Page 21 of 32
Re: Domoboard - General Discussions
Posted: Wednesday 25 January 2017 20:01
by squandor
Awst6000 wrote:A question about the selector:
Is this the three-way switch for the ventilation system?
Three way or four way doesn't matter it will dynamically add the number of buttons that you have in domoticz.
Posted: Thursday 26 January 2017 1:05
by jhenrikb
Is there any way to increase buttons size?
I tried to double all the pixels in bootstrap-switch and "buttons" file without success.
the other files I looked in I didnt find much related to size.
On the 2000x1500 pixel tablet a scene button becomes very small.
Sincerely
John
Posted: Thursday 26 January 2017 9:33
by squandor
jhenrikb wrote:Is there any way to increase buttons size?
Sincerely
John
Hi john the scene buttons style is located in the buttons.css so maybe if you change the values in that file that the buttons will change to.
Posted: Thursday 26 January 2017 12:11
by Zahariac
I can't seem to get it working. When I want to startup domoboard with the Python server.py config file this is what I get:
File "server.py", line 149, in <module>
unsanitizedConfig = configobj.ConfigObj(configfile)
File "/usr/local/lib/python2.7/dist-packages/configobj-5.0.6-py2.7.egg/configobj.py", line 1229, in __init__
self._load(infile, configspec)
File "/usr/local/lib/python2.7/dist-packages/configobj-5.0.6-py2.7.egg/configobj.py", line 1318, in _load
raise error
configobj.ConfigObjError: Parsing failed with several errors.
First error at line 67.
When I go to that map the file configonj does'nt exist. Can somebody help me? I am clearly not an expert in linux
PS: On the easy install configobj is installed with the correct version
Posted: Thursday 26 January 2017 12:48
by jhenrikb
Zahariac wrote:I can't seem to get it working. When I want to startup domoboard with the Python server.py config file this is what I get:
raise error
I get those errors when there is something wrong with my .config file. eg example.config
Got it last night when I tried to show a dimmer as a switch.
Posted: Thursday 26 January 2017 12:56
by Zahariac
jhenrikb wrote:Zahariac wrote:I can't seem to get it working. When I want to startup domoboard with the Python server.py config file this is what I get:
raise error
THANK YOU! Now I got another fault.
But can I change the port with no problems? Yes I can! Thanks it is working I think.
Error when starting the Flask server: [Errno 98] Address already in use
Still have a lot of 404 errors on several pages but I am getting somewhere
Posted: Thursday 26 January 2017 13:26
by anconakip
I have installed all by this post on my pi2. I changed the flask_url port to 5000. But when i go to myip:5000 the browser wil not connect. What do i wrong?
Posted: Thursday 26 January 2017 13:36
by Zahariac
anconakip wrote:I have installed all by this post on my pi2. I changed the flask_url port to 5000. But when i go to myip:5000 the browser wil not connect. What do i wrong?
Does your router support up to range 5000 for the port? Or your PI2 for that matter?
Posted: Thursday 26 January 2017 13:43
by anconakip
Zahariac wrote:anconakip wrote:I have installed all by this post on my pi2. I changed the flask_url port to 5000. But when i go to myip:5000 the browser wil not connect. What do i wrong?
I changed the port to 85 and this works also not. What should i change on my pi then? all is on my locale network so i don't need portforwarding on my router i guess.
Posted: Thursday 26 January 2017 13:52
by Zahariac
anconakip wrote:Zahariac wrote:anconakip wrote:I have installed all by this post on my pi2. I changed the flask_url port to 5000. But when i go to myip:5000 the browser wil not connect. What do i wrong?
Are you sure that the installation is complete?
Posted: Thursday 26 January 2017 13:55
by anconakip
how can i check that? i folowwed this tut.
Posted: Thursday 26 January 2017 14:01
by Zahariac
Not sure on a Pi. But in my terminal I can see lines and lines of code running
Posted: Thursday 26 January 2017 14:05
by anconakip
with what command?
Posted: Thursday 26 January 2017 14:25
by dutchdevil83
with what command?
start with -d in terminal and you can run in debug mode :
python server.py -c <config_file> -d
Posted: Thursday 26 January 2017 15:45
by anconakip
with what command?
The only thing i see is:
Device and/or scene with IDX 22 is not available in Domoticz
and then my command line again.
Posted: Thursday 26 January 2017 16:47
by desertdog
Just a question to be sure I wont 'break' anything...
My Domoticz web interface is currently running on 192.168.0.2:8080
If I set the Domoboard config to:
[general_settings]
[[server]]
url = 192.168.0.2:8080 # IP-address of Domoticz backend
flask_url = 192.168.0.2:80 # Please note: this is the internal IP-address including port of the Domoboard server
Does this means that the domoticz interface is still available on port 8080 and the Domoboard interface in port 80?
Posted: Thursday 26 January 2017 17:29
by Snowtiger
anconakip wrote:dutchdevil83 wrote:anconakip wrote:
with what command?
in your configuration file (something like myconf.conf) you can only use IDX which are actually present and active in your Domoticz - you specified IDX 22 which is not present in your Domoticz so Domoboard will not run
Posted: Thursday 26 January 2017 17:31
by Snowtiger
desertdog wrote:Just a question to be sure I wont 'break' anything...
[general_settings]
[[server]]
Correct, maybe you should use another port number that 80 because this is the default port for webservers - or it must be that this is your intention
use for example 1500
Posted: Thursday 26 January 2017 21:35
by desertdog
Unfortunately I already get stuck at the first line:
sudo easy_install flask flask-auth configobj gitpython simplejson bleach requests
This gives the error: sudo: easy_install: command not found
I am trying to install on a Rasberry Pi 3B
what am I doing wrong?
Posted: Thursday 26 January 2017 21:51
by Felix82
desertdog wrote:Unfortunately I already get stuck at the first line:
Already posted, read forum, use google...
sudo install python-setuptools
