Home Automation Voice Commands
Javier
Re: Home Automation Voice Commands
Post by Javier »
No Problem, I forgot to change the instructions to document this "feature". I am trying to discourage multi-word corrections (unless absolutely needed) in favor of adding single word corrections, new devices, new locations, and new actions. The app will be faster with less Corrections, and there will be less opportunity for (REGEX) corrections to cause errors.
What is the phrase you are trying to correct? Maybe I can give you a suggestion....If it translates well, anyway.
You can still add multi-word corrections by Long Pressing "Word Corrections and Replacements".
Sent from my Nexus 6 using Tapatalk
Pietoesnoe
Post by Pietoesnoe »
I tryd this app yesterday, but I can't seem to connect to Domoticz. I don't have a password in Domoticz so I leave username and password empty? Wenn I fill in my external username and password I have the same issues. Anyone else having the same issues? Do I have to configure anything else to make it work? Wenn I push refesh I only get the message wenn I takes to long... I also use Dromotica and it works flawlessly at home and even over the internet.
Info: I have Domoticz on my Synology nas, Domoticz verions 3771.
Javier
Post by Javier »
Hi Pietoesno,
What is the message you see?
Also can you check to see if the file
"HA Chaining Voice Commands/DZnamstoaddrs.txt" was created on your device? I think the program will set a "blank" password if anything was entered for username or password, If this is the case you will need to delete the app then reinstall without going into the username or password, and only enter IP address, and port, then Refresh.
Let me the know if the uninstall works and I'll try to fix the problem.
Pietoesnoe
Javier wrote:Hi Pietoesno,
Thx Javier for the fast reply. The problem is solved by reinstalling the app and not going into the username and password. Any idee wenn scenes will be implented?The app you made is very easy to setup!Did not know voice control could be that easy!
Javier
Post by Javier »
Thanks, and I will add the username password bug to my to-do list.
Scenes are already implemented, only Domoticz variables are on the to-do list... Are your scenes missing?
Javier
Post by Javier »
If you installed the app prior to version 1.0.1.4 (Date 2015-12-20) you will need to correct word corrections for plural words. This is done by long clicking "WORD CORRECTIONS AND REPLACEMENTS" and adding a space to the end of the correct word i.e. change "light=lights" to "light=lights " ( notice the space on the end of the correct word). This only affects Autovoice users but all users should make the connection for uniformity of all app files. This correction is needed as AutoVoice will change plural words "lights" will be changed to "lightss" if the correction above is made AutoVoice will change "lights" to "lights s" and the app will be triggered correctly.
Example of string of corrected words "light=lights ,tim=dim ,jim=dim "
This will also fix AutiVoice use for some users. From 1.0.1.4 forward the app will automatically add the space to the end of word corrections.
Pietoesnoe
Javier wrote:Scenes are already implemented, only Domoticz variables are on the to-do list... Are your scenes missing?
No sorry, I was to fast.I made some mistakes with the scenes!Works perfect now!
wizzard72
Post by wizzard72 »
I'm using this app for a while. Works good. The problem I'm facing is that I cannot add a new voice command. When I try to link to domoticz, it presents me 2 options, 1) insteon hub device and 2) insteon hub scene. I don't use insteon, have only Domoticz. Anyone seen this behavior? I'm on version 1.0.1.4.
Verstuurd vanaf mijn SM-T700 met Tapatalk
Javier
Post by Javier »
wizzard72 wrote:I'm using this app for a while. Works good. The problem I'm facing is that I cannot add a new voice command. When I try to link to domoticz, it presents me 2 options, 1) insteon hub device and 2) insteon hub scene. I don't use insteon, have only Domoticz. Anyone seen this behavior? I'm on version 1.0.1.4.
Thanks for reporting! This explains the fall in current installs :(
I have been working on adding scenes to the insteon Hub and introduced a bug adding new devices for all hubs. I pushed an update without testing to address (plural) words in AutoVoice being "corrected" incorrectly....I was hoping the developer of AutoVoice would fix this but it continues to be a problem so I found a workaround.
I just uploaded 1.0.1.5 which will fix the problem, it should be available within the next few hours.
Sorry for the trouble,
Javier
wizzard72
Post by wizzard72 »
Its working again! Thanks for the quick fix!
toutazimuth
Post by toutazimuth »
Its working also for me ! Thanks a lot for this amazing apps!
amens
Post by amens »
This app looks like it completes my Domoticz adventure :)
I just installed it, will test it in the evening when I'm home. The app only works on a local network?
Javier
Re: RE: Re: Home Automation Voice Commands
Post by Javier »
amens wrote: The app only works on a local network?
Yes it is local network only.... for now.
Sent from my Nexus 6P using Tapatalk
amens
Post by amens »
Allright, thanks! Would it be possible to set the app for constant listening? I thought I did read it anywhere, but am not sure.
Javier
Re: RE: Re: RE: Re: Home Automation Voice Commands
Post by Javier »
This can be done with the AutoVoice Tasker plugin. Either with OK Google, which is dependent on your device, some devices only allow always listening while changing.
or
This can be done with AutoVoice Continuous listening, this will drain the battery, so is only recommend if connected to a power supply.
I posted setup instructions on g+
Best,
Javier
amens
Post by amens »
or
Best,
Javier
I will install an old Android Phone which will be on power constantly, thansk!
Javier
Post by Javier »
I have updated this tasker project to a native android app, I will need alpha testers to implement Domoticz, it currently supports Tasker and the ISY994i.
Let me know if you are interested.
Here are videos of setup and app in action:
Video Example of app in action:
https://youtu.be/IgzAdP2Obxk
Quick Setup:
https://youtu.be/OBH9SXRU10U
Javier
Zinken
Post by Zinken »
Hi Javier,
I would be interested in alpha testing this. I'm running domoticz (latest stable) on a raspberry pi.
Javier
Post by Javier »
Thanks Zinken!
PM sent.
james061
Post by james061 »
Javier wrote:Hi All,
I have created a free and open simple voice commands app which allows for chained voice commands. I added Domoticz to the supported hubs today.
Instructions can be found here:
https://plus.google.com/+JavierRefuerzo/posts/fbSM8WKAKse
App can be found here:
https://play.google.com/store/apps/details?id=com.yahoo.javierrefuerzo.homeautomationchainingvoicecommands
As of now it only supports domoticz devices (not scenes), If there is any interest in this app I will be happy to add scene support if anyone is willing to test, I use a different HA system but domoticz was very easy to add to the existing project. The project will also work with AutoVoice for "OK Google" commands although it is not required. Additonal Instructions are here: https://plus.google.com/+JavierRefuerzo/posts/Y2ANQYXS3bU
Hi Javier,
It is very nice.
Please let me know, from where I can download this app ?
Thanks in advance
