Mode-selector / multistate device
pepeEL
Re: Mode-selector / multistate device
Post by pepeEL »
Ahhh ok you use sctipt. But i use command to configure in GUI Domoticz which was implement some days ago.
Wysłane z mojego SM-G920F przy użyciu Tapatalka
cgaudry
Post by cgaudry »
Selector action shifting has been fixed a few minutes ago (waiting for compiling/merging)
pepeEL
Post by pepeEL »
jcjames13009
Domoticz version: 2023.2
Post by jcjames13009 »
Just discover an other issue. Selector switch shows only On/Off state in floor plan. Couldn't access levels selection :(
Hope this bug will be solved
Thanks in advance
JC
G3rard
Domoticz version: No
Post by G3rard »
cgaudry wrote:I'm still working on it :
- add a parameter to hide 'Off' "level" ;
- add an action to execute when a "level" is selected.
These features should be available next week.
Thanks for adding this!
Can you make it possible that the Off level is hidden when you tick the Hide Off level box, but that you can still use the icon of the switch to execute the off action? Currently that is not working.
I don't need the Off selector button if you can just press the icon to turn off the switch.
Not using Domoticz anymore
jcjames13009
@G3rard
I can switch it Off pressing the icon. Then I need to press corresponding level to change status. Icon has no more action when switch is Off. FYI, I run version 2.4031
JC
G3rard
Post by G3rard »
I am on 2.4192. That version has an option to not show the Off button. But if you do that then the icon cannot be used to switch it off. So you either have 2 off options or none.
My suggestion is that you can hide the Off button, but use the icon to execute the Off command.
jcjames13009
Ok clear.
I believed you were still using V2.4026 from your profile :?
JC
Toni
Post by Toni »
Nice work, I've used the mode selector on my heatpump / air conditioner control: viewtopic.php?f=34&t=7179#p69647
Eduard
Post by Eduard »
What's is the roadmap for adding notifications for this Selector-switch? Now the only options are on/off. I'd like to get a notification when for example Level1 is selected.
wizzard72
Post by wizzard72 »
Can I use this mode-selector / multistate device to define a few dimlevels like low, medium, high?
Number8
Domoticz version: 2022.1
Post by Number8 »
This has been a long awaited function, http://www.domoticz.com/forum/tracker.php?p=2&t=81
Thanks a lot.
- Would it possible to have On/Off http or script actions within the switch interface extented to all level actions. It would allow to trigger actions depending on the level selected without having to setup a blocky event. Currently, I wonder what is the use of the On action?
- Would it be possible to edit the Off string in order to match what the user wants?
Debian buster on NUC and three RPi with buster.
remb0
Post by remb0 »
I habve 4 ventilation buttons programma like the screenshot:
they send an on command, and after a second an off.
so the nodemcu with easy esp pushed a button on a remote to set it ON (like I pressed the remote controller) and after that it goes the same for the off command.
1=on 0 is off.
2016-01-22 23_18_56-Domoticz.png (175.08 KiB) Viewed 7944 times
when I will use only my selector I have to make an lua like:
if  (devicechanged['Fan'] == 'Off') then
   commandArray['FAN - Manual']='Off'
print('Fan op stand 0')
if  (devicechanged['Fan'] == "_1" ) then
commandArray[1]={['OpenURL']='192.168.0.60/control?cmd=GPIO,13,1' }
commandArray[2]={['OpenURL']='192.168.0.60/control?cmd=GPIO,13,0' }
print('Fan op stand 1')
if (devicechanged['Fan'] == '_2' ) then
    print('Fan gaat op stand 2')
commandArray[3]={['OpenURL']='192.168.0.60/control?cmd=GPIO,12,1' }
commandArray[4]={['OpenURL']='192.168.0.60/control?cmd=GPIO,12,0' }
print('Fan op stand 2')
if (devicechanged['Fan'] == '_3') then
commandArray[5]={['OpenURL']='192.168.0.60/control?cmd=GPIO,14,1' }
commandArray[6]={['OpenURL']='192.168.0.60/control?cmd=GPIO,14,0' }
print('Fan op stand 3')
if (devicechanged['Fan'] == '_4') then
commandArray[7]={['OpenURL']='192.168.0.60/control?cmd=GPIO,15,1' }
commandArray[8]={['OpenURL']='192.168.0.60/control?cmd=GPIO,15,0' }
print('Fan op stand 4')
But when I press the selector the lua won't push my buttons.
what's wrong here?
I thought I had it working this way before, but not sure anymore..
I hope I do something wrong, but an action like on/off as in a normal switch (with off delay) would be better then a lua I think. Is this possible?
2016-01-22 23_23_25-Domoticz.png (733.05 KiB) Viewed 7944 times
Eduard
Post by Eduard »
Eduard wrote:What's is the roadmap for adding notifications for this Selector-switch? Now the only options are on/off. I'd like to get a notification when for example Level1 is selected.
I've implemented Notifications for Selector-Switch :)
Pull-request has been made, waiting to be merged...
StephaneG
Post by StephaneG »
I have updated to current beta (4298), and my selector switches no longer work: selecting any level no longer activates the blocky events, nor changes the level in the selector switch itself.
I have created a new test selector, with everything set per defaults, doesnt work either.
Let me know if I can help to test/fix.
Regards,
Stéphane
TiXav
Post by TiXav »
I have updated to current beta (4298) too, and my selector switches no longer work too (same as Stephane)
selecting any level no longer activates Lua script_device_xxxx
I have created a new test selector, with everything set per defaults, doesnt work either. (same as Stephane)
I cannot control my heating anymore, oups
Regards,
Xavier
ben92
Post by ben92 »
hi,
same here with v2.4298
mKotek
Post by mKotek »
ben92 wrote:hi,
I think, a couple of confirmations is enough, but yes, I can confirm - it does not work for me any longer as well (direct http actions from selector levels).
Michal 'Kotek', greetings from Poland. Zapraszam na mój blog o automatyce domowej po polsku: http://www.ukotka.com.
pluggin
Post by pluggin »
StephaneG wrote:Hello,
Regards,
Stéphane
I cant figure out how to create a sensor with selector. Don't found that option.
My Domoticz is V2.3530
Razberry + 4 Eversrping HSM02 + 2 Aeotec Multi-Sensor + 1 Aeotec Micro Dimmer + 4 Aeotec Micro Smart Energy Switch, 2nd + 1 Remotec ZXT-120 + 1 Aeotec Smart Energy Monitor + 1 Everspring SE812 indoor Siren + 2 fibaro motion sensor + Aeotec water sensor
JacquesMulders
Post by JacquesMulders »
Works in v 2.4312 :)
