Page 3 of 36
Re: Amazon Echo to Domoticz Bridge: switches, sensors & more
Posted: Monday 27 June 2016 11:02
by Madgeni
You can actually test it remotely, if you use the app/site, you can add the Skill in, then run a discovery. It might freak someone out if they are at home, as it announces the devices it finds
Posted: Monday 27 June 2016 15:48
by mack
One thing I think should be in the readme doc is to make sure your console is set to N. Virginia before creating a lambda function, since that's the only location currently supporting Smart Home Kit. The selector is in the upper right corner. Mine was set to Oregon, and it threw me for a little while.
My setup is mostly working. Only a few devices weren't discovered. Scenes and the regular switches work fine, but Alexa insists to telling me that the "command doesn't work on that device" after she's done it. I haven't had time to troubleshoot that yet
Posted: Monday 27 June 2016 15:54
by Madgeni
I'll update that, you're 100% right.
It's not perfect, but there's a challenge between the way that Domoticz (and the individual vendors) present their switches, over how Alexa expects them, so it might well not be discovering all types of switch correctly. I can probably update it with a more generic type if you can get me some feedback.
You should be getting the response ok, but take a look at the logs, and let me know what the switch is coming back as etc. Maybe add in some console.logs to troubleshoot.
by Madgeni
oh, and you're welcome
Posted: Monday 27 June 2016 16:05
by Madgeni
ok, i've updated the domapi.js to provide a generic switch type for Alexa, which should resolve your missing lights (don't forget it's currently only discovering switches in Domoticz that are deemed 'lights'), and hopefully should provide feedback, as that's not been a problem for this release (for me).
Posted: Monday 27 June 2016 18:33
by superczar
Same problem as what Mack reported ..
I was able to get the switches and scenes as devices but Alexa comes back with a "command doesn't work on that device" prompt
Let me dig into the logs and see what I can find
Posted: Monday 27 June 2016 18:41
by Madgeni
ok, that's really odd!
If you use the test payload on/off - you should get:
"header": {
"namespace": "Alexa.ConnectedHome.Control",
"name": "TurnOffConfirmation",
"payloadVersion": "2",
"messageId": "12232132"
"payload": {}
or similar in the execution result, and { status: 'OK', title: 'SwitchScene' } in the Log Output. If you're not seeing that, there's a problem!
Posted: Monday 27 June 2016 21:08
by superczar
Here is what I get with the test payload
Execution result: succeeded
"header": {
"payload": {}
Edit: Some more troubleshooting yields the following
"header": {
"messageId": "01ebf625-0b89-4c4d-b3aa-32340e894688",
"name": "TurnOffRequest",
"payload": {
"accessToken": "123",
"appliance": {
"additionalApplianceDetails": {
"switchis": "On/Off",
"WhatAmI": "light"
"applianceId": CHANGETHISTOANIDXINYOURDOMOTICZ
- The above Works for switching off switches (or TurnOnRequest works for switching them on) i.e. the lambda code seems to work
- The scene changer payload does not seem to work at all
- device discovery works i.e. the alexa configuration works as well
- For the switch requests that work in lambda testing (tried with x10 and rgbw) - a switch on or off command via the echo returns "That command does not work on that device" error
Posted: Monday 27 June 2016 22:00
by Madgeni
ok, that's weird, the messageid appears to be missing for a start.
On the window on the left, in the execution results window, what's the output there?
edit - i'm assuming you've put a correct IDX in the bit where it says "CHANGEMEETC"?
Posted: Monday 27 June 2016 22:03
by superczar
added some more debug info - the lambda test code seems to be working for switches (but not scenes)
Device discovery works too (so the alexa skill seems configured correctly)
however voice command returns a "command does not work on that device error"
Log from switch test code
START RequestId: 4d0991c4-3ca2-11e6-9489-858dfe858127 Version: $LATEST
2016-06-27T20:04:05.705Z 4d0991c4-3ca2-11e6-9489-858dfe858127 Input { header:
{ messageId: '01ebf625-0b89-4c4d-b3aa-32340e894688',
namespace: 'Alexa.ConnectedHome.Control',
payloadVersion: '2' },
payload:
{ accessToken: '123',
appliance: { additionalApplianceDetails: [Object], applianceId: 25 } } }
2016-06-27T20:04:07.019Z 4d0991c4-3ca2-11e6-9489-858dfe858127 { status: 'OK', title: 'SwitchLight' }
END RequestId: 4d0991c4-3ca2-11e6-9489-858dfe858127
REPORT RequestId: 4d0991c4-3ca2-11e6-9489-858dfe858127 Duration: 1315.59 ms Billed Duration: 1400 ms Memory Size: 128 MB Max Memory Used: 59 MB
Log from scene test code
START RequestId: 88aa00d9-3ca2-11e6-8186-a554b0f42d0b Version: $LATEST
2016-06-27T20:05:45.695Z 88aa00d9-3ca2-11e6-8186-a554b0f42d0b Input { header:
payload:
appliance: { additionalApplianceDetails: [Object], applianceId: 4 } } }
2016-06-27T20:05:46.885Z 88aa00d9-3ca2-11e6-8186-a554b0f42d0b { status: 'ERR' }
END RequestId: 88aa00d9-3ca2-11e6-8186-a554b0f42d0b
REPORT RequestId: 88aa00d9-3ca2-11e6-8186-a554b0f42d0b Duration: 1191.24 ms Billed Duration: 1200 ms Memory Size: 128 MB Max Memory Used: 59 MB
Posted: Tuesday 28 June 2016 8:49
by Madgeni
can you just put a console.log in both cases of the switch statement ("i'm in Switch") or ("i'm in Scene"), just to make sure it's calling the scene case? Also, silly Q, but you the scene you're controlling definitely has an IDX of 4?
