Luxtronic Heatpump controller
poostrom
Domoticz version: Latest
Re: Luxtronic Heatpump controller
Post by poostrom »
Hoi Willem,
Somewhere at the end of the script you see:
# Lees huidige functie warmtepomp
if array_calculated[119] == 1: array_calculated[119] = '0'
if array_calculated[119] == 0: array_calculated[119] = '10'
if array_calculated[119] == 5: array_calculated[119] = '20'
if array_calculated[119] == 10: array_calculated[119] = '30'
if array_calculated[119] == 15: array_calculated[119] = '30'
That is being sent to a "selector switch" where value 0 is off, 10 is heating, 20 is hot water and 30 is cooling.
So you have to add a virtual switch with type "selector".
Regards,
Patrick
Wiljums
Post by Wiljums »
poostrom wrote: Saturday 05 October 2019 16:21 Hoi Willem,
Regards,
Patrick
Yes, I understand that. But can someone post a screenshot of the switch settings (with the states and action settings)?
poostrom
Post by poostrom »
Hi, there's no action.... Since the function is read from the heatpump to Domoticz, not the other way around. I'ts just an indicator showing what the heatpump is doing at this moment.
2019-11-24 19_11_09-Start.jpg (78.21 KiB) Viewed 3126 times
snahsiub
Post by snahsiub »
Hi Everybody,
I was searching for a topic to read and log data from a Alpha Innotec heatpump. I have a MSW3-12 type and have a webinterface, however the port 8888 or 8889 does not work for me. Is this device specific?
Are there any new developments on this or perhaps some easy to use scripts for I am a rookie at this :)
Thanks in advance.
Hans
snahsiub
Post by snahsiub »
Got it all figured out thanks to these amazing examples. It appeared port 8889 was listening after all. Nice!
snahsiub
Post by snahsiub »
Finally after some scripts, I've chosen to use the excellent script of Matis of Tweakers:
https://gathering.tweakers.net/forum/li ... 0#60239110
There are 2 files:
Make sure you put the first one in something like:
importer.py
And the second part in a new file:
file_cache.py
Then you can run it like:
python3 importer.py
Obviously you need to make adjustments to your idx of Domoticz. If you need to run it every minute:
crontab -e
And add this line below:
* * * * *  /usr/bin/python3 /home/pi/importer.py
smitec
Domoticz version: 2021.2
Post by smitec »
@snahsiub,
can you give me some more detail how you did the setup for the heatpump in domoticz? (screenshot?)
(or can you PM me?)
Wiljums
Post by Wiljums »
Has anyone managed to read the current power ('Leistung Istwert' or 'Vermogen') in kW? I think it's ID 188.
ajarzyn
Post by ajarzyn »
You can try python plugin:
https://github.com/ajarzyn/domoticz-luxtronic2
Still there's some work to do but it's something to start with.
klaaspiet
Post by klaaspiet »
Hey i'am going to try this
thanks for sharing
ajarzyn
Post by ajarzyn »
You are welcome.
In case of any issue, send a ticket or just fixit yourself :)
I saw mentions regarding state of the device (I plan to add this as soon as I finish with venta humidifier plugin).
ajarzyn
Post by ajarzyn »
To anyone interested in this plugin.
I've released new version.
snahsiub
Post by snahsiub »
Can you explain in a few steps how to use this python code?
