Page 21 of 22
Re: Controlling Toon [HACKED] from Domoticz
Posted: Friday 19 February 2021 14:22
by madpatrick
Alxxx wrote: Friday 19 February 2021 14:15
madpatrick wrote: Thursday 18 February 2021 20:28
If you want have a easy setup you better can you this plugin
viewtopic.php?f=34&t=34986
Otherwise if you to use this script, you need to give more information.
Check all names and uservariables in detail. A misspell is easy made
u am trying to use the script i checked the uservariables for at least 10 times made 2 times form scratch new settings.
but the temperature will not show the signal to the toon like home,comfort,away, manual are working OK
Which version of the script are you using.
There are several version floating on the forum or in this tread.
Try to check each function each time.
If one is working go to the other.
What is your log telling you ?
for your convenience, this is my script.
local scriptVersion = 'Versie 1.03 '
local scriptVar = '-=# TOON Script #=-'
on = { timer = {'every minute'},
logging = { level = domoticz.LOG_ERROR,
marker = scriptVar },
execute = function(domoticz)
local ToonThermostat = 'Toon Thermostaat' -- Sensor showing setpoint
local ToonTemperature = 'Temperatuur Kamer' -- Sensor showing room temperature
local ToonAutoProgram = 'Toon Auto Program' -- Sensor showing auto program status
local ToonBoilerModulation = 'ModulationLevel' -- * Sensor showing Boiler Modulation
local ToonScenes = 'Toon Scenes' -- * Sensor showing program
local ToonBoilerSetpoint = 'Ketel Setpoint' -- * Sensor showing boiler temperature set point
local ToonBoilerTempIn = 'Ketel Temp IN' -- * Sensor showing water temp return
local ToonBoilerTempOut = 'Ketel Temp UIT' -- * Sensor showing water temp out
local ToonBoilerPressure = 'Keteldruk' -- Sensor showing boilerpressure
local ToonBurnerName = 'Ketelstand' -- Sensor showing boiler modus
local P1SmartMeterPower = 'P1 Elektra' -- Sensor Energy consumption
local P1SmartMeterGas1 = 'P1 Gas' -- Sensor Gas consumption
local ToonIP = '192.168.1.200' -- IP address of your Toon
local DomoticzIP = '192.168.1.1:9200' -- IP address and portnumber of your Domoticz server
local SetPointAway = 18.5 -- temperature of setpoint Away
local SetPointSleep = 17.0 -- temperature of setpoint Sleep
local SetPointHome = 20.0 -- temperature of setpoint Home
local SetPointComfort = 20.5 -- temperature of setpoint Comfort
-- Handle json
-- local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux
local json = assert(loadfile "/var/domoticz/scripts/lua/JSON.lua")() -- For Linux (ClearOS)
local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
local ThermostatInfo = handle:read('*all')
handle:close()
local jsonThermostatInfo = json:decode(ThermostatInfo)
if jsonThermostatInfo == nil then
return
local handle2 = assert(io.popen(string.format('curl http://%s/boilerstatus/boilervalues.txt', ToonIP)))
local BoilerInfo = handle2:read('*all')
handle2:close()
-- JSON data from Toon contains a extra "," which should not be there.
BoilerInfo = string.gsub(BoilerInfo, ",}", "}")
jsonBoilerInfo = json:decode(BoilerInfo)
-- http://IP_TOON/hdrv_zwave?action=getDevices.json
local handle4 = assert(io.popen(string.format('curl http://%s/hdrv_zwave?action=getDevices.json', ToonIP)))
local GasPowerInfo = handle4:read('*all')
handle4:close()
-- JSON data from Toon contains a extra "." which should not be there.
