02-07 13:58:05.797 rm2: data:b'{"end":{"step":"remotePlugin","msg":"END of remotePlugin"}}'
2022-02-07 13:58:05.797 rm2: {"end":{"step":"remotePlugin","msg":"END of remotePlugin"}}
2022-02-07 13:58:05.798 rm2: processing data : {"end":{"step":"remotePlugin","msg":"END of remotePlugin"}}
2022-02-07 13:58:05.804 rm2: Update 1:'END of remotePlugin' (rm2 - RM2-Status)
2022-02-07 13:58:05.810 rm2: Update 1:'On' (rm2 - RM2-Status)
2022-02-07 13:58:05.811 rm2: data process OK
2022-02-07 13:58:05.875 rm2: onDisconnect called for connection 127.0.0.1:54340
2022-02-07 13:58:05.875 rm2: Server Connections:
2022-02-07 13:58:05.875 rm2: --> 127.0.0.1:54340'.
on the test system, we can see also another log entry not present on the production one :
2022-02-07 14:00:35.224 Error: rm3: Traceback (most recent call last):
2022-02-07 14:00:35.224 File "C:\Program Files (x86)\Python37-32\lib\site-packages\broadlink\__init__.py", line 369, in send_packet
2022-02-07 14:00:35.224 response = cs.recvfrom(2048)
2022-02-07 14:00:35.224 socket.timeout: timed out
2022-02-07 14:00:35.224 During handling of the above exception, another exception occurred:
2022-02-07 14:00:35.224 Traceback (most recent call last):
2022-02-07 14:00:35.224 File "C:\Program Files (x86)\Domoticz\plugins\Broadlink\plugin.py", line 1803, in broadlink_connect
2022-02-07 14:00:35.224 DEVICE.auth()
2022-02-07 14:00:35.224 File "C:\Program Files (x86)\Python37-32\lib\site-packages\broadlink\__init__.py", line 270, in auth
2022-02-07 14:00:35.224 response = self.send_packet(0x65, payload)
2022-02-07 14:00:35.224 File "C:\Program Files (x86)\Python37-32\lib\site-packages\broadlink\__init__.py", line 374, in send_packet
2022-02-07 14:00:35.224 raise exception(0xfffd)
2022-02-07 14:00:35.224 broadlink.exceptions.DeviceOfflineError: The device is offline
2022-02-07 14:00:35.224 Error: rm3: Error to connect to Broadlink device: 192.168.1.34
2022-02-07 14:01:11.447 Status: rm2: Stop directive received.
2022-02-07 14:01:11.501 Status: rm2: Exiting work loop.
2022-02-07 14:01:11.549 Status: rm2: Stopping threads.
2022-02-07 14:01:11.549 Status: rm2: Stopped.
2022-02-07 14:01:11.550 Status: rm2: Started.
2022-02-07 14:01:11.550 Status: rm2: Entering work loop.
2022-02-07 14:01:11.472 Error: (FindModule) Domoticz/DomoticzEx modules not found in interpreter.
2022-02-07 14:01:11.473 Error: (FindModule) Domoticz/DomoticzEx modules not found in interpreter.
2022-02-07 14:01:12.080 Status: rm2: Initialized version 1.6.3, author 'zak45'
2022-02-07 14:01:13.093 rm2: 'Mode4':'192.168.1.33'
2022-02-07 14:01:13.093 rm2: 'Mode5':'9000'
2022-02-07 14:01:13.093 rm2: 'Mode6':'-1'
2022-02-07 14:01:13.093 rm2: 'DomoticzVersion':'2021.1 (build 13954)'
2022-02-07 14:01:13.093 rm2: 'DomoticzHash':'43ee2af49'
2022-02-07 14:01:13.094 rm2: 'DomoticzBuildTime':'2021-12-23 23:07:32'
2022-02-07 14:01:13.094 rm2: Device count: 3
2022-02-07 14:01:13.094 rm2: Device: 1 - ID: 58, Name: 'rm2 - RM2-Status', nValue: 1, sValue: 'On'
2022-02-07 14:01:13.094 rm2: Device ID: '58'
2022-02-07 14:01:13.094 rm2: Device Name: 'rm2 - RM2-Status'
2022-02-07 14:01:13.094 rm2: Device nValue: 1
2022-02-07 14:01:13.094 rm2: Device sValue: 'On'
2022-02-07 14:01:13.095 rm2: Device LastLevel: 0
2022-02-07 14:01:13.095 rm2: Device: 2 - ID: 59, Name: 'rm2 - IR Commands', nValue: 0, sValue: 'Off'
2022-02-07 14:01:13.095 rm2: Device ID: '59'
2022-02-07 14:01:13.095 rm2: Device Name: 'rm2 - IR Commands'
2022-02-07 14:01:13.095 rm2: Device nValue: 0
2022-02-07 14:01:13.095 rm2: Device sValue: 'Off'
2022-02-07 14:01:13.095 rm2: Device LastLevel: 10
2022-02-07 14:01:13.096 rm2: Device: 3 - ID: 60, Name: 'rm2 - RF Commands', nValue: 0, sValue: 'Off'
2022-02-07 14:01:13.096 rm2: Device ID: '60'
2022-02-07 14:01:13.096 rm2: Device Name: 'rm2 - RF Commands'
2022-02-07 14:01:13.096 rm2: Device nValue: 0
2022-02-07 14:01:13.096 rm2: Device sValue: 'Off'
2022-02-07 14:01:13.096 rm2: Device LastLevel: 50
2022-02-07 14:01:13.096 rm2: Pushing 'PollIntervalDirective' on to queue
2022-02-07 14:01:13.098 rm2: ini file read....C:/Program Files (x86)/Domoticz/plugins/Broadlink/ini/remote/Broadlink-10-001.ini
2022-02-07 14:01:13.099 rm2: Custom Commands: 0,
2022-02-07 14:01:13.099 (rm2 - IR Commands) Updating device from 0:'Off' to have values 0:'Off'.
