Page 3 of 5
Re: Heatit Z-wave thermostat
Posted: Monday 08 August 2016 20:42
by lagus
alexsh1 wrote:
- thermostat mode (Off, Heat, Cool, Heat Econ); no idea what Heat Econ means
- two setpoints (one for heating and one for cooling) - only one applicable in my case for heating
- temperature (I have an external underfloor sensor connected to Heatit)
...And IMHO this is not a Domoticz issue, but integration between OZW and the thermostat.
Are you sure you get the underfloor temperature reported? Mine seems to be reporting the internal temperature sensor.
I still haven't been able to get the underfloor temperature reported and not even seen on the thermostat itself.
You are right, it's a failure between OZW and the thermostat... I do not want to point a finger to Domoticz!
Posted: Tuesday 23 August 2016 21:14
by micha_pr
The following reports are sent periodically to the node in association group 1: “Lifeline”
• Room temperature
• Current operation mode (CO/ECO/OFF) (+Cooling in special model)
• Current setpoint
• Basic report (0x00/0xFF) depending on operation mode
so underfloor sensor temperature should not be reported, as far as I understand...
Posted: Wednesday 31 August 2016 13:54
by alexsh1
Yes, I am sure. Check the settings on the thermostat - you can toggle between internal and external sensors
Posted: Wednesday 31 August 2016 13:55
by alexsh1
No, this is wrong. You setup on the thermostat which temperature sensor to use internal or external.
Posted: Wednesday 31 August 2016 15:12
by micha_pr
It was from manufacturers documentation...
Maybe it depends on the firmware... They told me that there were different changes. As sample before 1.7 was shown a room temperature, now only the SetPoint (if no external sensor) or the external sensor temperature at display.
Soon (or just now) will coming out the 1.8.
@alexsh1: Can you post the part from OZW.log please, where is reported the temperature from external sensor?
And please add the firmware version (will be shown on display after power on)
Posted: Saturday 03 September 2016 14:00
by cogliostrio
I added some code to the config, an managed to get the CO (heat) setpoint to work from domoticz.
I now have these 4 devices.
- heatit devices.png (24.38 KiB) Viewed 9745 times
Heating 1 is the setpoint for CO mode. The other i presume is for COO mode.
This is showing 0dgrs, and is currently not working.
Setting temperature from web.
- heatit CO setpoint.png (46.2 KiB) Viewed 9745 times
This is the code I added to the config
<CommandClass id="67" name="COMMAND_CLASS_THERMOSTAT_SETPOINT" base="0">
</CommandClass>
Full config.
Posted: Saturday 17 September 2016 7:16
by cogliostrio
Made some more progress. Now both setpoints work, and can be adjusted from their respective devices on the web interface.
The config now creates two setpoints named "Heating" and "Energy heat". I have set them to start with temps
of 20 and 16 degrees Celsius respectively.
I still havent been able to adjust it in blockly.
Posted: Tuesday 27 September 2016 10:22
by Gijs69
It seems that you made quite some progress in getting the device to work properly in domoticz. Am I right?
Can you state what exactly is not yet working on updating from blockly? Can't you set the thermostat's setpoints, or can't you control the HeatIT working mode?
My magnum floor heating thermostat broke down, and this thermostat seems the most promising, and since the winter is starting to come in.....
Posted: Tuesday 27 September 2016 15:52
by cogliostrio
As far as I can tell, all functionality is working now. Thermostat mode and both setpoints
can be adjusted from their respective domoticz devices in the web interface.
I havent been able to get it working in blockly (havnt had time to look to much at it yet). Did a quick
search and found only
one thread with blockly. So support for it is implemented, but it could be
that most use lua for temperature controll.
Posted: Thursday 29 September 2016 21:21
by Gijs69
Dear cogliostrio,
I installed my thermostat and tried your xml file. It truns out there were still a few bugs in it. I corrected them and ataatced the update XML file.
Summary:
- index values of SETPOINTs were not consistent. I was changing the setpoint of the Cool mode when I updated the Energy Heat values
- Configuration values for tmerperatures should be shorts instead of bytes to cever for the full temp. range.
Posted: Sunday 09 October 2016 20:24
by admiral
I am not entirely sure where to place this xml data.
Would it be this xml file?
~/domoticz/Config/thermofloor/multireg.xml
hm.. sorry missed some posts on the first page apparently. I edited the multireg and deleted the Config/zwcfg*.xml files.
Now restarting domoticz. That should be it?
Or is there a better, more preferred way, to edit xml data?
Posted: Thursday 13 October 2016 18:15
by cogliostrio
Gijs69 wrote:Dear cogliostrio,
Summary:
I now get 4 devices in domoticz. Teperature, thermostat mode, setpoint cooling 1 and setpoint dry air. None of the setpoints work.
Changing thermostat mode works, but if I set it to cooling, it locks the screen of my thermostat. Dry air setpoint shows zero, and wont accept any input, from either web or thermostat itself.
Looking at the engineering spec, it only mentions cooling "...if enabled..". Functionality spec mentions it "...in special model...". Connections schematic for my thermostats does not have any info on connections for cooling. This leads me to believe that cooling should be removed from config file all together, and is possibly included for a future hardware update(?)
I had to remove all cooling references in config file to make it work correctly again. I now have two setpoint which both work, heating and energy heat.
@admiral
If you are on the beta channel, just update your install. You can include it manually as well.
Multireg xml config must be located at this path
/domoticz/Config/thermofloor/heatit02.xml
Then update your manufacturer_specific.xml located here:
/domoticz/Config/manufacturer_specific.xml
Like this.
<Manufacturer id="019b" name="ThermoFloor AS">
<Product type="0001" id="0001" name="Heatit Thermostat TF 021" config="thermofloor/heatit021.xml"/>
</Manufacturer>
Posted: Friday 04 November 2016 14:11
by RomanDO
I have the same problem with thermostat. Could you give here your new xml file please?
Posted: Friday 04 November 2016 14:33
by oldsam
You can also check the most recent file in OpenZWave project:
https://github.com/domoticz/domoticz/bl ... tit021.xml
Posted: Tuesday 08 November 2016 14:22
by alexsh1
Mine is working fine with the above settings. zwcfg**** has to be corrected or the thermostat has to be excluded/included.
Posted: Friday 23 December 2016 10:50
by Ploegie
Hi Guys,
first of all thanks for all the sweat and tears, i am newbie on this.
I followed all the steps and it looks that the thermostat is working fine.
the only thing what is not working is the set-point value disappears after the input.
can any one tell me what i have to do, how to hold the set point on screen?
thanks
Posted: Thursday 02 March 2017 15:29
by tlpeter
Anybody succesfully included this thermostat with the Aeon labs S2 zwave stick?
I did read that it only works with the zwave + version.
I cannot get it included with the S2 version.
Posted: Friday 24 March 2017 12:26
by Underscore
I've got the same problem; including doesn't seem to work with Aeon Labs Z-Stick USB Adapter.
Does anyone have an idea or suggestion to solve this?
Posted: Friday 09 June 2017 12:33
by tlpeter
I now have the gen5 (zwave+) stick and i got the heatit thermostat working now.
One thing that won't work is setting it to eco with json. Should this still be 11?
Posted: Friday 09 June 2017 14:18
by tlpeter
Ok i found it.
Although the XML says you need 11 i tested it with 3 and then it went to ECO mode.
2 is still cooling but i do not have that option in the thermostat.
So now i use a selector switch with the buttons Off, On and Eco instead of the stupid Thermostat mode button which only shows which mode it is.