GasPowerInfo = string.gsub(GasPowerInfo, "dev_2.", "dev_2")
GasPowerInfo = string.gsub(GasPowerInfo, "dev_2:", "dev_2\":")
local jsonGasPower = json:decode(GasPowerInfo)
-- Update the powerconsumption
local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_24.CurrentElectricityFlow) --stroomverbruik momenteel hoogtarief
local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_26.CurrentElectricityFlow) --stroomverbruik momenteel laagtarief
local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_24.CurrentElectricityQuantity) --stroomverbruik totaal hoogtarief
local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_26.CurrentElectricityQuantity) --stroomverbruik totaal laagtarief
local CurrentElectricityDeliveredHoog = tonumber(jsonGasPower.dev_25.CurrentElectricityQuantity) --stroomgeleverd momenteel hoogtarief
local CurrentElectricityDeliveredLaag = tonumber(jsonGasPower.dev_27.CurrentElectricityQuantity) --stroomgeleverd momenteel laagtarief
local CurrentElectricityDeliveredFlowHoog = tonumber(jsonGasPower.dev_25.CurrentElectricityFlow) --stroomgeleverd momenteel laagtarief
local CurrentElectricityDeliveredFlowLaag = tonumber(jsonGasPower.dev_27.CurrentElectricityFlow) --stroomgeleverd momenteel hoogtarief
local PowerConsumption = CurrentElectricityFlowHoog + CurrentElectricityFlowLaag --stroomverbruik totaal aktueel
local PowerProduction = CurrentElectricityDeliveredFlowHoog + CurrentElectricityDeliveredFlowLaag --stroomverbruik totaal geleverd
--USAGE1= energy usage meter tariff 1
--USAGE2= energy usage meter tariff 2
--RETURN1= energy return meter tariff 1
--RETURN2= energy return meter tariff 2
--CONS= actual usage power (Watt)
--PROD= actual return power (Watt)
--updateP1(usage1, usage2, return1, return2, cons, prod): Function. Updates the device. Supports command options.
domoticz.devices(P1SmartMeterPower).updateP1(CurrentElectricityQuantityLaag, CurrentElectricityQuantityHoog, CurrentElectricityDeliveredLaag, CurrentElectricityDeliveredHoog, PowerConsumption, PowerProduction).silent()
domoticz.log('P1 : Meter Verbruik laagtarief : ' .. CurrentElectricityQuantityLaag/1000 .. ' kWh ', domoticz.LOG_FORCE)
domoticz.log('P1 : Meter Verbruik hoogtarief : ' .. CurrentElectricityQuantityHoog/1000 .. ' kWh', domoticz.LOG_FORCE)
domoticz.log('P1 : Meter Levering laagtarief : ' .. CurrentElectricityDeliveredLaag/1000 .. ' kWh', domoticz.LOG_FORCE)
domoticz.log('P1 : Meter Levering hoogtarief : ' .. CurrentElectricityDeliveredHoog/1000 .. ' kWh', domoticz.LOG_FORCE)
domoticz.log('P1 : Huidig Stroom Verbruik : ' .. PowerConsumption .. ' W', domoticz.LOG_FORCE)
domoticz.log('P1 : Huidig Stroom Opbrengst : ' .. PowerProduction .. ' W', domoticz.LOG_FORCE)
-- Update the gasconsumption
local CurrentGasFlow = tonumber(jsonGasPower.dev_21.CurrentGasFlow)
local CurrentGasQuantity = tonumber(jsonGasPower.dev_21.CurrentGasQuantity)
domoticz.devices(P1SmartMeterGas1).updateGas(CurrentGasQuantity).silent()
-- Update the Boiler Water In to current value
-- local currentboilerInTemp = tonumber(jsonBoilerInfo.boilerInTemp)
-- currentboilerInTemp = tonumber(string.format("%.0f", currentboilerInTemp)) -- afgeronde getallen is voldoende [PdB]
-- if domoticz.utils.round(domoticz.devices(ToonBoilerTempIn).temperature,0) ~= domoticz.utils.round(currentboilerInTemp,0) then
-- domoticz.log('Update van de CV-water temperatuur IN: ' ..currentboilerInTemp .. ' °C',domoticz.LOG_INFO)
