Nefit Easy™ client library (How to install on the Pi)
Posted: Sunday 03 January 2016 23:13
Yes I changed these locations.. But where to check the mqtt settings? I might missed that one.
Where to find enable MQTT support in Domoticz?pepijn wrote:If you place the scripts in a different location you have to edit the 'EXEC' nodes in Node-RED.
Do you have MQTT enabled on your Domoticz setup?
All flows import fine in the node-red on my pi except you latest. After the functions 2 unknown nodes "unknown rbe" have appearedpepijn wrote:Here is my current Node-RED flow, have fun.
[{"id":"22a46350.4b5c8c","type":"mqtt-broker","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"verifyservercert":true,"compatmode":true,"keepalive":15,"cleansession":true,"willQos":"0","birthQos":"0"},{"id":"8b0bfef4.74f4","type":"inject","z":"b83a61b3.47c5a","name":"","topic":"nefit-update","payload":"","payloadType":"date","repeat":"30","crontab":"","once":true,"x":210.92857360839844,"y":72.4285717010498,"wires":[["b358d0b9.4ca73"]]},{"id":"b358d0b9.4ca73","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-status","addpay":false,"append":"","useSpawn":"","name":"Nefit Status","x":366.3730163574219,"y":72.09524345397949,"wires":[["6ebefa6b.914104","5ddfad82.a22054"],[],[]]},{"id":"3876c9bf.c78936","type":"debug","z":"b83a61b3.47c5a","name":"","active":true,"console":"true","complete":"true","x":1248.1825561523438,"y":201.17855834960938,"wires":[]},{"id":"1caaaa11.e35556","type":"mqtt in","z":"b83a61b3.47c5a","name":"domoticz/out/#","topic":"domoticz/out/#","broker":"22a46350.4b5c8c","x":195.92855834960938,"y":371.4285717010498,"wires":[["577c156d.a883ec"]]},{"id":"577c156d.a883ec","type":"function","z":"b83a61b3.47c5a","name":"de-jsonify","func":"var payload = JSON.parse(msg.payload);\nreturn payload;","outputs":1,"noerr":0,"x":361.9285583496094,"y":371.4285717010498,"wires":[["342ad05e.cbd53"]]},{"id":"23467d6a.dcb982","type":"debug","z":"b83a61b3.47c5a","name":"","active":true,"console":"false","complete":"true","x":1073.1785583496094,"y":357.1785717010498,"wires":[]},{"id":"50e0c648.af1f38","type":"function","z":"b83a61b3.47c5a","name":"Get SetPoint Value","func":"msg.payload = msg.svalue1\nreturn msg;","outputs":1,"noerr":0,"x":741.1230239868164,"y":370.5118885040283,"wires":[["a97981c8.56868"]]},{"id":"342ad05e.cbd53","type":"switch","z":"b83a61b3.47c5a","name":"filter Setpoint IDX","property":"idx","rules":[{"t":"eq","v":"160"}],"checkall":"true","outputs":1,"x":540.3729858398438,"y":370.9841136932373,"wires":[["50e0c648.af1f38"]]},{"id":"a97981c8.56868","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-set","addpay":true,"append":"","useSpawn":"","name":"Nefit Set Temp","x":930.9285697937012,"y":370.17857551574707,"wires":[["23467d6a.dcb982"],[],[]]},{"id":"6440aca2.9bbf54","type":"comment","z":"b83a61b3.47c5a","name":"Read changes from Domoticz and send to Easy","info":"","x":296.9285583496094,"y":334.4285717010498,"wires":[]},{"id":"6ebefa6b.914104","type":"function","z":"b83a61b3.47c5a","name":"Domoticz MQTT","func":"// Configuration\nconst IDX_SetPoint = 160;\nconst IDX_RoomTemp = 161;\nconst IDX_Pressure = 162;\nconst IDX_StatusCode = 163;\n\n\nvar domoticz_msg = {};\ndomoticz_msg.topic = \"domoticz/in\";\ndomoticz_msg.payload = {};\n\nif (msg.topic == 'nefit-update') {\n var NefitJSON = JSON.parse(msg.payload);\n domoticz_msg.payload.idx = IDX_RoomTemp;\n domoticz_msg.payload.nvalue = 0;\n domoticz_msg.payload.svalue = \"\" + NefitJSON['in house temp'];\n}\nif (msg.topic == 'nefit-pressure') {\n var NefitJSON = JSON.parse(msg.payload);\n domoticz_msg.payload.idx = IDX_Pressure;\n domoticz_msg.payload.nvalue = 0;\n domoticz_msg.payload.svalue = \"\" + NefitJSON['pressure'];\n}\nif (msg.topic == 'nefit-setpoint') {\n domoticz_msg.payload.idx = IDX_SetPoint;\n domoticz_msg.payload.nvalue = 0;\n domoticz_msg.payload.svalue = \"\" + msg.payload;\n}\nif (msg.topic == 'nefit-statuscode') {\n domoticz_msg.payload.idx = IDX_StatusCode;\n domoticz_msg.payload.nvalue = 0;\n domoticz_msg.payload.svalue = \"\" + msg.payload;\n}\n\nreturn