[DIY] Garden irrigation and learning project
Siewert308SW
Domoticz version: Stable
Re: [DIY] Garden irrigation and learning project
Post by Siewert308SW »
I think i should put this in the wiki.
It is going out of hand... :D
Latest additions and changes:
Version 0.5
- MaxRainFall changed, it is now a average of your desired "Buienradar" max rain fall input to prevent the switch to flip flop
- Optimized Moist sensor script as it now triggers irrigation on a minimum value and shutsdown on a maximum value
- Added extra loggin option
- Added option to use Buienradar or not
- Added option to use Dutch or English translation
This script is still in BETA as i just wrote it and haven't fully tested it.
Be aware that i'm not a coder and it's maybe the cleanest script ever, but who cares as it works ;-)
I hope it can be of use to you and feel free to adapt it.
Bug fixes, patches, and improvements are hapiliy accepted of course.
Same counts for LUA optimizations as this is the first time i wrote,copy/past a LUA script.
When i started this i didn't had a clue what i was doing ;-)
	script_time_irrigation.lua
	@author: Siewert Lameijer
	@since: 2015-06-30
	@version: 0.5 (BETA)
	@Garden Irrigation lua script
Credits:
- Nicky Bulthuis -/- for the dusk sensor script
- Hans van der Heijden -/- for the IsItGonnaRain script
- anonymous user -/- for the "Reading weather station data" script
- dannybloe -/- for Humidity Control script
- And to all those who i forgot to mention
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
This script has the intention to control and maintain your garden soil humidity.
And is it is a hodgepodge of different scripts found on the Domoticz forum.
I wrote this script for my own little garden project and to beable to automate irrigation while i'm gone.
The topic can be found here: https://www.domoticz.com/forum/viewtopic.php?f=38&t=6904
Somehow it got out of hand and got big.
So i thought that maybe some of you could have a benefith of this.
Although the script is intended for irrigation.
You could adapt it for other projects.
I do assume that when you want to use this script you already have the knowhow of Lua and Domoticz.
As i won't explain the entire installation ;-)
The script does the following:
- It scraps WeatherUnderground data and processing it usable data
- It monitors buienradar (optional) to see if there are any showers upcoming 24hr
- It scraps temperature and humidity from your moist sensor and processing it usable data
- It lets you choose when (Day of the week, month and time of the day) to irrigate
- By an extensive Settings Menu you can set various settings to control when to irrigate
settings ranges from: Min/Max Temp, Min/Max Humidity pct, Amount of rain, wind, UV, day, month to stop or start irrigating.
The Hardware i use:
- DIY Garden irrigation piping as seen in the topic
- Washer 220v Watervalve 2-way
- KaKu ACM-3500-3 3-in-1 unit (controlling the 2 valves) 1 reserve for pond protector to scare the cats ;-)
Siewert Lameijer
Necessities:
1x Virtual switch to be able to manual override the irrigation program (Manual Override)
1x Soil Moist & Humidity sensor
1x Active WeatherUnderground account
1x Switch to be able to control your waterpump/valve which is somehow wireless connected to domoticz
1x Garden with irrigation hardware xD
The following UserVariable have to be create:
- VarManOverride (type=integer, value=0)
- VarTimeCon (type=integer, value=0)
- VarWeatherCon (type=integer, value=0)
- VarTimeOfDayCurrent (type=integer, value=0)
- VarMayFollowProgram (type=integer, value=0)
- VarFollowsProgram (type=integer, value=0)
- VarMaxRunTime (type=integer, value=0)
- VarMoistOnline (type=integer, value=0)
- VarMoistOnlineHum (type=integer, value=0)
- VarMoistConTemp (type=integer, value=0)
- VarMoistConHum (type=integer, value=0)
- VarProgramOverride (type=integer, value=0)
- VarProgramRun (type=integer, value=0)
- VarTimeFrame (type=integer, value=0)
- VarManOverrideCon (type=integer, value=0)
- VarBuienRadarCon (type=integer, value=0)
- VarTimeFrameMon (type=integer, value=0)
Changelog:
Version 0.5
- Buienradar MaxRainFall changed, it is now a average of your desired max rain fall input to prevent the switch to flip flop
Version 0.4
- Changed Days, Months to text instead of numbers as input
- Optimized irrigation program ending and keeping it that until the next time schedule
Version 0.3
- Added Buienradar (IsItGonnaRain) script
- Optimized Max irrigation time script
- Clean some code
- Reorderd printed text
Version 0.2
- Added counter for Max irrigation time
- Added manual override
- Optimized WeatherUnderground scraping data
- Optimized Moist sensor scraping data
- Optimized user input Time Of The Day, Days and Months
Version 0.1
- Added WeatherUnderground and scraping data
- Added Moist sensor scraping Temp & Humidity data
- Added Moist sensor online check
- Added user input for Time Of The Day where irrigation may start
- Added user input for days and months where the irrigation may start
time = os.date("*t")
-- Settings Begin
-- Set your desired language (English, Dutch)
local lang = 'Dutch'
-- Lua script interval check, change the number 1 to every desired number in minutes
-- Logging:
-- 0 = None
-- 1 = Only critical
-- 2 = All
local logging = 2
-- Location and minimum Rain Fall Variables For BuienRadar
-- Do you want to use BuienRadar? Yes or No
local Buienradar = 'No' --(Dutch weather, rain prediction)
-- Set your location by adding Lat/Lon
local lat = '53.338023'
local lon = '6.303114'
-- Set your minimum rain fall for in a periode of 24hr
local  VarMaxRainFall = '20'
-- WeatherUnderGround Variables
-- Name of your Weatherstation widget which contains humidity,uv,temp and pressure
local weatherstation = 'Barometer'
-- Name of your Weatherstation Wind widget
local wind = 'Wind'
-- Name of your Weatherstation Rain widget
local rain = 'Regenmeter'
-- Name of your Weatherstation UV widget
local uv = 'UV'
-- Switches and Virtual Switches Variables
-- Name of your manual override virtual switch
local VitManOverride = 'Irrigatie Manual Override'
-- Name of your irrigation switch for water valve/pump
local VarPump = 'Irrigatie 1 Check'
-- Moist Sensor Variables
-- Name of your Moist Sensor device
local MoistSensor = 'Vocht Sensor (border 1)'
-- Your target soil humidity percentage
local VarTarHum = '80'
-- Your minumim soil humidity percentage from which the irrigation will start
local VarMinHum = '55'
-- Your Minumum soil temperature, Lower won't trigger irrigation
local VarTarTempMin = '12'
-- Your Maximum soil temperature, Higher won't trigger irrigation
local VarTarTempMax = '25'
-- Amount of minuten/times we want to switch OFF irrigation after the program has started.