2022-02-07 14:01:13.103 rm2: Update 0:'Off' (rm2 - IR Commands)
2022-02-07 14:01:13.103 (rm2 - RF Commands) Updating device from 0:'Off' to have values 0:'Off'.
2022-02-07 14:01:13.108 rm2: Update 0:'Off' (rm2 - RF Commands)
2022-02-07 14:01:13.108 rm2: Plugin Device count start on : 9
2022-02-07 14:01:13.112 rm2: Command line file updated: C:\Program Files (x86)\Domoticz\plugins\Broadlink\log/10RM2.txt
2022-02-07 14:01:13.112 rm2: Connecting to: 192.168.1.33 : b4430dda260b
2022-02-07 14:01:13.148 rm2: Connected to Broadlink device: 192.168.1.33 RM2
2022-02-07 14:01:13.152 rm2: Admin html file created: C:\Program Files (x86)\Domoticz\www/templates/Broadlink-RM2-10.html
2022-02-07 14:01:13.152 rm2: command to execute : "C:\Program Files (x86)\Domoticz\plugins\Broadlink\scr/dombr.cmd" "C:\Program Files (x86)\Domoticz\plugins\Broadlink\Dombroadlink.py" "192.168.1.17;8080;b4430dda260b;C:/Program Files (x86)/Domoticz/plugins/Broadlink/ini/;RM2;192.168.1.33;9000;-1;10;C:\Program Files (x86)\Domoticz\plugins\Broadlink\;9;en;remotePlugin" no
2022-02-07 14:01:13.202 (rm2) Releasing lock for 'onStartCallback'
2022-02-07 14:01:13.203 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:13.203 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:13.203 rm2: (rm2) Processing 'ListenDirective' message
2022-02-07 14:01:13.203 (rm2) Acquiring lock for 'ListenDirective'
2022-02-07 14:01:13.203 rm2: Protocol for 'BROWebServer' not specified, 'None' assumed.
2022-02-07 14:01:13.203 rm2: Transport set to: 'TCP/IP', :9000.
2022-02-07 14:01:13.204 rm2: Listen directive received, action initiated successfully.
2022-02-07 14:01:13.204 (rm2) Releasing lock for 'ListenDirective'
2022-02-07 14:01:13.204 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:13.204 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:13.204 rm2: (rm2) Processing 'PollIntervalDirective' message
2022-02-07 14:01:13.204 (rm2) Acquiring lock for 'PollIntervalDirective'
2022-02-07 14:01:13.204 rm2: Heartbeat interval set to: 30.
2022-02-07 14:01:13.204 (rm2) Releasing lock for 'PollIntervalDirective'
2022-02-07 14:01:13.261 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:13.261 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:13.324 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:13.324 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:13.388 (rm2) Requesting lock for 'rm2', waiting...
2022-02-07 14:01:13.388 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:13.388 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:13.452 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:13.452 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:13.516 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:13.516 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:13.579 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:13.579 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:13.643 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:13.643 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:13.707 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:13.707 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:13.770 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:13.770 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:13.833 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:13.833 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:13.897 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:13.897 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:13.961 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:13.961 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:14.025 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:14.025 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:14.089 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:14.089 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:14.153 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:14.153 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:14.217 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:14.217 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:14.279 (rm2) Requesting lock for 'rm2', waiting...
2022-02-07 14:01:14.279 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:14.279 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:14.342 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:14.342 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:14.405 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:14.405 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:14.467 (rm2) Requesting lock for 'rm2', waiting...
