Page 21 of 36
Re: Amazon Echo to Domoticz Bridge: switches, sensors & more
Posted: Thursday 06 April 2017 10:58
by jono
Good morning
I've been using Domoticz for a year now and thinks it's a brilliant system to control sockets
I've just got a echo dot and wud like to add it to my system but can anybody give me a step by step setup guide as I only know the basics of programming but love to learn
Hardware I have
Amerzon echo dot
Raspberry pi 2 ( running Domoticz )
Rfx mitter ( running home easy products )
KM tronic relay boards
I have a spare raspberry pi 3 if needed ?
Thanks in advance
Posted: Thursday 06 April 2017 11:33
by Madgeni
Hi there :)
You can find the code, and a new and improved manual (thanks to Borcon) here:
https://github.com/madgeni/alexa_domo
Any questions, just post here
Posted: Friday 07 April 2017 20:05
by borcon
Some informations for you
In some cases you want another name in alexa then the device name in domoticz.
Because alexa does not unterstand the name or the name is too long to speak.
Now it's possible (with the new version of domapi.js) to set the device name for alexa in the description field of each domoticz device.
Write in the description field: Alexa_Name:Your Name For Alexa
See attachment (1).
So the device name "Light Test" is ignored and "Your Name For Alexa" is the new device name.
You can write additional informations in the description field. No problem. But not in the same line!
@madgeni: In the next days, i will add these informations to the manual.
Posted: Friday 07 April 2017 22:05
by Bigted
Thanks for the update, haven't updated for a while as I've been pleased with the way it was working, but the renaming of devices for Alexa has taken it to a new level
Posted: Friday 07 April 2017 23:54
by jono
Madgeni wrote:Hi there :)
thanks for you quick reply and help much appreciated :)
I'm following the tutorial manual and I'm done okey antill i get to section
3.4 on Lambda
i cannot see on select Blueprint
alexia-smart-home-skill-adapter I'm only viewing Blue print skills 1-5 and manual says they can view 1-7
I've tried selecting different regions Eu London , Eu Ireland and US N Virginia still the same
any ideas
Thanks in Advance
john
Posted: Saturday 08 April 2017 0:27
by borcon
Hey john,
i can confirm, that the skill adapter is missing at the moment.
Please try it tomorrow again. Maybe amazon is working on it.
Posted: Saturday 08 April 2017 17:36
by jono
borcon wrote:Hey john,
Hi thanks for letting me know
I checked again today still no skill is they a way of finding out when it be back online ?
Thanks in adavace
John
Posted: Monday 10 April 2017 0:37
by jono
I
Posted: Monday 10 April 2017 4:06
by jono
good Evening
i followed the step by step guide
the only bit i didn't do was select the blue print "alexia-smart-home-skill-adapter"
is the amazon blue print still down ?
i get the following error message in AWS Control when i save and test
"errorMessage": "Cannot find module '/var/task/domapi'",
"errorType": "Error",
"stackTrace": [
"Module.require (module.js:353:17)",
"require (internal/module.js:12:17)"
am i anywhere close or do i need togo recheck my configurations ?
I can see Domoticz I set up on the Amazon Alexa app
I've enabled it but cannot Descover any devices
My Domoticz runs on port 8080 should I change in Conf.json port 80 to 8080
thanks in advance John
Posted: Monday 10 April 2017 11:03
by Madgeni
so, in the lambda, you've run a test and get that error?
You've not renamed the domapi.js have you?
Yes, the conf.json should reflect the config to your domoticz host
Posted: Monday 10 April 2017 17:22
by jono
Madgeni wrote:so, in the lambda, you've run a test and get that error?
Hi Madgeni
i haven't changed the name of domapi.js still same
in conf.json
I've changed to port 8080 instead of 80
under username "" as not using login Id at moment
password "" as not using password at moment
could it be because i didn't select a Alexa-home-smart Blue print because not available to select ?
i get the following error message in Lambda when excuse a test
thanks in advance
John
Posted: Monday 10 April 2017 18:25
by Madgeni
I've just created a new lambda function via the blank template, selecting Smart Home Skill as the Trigger. Zipped up domapi.js/conf.json/node_modules/package.json - uploaded and tested all ok here. I wonder if it's the blank user/pwd..
Posted: Monday 10 April 2017 19:01
by Madgeni
so you need to be using (for your safety!) https, and specify a username/pwd. I'm assuming you're doing this?
