Page 3 of 3
Re: [677] Tado thermostat
Posted: Monday 25 December 2017 2:38
by sammyke007
Hi rjblake
Tnx for writing this script!
I created a temp+humidity virtual device and your script is providing my TADO's measurements correctly!
What kind of devices do I create for
$tado_setpointIDX = "nnn"; // Your Domoticz DeviceID for the Tado Setpoint device
$tado_heatdemandIDX = "nnn"; // Your Domoticz DeviceID for the current Tado Heat Demand
$tado_anyoneHomeIDX = "nnn"; // Your Domoticz DeviceID for the Anyone Home? alert
EDIT:
A virtual switch device on/off seems OK for $tado_anyoneHomeIDX
A virtual Setpoint (Temperature) seems OK for $tado_setpointIDX.
Domoticz receives temp+hum / homestatus / setpoint. Can it work in the other direction too? Changing the setpoint temp from Domoticz?
Also, sometimes the script is spitting out this error and returning temp 0 and humidty 0 to Domoticz
Token Age: 142 | Used cached token | HomeID: - ZoneID: - Temp&Humidity: ;;2 - Setpoint: - Status: Off
PHP Warning: min(): When only one parameter is given, it must be an array in /volume1/tado.php on line 322
Is this because I didn't make all devices in Domoticz?
Posted: Wednesday 17 January 2018 13:40
by tacoschuur
rjblake wrote: Thursday 20 July 2017 11:39
Additionally, you'll need the JSON modules/extension installed if they are not as this will definitely cause an issue (check to see modules installed with "php -m" or "php70 -m").
I know nothing about linux but got domoticz to work on a raspberry pi by following a manual i found on the internet. I didn't know what I was doing but in the end it worked and i could read out my smart meter.
Now I would really like to add the Tado script, but I don't have a clue where to put it. Nor do i know how to add something to start the script.
Next to that I believe I dont have (the right) JSON libraries. When I type php -m or php70 -m in putty it gives me "-bash: php: command not found"
Could somebody please help me to a guide how to install this library and script.
Many thanks in advance! I would really like to use domoticz on a higher level.
Cheers, Taco
Posted: Friday 19 January 2018 18:49
by rjblake
tacoschuur wrote: Wednesday 17 January 2018 13:40
Cheers, Taco
Taco - first thing is you will need to install PHP, as this is not installed. There are plenty of guides online for this (...or simply "sudo apt install php7.0 php7.0-curl php7.0-cli php7.0-json" should cover it. You can create a folder where you choose to install the scripts (e.g. /home/pi/tado). After that, create a bash script (e.g. tado.sh with rwx permissions) which contains the following lines
#!/bin/bash
php -f tado.php > /dev/null &
Call this script at startup and it'll run on restart/reboot
Not a detailed step by step guide, but should be enough to get you sorted.
Posted: Friday 26 January 2018 16:52
by tacoschuur
Hi rjblake,
I will try it this weekend.
Thanks a Lot!
Posted: Friday 16 March 2018 13:57
by SentryneL
Hi all!
I'm quiet new to domoticz and thats my first post in the forum.
I would like to thank you rjblake for this script. Very usefull.
I'm running domoticz on a Raspberry Pi. Followed your instructions as in the quoted post. Script is running, everything is ok, but I'm not able to get the script running on startup. If I execute tado.sh (located at home/pi/domoticz/scripts) on command line as pi user in that folder, works like a charm.
I've tried to call it from /etc/init.d/domoticz.sh in several ways but with no results. Also tried with contab. Nothing.
I'm doing something wrong but don't know what. Take into account that i'm also new on linux environement.
Any ideas??
Thank you!!
rjblake wrote: Friday 19 January 2018 18:49
Cheers, Taco
#!/bin/bash
Posted: Saturday 17 March 2018 22:09
by rjblake
SentryneL wrote: Friday 16 March 2018 13:57
Hi all!
Any ideas??
Thank you!!
Quick and easy fix is to add it to the end of /etc/rc.local file. Example entry as follows:
php -f /home/homeauto/remeha/remeha.php > /dev/null &
, where /home/homeauto/remeha/ is the full path to the remeha.php file
