Dashticz - Module - Garbage collector Topic is solved
jdemas
Re: Dashticz - Module - Garbage collector
Post by jdemas »
rd4 doesn't work [solved]
i changed in garbage.js
line 222
'dddd DD MMMM YYYY' to 'dddd dd MMMM yyyy' and then it's working again.
Jeffrey
jdemas
Post by jdemas »
I am sorry last thing wasn't the solution.
please ad Snoeiafval and kerstbomen as gabage types then it works.
JD
Derik
Post by Derik »
Dear: aiolos
Not working...
Please will you share your code??
aiolos
Domoticz version: stable
Post by aiolos »
Derik wrote: Wednesday 03 January 2018 14:46 Dear: aiolos
Not working...
With this CONFIG.js:
var config = {}
config['domoticz_ip'] = 'http://ip:8080';
config['domoticz_refresh'] = '50';
config['dashticz_refresh'] = '600';
config['garbage_use_names']    = true;
config['garbage_use_colors']   = true;
config['garbage_icon_use_colors'] = true;
config['garbage_company']  = 'mijnafvalwijzer';
config['garbage_zipcode']  = '6865ED';
config['garbage_housenumber']  = '100';
var columns = {};
columns['bar'] = {};
columns['bar']['blocks'] = ['logo','miniclock','settings'];
columns[1] = {};
columns[1]['blocks'] = ['garbage'];
columns[1]['width'] = 12;
var screens = {};
screens[1] = {};
screens[1]['background'] = 'bg2.jpg';
screens[1]['columns'] = [1];
and this custom.css
.trash .state div.trashtoday      { font-size: 30px; font-weight: 3; margin-left: 29px; font-weight: bold; font-variant: small-caps;}
.trash .state div.trashtomorrow       { font-size: 27px; font-weight: 2; margin-left: 29px; font-variant: small-caps;}
.trash .state div.trashrow        { font-size: 25px; font-weight: 1; margin-left: 29px; font-variant: small-caps;}
.img.trashcan           { height: 65px; width: 65px; margin-left:0px; margin-top: 20px;}
div.col-icon { width: 100px !important; max-width: 100px !important;}
(it turns out you also need to add the 'max-width' property for div.col-icon if you have a smaller screen.)
I get this result:
Schermafbeelding 2018-01-03 om 17.45.38.png (76.26 KiB) Viewed 3909 times
Contributor to Dashticz
More on my Github profile
aiolos
Post by aiolos »
jdemas wrote: Wednesday 03 January 2018 6:42 Hi,
JD
Can you show the relevant parts of your CONFIG.js? It is loading at my side. Kerstbomen just falls back to the 'black' option. (however, this might give an unexpected result if you use config['garbage_use_colors'])
Edit:
I created a PR with some changes:
- The 'kerstboom' garbage type is added (including icon)
- If a garbage type is not in the config['garbage'] setting, it is not shown anymore: For example: if you don't want to see the 'gft' garbage type: remove it from config['garbage']
- 'snoei' now falls also in the category 'gft'
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
PR is merged :)
Derik
Post by Derik »
Dear... aiolos
When i use your code my whole dash is going crazy....
So i think you have a strange part in your code.
Or i have..
I checkt the mine in the w3 html 5 checker:
https://validator.w3.org/#validate_by_i ... th_options
Warning: This document appears to be written in English. Consider adding lang="en" (or variant) to the html start tag.
From line 1, column 1; to line 1, column 15
var config = {}↩confi
For further guidance, consult Declaring the overall language of a page and Choosing language tags.
If the HTML checker has misidentified the language of this document, please file an issue report or send e-mail to report the problem.
Error: Non-space characters found without seeing a doctype first. Expected <!DOCTYPE html>.
Error: Element head is missing a required instance of child element title.
Content model for element head:
If the document is an iframe srcdoc document or if title information is available from a higher-level protocol: Zero or more elements of metadata content, of which no more than one is a title element and no more than one is a base element.
Otherwise: One or more elements of metadata content, of which exactly one is a title element and no more than one is a base element.
Only 1 warn en 2 errors from out the warn..
So i think my document is ok?
I do not understand what i can i do with this warn... [ so i think it is ok :-) ]
So i turn off the icon....
Can i have your compleet code ex. private settings..
So i can learn or check the different s between us...
xx
aiolos
Post by aiolos »
Derik wrote: Thursday 04 January 2018 11:27 Dear... aiolos
Or i have..
xx
The code I pasted is literally all I have in my CONFIG.js and custom.css to test it (you only need to adjust your domoticz information: config['domoticz_ip'] = 'http://ip:8080';)
aiolos
Post by aiolos »
JacEngels wrote: Monday 01 January 2018 22:05
timyboyb wrote: Monday 01 January 2018 21:57 Hello,
Since my town Groningen is also not digital available I try to get the ical from google working and make my own. He says only "loading". What to do? how to check the diffrent parts?
