Just an idea: burn a piece of paper next the sensor, etc.havnegata wrote:Thanks for the feedback! I have a general question about testing a smoke detector. Apart from pressing a test button, how do one actually test if a detector works?
Sent from my Nexus 6P using Tapatalk
Cheap chinese z-wave products
- LouiS22
Re: Cheap chinese z-wave products
- gielie
- Domoticz version: latest β
Make an automatic signal to the fire department and then set your house on fire.havnegata wrote:Thanks for the feedback! I have a general question about testing a smoke detector. Apart from pressing a test button, how do one actually test if a detector works?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
I saw that in openzwave the manufacturer ID of Domux is now 0x021c and Heiman is 0x0260
Slorf
To come back about how to test your smokealarms without burning your house.
There are spraycans for sale ( I got one ), just spray the stuff ( don't know whats in there ) on the detector and it should go off.
https://www.google.nl/search?q=smoke+de ... 92&bih=882
Alex
Alex
A lot of stuff :[-)
Orange PI
Evohome with HGI-80
SmartMeter USB Cable
Solar panels
RFLINK 433 MHz
AeonLabs usb z-wave plus
My Sensors ( Lan Gateway )
Wemos sensors
Arduino sensors
Orange PI
Evohome with HGI-80
Solar panels
RFLINK 433 MHz
Wemos sensors
Arduino sensors
gtbuchanan
- Domoticz version: 3.7988
I have a suspicion this is the case due to the fairly new Z-Wave Alliance security mandate for S2 support [1]. Manufacturers may be prepping new devices for this.LouiS22 wrote:Wonder if it's a stock cleanup and sign of new, upgraded/better versions arriving soon?blacksn0w wrote:Just bought 2 plugs for 24$ each at Fasttech a few days ago, now they are 21$ at AliExpress... Think i have to order them there too
The new NEO Coolcam Motion Sensor (NAS-PD02Z [2]) isn't registered with the Z-Wave Alliance, even though NEO's other devices are. I imagine it's because the new device does not adhere to the mandate.
I've emailed support at NEO to find out if their existing devices already have S2 support, if they plan on manufacturing new devices to add S2 support, and to see if they plan on registering the NAS-PD02Z device. I was planning on purchasing a bunch of NEO devices, but now I might wait and see if some more secure devices are released.
[1]: http://z-wavealliance.org/mandatory-sec ... fect-today
[2]: https://www.aliexpress.com/item/NEO-COO ... 00186.html
Domoticz master on ODROID-C2 with Aeotec Z-Stick Gen5
- LouiS22
Will Z-Wave devices that existed previously be able to upgrade to the S2 framework?gtbuchanan wrote:I have a suspicion this is the case due to the fairly new Z-Wave Alliance security mandate for S2 support [1]. Manufacturers may be prepping new devices for this.LouiS22 wrote:Wonder if it's a stock cleanup and sign of new, upgraded/better versions arriving soon?blacksn0w wrote:Just bought 2 plugs for 24$ each at Fasttech a few days ago, now they are 21$ at AliExpress... Think i have to order them there too
Wijgergangs: Yes. Not only will devices with S2 be able to be included in an existing network using the previous security model, Z-Wave devices featuring the 500 Series chipset that’s upgradeable over-the-air (OTA) can be upgraded to 6.7x and utilize the S2 framework. Z-Wave will always be backward- and forward-compatible regardless of the upgrades in future versions.
As an example, if the controller or hub within the network upgraded to S2, an existing device (i.e., door lock) will be able to be included as a S2 device if it’s upgraded. It’s even able to utilize existing nodes in the network as a repeater for the necessary S2 commands and messages. We expect manufacturers to be rolling out device updates and new certified Z-Wave devices with S2 within the coming months.
http://www.electronicdesign.com/embedde ... ty-support
But it's up to manufacturers to release a FW upgrade. Personally I've never seen an OTA FW update to any z-wave stuff, even Fibaro, Aeotec, etc. It's much more easy to stay: buy our new, upgraded, etc... device.