local VarMaxRunTime_off = 60
-- Day, Month and Time Variables
-- Set your desired TimeOfDay for irrigation (Morning=0, Afternoon=1, Evening=2 or Night=3)
local VarTimeOfDay = '2'
-- Set your desired irrigation day, leave blank for no irrigation
-- Set Mon, Tue, Wed, Thu, Fri, Sat or Sun
local VarDay1 = 'Mon'
local VarDay2 = ''
local VarDay3 = 'Wed'
local VarDay4 = ''
local VarDay5 = 'Fri'
local VarDay6 = ''
local VarDay7 = 'Sun'
-- Set your desired irrigation month, leave blank for no irrigation,
-- Set months like: Jan, Feb, Apr, May, Jun, Jul, Aug, Sep, ect ect
local VarMonth1 = ''
local VarMonth2 = ''
local VarMonth3 = ''
local VarMonth4 = 'Apr'
local VarMonth5 = 'May'
local VarMonth6 = 'Jun'
local VarMonth7 = 'Jul'
local VarMonth8 = 'Aug'
local VarMonth9 = 'Sep'
local VarMonth10 = ''
local VarMonth11 = ''
local VarMonth12 = ''
-- Weather Variables
-- Set your prefered max rain fall, higher won't trigger irrigation
local RainCurrent = '0'
-- Set your prefered minimum outside temperature for irrigation, Lower won't trigger irrigation
local WeatherTempMin = '13'
-- Set your prefered maximum outside temperature for irrigation, Higher won't trigger irrigation
local WeatherTempMax = '24'
-- Set your prefered maximum UV for irrigation, Higher won't trigger irrigation
local UVMax = '4'
-- Set your prefered max windspeed km/h, higher won't trigger irrigation
local WindSpeed = '50'
-- Set your prefered max windgust km/h, higher won't trigger irrigation
local WindGust = '150'
-- Settings END
--> Don't edit anything below this line or you could break the script!
    week       = tonumber(os.date("%V"));
	month       = tostring(os.date("%b"));
    dayno       = tonumber(os.date("%d"));
    dayofweekno = tonumber(os.date("%w"));
    day       = tostring(os.date("%a"));
    hour       = tonumber(os.date("%H"));
    min       = tonumber(os.date("%M"));
-- Scrapping Weather Data from WeatherUnderground
-- Weatherstation data:
sWeatherTemp, sWeatherHumidity, sWeatherUV, sWeatherPressure, sWeatherUV2 = otherdevices_svalues[weatherstation]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
sWeatherTemp = tonumber(sWeatherTemp);
sWeatherHumidity = tonumber(sWeatherHumidity);
sWeatherUV = tonumber(sWeatherUV);
sWeatherPressure = tonumber(sWeatherPressure);
sWeatherUV2 = tonumber(sWeatherUV2);
	if logging == 1 then
		print("--------------------------------------------------------------------------------------")
		if lang == 'Dutch' then
		print("Irrigatie [HET WEER]");
		print("-- Irrigatie ==> [WeerStation] - Temperatuur: " .. sWeatherTemp .. " ");
		print("Irrigation [WEATHER]");
		print("-- Irrigation ==> [WeatherStation] - Temperature: " .. sWeatherTemp .. " ");
	if logging >= 2 then
		print("-- Irrigatie ==> [WeerStation] - Luchtvochtigheid: " .. sWeatherHumidity .. " ");
		print("-- Irrigatie ==> [WeerStation] - Barometer: " .. sWeatherPressure .. " ");
		print("-- Irrigation ==> [WeatherStation] - Humidity: " .. sWeatherHumidity .. " ");
		print("-- Irrigation ==> [WeatherStation] - Pressure: " .. sWeatherPressure .. " ");
-- Windmeter data:
sWindDirectionDegrees, sWindDirection, sWindSpeed, sWindGust, sWindTemperature, sWindFeel = otherdevices_svalues[wind]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
sWindDirectionDegrees = tonumber(sWindDirectionDegrees);
sWindDirection = (sWindDirection);
sWindSpeed = tonumber(sWindSpeed);
sWindGust = tonumber(sWindGust);
sWindTemperature = tonumber(sWindTemperature);
sWindFeel = tonumber(sWindFeel);
		print("-- Irrigatie ==> [Windmeter] - Windsnelheid: " .. sWindSpeed .. " ");
		print("-- Irrigatie ==> [Windmeter] - Windvlaag: " .. sWindGust .. " ");
		print("-- Irrigation ==> [Windmeter] - Windspeed is: " .. sWindSpeed .. " ");
		print("-- Irrigation ==> [Windmeter] - Windgust is: " .. sWindGust .. " ");
		print("-- Irrigatie ==> [Windmeter] - Windrichting (in graden): " .. sWindDirectionDegrees .. " ");
		print("-- Irrigatie ==> [Windmeter] - Windrichting: " .. sWindDirection .. " ");
		print("-- Irrigatie ==> [Windmeter] - Windtemperatuur: " .. sWindTemperature .. " ");
		print("-- Irrigatie ==> [Windmeter] - Gevoelstemperatuur: " .. sWindFeel .. " ");
		print("-- Irrigation ==> [Windmeter] - Winddirection (in degrees) is: " .. sWindDirectionDegrees .. " ");
		print("-- Irrigation ==> [Windmeter] - Winddirection is: " .. sWindDirection .. " ");
		print("-- Irrigation ==> [Windmeter] - Windtemperature is: " .. sWindTemperature .. " ");
		print("-- Irrigation ==> [Windmeter] - Windfeel is: " .. sWindFeel .. " ");
-- Rainmeter data:
sRainmeterCurrent, sRainmeterTotal = otherdevices_svalues[rain]:match("([^;]+);([^;]+)")
sRainmeterCurrent = tonumber(sRainmeterCurrent);
sRainmeterTotal = tonumber(sRainmeterTotal);
		print("-- Irrigatie ==> [Regenmeter] - Regenval nu: " .. sRainmeterCurrent .. " ");
		print("-- Irrigatie ==> [Regenmeter] - Totale Regenval: " .. sRainmeterTotal .. " ");
		print("-- Irrigation ==> [Rainmeter] - Actual rain is: " .. sRainmeterCurrent .. " ");
		print("-- Irrigation ==> [Rainmeter] - Total rain is: " .. sRainmeterTotal .. " ");
-- UV data:
sUV, sSolar = otherdevices_svalues[uv]:match("([^;]+);([^;]+)")
sUV = tonumber(sUV);
sSolar = tonumber(sSolar);
	if logging >= 1 then
		print("-- Irrigatie ==> [UV] - UV Sterkte: " .. sUV .." ");
		print("-- Irrigation ==> [UV] - UV Strength is: " .. sUV .." ");
if  sRainmeterCurrent >= tonumber (RainCurrent)
	and sWeatherTemp >= tonumber (WeatherTempMin)
	and sWeatherTemp <= tonumber (WeatherTempMax)
	and sUV <= tonumber (UVMax)
	and sWindSpeed <= tonumber (WindSpeed)
	and sWindGust <= tonumber (WindGust)
then
		print("-- Irrigatie ==> [HET WEER] - Weer conditie lijkt goed om te irrigeren");
		print("-- Irrigation ==> [WEATHER] - Weather conditions are looking good and ready for irrigation");