-- domoticz.devices(ToonBoilerTempIn).updateTemperature(currentboilerInTemp).silent()
-- end
-- Update the Boiler water Out to current value
-- local currentboilerOutTemp = tonumber(jsonBoilerInfo.boilerOutTemp)
-- currentboilerOutTemp = tonumber(string.format("%.0f", currentboilerOutTemp)) -- afgeronde getallen is voldoende [PdB]
-- if domoticz.utils.round(domoticz.devices(ToonBoilerTempOut).temperature,0) ~= domoticz.utils.round(currentboilerOutTemp,0) then
-- domoticz.log('Update van de CV-water temperatuur UIT : ' ..currentboilerOutTemp .. ' °C',domoticz.LOG_INFO)
-- domoticz.devices(ToonBoilerTempOut).updateTemperature(currentboilerOutTemp).silent()
-- end
-- Update the Boiler water Pressure to current value
local currentBoilerPressure = tonumber(jsonBoilerInfo.boilerPressure)
currentBoilerPressure = tonumber(string.format("%.1f", currentBoilerPressure)) -- 1 decimaal is voldoende [PdB]
if domoticz.utils.round(domoticz.devices(ToonBoilerPressure).sValue,1) ~= domoticz.utils.round(currentBoilerPressure,1) then
domoticz.log('Update van de waterdruk : ' ..currentBoilerPressure .. ' bar',domoticz.LOG_FORCE)
domoticz.devices(ToonBoilerPressure).updatePressure(currentBoilerPressure).silent()
-- Update the current temperature setpoint
local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
currentTemperature = tonumber(string.format("%.1f", currentTemperature)) -- 1 decimaal is voldoende [PdB]
-- Update the current auto program
local currentProgramState = tonumber(jsonThermostatInfo.programState)
if currentProgramState == 0 then currentProgramState = 10 -- No
elseif currentProgramState == 1 then currentProgramState = 20 -- Yes
elseif currentProgramState == 2 then currentProgramState = 30 -- Temporary
-- Update the current scene by state
local currentActiveState = tonumber(jsonThermostatInfo.activeState)
-- Update the current scene by temperature
local currentActiveTemp = tonumber(jsonThermostatInfo.currentSetpoint) / 100
if currentActiveState == 0 or currentActiveTemp == SetPointComfort then currentActiveState = 40 -- Comfort
elseif currentActiveState == 1 or currentActiveTemp == SetPointHome then currentActiveState = 30 -- Home
elseif currentActiveState == 2 or currentActiveTemp == SetPointSleep then currentActiveState = 20 -- Sleep
elseif currentActiveState == 3 or currentActiveTemp == SetPointAway then currentActiveState = 10 -- Away
elseif currentActiveState == -1 then currentActiveState = 50 -- Manual
--domoticz.log('Update Toon scene door temperature of Scene wijziging : ' ..currentActiveState,domoticz.LOG_FORCE)
-- Update the toon burner selector to current program state
local currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo)
local CurrentToonBurnerValue = domoticz.devices(ToonBurnerName).level
if currentBurnerInfo == 0 then currentBurnerInfo = 0 -- uit
elseif currentBurnerInfo == 1 then currentBurnerInfo = 10 -- cv aan
elseif currentBurnerInfo == 2 then currentBurnerInfo = 20 -- warmwater aan
-- elseif currentBurnerInfo == 3 then currentBurnerInfo = 30 -- voorverwarmen volgend setpoint
-- Update toon burner selector if it has changed
if CurrentToonBurnerValue ~= currentBurnerInfo then
domoticz.log('Update van de ketelstand: ' ..currentBurnerInfo,domoticz.LOG_FORCE)
domoticz.devices(ToonBurnerName).switchSelector(currentBurnerInfo)
-- Update the modulation level of the burner