Maybe for Groningen this link can be used and implemented: https://gemeente.groningen.nl/afvalwijzer/groningen
A PR for the garbage collection in Groningen is ready for merge.
Configuration:
config['garbage_company'] = 'groningen';
and of course the postal code and house number.
Derik
Post by Derik »
dear aiolos..
Something is not correct with your code.
In the wiki is more code then u use?
What part do i need yours or the latest in the wiki??
config['garbage'] = {
  gft:	{kliko: 'green', 	code: 'green', name: 'GFT-Folie'},
  pmd: 	{kliko: 'orange', 	code: '#db5518', name: 'PMD'},
    rest: 	{kliko: 'grey', 	code: 'grey', name: 'Rest'},
    papier: 	{kliko: 'blue', 	code: 'blue', name: 'Papier'},
    kca:	{kliko: 'red', 		code: '#b21807', name: 'Chemisch afval'},
    brown: 	{kliko: 'brown', 	code: '#7c3607', name: 'Bruin'},
  black: 	{kliko: 'black',	code: '#000000', name: 'Zwart'},};
When i remove this part.. is see finale a kliko///
The wiki is not correct??
Pff cost me 2 days..
thanks/..
Hope the switch is going well without this part code??
timyboyb
Post by timyboyb »
Configuration:
Oh seriously, that is great. Testing will be next week but thanks in advanced.
aiolos
Post by aiolos »
Derik wrote: Thursday 04 January 2018 22:04 dear aiolos..
thanks/..
It looks like the code on the wiki is missing the icon part. The default value in the current codebase is
        gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
        pmd: {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
        rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
        papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
        kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
        brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
        black: {kliko: 'black', code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
        milieu: {kliko: 'yellow', code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
        kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},
But remember: if you don't change anything in there, you don't need it in your CONFIG.js (and it is better to keep your CONFIG.js as little as possible, since future changes otherwise might require you to update your config (as you can see now, since the icon part is added a while ago)). Also for debugging it is easier to start with a small config and add the lines part by part. That's why I only put in the bare minimum, where the code from above was not present.
htilburgs
Post by htilburgs »
When using config['garbage_icon_use_colors'] = false; in your config.js, no icon is showed.
When checking I think the problem is:
<img class="trashcan" src="img/kliko.png" style="opacity: 1;">
While it should be img/trashcan/kliko.png
Hardware:
Derik
Post by Derik »
i don't use the icon settings any more...
Not working stable unfortunately....
The lines ar good for my wife...
So i have more space left for more nice stuff..
Only a difficult part because it is free time for the developers..
Only when the wiki is not correct to last beta.
Then i think there are lost of problems
use the wiki or not?
Or some where in a thread you can find the answer.
sorry for my feedback. Only when there is a important change in the code.
Please update the wiki, or remove the old settings.. [ so there will be les questions on the forum [ i think ]
AndreFR
Post by AndreFR »
hi Rob,
is it possible to add: afvalkalender.container-beheer.nl (that's for the Rotterdam area) as the mijnafvalwijzer won't work (mijnafvalwijzer is only pointing to a 'demo'). Thanks in advance :)
aiolos
Post by aiolos »
AndreFR wrote: Saturday 06 January 2018 14:03 hi Rob,
Hi Andre,
At first site it looks tricky to add this. Do you know if there is an app that can also be used to get the information? It might be easier to see how the app fetches the data.
Thanks.
AndreFR
Post by AndreFR »
aiolos wrote: Sunday 07 January 2018 23:49
Hi Andre,
Thanks.
hi Aiolos, unfortunately the app 'Afvalwijzer' isn't working as it's pointing to the 'mijnafvalwijzer' website :( de link I've given is the only one working.
robgeerts
Post by robgeerts »
Hmm indeed, we cannot use the afvalkalender.container-beheer.nl website.
But I've read on the website of Rotterdam that you should be able to use mijnafvalwijzer.
Try choosing this in dashticz-settings and enter your zipcode and house number.
Moosjes
Post by Moosjes »
I have added the Garbage calander of Veldhoven to my Dashticz but all I get in the dashboard is 'Laden...'
Moosjes
Post by Moosjes »
Moosjes wrote: Wednesday 10 January 2018 14:32 I have added the Garbage calander of Veldhoven to my Dashticz but all I get in the dashboard is 'Laden...'
I found the sollution to my own problem. I had selected the company 'Veldhoven' instead of 'veldhoven' (mind the capital V). After changing this it still did not work.
After I changed the company to 'ical' it worked :D