domoticz_msg;","outputs":1,"noerr":0,"x":1028.4285354614258,"y":140.78571891784668,"wires":[["5bc7035e.a438fc","3876c9bf.c78936"]]},{"id":"5bc7035e.a438fc","type":"mqtt out","z":"b83a61b3.47c5a","name":"Domoticz MQTT","topic":"","qos":"","retain":"","broker":"22a46350.4b5c8c","x":1273.1785507202148,"y":142.53571319580078,"wires":[]},{"id":"2f2db332.d0d24c","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-pressure","addpay":false,"append":"","useSpawn":"","name":"Nefit Easy Pressure","x":393.9285659790039,"y":211.17857551574707,"wires":[["6ebefa6b.914104"],[],[]]},{"id":"baf3b005.450c5","type":"inject","z":"b83a61b3.47c5a","name":"","topic":"nefit-pressure","payload":"","payloadType":"date","repeat":"300","crontab":"","once":false,"x":208.67857360839844,"y":211.17857551574707,"wires":[["2f2db332.d0d24c"]]},{"id":"2b4dca2.fd4b236","type":"comment","z":"b83a61b3.47c5a","name":"Publish data from Nefit Easy Client to Domoticz","info":"","x":289.9285583496094,"y":24.428571701049805,"wires":[]},{"id":"906bc261.6f944","type":"rbe","z":"b83a61b3.47c5a","name":"","func":"rbe","gap":"","x":794.1428527832031,"y":40.42856979370117,"wires":[["6ebefa6b.914104"]]},{"id":"5ddfad82.a22054","type":"function","z":"b83a61b3.47c5a","name":"Get Setpoint","func":"var NefitJSON = JSON.parse(msg.payload);\nmsg.topic = 'nefit-setpoint';\nmsg.payload = NefitJSON['temp setpoint'];\nreturn msg;","outputs":1,"noerr":0,"x":632,"y":40.571428298950195,"wires":[["906bc261.6f944"]]},{"id":"2296752e.dd698a","type":"inject","z":"b83a61b3.47c5a","name":"","topic":"nefit-statuscode","payload":"","payloadType":"date","repeat":"10","crontab":"","once":false,"x":200.57141876220703,"y":145.6785717010498,"wires":[["4e5066ef.b1af98"]]},{"id":"4e5066ef.b1af98","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-code","addpay":false,"append":"","useSpawn":"","name":"Nefit Status Code","x":386.1785659790039,"y":145.92857360839844,"wires":[["8e61f998.719e08"],[],[]]},{"id":"8e61f998.719e08","type":"function","z":"b83a61b3.47c5a","name":"Get Status Code","func":"var NefitJSON = JSON.parse(msg.payload);\nmsg.topic = 'nefit-statuscode';\nmsg.payload = \"\"+\"[ \"+NefitJSON['code']+\" ] \"+NefitJSON['description'];\nreturn msg;","outputs":1,"noerr":0,"x":586.4285888671875,"y":132.92857360839844,"wires":[["8553f832.7aac08"]]},{"id":"8553f832.7aac08","type":"rbe","z":"b83a61b3.47c5a","name":"","func":"rbe","gap":"","x":741.5714111328125,"y":138.14286041259766,"wires":[["6ebefa6b.914104"]]}]
~ $ sudo apt-get install nodered
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package noderedI have found itpepijn wrote:In the hardware settingscheck the wiki for more information
Dutchsea wrote:All flows import fine in the node-red on my pi except you latest. After the functions 2 unknown nodes "unknown rbe" have appearedpepijn wrote:Here is my current Node-RED flow, have fun.
Message:
"This node is a type unknown to your installation of Node-RED.
If you deploy with the node in this state, it's configuration will be preserved, but the flow will not start until the missing type is installed.
See the Info side bar for more help"
[img]Knipsel.PNG[/img]
Updating my version isnt working
~ $ sudo apt-get install nodered Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package nodered
I have been looking myself but did bot find it in the Wiki or set-up page. Can you give me more hints?andreo wrote:I have found itpepijn wrote:In the hardware settingscheck the wiki for more information
thanx
$ npm install robertklep/nefit-easy-client -g here too. Updated node.js and created scripts (pepijn). Dummy sensors created. But cannot update node-red unfortunately. The nefit client is working because I saw some values when using the 3 export functions.andreo wrote:Dutchsea wrote:All flows import fine in the node-red on my pi except you latest. After the functions 2 unknown nodes "unknown rbe" have appearedpepijn wrote:Here is my current Node-RED flow, have fun.
Message:
Same issue here
npm updateCode: Select all
sudo npm cache clean
sudo npm install -g --unsafe-perm node-red