local currentModulationLevel = tonumber(jsonThermostatInfo.currentModulationLevel)
if domoticz.devices(ToonBoilerModulation).percentage + 1 ~= currentModulationLevel + 1 then
domoticz.log('Update van de Modulatie stand: ' ..currentModulationLevel .. ' %',domoticz.LOG_FORCE)
domoticz.devices(ToonBoilerModulation).updatePercentage(currentModulationLevel)
-- Update the temperature Boiler setpoint to current boiler set point
local currentInternalBoilerSetpoint = jsonThermostatInfo.currentInternalBoilerSetpoint+1
if domoticz.utils.round(domoticz.devices(ToonBoilerSetpoint).temperature, 1) ~= domoticz.utils.round(currentInternalBoilerSetpoint, 1) then
domoticz.log('Update van het ketelwater temperatuur setpunt: ' ..currentInternalBoilerSetpoint .. ' °C',domoticz.LOG_FORCE)
domoticz.devices(ToonBoilerSetpoint).updateTemperature(currentInternalBoilerSetpoint)
-- Update the thermostat sensor to current setpoint
if domoticz.devices(ToonThermostat).setPoint*100 ~= currentSetpoint*100 then
domoticz.log('Update van de temperatuur instelling naar: ' ..currentSetpoint .. ' °C',domoticz.LOG_FORCE)
domoticz.devices(ToonThermostat).updateSetPoint(currentSetpoint).silent()
-- Update the temperature sensor to current room temperature
if domoticz.utils.round(domoticz.devices(ToonTemperature).temperature, 1) ~= domoticz.utils.round(currentTemperature, 1) then
domoticz.log('Update van de kamertemparatuur : ' ..currentTemperature .. ' °C',domoticz.LOG_FORCE)
domoticz.devices(ToonTemperature).updateTemperature(currentTemperature)
-- Update the toon scene selector sensor to current program state
if domoticz.devices(ToonScenes).level ~= currentActiveState then -- Update toon selector if it has changed
domoticz.log('Update van de Toon Scene : '..currentActiveState,domoticz.LOG_FORCE)
domoticz.devices(ToonScenes).switchSelector(currentActiveState).silent()
-- Updates the toon auto program switch
-- if domoticz.devices(ToonAutoProgram).level ~= currentProgramState then -- Update toon auto program selector if it has changed
-- domoticz.log('Update van het Toon Auto Program : '..currentProgramState,domoticz.LOG_FORCE)
-- domoticz.devices(ToonAutoProgram).switchSelector(currentProgramState).silent()
-- end
Adjust it to your system
Posted: Friday 19 February 2021 17:10
by Alxxx
madpatrick wrote: Friday 19 February 2021 14:22
-- Handle json
handle:close()
return
handle2:close()
handle4:close()
-- end
-- end
-- end
I tried the easy plugin but still not working. i Think there is something wrong in basic .The hardware i can choose and install
but there are no devices coming after restart.
Posted: Friday 19 February 2021 17:15
by madpatrick
Alxxx wrote: Friday 19 February 2021 17:10
Check in your settings menu at devices and add them to your system (green arrow)
In dutch : Instellingen/Apparaten en zoek de toegevoegde hardware
Posted: Sunday 21 March 2021 19:41
by EdwinK
I find this error in the log:
2021-03-21 19:23:00.615 Error: dzVents: Error: (3.1.6) ...e/pi/domoticz/scripts/dzVents/generated_scripts/Toon.lua:73: attempt to index a nil value (global 'jsonBoilerInfo')
This is line 73:
Posted: Sunday 21 March 2021 19:46
by madpatrick
Which firmware version do you have on your Toon ?
Since firmware 5.39.7 the boiler inlet and outlet temperature has been disabled.
You need to remove these line in the script and remove the devices in your domoticz
Posted: Sunday 21 March 2021 22:16
by EdwinK
I believe it's 5.22.14.