	if(uservariables['VarWeatherCon'] == 0) then
	commandArray['Variable:VarWeatherCon']= '1'
		print("-- Irrigatie [INFO] ==> Weer conditie lijkt niet goed voor irrigatie");
		print("-- Irrigation [INFO] ==> Weather conditions aren't good for irrigation");
	if(uservariables['VarWeatherCon'] == 1) then
	commandArray['Variable:VarWeatherCon']= '0'
-- Scrapping Temparature and moist humidity from moist sensor
-- Moist Sensor data:
    smoistsensorTemp, smoistsensorHumidity = otherdevices_svalues[MoistSensor]:match("([^;]+);([^;]+);([^;]+)")
    smoistsensorTemp = tonumber(smoistsensorTemp);
    smoistsensorHumidity = tonumber(smoistsensorHumidity);
		print("Irrigatie [GROND CONDITIE]");
		print("-- Irrigatie ==> [VochtSensor] - Grond Temperatuur: " .. smoistsensorTemp .. " ");
		print("-- Irrigatie ==> [VochtSensor] - Grond Vochtigheid: " .. smoistsensorHumidity .. " ");
		print("Irrigation [SOIL CONDITION]");
		print("-- Irrigation ==> [MoistSensor] - Soil Temperature: " .. smoistsensorTemp .. " ");
		print("-- Irrigation ==> [MoistSensor] - Soil Humidity: " .. smoistsensorHumidity .. " ");
-- Moist Sensor online check
if (smoistsensorTemp == 0 or smoistsensorTemp == nil) then
    print('-- Irrigatie ==> [VochtSensor] - [ERROR] Vocht sensor geeft een temperatuur aan van 0 of nil, irrigatie word gestaakt')
    print('-- Irrigation ==> [MoistSensor] - [ERROR] Moist Sensor reports Temp is 0 or nil. Skipping Irrigation')
	if(uservariables['VarMoistOnline'] == 1) then
	commandArray['Variable:VarMoistOnline']= '0'
	if(uservariables['VarMoistOnline'] == 0) then
	commandArray['Variable:VarMoistOnline']= '1'
if (smoistsensorHumidity <= 6 or smoistsensorHumidity >= 99 or smoistsensorHumidity == nil) then
    print('-- Irrigatie ==> [VochtSensor] - [Error] ==> Vocht sensor geeft een verkeerde vochtigheids waarde aan,, irrigatie word gestaakt')
    print('-- Irrigation ==> [MoistSensor] - [Error] ==> Moist Sensor reports wrong Humidity values. Skipping Irrigation')
	if(uservariables['VarMoistOnlineHum'] == 1) then
	commandArray['Variable:VarMoistOnlineHum']= '0'
	if(uservariables['VarMoistOnlineHum'] == 0) then
	commandArray['Variable:VarMoistOnlineHum']= '1'
-- Checking Grond Temperature Conditions
if 	smoistsensorTemp >= tonumber (VarTarTempMin)
	and smoistsensorTemp <= tonumber (VarTarTempMax)
then
		print("-- Irrigatie ==> [VochtSensor] - Grond temperatuur is goed voor irrigatie");
		print("-- Irrigation ==> [MoistSensor] - Soil Temp conditions are fine for irrigation");
	if(uservariables['VarMoistConTemp'] == 0) then
	commandArray['Variable:VarMoistConTemp']= '1'
	print("-- Irrigatie ==> [VochtSensor] - Grond temperatuur is niet goed voor irrigatie");
	print("-- Irrigation ==> [MoistSensor] - Soil Temp conditions aren't good for irrigation");
	if(uservariables['VarMoistConTemp'] == 1) then
	commandArray['Variable:VarMoistConTemp']= '0'
if 	smoistsensorTemp <= tonumber (VarTarTempMin)
then
		print("-- Irrigatie ==> [VochtSensor] - Grond temperatuur is te laag...");
		print("-- Irrigation ==> [MoistSensor] - Soil Temp is to low...");
if 	smoistsensorTemp >= tonumber (VarTarTempMax)
then
		print("-- Irrigatie ==> [VochtSensor] - Grond temperatuur is te hoog...");
		print("-- Irrigation ==> [MoistSensor] - Soil Temp is to high...");
-- Checking Grond Humidity Conditions
if smoistsensorHumidity >= tonumber (VarMinHum) or smoistsensorHumidity <= tonumber (VarTarHum) or smoistsensorHumidity >= tonumber (VarTarHum)
then
		print("-- Irrigatie ==> [VochtSensor] - Grond vochtigheid is goed, geen irrigatie nodig");
		print("-- Irrigation ==> [MoistSensor] - Soil humidity is fine and doesn't need irrigation");
	if(uservariables['VarMoistConHum'] == 1) then
	commandArray['Variable:VarMoistConHum']= '0'
if smoistsensorHumidity <= tonumber (VarMinHum)
then
		print("-- Irrigatie ==> [VochtSensor] - Grond is droog...");
		print("-- Irrigation ==> [MoistSensor] - Soil is dry...");
	if(uservariables['VarMoistConHum'] == 0) then
	commandArray['Variable:VarMoistConHum']= '1'
if smoistsensorHumidity >= tonumber (VarTarHum)
then
		print("-- Irrigatie ==> [VochtSensor] - Grond is nat...");
		print("-- Irrigation ==> [MoistSensor] - Soil is wet...");
-- Checking Buienradar
if Buienradar == 'Yes' then
		print("Irrigatie [BUIENRADAR]");
    tempfilename = '/var/tmp/rain.tmp'
    totalrain = 0
    rainlines = 0
   function IsItGonnaRain( minutesinfuture )
       url='http://gps.buienradar.nl/getrr.php?lat='..lat..'&lon='..lon
       read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
       file = io.open(tempfilename, "r")
       while true do
          line = file:read("*line")
          if not line then break end
          linetime=string.sub(tostring(line), 5, 9)
          linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
          difference = os.difftime (linetime2,os.time())
          if ((difference > 0) and (difference<=minutesinfuture*60)) then
             rain=tonumber(string.sub(tostring(line), 0, 3))
             totalrain = totalrain+rain
             rainlines=rainlines+1
       file:close()
       averagerain=totalrain/rainlines
       return(averagerain)
    function round(num, idp)
       local mult = 10^(idp or 0)
       return math.floor(num * mult + 0.5) / mult
-- Is it gonna rain for the upcoming 24hr YES/NO
local VarMaxRainFallPlus = VarMaxRainFall * 0.5 + VarMaxRainFall
       minutes=1440
       RainPrediction = IsItGonnaRain(minutes)
       RainmmHour=10^((RainPrediction-109)/32)
       if RainPrediction >= tonumber (VarMaxRainFallPlus) then
          verw = 3
		  if (uservariables['VarBuienRadarCon']) == 1  then
		  commandArray['Variable:VarBuienRadarCon']= '0'
			print('-- Irrigatie ==> [REGEN] - Verwacht '..RainPrediction..' binnen 24 uur.')