Posted: Tuesday 11 April 2017 1:08
by jono
Madgeni wrote:so you need to be using (for your safety!) https, and specify a username/pwd. I'm assuming you're doing this?
hi Madgeni
I've setup My domoticz web browser with a password and user name and updated the conf.json with user name and password re zipped
I've restarted the whole install from scratch including selecting the blank Blueprint
I'm using EU Ireland as my region
i get the following error in lambada when i upload the new code and carried out save and test
Execution result: failed(logs)
The area below shows the result returned by your function execution. Learn more about returning results from your function.
"stackTrace": [
"Function.Module._load (module.js:276:25)",
Summary
Code SHA-256
Ol9wwGkxmGJC0RgBiL0hDC3W4jBcnRvAln8n3fSDNyI=
Request ID
c1e70dea-1e3e-11e7-ac29-7f9766942959
Duration
89.92 ms
Billed duration
100 ms
Resources configured
128 MB
Max memory used
15 MB
Log output
The area below shows the logging calls in your code. These correspond to a single row within the CloudWatch log group corresponding to this Lambda function. Click here to view the CloudWatch log group.
START RequestId: c1e70dea-1e3e-11e7-ac29-7f9766942959 Version: $LATEST
Unable to import module 'domapi': Error
at Function.Module._resolveFilename (module.js:325:15)
at Function.Module._load (module.js:276:25)
at Module.require (module.js:353:17)
at require (internal/module.js:12:17)
END RequestId: c1e70dea-1e3e-11e7-ac29-7f9766942959
REPORT RequestId: c1e70dea-1e3e-11e7-ac29-7f9766942959 Duration: 89.92 ms Billed Duration: 100 ms Memory Size: 128 MB Max Memory Used: 15 MB
thanks in advance
john
Posted: Tuesday 11 April 2017 9:40
by Madgeni
It's implying the domapi.js file isn't present - it gets the name from the Handler name - in our case domapi.handler.
Can you check file permissions before zipping? How are you zipping the files?
Posted: Tuesday 11 April 2017 12:46
by markk
Hi. I followed the original instructions weeks ago and was so pleased to get this working. The update to allow renaming of devices is drawing me in but I don't want to start the whole process again in case I break anything. Is someone able to tell me what are the bits I need to amend please?
Posted: Tuesday 11 April 2017 13:16
by jono
Madgeni wrote:It's implying the domapi.js file isn't present - it gets the name from the Handler name - in our case domapi.handler.
I've checked the following
Conf.json (change name and from example Conf.json) added my external IP, user/password
domapi.js not touched
Package.json (not touched)
Folder nodes_modules ( not touched )
I then select all 4 then compress on my mac air it then generates a zip folder then I uploaded to lambada
Can you give me details how to re upload the folder to lambada
John
Posted: Tuesday 11 April 2017 13:37
by Madgeni
markk wrote:Hi. I followed the original instructions weeks ago and was so pleased to get this working. The update to allow renaming of devices is drawing me in but I don't want to start the whole process again in case I break anything. Is someone able to tell me what are the bits I need to amend please?
All you need to do is:
In Domoticz - under switches
in the Description - put: Alexa_Name:Your Name For Alexa - where Your Name For Alexa is the name you want.
Then Forget and Discover in Alexa app.
This is after you've downloaded, zipped and uploaded the code from github (making sure to update the conf.json to your own settings).
To be sure, download your code from your lambda first, so you can revert back to it with no problem
Posted: Tuesday 11 April 2017 14:34
by Madgeni
@jono - still not sure what's happening to you. I use a Mac, compress the same way you do, and I don't have any special permissions set (Although this was a problem for some running on linux).
here's my conf - IP & U:P changed -
    "protocol": "https",
    "host": "12.34.567.890",
    "port": 8443,
    "username": "username",
    "password": "password"
Posted: Tuesday 11 April 2017 20:08
by qwerk
I know it has been asked before in this topic, but the given solution did not help me.
Today I made my first skill (thank you Madgeni)
when testing the discovery in AWS I get all my devices, complete with friendlynames etc.
Trying to turn off a light with the AWS test, it works fine.
but.... I don't get any devices in my alexa environment. I get my Harmony devices and my HA-bridge, but no domoticz-alexa devices.
this looks correct. What else can I test??
thanks in advance