Removing those lines
Posted: Wednesday 07 April 2021 9:00
by S10NL
Since some days my log keeps spamming the same error, which i cant figure out:
2021-04-07 08:51:00.922 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Toon
2021-04-07 08:51:00.922 Error: dzVents: Error: (3.0.2) /opt/domoticz/dzVents/runtime/Utils.lua:121: attempt to perform arithmetic on a nil value (local 'x')
2021-04-07 08:52:00.909 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Toon
2021-04-07 08:52:00.910 Error: dzVents: Error: (3.0.2) /opt/domoticz/dzVents/runtime/Utils.lua:121: attempt to perform arithmetic on a nil value (local 'x')
2021-04-07 08:53:00.885 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Toon
2021-04-07 08:53:00.886 Error: dzVents: Error: (3.0.2) /opt/domoticz/dzVents/runtime/Utils.lua:121: attempt to perform arithmetic on a nil value (local 'x')
2021-04-07 08:54:00.883 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Toon
2021-04-07 08:54:00.884 Error: dzVents: Error: (3.0.2) /opt/domoticz/dzVents/runtime/Utils.lua:121: attempt to perform arithmetic on a nil value (local 'x')
2021-04-07 08:55:01.008 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Toon
2021-04-07 08:55:01.009 Error: dzVents: Error: (3.0.2) /opt/domoticz/dzVents/runtime/Utils.lua:121: attempt to perform arithmetic on a nil value (local 'x')
2021-04-07 08:56:00.951 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Toon
2021-04-07 08:56:00.953 Error: dzVents: Error: (3.0.2) /opt/domoticz/dzVents/runtime/Utils.lua:121: attempt to perform arithmetic on a nil value (local 'x')
2021-04-07 08:57:00.930 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Toon
2021-04-07 08:57:00.930 Error: dzVents: Error: (3.0.2) /opt/domoticz/dzVents/runtime/Utils.lua:121: attempt to perform arithmetic on a nil value (local 'x')
2021-04-07 08:58:01.042 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Toon
2021-04-07 08:58:01.042 Error: dzVents: Error: (3.0.2) /opt/domoticz/dzVents/runtime/Utils.lua:121: attempt to perform arithmetic on a nil value (local 'x')
I've read the posts above and removed the - boilerOutTemp and boilerInTemp variables in the script, but the message keeps spamming the log.
Does anyone know a solution or where to start?
Below my toon script:
timer = {
'every minute'
local ToonThermostat = domoticz.variables('UV_ToonThermostatSensorName').value -- Sensor showing current setpoint
local ToonTemperature = domoticz.variables('UV_ToonTemperatureSensorName').value -- Sensor showing current room temperature
--local ToonBoilerTempIn = domoticz.variables('UV_ToonboilerInTempName').value -- Sensor showing water temp return
--local ToonBoilerTempOut = domoticz.variables('UV_ToonboilerOutTempName').value -- Sensor showing current water temp out
local ToonBoilerPressure = domoticz.variables('UV_ToonboilerPressure').value -- Sensor showing current room temperature
local ToonBoilerModulation = domoticz.variables('UV_ToonboilerModulationLevel').value -- Sensor showing current Boiler Modulation
local ToonScenes = domoticz.variables('UV_ToonScenesSensorName').value -- Sensor showing current program
local ToonAutoProgram = domoticz.variables('UV_ToonAutoProgramSensorName').value -- Sensor showing current auto program status
local ToonProgramInformation = domoticz.variables('UV_ToonProgramInformationSensorName').value -- Sensor showing displaying program information status
local ToonIP = domoticz.variables('UV_ToonIP').value
local DomoticzIP = domoticz.variables('UV_DomoticzIP').value
local ToonBurnerName = domoticz.variables('UV_ToonBurnerName').value
-- local P1SmartMeterPower = domoticz.variables('UV_P1SmartMeterElectra').value
-- local P1SmartMeterGas1 = domoticz.variables('UV_P1SmartMeterGasMeterStand').value
local ToonBoilerSetpoint = domoticz.variables('UV_ToonBoilerTempSetpointSensorName').value -- Sensor showing current boiler set point water temp out
-- Handle json
local json = assert(loadfile "/opt/domoticz/scripts/lua/JSON.lua")() -- For Linux
handle:close()
ThermostatInfo = string.gsub(ThermostatInfo, ",}", "}")
return
handle2:close()
-- local handle4 = assert(io.popen(string.format('curl http://%s/hdrv_zwave?action=getDevices.json', ToonIP)))