Posted: Tuesday 28 June 2016 9:43
by superczar
Madgeni wrote:can you just put a console.log in both cases of the switch statement ("i'm in Switch") or ("i'm in Scene"), just to make sure it's calling the scene case? Also, silly Q, but you the scene you're controlling definitely has an IDX of 4?
Here are the execution and console logs for a switch and a scene
Have also attached a screenshot of the devices - Both the switch and scene are captured there justt in case it helps with the debugging
Execution Log for Switch
"header": {
"payload": {}
Console Log for Switch
START RequestId: e6c2bec4-3d02-11e6-b3e6-631cdc78fced Version: $LATEST
2016-06-28T07:35:36.823Z e6c2bec4-3d02-11e6-b3e6-631cdc78fced Input { header:
payload:
appliance: { additionalApplianceDetails: [Object], applianceId: 23 } } }
2016-06-28T07:35:38.124Z e6c2bec4-3d02-11e6-b3e6-631cdc78fced { status: 'OK', title: 'SwitchLight' }
END RequestId: e6c2bec4-3d02-11e6-b3e6-631cdc78fced
REPORT RequestId: e6c2bec4-3d02-11e6-b3e6-631cdc78fced Duration: 1364.86 ms Billed Duration: 1400 ms Memory Size: 128 MB Max Memory Used: 54 MB
Execution log for scene
"header": {
"payload": {}
Console Log for Scene
START RequestId: 5c3593bf-3d03-11e6-bc26-778b70fdef7e Version: $LATEST
2016-06-28T07:38:52.295Z 5c3593bf-3d03-11e6-bc26-778b70fdef7e Input { header:
payload:
2016-06-28T07:38:52.888Z 5c3593bf-3d03-11e6-bc26-778b70fdef7e { status: 'ERR' }
END RequestId: 5c3593bf-3d03-11e6-bc26-778b70fdef7e
REPORT RequestId: 5c3593bf-3d03-11e6-bc26-778b70fdef7e Duration: 626.62 ms Billed Duration: 700 ms Memory Size: 128 MB Max Memory Used: 54 MB
Posted: Tuesday 28 June 2016 10:15
by Madgeni
ok, so there's clearly a problem with the responses, as the messageid isn't there.
Are your scenes groups or scenes? According to the Domoticz API documentation, you can only turn Scenes 'On' - Groups can be turned on/off. Can you try that, and also put the logging into the Switch statements?
We'll get there
Posted: Tuesday 28 June 2016 10:30
by Madgeni
i've updated the domapi.js on github with some logging - i've tested it, and it's still working for me, with feedback. Can you try this one?
Posted: Tuesday 28 June 2016 11:57
by superczar
Uploaded the new files from github and changed test code to TurnOnRequest
Test request
"header": {
"name": "TurnOnRequest",
"payload": {
"appliance": {
"WhatAmI": "scene"
"applianceId": 4
Response log
START RequestId: b265cae9-3d12-11e6-91ee-a7521e434e0d Version: $LATEST
2016-06-28T09:28:40.704Z b265cae9-3d12-11e6-91ee-a7521e434e0d Input { header:
payload:
2016-06-28T09:28:40.963Z b265cae9-3d12-11e6-91ee-a7521e434e0d I'm in the scene case
2016-06-28T09:28:41.827Z b265cae9-3d12-11e6-91ee-a7521e434e0d { status: 'ERR' }
END RequestId: b265cae9-3d12-11e6-91ee-a7521e434e0d
REPORT RequestId: b265cae9-3d12-11e6-91ee-a7521e434e0d Duration: 1193.56 ms Billed Duration: 1200 ms Memory Size: 128 MB Max Memory Used: 55 MB
Posted: Tuesday 28 June 2016 14:14
by Madgeni
I think i've got it -
It's my fault for not explaining this - so Domoticz manages Scenes differently to switches etc, and stores them in a different table, allowing them to have the same IDX.
Alexa can't (rather understandably) handle this, so i cheat - essentially converting the IDX into a number, add another number to it to provide a unique IDX.
When testing it, can you try 204 for the IDX, rather than 4?
Still not sure why you're not getting good feedback though, but this should fix the Scenes
Posted: Friday 08 July 2016 23:48
by superczar
Sorry about the delayed response, had a rather demanding last few weeks at work
Was WFH today and managed to discover a rather nice piece of code at
https://github.com/bwssytems/ha-bridge
I can confirn that it works perfectly well with with both Amazon echo and harmony
It's a lot easier for the significant other to use alexa for tasks with the HA bridge that I now have running on a spare Pi
It's a lot more intuitive to say "Alexa, turn on the TV/ turn on all lights" vs "Alexa, tell Jarvis to switch on the TV/Alexa, tell lifx to switch on all lights/alexa, trigger on porch"
I may move it to the synology or the domoticz pi perhaps but for now a separate pi running this doesn't hurt either..
Posted: Saturday 09 July 2016 8:58
by Madgeni
that's interesting work.
A note of caution - i'm assuming that this is now deprecated from Amazon, as it's not code that runs in the cloud, so there's a concern that they may change someone on their side in the longer term that breaks this.
And my use of the Smart Home skill doesn't require you to call 'Jarvis', rather simply say "Alexa, turn on the kitchen lights' etc.
Posted: Sunday 10 July 2016 20:31
by superczar
It is deprecated from amazon in the sense that it runs as a Hue emulator on your LAN so hopefully shouldn't break unless Hue changes their API which is unlikely..
It actually runs quite beautifully well - It's a one time task to manually add all scenes/switches but the results are worth it
Hopefully I shall have a light day at work one of these days so I can add it to the wiki
Posted: Wednesday 13 July 2016 0:18
by Madgeni
That's a very neat solution