2022-02-07 14:01:14.467 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:14.467 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:17.539 rm2: 70 74 3e 0a 20 20 20 20 20 20 20 20 20 20 20 20 3c 2f 62 6f pt>.............</bo
2022-02-07 14:01:17.539 rm2: 64 79 3e 20 20 20 20 20 20 20 20 20 20 20 20 0a 20 20 20 20 dy>.................
2022-02-07 14:01:17.540 rm2: 20 20 20 20 20 20 20 20 3c 2f 68 74 6d 6c 3e 0a 20 20 20 20 ........</html>.....
2022-02-07 14:01:17.540 rm2: 20 20 20 20 20 20 20 20 .. .. .. .. .. .. .. .. .. .. .. .. ........
2022-02-07 14:01:17.540 (rm2) Releasing lock for 'WriteDirective'
2022-02-07 14:01:17.540 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:17.540 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:17.541 (rm2) Acquiring lock for 'CPluginTransportTCP::handleRead'
2022-02-07 14:01:17.541 Queued asynchronous read aborted (127.0.0.1:55048), [2] End of file.
2022-02-07 14:01:17.541 rm2: Pushing 'DisconnectedEvent' on to queue
2022-02-07 14:01:17.541 (rm2) Releasing lock for 'CPluginTransportTCP::handleRead'
2022-02-07 14:01:17.592 rm2: (rm2) Processing 'DisconnectedEvent' message
2022-02-07 14:01:17.592 (rm2) Acquiring lock for 'DisconnectedEvent'
2022-02-07 14:01:17.592 rm2: Disconnect event received for '127.0.0.1:55048'.
2022-02-07 14:01:17.592 rm2: Pushing 'onDisconnectCallback' on to queue
2022-02-07 14:01:17.593 (rm2) Releasing lock for 'DisconnectedEvent'
2022-02-07 14:01:17.593 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:17.593 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:17.593 rm2: (rm2) Processing 'onDisconnectCallback' message
2022-02-07 14:01:17.593 (rm2) Acquiring lock for 'onDisconnectCallback'
2022-02-07 14:01:17.594 rm2: Calling message handler 'onDisconnect' on 'module' type object.
2022-02-07 14:01:17.594 rm2: onDisconnect called for connection 127.0.0.1:55048
2022-02-07 14:01:17.594 rm2: Server Connections:
2022-02-07 14:01:17.594 rm2: --> 127.0.0.1:55048'.
2022-02-07 14:01:17.594 (rm2) Releasing lock for 'onDisconnectCallback'
2022-02-07 14:01:17.594 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:17.595 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:17.595 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:17.655 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:17.655 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:17.718 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:17.718 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:17.780 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:17.780 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:17.843 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:17.843 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:17.905 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:17.905 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:17.967 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:17.967 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:18.030 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:18.030 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:18.092 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:18.092 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:18.155 (rm2) Requesting lock for 'rm2', waiting...
2022-02-07 14:01:18.155 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:18.155 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:18.217 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:18.217 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:18.279 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:18.279 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:18.341 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:18.341 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:18.404 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:18.404 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:18.466 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:18.466 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:18.528 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:18.528 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:18.589 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:18.589 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:18.653 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:18.653 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:18.714 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:18.714 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:18.778 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:18.778 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:18.839 (rm2) Requesting lock for 'rm2', waiting...
2022-02-07 14:01:18.839 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:18.839 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:18.901 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:18.901 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:18.962 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:18.962 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:19.026 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:19.026 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:19.088 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:19.088 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:19.151 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:19.151 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:19.215 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:19.215 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:19.277 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:19.277 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:19.339 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:19.339 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:19.402 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:19.402 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:19.465 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:19.465 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:19.527 (rm2) Requesting lock for 'rm2', waiting...
2022-02-07 14:01:19.527 (rm2) Acquiring lock for 'rm2'
2022-02-07 14:01:19.527 (rm2) Releasing lock for 'rm2'
2022-02-07 14:01:19.550 (rm2) Acquiring lock for 'CPluginTransportTCP::handleAsyncAccept'
2022-02-07 14:01:19.550 rm2: Pushing 'ProtocolDirective' on to queue
2022-02-07 14:01:19.550 rm2: Pushing 'onConnectCallback' on to queue
2022-02-07 14:01:19.551 (rm2) Releasing lock for 'CPluginTransportTCP::handleAsyncAccept'
As we can see, there is 'millions of ' :
Maybe I'm wrong, but looks like this has been introduced during this update :
https://github.com/domoticz/domoticz/issues/5046
according this topic:
viewtopic.php?p=285420#p285420
@dnpwwo,
any thoughts about that ?????
thanks
Posted: Monday 07 February 2022 23:04
by kollemt
I am currently on the latest version 2022.1
I tried the following:
Deactivate the Slaapkamer hardware
Activate the Woonkamer hardware
Reboot
Activate the Slaapkamer hardware
Then all works fine and no problems at all.