-- local GasPowerInfo = handle4:read('*all')
-- handle4:close()
-- GasPowerInfo = string.gsub(GasPowerInfo, "dev_4.", "dev_4")
-- GasPowerInfo = string.gsub(GasPowerInfo, "dev_4:", "dev_4\":")
-- local jsonGasPower = json:decode(GasPowerInfo)
-- domoticz.log(jsonGasPower)
-- local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityFlow )
-- local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityQuantity)
-- local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_46.CurrentElectricityFlow )
-- local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_46.CurrentElectricityQuantity)
-- local CurrentGasFlow = tonumber(jsonGasPower.dev_41.CurrentGasFlow)
-- local CurrentGasQuantity = tonumber(jsonGasPower.dev_41.CurrentGasQuantity)
-- local CurrentElectricityQuantity = CurrentElectricityFlowHoog + CurrentElectricityFlowLaag
-- local CurrentElectricityDeliveredLaag = 0
-- local CurrentElectricityDeliveredHoog = 0
-- local totalDeliveredPower = 0
-- domoticz.devices(P1SmartMeterPower).updateP1(CurrentElectricityQuantityLaag, CurrentElectricityQuantityHoog, CurrentElectricityDeliveredLaag, CurrentElectricityDeliveredHoog, CurrentElectricityQuantity, totalDeliveredPower).silent()
-- domoticz.devices(P1SmartMeterGas1).updateGas(CurrentGasQuantity).silent()
-- domoticz.log('Updating Boiler Water In to current value: ' ..currentboilerInTemp)
-- domoticz.log('Updating Boiler Water Out to current value: ' ..currentboilerOutTemp)
if domoticz.utils.round(domoticz.devices(ToonBoilerPressure)._nValue,0) ~= domoticz.utils.round(currentBoilerPressure,0) then
-- domoticz.log('Updating Boiler Pressure to current value: ' ..currentBoilerPressure)
local currentTemperature = domoticz.utils.round(tonumber(jsonThermostatInfo.currentTemp) / 100,1)
elseif currentActiveState == 0 then currentActiveState = 40 -- Comfort
elseif currentActiveState == 1 then currentActiveState = 30 -- Home
elseif currentActiveState == 2 then currentActiveState = 20 -- Sleep
elseif currentActiveState == 3 then currentActiveState = 10 -- Away<br> elseif currentActiveState == 4 then currentActiveState = 60 -- Holiday
elseif currentBurnerInfo == 2 then currentBurnerInfo = 20 -- warmwater aan<br>
elseif currentBurnerInfo == 3 then currentBurnerInfo = 10 -- voorverwarmen volgend setpoint
if CurrentToonBurnerValue ~= currentBurnerInfo then -- Update toon burner selector if it has changed
-- domoticz.log('Updating Toon burner info:')
-- domoticz.log('Updating the Modulation sensor to new value: ' ..currentModulationLevel)
-- domoticz.log('Updating the Boiler internal temperature setpoint to new value: ' ..currentInternalBoilerSetpoint)
-- domoticz.log('Updating thermostat sensor to new set point: ' ..currentSetpoint)
-- domoticz.log('Updating the temperature sensor to new value: ' ..currentTemperature)
-- domoticz.log('Updating Toon Scenes selector to: '..currentActiveState)
-- domoticz.log('Updating Toon Auto Program selector to: '..currentProgramState)
-- Updates the toon program information text box
local currentNextTime = jsonThermostatInfo.nextTime
local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
if currentNextTime == 0 or currentNextSetPoint == 0 then
ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
if domoticz.devices(ToonProgramInformation).text ~= ToonProgramInformationSensorValue then
-- domoticz.log('Updating Toon Program Information to: '..ToonProgramInformationSensorValue)
domoticz.devices(ToonProgramInformation).updateText(ToonProgramInformationSensorValue)
Posted: Wednesday 07 April 2021 9:28
by EdwinK
deleted as it were some stupid old Lua scripts
Posted: Wednesday 07 April 2021 9:41
by EdwinK
@S10NL Guess what. I now tried your version, and that is working. Strange.
Edit: alright, some small issue
2021-04-07 09:43:00.615 Error: dzVents: Error: (3.1.7) ...e/pi/domoticz/scripts/dzVents/generated_scripts/Toon.lua:8: attempt to index a nil value
Posted: Wednesday 07 April 2021 9:48
by S10NL
S10NL wrote: Wednesday 07 April 2021 9:00
timer = {
'every minute'
-- Handle json
handle:close()
return
handle2:close()
-- handle4:close()
Fixed it myself. There was still a bit of code refering to the boilertempIN and boilertempOUT variables.