          verw = 2
		  if (uservariables['VarBuienRadarCon']) == 0  then
		  commandArray['Variable:VarBuienRadarCon']= '1'
			print('-- Irrigatie ==> [REGEN] - Geen of weinig regen verwacht binnen 24 uur.')
-- Checking Time Frame
		print("Irrigatie [TIMEFRAME]");
		print("Irrigation [TIMEFRAME]");
if day == VarDay1 or day == VarDay2 or day == VarDay3 or day == VarDay4 or day == VarDay5 or day == VarDay6 or day == VarDay7
	then
		print(os.date("-- Irrigatie ==> [TimeFrame] - Vandaag is het %A en aangemerkt als irrigatie dag"))
	print(os.date("-- Irrigation ==> [TimeFrame] - Today is %A and it is a irrigation day"))
		print('-- Irrigatie ==> [TimeFrame] - Ingeroosterde dagen: '..VarDay1..'  '..VarDay2..'  '..VarDay3..'  '..VarDay4..'  '..VarDay5..'  '..VarDay6..'  '..VarDay7..'')
		print('-- Irrigation ==> [TimeFrame] - Scheduled days are: '..VarDay1..'  '..VarDay2..'  '..VarDay3..'  '..VarDay4..'  '..VarDay5..'  '..VarDay6..'  '..VarDay7..'')
	if(uservariables['VarTimeFrame'] == 0) then
	commandArray['Variable:VarTimeFrame']= '1'
		print(os.date("-- Irrigatie ==> [TimeFrame] - Vandaag is het %A en niet aangemerkt als irrigatie dag"))
		print(os.date("-- Irrigation ==> [TimeFrame] - Today is %A and isn't a scheduled irrigation day"))
	if(uservariables['VarTimeFrame'] == 1) then
	commandArray['Variable:VarTimeFrame']= '0'
if month == VarMonth1 or month == VarMonth2	or month == VarMonth3 or month == VarMonth4 or month == VarMonth5 or month == VarMonth6 or month == VarMonth7 or month == VarMonth8 or month == VarMonth9 or month == VarMonth10 or month == VarMonth11 or month == VarMonth12
then
		print(os.date("-- Irrigatie ==> [TimeFrame] - Vandaag is het een dag in %B, en deze maand is aangemerkt als irrigatie maand"))
		print(os.date("-- Irrigation ==> [TimeFrame] - Today is a day in %B, and is scheduled for irrigation"))
		print('-- Irrigatie ==> [TimeFrame] - Ingeroosterde maanden: '..VarMonth1..'  '..VarMonth2..'  '..VarMonth3..'  '..VarMonth4..'  '..VarMonth5..'  '..VarMonth6..'  '..VarMonth7..' '..VarMonth8..' '..VarMonth9..' '..VarMonth10..' '..VarMonth11..' '..VarMonth12..'')
		print('-- Irrigation ==> [TimeFrame] - Scheduled months are: '..VarMonth1..'  '..VarMonth2..'  '..VarMonth3..'  '..VarMonth4..'  '..VarMonth5..'  '..VarMonth6..'  '..VarMonth7..' '..VarMonth8..' '..VarMonth9..' '..VarMonth10..' '..VarMonth11..' '..VarMonth12..'')
	if(uservariables['VarTimeFrameMon'] == 0) then
	commandArray['Variable:VarTimeFrameMon']= '1'
			print(os.date("-- Irrigatie ==> [TimeFrame] - Vandaag is het een dag in %B, en deze maand is niet aangemerkt als irrigatie maand"))
			print(os.date("-- Irrigation ==> [TimeFrame] - Today is a day in %B, and isn't scheduled for irrigation"))
	if(uservariables['VarTimeFrameMon'] == 1) then
	commandArray['Variable:VarTimeFrameMon']= '0'
-- checking time of the day so irrigation may proceed
	if (time.hour >= 6) and (time.hour <= 11) then
		if  (uservariables['VarTimeOfDayCurrent'] ~= 0) then
				commandArray['Variable:VarTimeOfDayCurrent']= '0'
	if (time.hour >= 12) and (time.hour <= 19)then
		if (uservariables['VarTimeOfDayCurrent'] ~= 1) then
			commandArray['Variable:VarTimeOfDayCurrent']= '1'
	if (time.hour >= 20) and (time.hour <= 23)then
		if (uservariables['VarTimeOfDayCurrent'] ~= 2) then
			commandArray['Variable:VarTimeOfDayCurrent']= '2'
	if (time.hour >= 0) and (time.hour <= 5)then
		if (uservariables['VarTimeOfDayCurrent'] ~= 3) then
			commandArray['Variable:VarTimeOfDayCurrent']= '3'
	if (uservariables['VarTimeOfDayCurrent']) == tonumber (VarTimeOfDay) then
		print("-- Irrigatie ==> [TimeFrame] - Dit dagdeel komt overeen met jouw voorkeurs dagdeel voor irrigatie")
		print("-- Irrigation ==> [TimeFrame] - Time of the Day matches your desired irrigation value")
	if (uservariables['VarTimeCon']) == 0 then
	commandArray['Variable:VarTimeCon']= '1'
if (uservariables['VarTimeOfDayCurrent']) ~= tonumber (VarTimeOfDay) then
		print("-- Irrigatie ==> [TimeFrame] - Dit dagdeel komt niet overeen met jouw voorkeurs dagdeel")
		print("-- Irrigation ==> [TimeFrame] - Time of the Day doesnt match your criteria.")
