Re: Pilot: Home Automation Control (iOS app)
Posted: Thursday 04 February 2016 22:40
Hell yeah! And the watch!Steven84 wrote:I will immediately demand my boss to get me iphone6![]()
Open source Home Automation System
https://forum.domoticz.com/
This has to do with the translation, the dutch text are much longer.Steven84 wrote:Alarm panel shows status not correctly.
Verzonden vanaf mijn iPhone met behulp van Tapatalk
Yeah, that's exactly what I ended up doingSteven84 wrote:Why translate? Just arm home etc
I can confirm that removing the widget stopped the polling. I guess this is better for battery life and use of my mobile data.patoo77 wrote:That should be the notification center widget, yupBikey wrote: ** EDIT ** I may have found the reason (of regular polling form Pilot): I was using the Pilot widget, I guess that is doing the polling if you open the iPhone homescreen?
Have removed the widget, see what happens.please let me know if it gets better now!
I think not everybody will like to use my.domoticz.com, as it is another "man in the middle" and not so secure as solutions using VPN or client certificates.patoo77 wrote:Soon you will be able to use the reverse proxy server my.domoticz.com directly within Pilot. Lots of stuff to be done on the mydomoticz service first, but that would definitely be the easiest way to connnect to your Domoticz server from the outside, and securely.pepijn wrote: I'am not the developer of this app, maybe he will implement x509 but it's also not native supported by Domoticz.![]()
You shouldn't be too worried about your mobile data. Data used by Pilot is very low.Bikey wrote:I can confirm that removing the widget stopped the polling. I guess this is better for battery life and use of my mobile data.patoo77 wrote:That should be the notification center widget, yupBikey wrote: ** EDIT ** I may have found the reason (of regular polling form Pilot): I was using the Pilot widget, I guess that is doing the polling if you open the iPhone homescreen?
Therefore I would really love it if Pilot would also implement x509 support as that is really a secure way to protect your home-network from the risks of the Internet. Is this something you consider to implement?
Bikey,Bikey wrote:Some feedback on the latest beta: the swipe control to switch a lamp on or really works nice. Nice change in last update is that it is now easier to distinguish between setting a lamp on at 100% or setting it on with the previous dimming level.
There is only one dimming behaviour with the swipe control that is implemented quite unintuitive:
I understand the idea that swiping to the right is increasing the dim level and to the left decreasing.
The problem with this is that if the lamp is off and for example you want switch the lamp on at 50%. Now sometimes you have swipe to the left and sometimes to the right, depending of the previous set level, if it was respectively greater or smaller then 50%. So you first have to look at the % in the circle and then figure out to which side you should slide. Very cumbersome and against consequent design conventions.
So please, change the behaviour so that the sliding to the right always sets the dimming level using the full scale from 0 - 100%. Remove the dimming action when sliding to the left, only use this to switch the lamp off.
I agree that this is a problem.Bikey wrote:The problem with this is that if the lamp is off and for example you want switch the lamp on at 50%. Now sometimes you have swipe to the left and sometimes to the right, depending of the previous set level, if it was respectively greater or smaller then 50%. So you first have to look at the % in the circle and then figure out to which side you should slide. Very cumbersome and against consequent design conventions.
I don't agree with your proposal. You throw the baby out with the bathwater. I think there is an easy and better solution to this particular problem:Bikey wrote:So please, change the behaviour so that the sliding to the right always sets the dimming level using the full scale from 0 - 100%. Remove the dimming action when sliding to the left, only use this to switch the lamp off.
Ok, that could work!dannybloe wrote: When the device is off, swiping is always absolute: you always start at 0 or at 100 (depending on the direction) and when you release it, the device is turned on at the release level. When the device is on, swiping is always relative.
No, that works great as it is now: if you slide fully to the right - way past the 100% - it switches the lamp on at the previous dimming level. Please don't change that, it should not be needed to tap two times to switch a lamp on!dannybloe wrote:If, however, when the device is off and you want to turn it on at the previous dimming level, you click on the device and press 'Turn on'.
Why would this be any different then? Pilot would believe it is OFF (Domoticz is the only holding the truth even when it is wrong) so all you can do is assume it is OFF and you make swiping absolute. But what happens when the next upstream update comes in? Will the device be ON? Or will it still be OFF? In either case... I don't see if that makes it any different. If Pilot thinks it is ON, the user also thinks it is ON (that's what he sees in the app, right?) so when he starts swiping he is increasing or decreasing. And if Pilot thinks it is OFF, it would be absolute: turn it on to a specific level.patoo77 wrote:If the device is ON but Domoticz shows it as being OFF, it doesn't make sense anymore in my opinion.
Oh yeah, forgot about that. There goes the consistencyBikey wrote: No, that works great as it is now: if you slide fully to the right - way past the 100% - it switches the lamp on at the previous dimming level. Please don't change that, it should not be needed to tap two times to switch a lamp on!
Oh crap.. it is already working like thisdannybloe wrote:Let's extend this a bit further then....
Device is OFF (5%), you swipe to the right to 100%, you see 100% in the slider, you release, you get 100%
Device is OFF (5%), you swipe to the right to 100% and .. even further, 100% is replaced by ON, you release, you get 5%.
Is this confusing? Perhaps not because you see the percentage while you are swiping and you release at the level that satisfies you need (either 100% or ON).
Yes, but for me, only when it is offBikey wrote: Absolute dimming is best!
