Page 3 of 3
Re: MySensors S_RGB_LIGHT WS2812 ledstrip
Posted: Tuesday 16 August 2016 18:56
by Ritmeester
I’m sorry, but if I don’t understand or see it, than I get questions. Maybe it is simple, if you know HOW to make it, …. Yes than it is very simple.
I was really happy that I made a sketch with “wires” and that this is working with two (or more) mode’s. I have a little bit of programing experience.
I will see if I can figure out what is: 4 V_LIGHT
Posted: Tuesday 16 August 2016 19:05
by tlpeter
He means that you need to program 4 different "lights"
Read this page and see why it uses these names:
https://www.mysensors.org/download/serial_api_20
It defines which type to use like light is for light and V_TEMP orcourse for temperature.
Domoticz than knows which type of sensor is used.
Posted: Wednesday 17 August 2016 16:30
by Ritmeester
Thanks for your answers. But I still do not understand what kind of switch I have to make in my sketch.
This switch I have made:
- 2016-08-17_14-01-09.png (22.2 KiB) Viewed 12565 times
The mode buttons must change the pattern in the sketch.
How my “signals” from this Selector Switch will arrive in my node and the node is switching to a different pattern. (Mode)
Posted: Thursday 18 August 2016 19:24
by Ritmeester
Ok , I will go to a wired connection for my question to use the Selector Switch for my situation. Unfortunately it seems not be possible to send a self-chosen command (variable) to an Mysensors node to handle this. With Wires it works very well.
Can I “combine” two or more switches in a JSON command?
Example:
I have two switches with IDX 50 and 51. In one command I want to switch them off like this:
/json.htm?type=command¶m=switchlight&idx=50&switchcmd=Off
But then for two switches, or more in the same rule. Or can I make some group of switches to turn them off by one command?
Posted: Sunday 15 January 2017 23:21
by Flopp
Ritmeester wrote:I’m trying to get the sketch from gizmocuz to work with MySensors 2.0. I have made the necessary conversion from MySensors 1.5 to 2.0. It compiles without errors.
If I run the sketch the “SendColor2AllLEDs” works. And then it stops because I don’t get any information from Domoticz to this Node. So, Domoticz is not sending commands, or it is not receiving commands.
Maybe (pretty possible) that I have overlooked something but I don’t know what.
Sketch:
// PROJECT: MySensors / RGB test for Light & Sensor
// PROGRAMMER: AWI/GizMoCuz
// DATE: september 27, 2015/ last update: October 10, 2015
// LAST UPDATE: August 16, 2016 by Ritmeester
// FILE: AWI_RGB.ino
// LICENSE: Public domain
// Hardware: Nano and MySensors 2.0
// Special:
// uses Fastled library with NeoPixel (great & fast RBG/HSV universal library) https://github.com/FastLED/FastLED
// Remarks:
// Fixed node-id
// Added option to request/apply last light state from gateway
// Domoticz typicals - 2015 10 10:
// - Domoticz is using HUE values internally, there might be a slight difference then using direct RGB colors.
// Enable debug prints to serial monitor
// #define MY_DEBUG
// Enable and select radio type attached
#define MY_RADIO_NRF24
//#define MY_RADIO_RFM69
// Enable repeater functionality for this node
#define MY_REPEATER_FEATURE
#include <MySensors.h>
#include <SPI.h>
#include <FastLED.h>
#define LED_PIN 4 // Pin to connect WS2812B (strip)
#define NUM_LEDS 10
#define COLOR_ORDER GRB // It's GRB for WS2812B
#define LED_TYPE WS2812B // What kind of strip are you using (APA102, WS2801 or WS@2812B
#define NODE_ID 254 // fixed MySensors node id
#define CHILD_ID 0 // Child Id's
CRGB leds[NUM_LEDS];
char actRGBvalue[] = "000000"; // Current RGB value
uint16_t actRGBbrightness = 0xFF ; // Controller Brightness
int actRGBonoff = 0; // OnOff flag
MyMessage lastColorStatusMsg(CHILD_ID, V_VAR1);
void presentation() {
sendSketchInfo("AWI RGB Light", "1.1");
present(CHILD_ID, S_RGB_LIGHT); // present to controller
void setup() {
LEDS.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS); // Use this for WS2812B - initialize led strip
// Flash the "hello" color sequence: R, G, B, black.
