Page 3 of 3
Re: Elemental Theme
Posted: Saturday 05 March 2016 16:46
by raym
Well wouldn't you know it... After updating to the latest beta, I can't repro the issue anymore. Just forget I ever mentioned it
Re: Elemental Theme
Posted: Thursday 23 June 2016 0:30
by Nautilus
nayr wrote:i'll do some more work cleaning up selector switches soon, but @Nautilus I think i have that as wide as I could get it without breaking it for other devices.. I'll revisit though since I am going to need to refactor that device, mebe you'll get lucky
Hi, it's been a while but I revisited the subject and decided to use "select menu" instead of the buttons on selector switches that did not fit the buttons on one row. But I ran into a new issue when using the "compact" mode in dashboard. The select menu is not resized to fit the smaller area and thus it hovers below the switch area. Would there be some easy fix for this?
edit: while I'm at it I also noticed there is one image missing that is referenced in the theme .css:
.dimslider {
z-index:1;
border-width: 1px;
border-style: solid;
border-color: #333 #333 #777 #333;
border-radius: 25px;
margin-top: 0px;
margin-bottom: .5em;
height: 13px;
width: calc(98% - 70px) !important;
position: relative;
background-color: #8e8d8d;
background: url('images/bg-track.png') repeat top left;
box-shadow: inset 0 1px 5px 0px rgba(0, 0, 0, .5),
0 1px 0 0px rgba(250, 250, 250, .5);
Seems there is no such image (bg-track.png) in the repository...
Re: Elemental Theme
Posted: Thursday 23 June 2016 20:10
by remb0
this theme make domoticz a low nicer for sure!!
But I have one question: when a dimmable light is off, the bar to the dot (in the slider) is this blue.
is that possible to be grey when the light is out?
Re: Elemental Theme
Posted: Sunday 03 July 2016 0:45
by Nautilus
Nautilus wrote:...when using the "compact" mode in dashboard. The select menu is not resized to fit the smaller area and thus it hovers below the switch area...
On another look this seems to affect other themes as well so maybe some general fix would be needed. Is there some preferred way to report this so that possibly someone with skills to develop the web front end could take a look at it?
Re: Elemental Theme
Posted: Saturday 23 July 2016 0:33
by bxlouis
Hi!
Sorry if I sound stupid but I love this theme but I would like to change the background picture.
I'd like some plain color background, I like it very simple.
How may I achieve that ?
Anyway, thank you very much for your hard work, it is really great !
Re: Elemental Theme
Posted: Saturday 23 July 2016 12:33
by jjnj
You can switch the background image to the one you desire. If you check the theme installed you should be able to find the current wallpaper in that folder. Simply replace with the one you want (exact same naming should be used) and you are done.
Verstuurd vanaf mijn LG-H850 met Tapatalk
Re: Elemental Theme
Posted: Sunday 24 July 2016 14:41
by bxlouis
Hi!
Thank you for your help, I found the background image!
I think I found a visual bug on mobile (iPhone 6). When using a selector switch, the margin on the right seems wrong.
See the "Media Chambre" selector switch on the screenshot.
Is it possible to align the set of button on the right? Such as the other regular buttons?
Thank you!
Re: Elemental Theme
Posted: Tuesday 16 August 2016 17:27
by sylvaing26
I'm french too
I have the same problem and I've modified a part of the CSS file like this :
@media (max-width: 767px) {
.nav > li > a > img {
display: inline;
.navbar .nav { margin: 2px !important; }
#timesun { display: none; }
#dashcontent .selectorlevels {
font-size: 0.95em;
margin-top: -10px !important;
text-align: right;
Re: Elemental Theme
Posted: Tuesday 16 August 2016 21:58
by Nautilus
sylvaing26 wrote:Hi,
I'm french too
could perhaps make a git pull request to merge the fix to the master branch? Otherwise it'll be overwritten with each update, yes?
Re: Elemental Theme
Posted: Wednesday 17 August 2016 8:39
by gizmocuz
This is close, but not the way it is solved.
We can also have mobile modes on screens larger then 768 pixels (you can also force your dashboard in mobile mode)
Therefor i made a patch in the dashboard controller (beta #5510)
It was also not related to a theme
But maybe i'm wrong, but why a new table row for this switch ? I would have put it in the 'status' field (like the ITHO),
this way, you do not have an extra line/space
A patch for this is welcome
Re: Elemental Theme
Posted: Wednesday 17 August 2016 10:02
by sylvaing26
Good remark
Thanks for your great job !
Re: Elemental Theme
Posted: Wednesday 17 August 2016 22:41
by Nautilus
I think the issue that I mentioned about selector switches with "select menu" option on dashboard is existing in all themes (i.e. not a theme related issue). Could someone with proper .css / html etc. skills take a look at this? This happens at least on screen sizes where the item's area needs to be resized to a smaller size, in this case the selector menu is not resized and it disappears somewhere:
- Screen Shot 2016-08-17 at 23.34.04.png (221.71 KiB) Viewed 5570 times
Check the upper left item for example, the menu is behind the lower item
Re: Elemental Theme
Posted: Saturday 20 August 2016 20:15
by bxlouis
Solved in the latest builds. A big thank to all of you for your work !
Re: Elemental Theme
Posted: Sunday 30 October 2016 15:59
by Fainted
Hi good work nayr!
I was wondering how to change the color of the bar as pictured
Re: Elemental Theme
Posted: Saturday 01 April 2017 10:27
by Awst6000
Nice theme.
A small remark: the background of the blind switches are not transparant. They are white.
I hope Nayr still supports this theme.
Also:
Is there perhaps a way to show 5 or 6 columns of switches?
Txs!
Re: Elemental Theme
Posted: Tuesday 11 April 2017 15:05
by Awst6000
Unfortunately Nayr didn't respond to an email I sent.
Re: Elemental Theme
Posted: Tuesday 20 June 2017 20:04
by natywna
With such theme OpenSource will be beautiful!
