Page 3 of 4
Re: Air quality sensor not added
Posted: Sunday 13 March 2016 19:48
by Flopp
I restarted node but I don't get any new sensor. I will contact a pc so I can see what it write as debug
Posted: Sunday 13 March 2016 20:02
by Flopp
Should I use V_LEVEL and S_DUST?
Posted: Sunday 13 March 2016 20:03
by gizmocuz
Yes
Please have a look at the code
Posted: Sunday 13 March 2016 20:04
by Flopp
Ok.
I have not change the code so it must be something in Domotics.
I get OK in DEBUG but that only means that GW received it.
I see CO2 in Domoticz LOG so I have connection between node and Domoticz
Posted: Sunday 13 March 2016 20:08
by Flopp
I have CO2 and DUST sensor in this node
Posted: Sunday 13 March 2016 20:12
by Flopp
I also cleared the EEPROM so I get new Node ID from Domoticz and it is still same thing, only CO2 appear
Posted: Monday 14 March 2016 8:17
by gizmocuz
That wont work, you can either present the node as S_AIR_QUALITY or as S_DUST, and not both
Both types also use the same V_LEVEL
Posted: Monday 14 March 2016 8:54
by Flopp
Ok, so it must be one sensor for each node?
Posted: Monday 14 March 2016 9:08
by gizmocuz
In this case, yes, else we dont know what type of 'node' you made...
Of course you can combine a temp sensor and a dust sensor if you want...
Posted: Monday 14 March 2016 9:19
by Flopp
Ok. Then I will try to change my code and only have one sensor.
Posted: Monday 14 March 2016 9:32
by gizmocuz
Sorry, i was wrong here...
You should be able to have multiple sensors in 1 node, but you have to present the child's correct
Like:
present(CHILD_ID_AIRQ, S_AIR_QUALITY);
present(CHILD_ID_DUST, S_DUST);
Posted: Monday 14 March 2016 9:33
by Flopp
I am doing that.
Posted: Monday 14 March 2016 20:56
by Flopp
Any possible error in Domoticz you think?
by gizmocuz
Need to check.... Could take some days
by Flopp
Ok no worries
Posted: Tuesday 15 March 2016 9:11
by gizmocuz
Found the issue... really strange, some code i added, was lost in an commit....
There is a new beta available #4965, it should now work (tested with a mysensor...)
Posted: Tuesday 15 March 2016 22:59
by Flopp
WOW
It is working and i really like the Custom Sensor.
Thank you, thank you
Posted: Wednesday 16 March 2016 8:18
by gizmocuz
Great to hear, thanks for the feedback!
Posted: Friday 18 March 2016 21:50
by JacquesMulders
is it also possible to add it as a dummy sensor?
Posted: Saturday 19 March 2016 9:07
by gizmocuz
JacquesMulders wrote:is it also possible to add it as a dummy sensor?
Yes, Custom Sensor it is called