		print('-- Irrigatie ==> [TimeFrame] - Programma wacht op het geschikte dagdeel')
		print('-- Irrigation ==> [TimeFrame] - Waiting for the right Time of the Day')
	if (uservariables['VarTimeCon']) == 1 then
	commandArray['Variable:VarTimeCon']= '0'
		print("Irrigatie [PROGRAMMA]");
		print("Irrigation [Program]");
-- Giving the irrigation program a Go or NoGo
if Buienradar == Yes then
		and (uservariables['VarTimeFrame']) == 1
		and (uservariables['VarTimeFrameMon']) == 1
		and (uservariables['VarWeatherCon']) == 1
		and (uservariables['VarMoistOnline']) == 1
		and (uservariables['VarMoistOnlineHum']) == 1
		and (uservariables['VarMoistConTemp']) == 1
		and (uservariables['VarBuienRadarCon']) == 1
	then
		print("-- Irrigatie [Condities] ==> Alle condities lijken goed, en het irrigatie programma mag vervolgt worden")
		print("-- Irrigation [Conditions] ==> All conditions seems to be okay, Irrigation may if needed continue program")
	if (uservariables['VarMayFollowProgram']) == 0
    then
		commandArray['Variable:VarMayFollowProgram']= '1'
		print("-- Irrigatie [Condities] ==> Niet alle condities lijken goed, en het irrigatie programma mag niet vervolgt worden")
		print("-- Irrigation [Conditions] ==> Not all conditions seems to be okay, Irrigation may NOT continue program")
	if (uservariables['VarMayFollowProgram']) == 1
    then
		commandArray['Variable:VarMayFollowProgram']= '0'
	then
    then
    then
-- Irrigatie Program Active
	and (uservariables['VarProgramRun']) == 0
	and (uservariables['VarProgramOverride']) == 0
	and (uservariables['VarManOverrideCon']) == 0
	then
if (uservariables['VarFollowsProgram']) == 0 then
	commandArray['Variable:VarFollowsProgram']= '1'
		print("-- Irrigatie [Programma] ==> Irrigatie Programma Geactiveerd...")
		print("-- Irrigatie [Programma] ==> Irrigatie pomp zal spoedig starten...")
		print("-- Irrigation [Program] ==> Irrigation Program Activated.")
		print("-- Irrigation [Program] ==> Irrigation pump will start in a minute...")
-- Irrigatie stopped after a full runtime cycle
if (uservariables['VarProgramRun']) == 1
	and (uservariables['VarProgramOverride']) == 1
then
		print("-- Irrigatie [Programma] ==> Irrigatie Gestopt, Pomp heeft de maximale looptijd overschreden...")
		print("-- Irrigatie [Programma] ==> Wachten op een nieuwe TimeFrame...")
		print("-- Irrigation [Program] ==> Irrigation Stopped, Maximum RunTime Exceeded...")
		print("-- Irrigation [Program] ==> Awaiting new TimeFrame...")
-- New timeframe so irrigation reactivated
	and (uservariables['VarMayFollowProgram']) == 0
	then
if (uservariables['VarProgramOverride']) == 1 then
	commandArray['Variable:VarProgramOverride']= '0'
		commandArray['Variable:VarProgramRun']= '0'
		print("-- Irrigatie [Programma] ==> Irrigatie Programma Gereactiveerd...")
-- Irrigatie stoppen, Regen Verwacht
local VarMaxRainFallAv = VarMaxRainFallPlus * 0.5 + VarMaxRainFall
if (uservariables['VarBuienRadarCon']) == 1 and (uservariables['VarProgramRun']) == 1 and RainPrediction >= tonumber (VarMaxRainFallAv)
	then
if (uservariables['VarProgramOverride']) == 0 then
	commandArray['Variable:VarProgramOverride']= '1'
	commandArray['Variable:VarMaxRunTime']= '-1000'
	commandArray[VarPump]='Off'
		print("-- Irrigatie [Programma] ==> Irrigatie Programma gestopt, Regen Verwacht...")
-- Irrigatie stopped as the moist humidity exceed your desired value
	then
		print("-- Irrigatie [Programma] ==> Irrigatie Programma Gestopt, Grond vochtigheid heeft zijn maximale waarde behaald...")
		print("-- Irrigation [Program] ==> Irrigation Program Stopped, Moist Humidity exceeded your desired value...")
-- Irrigatie stoppen, Manual Override
if otherdevices[VitManOverride] == 'On'
	then
	commandArray['Variable:VarManOverrideCon']= '1'
	and (uservariables['VarManOverrideCon']) == 1
	then
		print("-- Irrigatie [Programma] ==> Irrigatie Programma Manueel gestopt!")
		print("-- Irrigation [Program] ==> Irrigation Program Stopped, Manual Override")
if otherdevices[VitManOverride] == 'Off'
	then
	commandArray['Variable:VarFollowsProgram']= '0'
	commandArray['Variable:VarManOverrideCon']= '0'
		print("-- Irrigatie [Programma] ==> Irrigatie Programma Gereactivated!")
		print("-- Irrigation [Program] ==> Irrigation Program Reactivated, Manual Override OFF")
-- Irrigatie Counter MaxRunTime and validate check
-- Debug logging.
function debug(msg)
		print('-- Irrigatie [DEBUG] ==> ' .. msg)
		print('-- Irrigation [DEBUG] ==> ' .. msg)
-- Info logging.
function info(msg)
		print('-- Irrigatie [Programma] ==> ' .. msg)
		print('-- Irrigation [Program] ==> ' .. msg)
-- Error logging.
function error(msg)
	print('-- Irrigatie [ERROR] ==> ' .. msg)
	print('-- Irrigation [ERROR] ==> ' .. msg)
-- Validates the configuration
function validate()
	result = true
	if not (uservariables['VarMaxRunTime']) then
		error('Gebruikers Variable [' .. VarMaxRunTime .. '] bestaat niet.')
		error('User Variable [' .. VarMaxRunTime .. '] doesnt exist.')
		result = false
	if not otherdevices[VarPump] then
		error('Apparaat [' .. VarPump .. '] bestaat niet.')
		error('Device [' .. VarPump .. '] doesnt exist.')