Commented them out, and no more errors messages
Posted: Wednesday 07 April 2021 11:49
by EdwinK
Now only this error remains:
2021-04-07 12:43:00.421 Error: dzVents: Error: (3.1.7) An error occurred when calling event handler Toon
2021-04-07 12:43:00.421 Error: dzVents: Error: (3.1.7) /home/pi/domoticz/dzVents/runtime/Utils.lua:203: attempt to compare number with nil
Posted: Wednesday 07 April 2021 12:10
by madpatrick
EdwinK wrote: Wednesday 07 April 2021 11:49
2021-04-07 11:48:00.408 Error: dzVents: Error: (3.1.7) /home/pi/domoticz/dzVents/runtime/Utils.lua:203: attempt to compare number with nil
This looks to me an other script then the Toon script : Utils.lua
Posted: Wednesday 07 April 2021 12:42
by EdwinK
Yes, but i don't have a script with that name, and it only pops up if the Toonscript is running. It maybe is a part of Lua?
Posted: Wednesday 07 April 2021 12:59
by madpatrick
EdwinK wrote: Wednesday 07 April 2021 12:42
It is a part of Domoticz and you can find it here : /var/domoticz/www/app/devices
There a lot of altered scripts on the forum currently so difficult to check for you.
My script is still running without issue. If you like i can share it.
Posted: Wednesday 07 April 2021 13:33
by waaren
Utils.lua is part of the dzVents framework and the error in line 203 is caused by a call from your scripts to the round function with something that is not a number.
Posted: Wednesday 07 April 2021 15:46
by EdwinK
@madpatrick please do.
I now had the script that user S10NL posted a few post above this. I believe this is your script.
timer = {
'every minute'
-- Handle json
-- local json = assert(loadfile "/opt/domoticz/scripts/lua/JSON.lua")() -- For Linux
local json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
handle:close()
return
handle2:close()
-- handle4:close()
Posted: Wednesday 07 April 2021 16:22
by madpatrick
EdwinK wrote: Wednesday 07 April 2021 15:46
This is my latest script
local ToonIP = 192.168.x.x -- IP address of your Toon
-- Handle json
handle:close()
return
handle2:close()
handle4:close()
-- domoticz.log('P1 : Meter Verbruik laagtarief : ' .. CurrentElectricityQuantityLaag/1000 .. ' kWh ', domoticz.LOG_FORCE)
-- domoticz.log('P1 : Meter Verbruik hoogtarief : ' .. CurrentElectricityQuantityHoog/1000 .. ' kWh', domoticz.LOG_FORCE)
-- domoticz.log('P1 : Meter Levering laagtarief : ' .. CurrentElectricityDeliveredLaag/1000 .. ' kWh', domoticz.LOG_FORCE)
-- domoticz.log('P1 : Meter Levering hoogtarief : ' .. CurrentElectricityDeliveredHoog/1000 .. ' kWh', domoticz.LOG_FORCE)
-- domoticz.log('P1 : Huidig Stroom Verbruik : ' .. PowerConsumption .. ' W', domoticz.LOG_FORCE)
-- domoticz.log('P1 : Huidig Stroom Opbrengst : ' .. PowerProduction .. ' W', domoticz.LOG_FORCE)
-- end
-- end
domoticz.log('Update van de Ketelstand: ' ..currentBurnerInfo,domoticz.LOG_FORCE)
domoticz.log('Update van de Kamertemparatuur : ' ..currentTemperature .. ' °C',domoticz.LOG_FORCE)
-- end
Not sure if your are using the P1 or Solarpanel function. This can be deleted.
I think it is pretty straight forward.
I've implemented the Setpoint function, so Domoticz or Toon will also be updated when the temperature is set to a value which matches the setpoint.
Check the names of your devices with mine in the top line of the script at local xxxxx = yyyyyyyy (change yyyyyyy)
If not working 100% send me a PM
Posted: Wednesday 07 April 2021 17:02
by EdwinK
i don't have solarpanels
They keep telling me that my roof is not good enough.
Even with your script, I get the same error message
Posted: Wednesday 07 April 2021 17:08
by madpatrick
EdwinK wrote: Wednesday 07 April 2021 17:02
Then i think the value remain at 0.
If not we can try to set the Return vlaues to 0 or adjust the script
Just try it and let's see if it is working
Posted: Wednesday 07 April 2021 17:20
by EdwinK
So, what do you want me to do?
