How to install Domoticz on a Synology NAS
jumbotroll
Re: How to install Domoticz on a Synology NAS
Post by jumbotroll »
greuh wrote: Great !
I had indeed to remove also /var/packages/UsbSerialDrivers
Thanks a lot.
I am now trying to see if I can use domoticz with my Aeotec USB stick.
Should it be detected automatically ?
Try to do a dmesg and look if the stick is detected.
Sometimes you have to restart synology or only domoticz, but different solution has worked 8-)
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
greuh
Post by greuh »
Well, I tried the 4.2 package you compiled, without and with the USB serial drivers.
For both, I rebooted the NAS after installation, before to plug the USB stick.
I still have the same error message, and nothing is added to dmesg.
I will install a Windows version of domoticz on my laptop tomorrow and test if the key is working. Maybe I have a hardware problem...
I do not know if it make sense, but once plugged, the USB stick blinks as follow:
blue (1 sec) - off (0.5 sec) - almost white (1 sec) - off (0.5 sec) - red (1 sec) - off (0.5 sec) - ...
greuh
Post by greuh »
I installed Domoticz on a recent Windows 7.
Then ran domoticz.
Then plugged the stick.
The Aeotec GEN5 USB stick is still not recognized.
I can see this window for long:
and finnaly I had the message 'no driver found".
Before to return the ley to seller, can you confirm that it should be detected automatically? Should I do something I missed?
jumbotroll
greuh wrote:I installed Domoticz on a recent Windows 7.
Then ran domoticz.
I also have the blinking on my Z-stick Gen5, so i think this is normal.
I don't use Windows, so I tested to install domoticz on my Windows 10 in parallels and z-stick Gen5 working ok :)
It is detected as COM3
Jumbotroll
Last edited by jumbotroll on Friday 11 December 2015 11:57, edited 1 time in total.
Jumbotroll
jumbotroll
I did not install any drivers, but you can download drivers here:
Z-Stick Gen5 Drivers and Tools
http://aeotec.com/z-wave-usb-stick/1358 ... ivers.html
Jumbotroll
Jumbotroll
greuh
Post by greuh »
Yeah !
Windows 8 and 10 does not need any additional driver.
But Windows 7 does.
So I installed this driver, and I could finally install the stick on Windows.
Domoticz can now see it !
Well, it is not such a good news, it means I miss something on my Synology...
Even if I do not have the needed kernel module, I should see a new message in dmesg when plugging in the stick. Right?
I did not find the "lspci" command on my DSM-4.2. Is there an equivalent command?
jumbotroll
On my DS712+ Z-Stick Gen5 using cdc-acm driver.
cdc_acm 5-1:1.0: ttyACM1: USB ACM device.
I have compiled domoticz_88f6281-4.3_2.0.3780-7.spk for you to test including cdc-acm driver.
http://jadahl.dscloud.me/sspks/packages ... 3780-7.spk
Jumbotroll
Jumbotroll
greuh
Post by greuh »
Thanks again :)
I uninstalled the older one and installed this one.
I didn't know if I should keep the serial drivers, so I kept them.
It was still not recognized.
I uninstalled the serial drivers with no more success.
Here is the output of dmesg when plugging in the stick (without serial drivers here):
[25024.060000] usb 1-1.2: USB disconnect, address 4
[25024.300000] usb 1-1.2: new high speed USB device using orion-ehci and address 6
[25024.410000] Got empty serial number. Generate serial number from product.
[25024.420000] usb 1-1.2: configuration #1 chosen from 1 choice
[25024.460000] hub 1-1.2:1.0: USB hub found
[25024.460000] hub 1-1.2:1.0: 4 ports detected
[25024.760000] usb 1-1.2.4: new full speed USB device using orion-ehci and address 7
[25024.890000] Got empty serial number. Generate serial number from product.
[25024.900000] usb 1-1.2.4: configuration #1 chosen from 1 choice
[25024.910000] cp210x 1-1.2.4:1.0: ch341-uart converter detected
[25024.950000] cp210x: probe of 1-1.2.4:1.0 failed with error -5
[25024.950000] pl2303 1-1.2.4:1.0: ch341-uart converter detected
[25025.000000] pl2303: probe of 1-1.2.4:1.0 failed with error -5
[25025.000000] ch341 1-1.2.4:1.0: ch341-uart converter detected
[25025.050000] ch341: probe of 1-1.2.4:1.0 failed with error -5
[25025.050000] cp210x 1-1.2.4:1.1: ch341-uart converter detected
[25025.100000] cp210x: probe of 1-1.2.4:1.1 failed with error -5
[25025.110000] pl2303 1-1.2.4:1.1: ch341-uart converter detected
[25025.220000] pl2303: probe of 1-1.2.4:1.1 failed with error -5
[25025.220000] ch341 1-1.2.4:1.1: ch341-uart converter detected
[25025.280000] ch341: probe of 1-1.2.4:1.1 failed with error -5
jumbotroll
I'm out of ideas why this does not work on your NAS .
Do you use USB Hub ?
If so, test without USB Hub .
Jumbotroll
Jumbotroll
greuh
Post by greuh »
jumbotroll wrote:I'm out of ideas why this does not work on your NAS .
Jumbotroll
I do not use USB hub.
There is only a brand new 10m USB cable between the NAS and the key.