		result = false
	if not (uservariables['VarFollowsProgram']) then
		error('Gebruikers Variable [' .. VarFollowsProgram .. '] bestaat niet.')
		error('User Variable [' .. VarFollowsProgram .. '] doesnt exist.')
	result = false
	return result
-- Tests if irrigation may start.
function may_update(VarIsPump)
	counter = (uservariables['VarMaxRunTime'])
	current_counter = counter
	-- set the counter.
	if VarIsPump and counter >= 0 then
		counter = math.min(1, counter + 1)
	elseif not VarIsPump and counter <= 0 then
		counter = math.max(VarMaxRunTime_off * -1, counter - 1)
		counter = 0
	if counter ~= current_counter then
		commandArray['Variable:VarMaxRunTime']= tostring(counter)
	result = false
	if VarIsPump and counter >= 1 then
		result = true
	elseif not VarIsPump and math.abs(counter) >= VarMaxRunTime_off then
		result = true
	return result
-- Start irrigation
function on_off(VarIsPump)
	update_allowed = may_update(VarIsPump)
	info('Irrigatie Pomp = [' .. otherdevices[VarPump] .. ']')
	info('Irrigation Pump = [' .. otherdevices[VarPump] .. ']')
	if update_allowed then
		if otherdevices[VarPump] == 'Off' and VarIsPump then
 			commandArray[VarPump]='On'
			commandArray['Variable:VarProgramRun']= '1'
		elseif (otherdevices[VarPump] == 'On' and not VarIsPump) then
-- Is Irrigatie  On.
function is_VarFollowsProgram_aan()
	result = false
	result = (uservariables['VarFollowsProgram'] == 1)
    return result
-- Starting Irrigatie
if validate() then
	on_off(is_VarFollowsProgram_aan())
	if logging >= 1 and (uservariables['VarMayFollowProgram']) == 0
		and (uservariables['VarFollowsProgram']) == 0
	then
		print("-- Irrigatie [Standby] ==> Irrigatie Programma op Standby.")
		print("-- Irrigation [Standby] ==> Irrigation Program on Standby")
	if logging >= 1 and (uservariables['VarMayFollowProgram']) == 1
	then
		print("-- Irrigatie [Standby] ==> Er is al geirrigeerd vandaag, Irrigatie Programma op Standby.")
		print("-- Irrigation [Standby] ==> Already Irrigated today, Irrigation Program on Standby and awaiting new cycle")
THE END!
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
Siewert308SW
Version 0.6
- Optimized reset switches
- Added new UserVariable for be sure a irrigation cycle has complete ( VarProgramHasRun (type=integer, value=0) )
- Fixed some issues with Manual Override
- Added extra lines to show in log if you enabled manual override
	@since: 2015-06-30
	@version: 0.6 (BETA)
Credits:
The Hardware i use:
Siewert Lameijer
Necessities:
- VarProgramHasRun (type=integer, value=0)
Changelog:
Version 0.6
Version 0.5
Version 0.4
Version 0.3
- Clean some code
Version 0.2
Version 0.1
-- Settings Begin
-- Logging:
-- 0 = None
-- 2 = All
local logging = 2
local wind = 'Wind'
local uv = 'UV'
local VarDay2 = ''
local VarDay4 = ''
local VarDay6 = ''
local UVMax = '4'
-- Settings END
-- Irrigation Script Begin
local VarMaxRunTimeReset = VarMaxRunTime
		print("-- Irrigatie [HET WEER]");
		print("-- Irrigation [WEATHER]");
-- Windmeter data:
-- Rainmeter data:
-- UV data:
then
		print("-- Irrigatie [GROND CONDITIE]");
		print("-- Irrigation [SOIL CONDITION]");
then
then
then
then
then
then
		print("-- Irrigatie [BUIENRADAR]");
    totalrain = 0
    rainlines = 0
       while true do
       file:close()
       return(averagerain)
       minutes=1440
          verw = 3
          verw = 2
		print("-- Irrigatie [TIMEFRAME]");
		print("-- Irrigation [TIMEFRAME]");
	then
then
		print("-- Irrigation ==> [TimeFrame] - Time of the Day doesnt match your criteria")
		print("-- Irrigatie [Programma]");
		print("-- Irrigation [Program]");
	then
    then
    then
	then
    then
    then
	then
		print("-- Irrigation [Program] ==> Irrigation Program Activated")
then
	and (uservariables['VarProgramHasRun']) == 1
	then
	commandArray['Variable:VarProgramHasRun']= '0'
		print("-- Irrigatie [Program] ==> Irrigation Program Reactivated...")
	and (uservariables['VarProgramHasRun']) == 0
	then
if (uservariables['VarBuienRadarCon']) == 1 and (uservariables['VarProgramRun']) == 1 and RainPrediction >= tonumber (VarMaxRainFallAv) and (uservariables['VarManOverrideCon']) == 0
	then
	commandArray['Variable:VarMaxRunTime']= VarMaxRunTimeReset
	and (uservariables['VarProgramRun']) == 1 and (uservariables['VarManOverrideCon']) == 0
	then
	commandArray['Variable:VarProgramHasRun']= '1'
	then
	then
	then
-- Debug logging.
function debug(msg)
-- Info logging.
function info(msg)
-- Error logging.
function error(msg)
function validate()
	result = true
		result = false
		result = false
	result = false
	return result
	-- set the counter.
		counter = 0
	result = false
		result = true
		result = true
	return result
-- Start irrigation
-- Is Irrigatie  On.
	result = false
    return result
if validate() then
	if(uservariables['VarProgramHasRun']) == 1
	then
		print("-- Irrigatie [Standby] ==> Irrigatie Programma op Standby")
	then
		print("-- Irrigatie [Standby] ==> Er is al geirrigeerd vandaag, Irrigatie Programma op Standby")
	then
THE END!
Setup:
- DS923+ Docker
blackdog65
Post by blackdog65 »
Nice work!
I showed my wife your project and compared it to ours... she now wants to know if a PiCam can spot Greenfly and activate an insecticide sprayer :shock: I think she was joking :?
I've had pressure problems and thought it was all because I'm pumping water from a 2000L water butt and not from mains. So maybe it's really the valve to blame. I did think about using central heating motorised valves... but it then gets expensive
http://www.screwfix.com/p/flomasta-2790 ... alve/8982g
£45 each... and I need 4 eeeek!!! :o I'm glad I tried that green hose I showed you, it really works well.
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Siewert308SW
blackdog65 wrote:Nice work!
Thx...
Ha Ha... It could but needs a perfect and flawless recognition software :mrgreen:
What about a submersible pump and big enough to feed 4 hoses at the same time, or do you want to be able switch them separately?