colorBars();
//Request the last stored colors settings
request(CHILD_ID, V_VAR1);
void receive(const MyMessage &message) {
void loop() {
void colorBars()
SendColor2AllLEDs( CRGB::Red ); FastLED.show(); delay(500);
SendColor2AllLEDs( CRGB::Green ); FastLED.show(); delay(500);
SendColor2AllLEDs( CRGB::Blue ); FastLED.show(); delay(500);
SendColor2AllLEDs( CRGB::Black ); FastLED.show(); delay(500);
void SendColor2AllLEDs(const CRGB lcolor)
for (int i = 0 ; i < NUM_LEDS ; i++) {
leds[i] = lcolor;
void SendLastColorStatus()
String cStatus = actRGBvalue + String("&") + String(actRGBbrightness) + String("&") + String(actRGBonoff);
send(lastColorStatusMsg.set(cStatus.c_str()));
String getValue(String data, char separator, int index)
int found = 0;
int strIndex[] = {0, -1};
int maxIndex = data.length() - 1;
for (int i = 0; i <= maxIndex && found <= index; i++) {
if (data.charAt(i) == separator || i == maxIndex) {
found++;
strIndex[0] = strIndex[1] + 1;
strIndex[1] = (i == maxIndex) ? i + 1 : i;
return found > index ? data.substring(strIndex[0], strIndex[1]) : "";
void incomingMessage(const MyMessage &message) {
if (message.type == V_RGB) { // check for RGB type
actRGBonoff = 1;
strcpy(actRGBvalue, message.getString()); // get the payload
SendColor2AllLEDs(strtol(actRGBvalue, NULL, 16));
SendLastColorStatus();
else if (message.type == V_DIMMER) { // if DIMMER type, adjust brightness
actRGBonoff = 1;
actRGBbrightness = map(message.getLong(), 0, 100, 0, 255);
FastLED.setBrightness( actRGBbrightness );
else if (message.type == V_STATUS) { // if on/off type, toggle brightness
actRGBonoff = message.getInt();
FastLED.setBrightness((actRGBonoff == 1) ? actRGBbrightness : 0);
else if (message.type == V_VAR1) { // color status
String szMessage = message.getString();
strcpy(actRGBvalue, getValue(szMessage, '&', 0).c_str());
actRGBbrightness = atoi(getValue(szMessage, '&', 1).c_str());
actRGBonoff = atoi(getValue(szMessage, '&', 2).c_str());
FastLED.show();
I am using AWI and Gimoz example on 1.5.1 and it is working fine.
I only changed type to Dimmer and then clicked on the three cubes to see color wheel, as soon as I selected a color it changed on my LEDs.
I don't know how 2.x is working but don't you need gw.process( or equal) in LOOP?
Posted: Thursday 18 May 2017 15:22
by NiklasO
Nope. It will process automatically.
I am in the process to put up my ws2812b. Is there a sketch out there that works with 2.x or do I need to convert the older script?
Posted: Tuesday 23 May 2017 0:16
by NiklasO
Sketch for 2.x, working here. Add the new device, change to dimmer.
DATE: september 27, 2015/ last update: May 3, 2017
FILE: AWI_RGB.ino
Hardware: Nano and MySensors 2.x
Special:
Remarks:
Fixed node-id
Converted to work on 2.x
#define MY_DEBUG
#include <SPI.h>
const int stripPin = 4 ; // pin where 2812 LED strip is connected
const int numPixel = 25 ; // set to number of pixels
#define CHILD_ID 0 // Child id
CRGB leds[numPixel];
int actRGBonoff=0; // OnOff flag
MyMessage lastColorStatusMsg(CHILD_ID,V_VAR1);
void presentation()
sendSketchInfo("AWI RGB Light", "1.2");
void before() {
FastLED.addLeds<NEOPIXEL, stripPin >(leds, numPixel); // initialize led strip
colorBars();
void setup() {
void loop() {
void colorBars()
for(int i = 0 ; i < numPixel ; i++) {
leds[i] = lcolor;
String cStatus=actRGBvalue+String("&")+String(actRGBbrightness)+String("&")+String(actRGBonoff);
int found = 0;
int maxIndex = data.length()-1;
for(int i=0; i<=maxIndex && found<=index; i++){
if(data.charAt(i)==separator || i==maxIndex){
found++;
strIndex[0] = strIndex[1]+1;
strIndex[1] = (i == maxIndex) ? i+1 : i;
return found>index ? data.substring(strIndex[0], strIndex[1]) : "";
actRGBonoff=1;
actRGBonoff=1;
FastLED.setBrightness((actRGBonoff == 1)?actRGBbrightness:0);
else if (message.type==V_VAR1) { // color status
String szMessage=message.getString();
strcpy(actRGBvalue, getValue(szMessage,'&',0).c_str());
actRGBbrightness=atoi(getValue(szMessage,'&',1).c_str());
actRGBonoff=atoi(getValue(szMessage,'&',2).c_str());
FastLED.show();
Posted: Friday 14 July 2017 17:33
by sincze
Anything I should take in considiration to modify this great example to RGBWW strip ??
So I see normal values travelling to Mysensors like 000000 for RGB and 000000FF for white.
I am currently working from:
// Modified strandtest sketch to support also RGBW strips like SK6812 based:
// http://www.szledcolor.com/download/SK6812RGBW.pdf
// Should be used with Adafruit NeoPixel version 1.0.3
// Hacked by G. Knauf 2015-12-06
RGB is working however, still have some problems with the White Part. (it simply switches all leds off)
Posted: Sunday 23 July 2017 11:50
by sincze
I'll answer my own question
If the received color starts with '#'. It is white. Just modify that in the mysensor code and it works fine.
if (received_message.startsWith("#"))
color = WHITE_LED;
color = strtol(message.getString(), NULL, 16);
Posted: Wednesday 29 November 2017 20:04
by Flopp
This has been working for a long time now, but today I noticed one small thing, it is not problem.
If the LED is ON and I restart my node, the LED will turn on after restart but in DZ it shows that the LED is OFF.
I think it be OFF when the node is presenting the Child.
Posted: Wednesday 06 March 2019 22:19
by mickaelr30
since the update of domoticz in version 4.10157 I have a problem
I set the lighting of the leds every night at 18:30 and level at 25% in domoticz the order is well given but the brightness remains at 0 I am forced by imperihome to increase it.
do you have this problem?
thank you
