Page 22 of 49
Re: Dashticz - Module - Garbage collector
Posted: Wednesday 10 January 2018 17:12
by aiolos
Moosjes wrote: Wednesday 10 January 2018 16:59
Moosjes wrote: Wednesday 10 January 2018 14:32
I have added the Garbage calander of Veldhoven to my Dashticz but all I get in the dashboard is 'Laden...'
I found the sollution to my own problem. I had selected the company 'Veldhoven' instead of 'veldhoven' (mind the capital V). After changing this it still did not work.
After I changed the company to 'ical' it worked
But then you're using config['garbage_icalurl'] and not config['garbage_zipcode'] and config['garbage_housenumber']? Zipcode and housenumber are used by the veldhoven parser.
Posted: Wednesday 10 January 2018 19:07
by AndreFR
robgeerts wrote: Monday 08 January 2018 21:30
Hmm indeed, we cannot use the afvalkalender.container-beheer.nl website.
But I've read on the website of Rotterdam that you should be able to use mijnafvalwijzer.
Try choosing this in dashticz-settings and enter your zipcode and house number.
Hi Rob/aiolos,
I’ve requested to have our city to be included to the ‘mijnafvalwijzer.nl’ website, it works if I use another ‘postcode’....
Posted: Thursday 11 January 2018 22:25
by jake
htilburgs wrote:When using
config['garbage_icon_use_colors'] = false; in your config.js, no icon is showed.
When checking I think the problem is:
<img class="trashcan" src="img/kliko.png" style="opacity: 1;">
While it should be
img/trashcan/kliko.png
garbage.js needs an update. Indeed kliko.png has moved, but not yet in the code.
instead of "img/kliko.png", it should be "img/garbage/kliko.png"
Posted: Thursday 11 January 2018 22:32
by EdwinK
jake wrote: Thursday 11 January 2018 22:25
While it should be
Was just going to post about this
Posted: Friday 12 January 2018 13:53
by aiolos
Thanks for noticing. I made a
PR to fix it.
Posted: Friday 12 January 2018 15:39
by geertvercamer
There is a problem with the 'ophaalkalender' method for Belgium.
In the function mapGarbageType() a mapping is done from 'blue' to 'papier', however that should be 'PMD (line 350)'. 'brown' should map to 'papier'
In my region we only have 'pmd', 'restafval' and 'p-k', but there are more in ie. Gent:
- GFT: green
- Glas: yellow
- Grof huisvuil afroep: purple
- Kerstboom: lightgreen
- P-K: brown
- PMD: blue
- Restafval: grey
and it may be nice to have a config/setting variable for the date format.
Thanks.
Posted: Friday 12 January 2018 15:47
by EdwinK
aiolos wrote: Friday 12 January 2018 13:53
PR to fix it.
I still miss a 'thank you' button
So, thank you
Posted: Saturday 13 January 2018 17:35
by robgeerts
It's merged
Posted: Saturday 13 January 2018 20:12
by EdwinK
Thanks again
Posted: Saturday 13 January 2018 21:16
by maceddy
Any chance you will implement 'Area Reiniging'?
http://www.areareiniging.nl/home/bewone ... -digitaal/
It shows a Calendar in some sort of frame and there is a possibility to download iCal, but I can not get it to work..
You may use my ZIP and house number (request per DM please
) if you plan on testing it.
Posted: Sunday 14 January 2018 23:36
by Regdul
is there any change to add "de friese meren' garbage calendar? same as maceddy, i cant get it to work. there is an option for Ical
https://dfm.afvalalert.nl/#
thanks!
Posted: Monday 15 January 2018 11:57
by pkrabben
Hi All,
De Garbage collector is not working anymore in Almere
can you add
http://afvalportaal2.2go-mobile.com/mod ... /calendar/
Thanks In advance
Posted: Tuesday 16 January 2018 0:44
by aiolos
maceddy wrote: Saturday 13 January 2018 21:16
Both these garbage collection calendars are added. See this
PR
The garbage company configuration is:
config['garbage_company'] = 'area';
and
config['garbage_company'] = 'almere';
Please note that for Almere the GFT & Rest are combined, they show up as a green bin, this can of course be changed with selecting another bin for this type of garbage.
Both calendars use the same (or a very alike) API as 'Twente Milieu'. I expect more calendars are based on this API, which makes it very easy to add them.
I tested this with a random address in Emmen and Almere, please let me know if you experience any difficulties (after a merge of course, it is not in there yet)
I saw the 'De Friese Meren' request. Looks do-able, but I could not implement it in the short time I had available right now. I will look into it later.
Posted: Tuesday 16 January 2018 11:09
by pkrabben
Thanks Almere is working
Posted: Tuesday 16 January 2018 18:25
by EdwinK
Is it right that the colors of the trashbin's dont change anymore?
Posted: Tuesday 16 January 2018 23:58
by aiolos
Regdul wrote: Sunday 14 January 2018 23:36
thanks!
In
this PR the support for this garbage calendar is added.
Configuration:
config['garbage_company'] = 'afvalalert';
It is very likely this company also works for other regions than 'De Friese Meren'
EdwinK wrote: Tuesday 16 January 2018 18:25
It does with my config (which is pretty standard for development) For various garbage companies and addresses I saw different colours of bins.
Posted: Wednesday 17 January 2018 9:20
by robgeerts
PR is merged!
Posted: Wednesday 17 January 2018 10:01
by EdwinK
aiolos wrote: Tuesday 16 January 2018 23:58
Then I've to look through all the settings (again).
Posted: Wednesday 17 January 2018 10:29
by EdwinK
Looks there is something more happening.
As seen on
https://www.mijnafvalwijzer.nl/nl/3161LH/27/ today is 'grof vuil' and on Friday we have 'rest'. But on dashticz it shows all the dates as 'rest'. Only 'gft' is changing colors in the text.
Part of config.js
config['garbage_company'] = 'mijnafvalwijzer';
config['garbage_icalurl'] = '0';
config['garbage_calendar_id'] = '';
config['garbage_zipcode'] = '3161LH';
config['garbage_street'] = 'Jonkerhof';
config['garbage_housenumber'] = '27';
config['garbage_housenumberadd'] = '';
config['garbage_maxitems'] = 2;
config['garbage_width'] = '6';
config['garbage_hideicon'] = '0';
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = 1;
config['garbage_use_names'] = 1;
config['garbage_use_cors_prefix'] = '0';
//Afval
config['garbage'] = {
gft: {kliko: 'green', code: '#375b23', name: 'GFT'},
// pmd: {kliko: 'orange', code: '#db5518', name: 'PMD'},
rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval'},
papier: {kliko: 'blue', code: '#153477', name: 'Papier'},
// kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval'},
brown: {kliko: 'brown', code: '#7c3607', name: 'Grof Vuil'},
// black: {kliko: 'black', code: '#000000', name: 'Zwart'},
Posted: Wednesday 17 January 2018 13:48
by geertvercamer
Maybe this has also something to do with this function mapGarbageType()?