- havnegata
- Domoticz version: V4.10162
Thanks!Slorf wrote:To come back about how to test your smokealarms without burning your house.
Alex
gtbuchanan
Good points. You're right in that it appears manufacturers are more likely to release new devices with S0/S2 support rather than release FW updates (which is what I was hinting at). I contacted Dome Home Automation about S0/S2 support for devices other than their door/window sensor (which already supports S0) and they had this to say:LouiS22 wrote:Will Z-Wave devices that existed previously be able to upgrade to the S2 framework?
Additionally, some of the cheaper devices (e.g. NEO) don't appear to have the "Firmware Update MD V2" command class built-in. I don't know enough about Z-Wave yet to know if this is just a more "advanced" command class for FW updates, or if this command class is required for any FW updates. Either way, I don't imagine we'll get major upgrades via FW. Most likely just bug fixes, if that.Like we did with the Door Sensor and Door Sensor Pro we hope to add newer, better products that are overall improvements and will include security
Regards,
Michael S
- LouiS22
Haha, good old pr bullshit from Domegtbuchanan wrote:Good points. You're right in that it appears manufacturers are more likely to release new devices with S0/S2 support rather than release FW updates (which is what I was hinting at). I contacted Dome Home Automation about S0/S2 support for devices other than their door/window sensor (which already supports S0) and they had this to say:LouiS22 wrote:Will Z-Wave devices that existed previously be able to upgrade to the S2 framework?
Regards,
Michael S
gtbuchanan
Evidently this isn't possible anymore. Or maybe it's just because I'm in the US. Tried to buy some multisensors from them directly since I can't find them for sale anywhere. This was their response:LouiS22 wrote:I've wrote them a mail, and asked them if it's possible to purchase. It wasgielie wrote:Were did you buy this, id like to buy some multisensors.LouiS22 wrote:
I've ordered a plug from them (Hank), once I have it, will post photos, and a review. One more thing: they don't have a B2C channel yet, but it's still possible to deal with them
Trying to find an affordable multisensor with encryption. Aeotec is far too overpriced.Dear Taylor
thanks for your contact
Sorry that we only do OEM right now, don't face to consumers directly, hope you understand our policy as we are factory with massive production
appreciate your contact really
best regards
Steven
- LouiS22
Well, I had to sent mine back to RMA and the sales team is different now. Maybe one chinese sales person lost her job beacuse she offered me a piece before?
JohnBoy32
Hi Michaelmicha_pr wrote:Hi,Luigi87 wrote:...but i am not sure if they are supported by open zwave yet...
The "NAS-RC01Z"
https://nl.aliexpress.com/store/product ... 96163.html
and:
the "NAS-SC01Z-2"
https://nl.aliexpress.com/item/Smart-Ho ... .44.6Lxajd
products will be supported by Domoticz - we just have them in test.
The XML is missing in this time, but it is not a problem.
But please note - the products are not "safety certified" in this time (but very nice,... agree).
Michael
Any news on this issue?
I am unable to use the double switch or do you have a hint how I can use it without "official" support?
westd001
Hi guys,
I just made my own xml definitions for the Neo Coolcam NAS-SC 2 channel wall switch EU version because I can't find them on theOpen Zwave alliance site or Github. I am now able to switch off the LEDS. It's not exactly as described in the manual but I managed to switch them off. Here is the code,
In the manufacturer_specific.xml file I added this line at the end of the Neo Coolcam part:
and I added file nas-sc02.xml to the folder /home/pi/domoticz/Config/shenzen_neo with the following content:
I wait for the official files but for the time being its OK for me.
Have fun with it.