Does not matter which of the two I do deactivate.
I agree with you that the problem could be caused by a Domoticz update. The plugin startup process is problably changed as I read in your messages.
I have ordered a new sd card to test with an older domoticz version of my backups in a couple of days as i do not want to overwrite my production sd card.
Posted: Thursday 10 February 2022 0:50
by kollemt
I installed Domoticz version 2021.1. No problems.
When back to my production Domoticz version 2022.1. Again the same problems.
Looks indeed that the problem was introduced with a later Domoticz version:
2020.2 build 2021-03-11 OK
2021.1 build 2021-04-17 OK
2021.1 build 2021-12-23 NOT OK
2022.1 build 2022-01-31 NOT OK
Posted: Friday 11 February 2022 15:33
by psubiaco
I have the same problem with Domoticz beta and Kia - Hyundai plugin:
CPU goes to 30% and I can see a lot of the following lines in the log.
Should we change something on the python plugin, or wait for a domoticz update?
2022-02-11 15:28:18.413 (Kia eNiro) Releasing lock for 'Kia eNiro'
2022-02-11 15:28:18.463 (Kia eNiro) Acquiring lock for 'Kia eNiro'
2022-02-11 15:28:18.463 (Kia eNiro) Releasing lock for 'Kia eNiro'
2022-02-11 15:28:18.514 (Kia eNiro) Acquiring lock for 'Kia eNiro'
2022-02-11 15:28:18.514 (Kia eNiro) Releasing lock for 'Kia eNiro'
2022-02-11 15:28:18.564 (Kia eNiro) Acquiring lock for 'Kia eNiro'
2022-02-11 15:28:18.565 (Kia eNiro) Releasing lock for 'Kia eNiro'
2022-02-11 15:28:18.615 (Kia eNiro) Acquiring lock for 'Kia eNiro'
2022-02-11 15:28:18.615 (Kia eNiro) Releasing lock for 'Kia eNiro'
2022-02-11 15:28:18.665 (Kia eNiro) Requesting lock for 'Kia eNiro', waiting...
2022-02-11 15:28:18.735 (Kia eNiro) Acquiring lock for 'Kia eNiro'
2022-02-11 15:28:18.735 (Kia eNiro) Releasing lock for 'Kia eNiro'
Posted: Saturday 12 February 2022 11:35
by zak45
psubiaco wrote: Friday 11 February 2022 15:33 I have the same problem with Domoticz beta and Kia - Hyundai plugin:
probably wait for a domoticz update, hope that someone will take care of that!
Posted: Sunday 13 February 2022 17:57
by psubiaco
Domoticz update will not solve the problem.
I believe the problem is on logging class: maybe domoticz now is using python 3.10 and broadlink plugin, as kia-hyundai plugin, is using logging python lib. Now I'm doing a dist-upgrade to update everything on my RPI and retry using the plugin, then I'll update this post with the results....
Posted: Thursday 17 February 2022 0:50
by Valiran
zak45 wrote: Thursday 25 February 2021 0:38
albebert wrote: Wednesday 24 February 2021 23:49
need to understand how it works now :) (tried a single IR remote : ok) need to find how create a on/off command with different IR/RF command now
For a simple On/off switch in Domoticz, better create a dummy device and copy paste corresponding http command:
Hello!
Could you give the syntax of the HTML command please?
Another question is for my projector, it needs to send OFF 2 times, how can I duplicate the command sent, with a 1 sec timer between?
Thanks !
Posted: Thursday 17 February 2022 9:54
by zak45
Valiran wrote: Thursday 17 February 2022 0:50
Click on the earth icon to have the http link :
Create a multi code ini file by selecting your desired ini number, add 1 second timer, add any other ini number :
edit the multi code ini just created and replace with your desired ini number:
Posted: Thursday 17 February 2022 14:34
by Valiran
I should have a problem, because my earth button does nothing when I click on it :(
Posted: Thursday 17 February 2022 18:38
by zak45
Valiran wrote: Thursday 17 February 2022 14:34 Hello,
Try with another browser.
Posted: Thursday 17 February 2022 18:53
by Valiran
zak45 wrote: Thursday 17 February 2022 18:38
Same issue with Chrome, Firefox and Safari :-(
Posted: Thursday 17 February 2022 19:10
by zak45
try to run the Webadmin Page outside domoticz:
http://<your_domoticz_ip_address>:<plugin_port_number>
Posted: Thursday 17 February 2022 20:05
by Valiran
Same issue :(
Posted: Thursday 17 February 2022 23:47
by zak45
Try to see if Javascript is enabled.