I tried without it at the beginning, but my last attempts were made with it. Maybe can I try again without this cable.
After some readings, it seems that I should see a ttyACMx in the port list when I select OpenZwave USB.
I understand that the last package you provided includes USB ACM driver, but the package is compiled for DSM-4.3. Can't it be a problem?
Isn't there some other logs I may gather to understand what happens?
jumbotroll
There may be conflict if you use both UsbSerialDrivers and domoticz package with drivers .
Delete both packages and restart NAS .
Then install only this package including cdc-acm driver :domoticz_88f6281-4.2_2.0.3798-7.spk http://jadahl.dscloud.me/sspks/packages ... 3798-7.spk
In the info center on NAS should also see the devices attached to NAS.
USBDevice - Sigma Design, Inc. is my z-stick.
FT232 USB-Serial. is my RFXCOM
HL-340 is my RFLink
Jumbotroll
Last edited by jumbotroll on Saturday 12 December 2015 16:56, edited 1 time in total.
Jumbotroll
greuh
Post by greuh »
jumbotroll wrote:There may be conflict if you use both UsbSerialDrivers and domoticz package with drivers .
HL-340 is my RFLink
Jumbotroll
OK, i have uninstalled, rebooted, installed this new one, and rebooted (never know...).
I have to wait to be home to unplug and plug the stick and test. I do not have remote access to domoticz yet.
However I have checked my information center, and I can see the Sigma Design USB device. I believe... :D
greuh
Post by greuh »
I did the same without the stick plugged.
Uninstall package
reboot
install the new package (domoticz_88f6281-4.2_2.0.3798-7.spk)
reboot
start domoticz
Plug the zstick
Still no /dev/ttyAMC device in the "serial port" list.
Only /dev/ttyUSB0 to /dev/ttyUSB7. None of them is working.
Something prevents the stick from being viewed by domoticz :cry:
greuh
Post by greuh »
I also uninstalled any other (non-related) packages on my Synology (sabnzbd, sab2, perl, python).
Reinstalled domoticz as above, but still the same result.
The Stick is seen by the DSM, but not by Domoticz :evil:
jumbotroll
greuh wrote:I also uninstalled any other (non-related) packages on my Synology (sabnzbd, sab2, perl, python).
Sorry, but I have No idea why this is not working on your NAS.
Can you check if you have: /usr/local/domoticz/rules.d
60-synocommunity.domoticz.rules
#rules for USB ACM serial devices
KERNEL=="ttyACM*", ACTION=="add", MODE="0666"
KERNEL=="ttyUSB*", ACTION=="add", MODE="0666"
Jumbotroll
Jumbotroll
greuh
Post by greuh »
jumbotroll wrote: Sorry, but I have No idea why this is not working on your NAS.
Jumbotroll
Yes, I have exactly that content in /usr/local/domoticz/rules.d/60-synocommunity.domoticz.rules
As a last try, I will give a try with the package from synocommunity, which is quite old. We will see if there is any difference...
jumbotroll
The old package from synocommunity does not support OpenZWave.
Can you check if you have this modules:
/lib/modules/usbserial.ko and
/lib/modules/ftdi_sio.ko
If you run lsmod
The last line should show something like this:
usbcore 176292 17 ch341,snd_usb_hiface,snd_usb_audio,snd_usbmidi_lib,cdc_acm,pl2303,cp210x,ftdi_sio,usbserial,usbhid,usblp,usb_storage,etxhci_hcd,xhci_hcd,ehci_pci,ehci_hcd,uhci_hcd
usb_common 1488 1 usbcore
Jumbotroll
Jumbotroll
greuh
Post by greuh »
jumbotroll wrote:The old package from synocommunity does not support OpenZWave.
If you run lsmod
Jumbotroll
I have the modules installed, but I am not sure if my usbscore module is used by the expected modules:
DiskStation> ls /lib/modules/ | grep "usbserial\|ftdi"
ftdi_sio.ko
usbserial.ko
DiskStation>
DiskStation> lsmod | tail
dm_snapshot 21948 0
crc_itu_t 1043 1 udf
crc_ccitt 1065 0
quota_v2 2651 2
quota_tree 6676 1 quota_v2
usbcore 141170 13 ch341,pl2303,cp210x,ftdi_sio,usbserial,usbhid,usblp,usb_storage,etxhci_hcd,xhci_hcd,ohci_hcd,ehci_hcd
sg 21260 0
psnap 1655 0
llc 3178 1 psnap
ipv6 238252 58
DiskStation>
Thanks a lot (again)
Greuh
edit:
I also add the usbserial module usage:
DiskStation> lsmod | grep usbserial
usbserial 25216 4 ch341,pl2303,cp210x,ftdi_sio
jumbotroll
I think you are missing cdc_acm.
Try this: insmod /lib/modules/cdc-acm.ko
Jumbotroll
Jumbotroll
greuh
Post by greuh »
jumbotroll wrote:I think you are missing cdc_acm.
Jumbotroll
Indeed...
DiskStation> insmod /lib/modules/cdc_acm.ko
insmod: can't insert '/lib/modules/cdc_acm.ko': No such file or directory
DiskStation> find /lib/modules/ | grep cdc
/lib/modules/cdc_ether.ko
DiskStation>
Users browsing this forum: Varazir and 1 guest