Such a submersible pump cost less and has enough power.
8000l/h
https://www.conrad.nl/nl/renkforce-vuil ... 34026.html
Setup:
- DS923+ Docker
blackdog65
Hmmmm.... that's exactly the pump I have. It must have a valve of some type or it will syphon all the water over night when it's switched off. And it looks like the valve is the pressure limiter. Maybe the 2-port valve is the answer.
If I spend any more money on this... it would be cheaper to employ a Polish guy with a watering can :lol:
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Siewert308SW
blackdog65 wrote:Hmmmm.... that's exactly the pump I have. It must have a valve of some type or it will syphon all the water over night when it's switched off. And it looks like the valve is the pressure limiter. Maybe the 2-port valve is the answer.
LoL... Maybe i should call the Labor Office :lol:
I came home earlier due to the outside heat.
No way i'm going to be at a camping with 39 degrees, But i rebuild the irrigation this morning.
As the Valve was a 2way and i wanted to use one port for a different purpose when i started this project.
I now divide the 2 border sections.
Instead of 1 12mtr section with different tabs to each plant.
I now have 2 sections with different tabs to each plant.
1 section is 5mtr and the other 6mtr.
This solved my problem and now i do have enough pressure on both hoses.
Save me some more money to spent on a trail and error adventure ;)
Setup:
- DS923+ Docker
JacquesMulders
Post by JacquesMulders »
nice work!
I'm also making irrigation in my garden.
i've bin looking at your script, what a monster :oops: :D .
but how do you look if there is rain coming in the next 24 hours? buienradar only supplies coming 2 hours... when i use the link in your script...
keep up the good work!
Siewert308SW
JacquesMulders wrote:Hi,
nice work!
Thx...
As for buienradar, good question.
Never looked at how far Buienradar was sending data about upcoming rain.
Just had a look at what the script produced in the form of data.
And indeed, it only produces 2hr of info.
So 24hr is useless...
Have to think what i'm going to do with this script.
As for the irrigation script it self.
I'm completly rebuilding it.
There where/found some issues regarding overrides and the runmaxtime.
Couldn't find the culprit so rebuilding and testing every step to make sure it does work this time.
The issue is that in some cases the irrigation goes in a continues loop or after one cycle it will never turn on again.
Setup:
- DS923+ Docker
Siewert308SW
Rebuild and added some new features to the script...
Version 0.7
- Rewrote script due to a issue for which i couldn't find the culprit
- Reduced the amount of uservariables
- Some UserVariables have been renamed
- Fixed Soil Humidity scrap script
- Fixed MaxRunTime Counter
- Changed Buienradar prediction to 2hr as this is the max by Buienradar it self
- Optimized Manual pump start
- Optimized displayed text in log regarding the running program and it's doings
- Fixed program stop when target humidity has been reached
- Fixed TimeOfTheDay schedule
- Added counter to log to see how long the irrigation program is still active until shutdown
- Added code to check when the moist sensor was last seen, if longer then 10minuten then no irrigation
   @since: 2015-07-12
   @version: 0.7 (BETA)
Credits:
Be aware that using this script for the first time it may take awhile before irrigation script has collected all the data.
The Hardware i use:
Siewert Lameijer
Necessities:
- VarMoistHumCon (type=integer, value=0)
- VarMoistLastSeen (type=integer, value=0)
- VarMoistTempCon (type=integer, value=0)
- VarProgram (type=integer, value=0)
- VarProgramStopHum (type=integer, value=0)
- VarScheduledDays (type=integer, value=0)
- VarScheduledMonths (type=integer, value=0)
- VarScheduledTOD (type=integer, value=0)
- VarScheduledTODcurrent (type=integer, value=0)
Changelog:
Version 0.7
- Added MoistSensor Last Seen Check (max last seen is set to 10min)
Version 0.6
Version 0.5
Version 0.4
Version 0.3
- Clean some code
Version 0.2
Version 0.1
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-]]
-- Settings Begin
local lang = 'English'
-- Logging: 0 = None, 1 = Little Bit, 2 = All
local logging = 2
-- Water Valve/Pump Variables
local VarIsPump = 'Irrigatie 1 Check'
-- Max minuten/times we want to switch OFF irrigation after the program has started.
local VarMaxRunTime = 15
-- Virtual Switches Variables
-- WeatherUnderGround Settings
local wind = 'Wind'
local uv = 'UV'
-- WeatherUnderground Variables
local RainMax = '0'
local WeatherTempMax = '25'
local UVMax = '6'
-- BuienRadar Location and minimum Rain Fall Variables
local Buienradar = 'Yes' --(Dutch weather, rain prediction)
local  VarMaxRainFall = '100'
local MoistSensor = 'Vocht Sensor (border Zijkant)'
local VarTarHum = '50'
local VarMinHum = '40'
local VarTarTempMax = '30'
-- Scheduled Days
local VarTimeOfDay = '1'
local VarDay2 = 'Tue'
local VarDay4 = 'Thu'
local VarDay6 = 'Sat'
-- Scheduled Months
-- Settings End
	print('-- Irrigatie [HET WEER]');
	print('-- Irrigation [WEATHER]');
-- WeatherStation data:
		print("-- Irrigatie ==> [WeerStation] - Vochtigheid: " .. sWeatherHumidity .. " ");
-- Windmeter data:
		print("-- Irrigation ==> [Windmeter] - Windspeed: " .. sWindSpeed .. " ");
		print("-- Irrigation ==> [Windmeter] - Windgust: " .. sWindGust .. " ");
		print("-- Irrigation ==> [Windmeter] - Winddirection (in degrees): " .. sWindDirectionDegrees .. " ");
		print("-- Irrigation ==> [Windmeter] - Winddirection: " .. sWindDirection .. " ");
		print("-- Irrigation ==> [Windmeter] - Windtemperature: " .. sWindTemperature .. " ");