JJ
<Product type="0003" id="108b" name="Dual channel wallswitch" config="shenzen_neo/nas-sc02.xml"/>
<?xml version="1.0" encoding="utf-8"?>
<Product xmlns='http://code.google.com/p/open-zwave/'>
Shenzhen NEO Electronics (Neo-CoolCam) Smart Power Plug
http://products.z-wavealliance.org/products/xxxx
<!-- Configuration Parameters -->
<CommandClass id="112">
<Value type="list" genre="config" instance="1" index="1" label="Back light Enable" value="1" size="1">
<Help>This parameter defines the back light state of the touch button.</Help>
<Item label="Disable" value="0"/>
<Item label="Enable" value="1"/>
</Value>
<Value type="list" genre="config" instance="1" index="2" label="Relay On/Off indicate" value="1" size="1">
<Help>This parameter defines the relay state.</Help>
</Value>
<Value type="list" genre="config" instance="1" index="3" label="Relay On/Off States Saved Enable" value="1" size="1">
<Help>This parameter defines the on/off status of relay needs to be saved.</Help>
</Value>
<Value type="list" genre="config" instance="1" index="4" label="Root Device Mapped Setting" value="1" size="1">
</Value>
</CommandClass>
<!-- Association Groups -->
<CommandClass id="133">
<Associations num_groups="3">
<Group index="1" max_associations="5" label="Lifeline"/>
<Group index="2" max_associations="5" label="Sending Report Endpoint 1"/>
<Group index="3" max_associations="5" label="Sending Report Endpoint 2"/>
</Associations>
</CommandClass>
</Product>
Have fun with it.
JJ
nmaster
- Domoticz version: 3.6304
Does someone tested Heiman / Domux sensors with domoticz ?
How does it compare with NEO ones ?
micha_pr
yes, we have tested.
If you can use translator - try : http://zwave-review.com/Geraete/heiman.php
They are simple in use - in most cases no parameters can be set.
For motion sensor this maybe a missing feature.
Door sensor ia large comparing with others.
If special questions tell me
Michael
Michael
Michael Pruefer
http://www.zwave-review.com (German only)
http://www.SmartHome.Work (German only)
nmaster
Thanks Michael, I'll read your reviews.
- LouiS22
IMHO Neo sensors are better than Heiman. Neo's door sensor has a stylish design, while Heiman's is "just" a boring brick. On the other hand, Heiman's are using 2 AAA batteries (easier to replace, ie you can purchase them in every store), while NEO's using the not so common CR14250.nmaster wrote: Saturday 02 September 2017 19:11 Hi,
micha_pr
This is not correct for all devices:LouiS22 wrote: Sunday 03 September 2017 15:50On the other hand, Heiman's are using 2 AAA batteries (easier to replace, ie you can purchase them in every store), while NEO's using the not so common CR14250.
- Heiman HS1HT Smart temp. / hum sensor - CR2450
- Heiman HS1MS Smart Motion Sensor - CR2450
- Heiman HS1SA Smart Smoke sensor - CR123A
- Heiman HS1CA Smart CO sensor - CR123A
Michael
Michael Pruefer
- LouiS22
Indeed, but I stated it's for door sensormicha_pr wrote: Sunday 03 September 2017 17:07This is not correct for all devices:LouiS22 wrote: Sunday 03 September 2017 15:50On the other hand, Heiman's are using 2 AAA batteries (easier to replace, ie you can purchase them in every store), while NEO's using the not so common CR14250.
But the flooting sensor and door sensor - yes, here is used the AAA battery - for door sensor, I think, device is to big because of this batteries...
Michael
nmaster
OK LouiS22,
I already have power plugs and water leak sensors from NEO, giving me good results.
Now, I'm extending my home automation system with motion sensors and door sensors.
As I red, NEO devices have some parameters that can be adjusted contrary to Heiman ones.
I have no issue for CR123A, CR2 or 14250 batteries I use rechargeables ones successfully on mutiple devices.
So for now I will try NEO motion sensor and Door sensor.
But I probably order Temp / Hum sensors from Heiman.
