Air quality sensor not added
Flopp
Re: Air quality sensor not added
Post by Flopp »
I restarted node but I don't get any new sensor. I will contact a pc so I can see what it write as debug
Flopp
Post by Flopp »
Should I use V_LEVEL and S_DUST?
gizmocuz
Post by gizmocuz »
Yes
Please have a look at the code
Flopp
Post by Flopp »
Ok.
I have not change the code so it must be something in Domotics.
I get OK in DEBUG but that only means that GW received it.
I see CO2 in Domoticz LOG so I have connection between node and Domoticz
Flopp
Post by Flopp »
I have CO2 and DUST sensor in this node
Flopp
Post by Flopp »
I also cleared the EEPROM so I get new Node ID from Domoticz and it is still same thing, only CO2 appear
gizmocuz
Post by gizmocuz »
That wont work, you can either present the node as S_AIR_QUALITY or as S_DUST, and not both
Both types also use the same V_LEVEL
Flopp
Post by Flopp »
Ok, so it must be one sensor for each node?
gizmocuz
Post by gizmocuz »
In this case, yes, else we dont know what type of 'node' you made...
Of course you can combine a temp sensor and a dust sensor if you want...
Flopp
Post by Flopp »
Ok. Then I will try to change my code and only have one sensor.
gizmocuz
Post by gizmocuz »
Sorry, i was wrong here...
You should be able to have multiple sensors in 1 node, but you have to present the child's correct
Like:
present(CHILD_ID_AIRQ, S_AIR_QUALITY);
present(CHILD_ID_DUST, S_DUST);
Flopp
Post by Flopp »
I am doing that.
Flopp
Post by Flopp »
Any possible error in Domoticz you think?
gizmocuz
Post by gizmocuz »
Need to check.... Could take some days
Flopp
Post by Flopp »
Ok no worries
gizmocuz
Post by gizmocuz »
Found the issue... really strange, some code i added, was lost in an commit....
There is a new beta available #4965, it should now work (tested with a mysensor...)
Flopp
Post by Flopp »
WOW
It is working and i really like the Custom Sensor.
Thank you, thank you
gizmocuz
Post by gizmocuz »
Great to hear, thanks for the feedback!
JacquesMulders
Post by JacquesMulders »
is it also possible to add it as a dummy sensor?
gizmocuz
Post by gizmocuz »
JacquesMulders wrote:is it also possible to add it as a dummy sensor?
Yes, Custom Sensor it is called