		print("-- Irrigation ==> [Windmeter] - Windfeel: " .. sWindFeel .. " ");
-- Rainmeter data:
		print("-- Irrigatie ==> [Regenmeter] - Actuele regenval: " .. sRainmeterCurrent .. " ");
		print("-- Irrigatie ==> [Regenmeter] - Totale regenval: " .. sRainmeterTotal .. " ");
-- UV data:
	print("-- Irrigation ==> [UV] - UV Strength: " .. sUV .." ");
if  sRainmeterTotal >= tonumber (RainMax)
then
	print("-- Irrigatie ==> [WEER INFO] - Weer conditie lijkt goed voor irrigatie");
	print("-- Irrigation ==> [WEATHER INFO] - Weather conditions are looking good and ready for irrigation");
	print("-- Irrigatie ==> [WEER INFO] - Weer conditie lijkt NIET goed voor irrigatie");
	print("-- Irrigation [WEATHER INFO] ==> Weather conditions aren't good for irrigation");
		print("-- Irrigation [BUIENRADAR]");
    totalrain = 0
    rainlines = 0
       while true do
       file:close()
       return(averagerain)
-- Is it gonna rain for the upcoming 2hr YES/NO
       minutes=120
       if RainPrediction >= tonumber (VarMaxRainFall) then
          verw = 3
			print('-- Irrigation ==> [REGEN] - ['..RainPrediction..'] regen verwacht binnen 2uur')
          verw = 2
			print('-- Irrigatie ==> [REGEN] - Geen of weinig regen verwacht binnen 2uur')
-- MoistSensor Scrapping Temparature and humidity
		print("-- Irrigatie [GROND CONDITIES]");
-- Checking Soil Temperature Conditions
then
		print("-- Irrigation ==> [MoistSensor] - Soil temperatuur is fine for irrigation");
	if(uservariables['VarMoistTempCon'] == 0) then
	commandArray['Variable:VarMoistTempCon']= '1'
elseif 	smoistsensorTemp <= tonumber (VarTarTempMin) then
		print("-- Irrigatie ==> [VochtSensor] - Grond temperatuur is te laag");
		print("-- Irrigation ==> [MoistSensor] - Soil Temperature is to low");
		if(uservariables['VarMoistTempCon'] == 1) then
		commandArray['Variable:VarMoistTempCon']= '0'
elseif	smoistsensorTemp >= tonumber (VarTarTempMax) then
		print("-- Irrigatie ==> [VochtSensor] - Grond temperatuur is te hoog");
		print("-- Irrigation ==> [MoistSensor] - Soil Temperature is to high");
-- Checking Soil Humidity Conditions
	and smoistsensorHumidity <= tonumber (VarTarHum)
then
		print("-- Irrigation ==> [MoistSensor] - Soil Humidity conditions are fine, no irrigation required");
	if(uservariables['VarMoistHumCon'] == 1) then
	commandArray['Variable:VarMoistHumCon']= '0'
elseif 	smoistsensorHumidity <= tonumber (VarMinHum) then
		print("-- Irrigatie ==> [VochtSensor] - Grond vochtigheid is te laag");
		print("-- Irrigation ==> [MoistSensor] - Soil humidity is to low");
		if(uservariables['VarMoistHumCon'] == 0) then
		commandArray['Variable:VarMoistHumCon']= '1'
elseif	smoistsensorHumidity >= tonumber (VarTarHum) then
		print("-- Irrigatie ==> [VochtSensor] - Grond vochtigheid is te hoog");
		print("-- Irrigation ==> [MoistSensor] - Soil humidity is to high");
	print("-- Irrigatie ==> [VochtSensor] - [ERROR] Vochtsensor geeft een temperatuur aan van 0 of nil");
    print('-- Irrigation ==> [MoistSensor] - [ERROR] Moist Sensor reports Temp is 0 or nil')
if (smoistsensorHumidity <= 6 or smoistsensorHumidity == nil) then
	print("-- Irrigatie ==> [VochtSensor] - [ERROR] Vochtsensor geeft een vochtigheid aan van 0 of nil");
    print('-- Irrigation ==> [MoistSensor] - [ERROR] ==> Moist Sensor reports wrong Humidity values')
-- Moist Sensor Last Seen Check
t1 = os.time()
s = otherdevices_lastupdate[MoistSensor]
	year = string.sub(s, 1, 4)
	month = string.sub(s, 6, 7)
	day = string.sub(s, 9, 10)
	hour = string.sub(s, 12, 13)
Moist = (os.difftime (t1, t2))
if (Moist > 600) then
print('--')
	print('--')
	print('-- Irrigatie ==> [VochtSensor] - [ERROR] Vochtsensor '..Moist..' Seconden geleden voor het laatste gezien')
	print('-- Irrigatie ==> [VochtSensor] - Dat is te lang geleden om een betrouwbaar beeld te vormen')
	print('--')
	print('-- Irrigation ==> [MoistSensor] - [ERROR] MoistSensor last seen '..Moist..' seconds ago')
	print('-- Irrigation ==> [MoistSensor] - Thats too long ago to be reliable')
	if(uservariables['VarMoistLastSeen'] == 1) then
	commandArray['Variable:VarMoistLastSeen']= '0'
	print('-- Irrigatie ==> [VochtSensor] - Vochtsensor '..Moist..' Seconden geleden voor het laatste gezien')
	print('-- Irrigation ==> [MoistSensor] - MoistSensor last seen '..Moist..' seconds ago')
	if(uservariables['VarMoistLastSeen'] == 0) then
	commandArray['Variable:VarMoistLastSeen']= '1'
-- Retrieve Date & Time
-- Checking Scheduled Days
   print('-- Irrigatie [ROOSTER]')
   print('-- Irrigation [TIMEFRAME]')
	then
	print(os.date("-- Irrigatie ==> [Rooster] - Vandaag is het %A en jouw ingeroosterde voorkeurs irrigatie dag"))
	print(os.date("-- Irrigation ==> [Scheduled Days] - Today is %A and it is your desired scheduled day"))
	print('-- Irrigatie ==> [Rooster] - Ingeroosterde dagen: '..VarDay1..'  '..VarDay2..'  '..VarDay3..'  '..VarDay4..'  '..VarDay5..'  '..VarDay6..'  '..VarDay7..'')
	print('-- Irrigation ==> [Scheduled Days] - Scheduled days: '..VarDay1..'  '..VarDay2..'  '..VarDay3..'  '..VarDay4..'  '..VarDay5..'  '..VarDay6..'  '..VarDay7..'')
	if(uservariables['VarScheduledDays'] == 0) then
	commandArray['Variable:VarScheduledDays']= '1'
	print(os.date("-- Irrigatie ==> [Rooster] - Vandaag is het %A en is NIET jouw ingeroosterde voorkeurs irrigatie dag"))
		print(os.date("-- Irrigation ==> [Scheduled Days] - Today is %A and it is NOT your desired scheduled day"))
		print('-- Irrigation ==> [Scheduled Days] - Scheduled days are: '..VarDay1..'  '..VarDay2..'  '..VarDay3..'  '..VarDay4..'  '..VarDay5..'  '..VarDay6..'  '..VarDay7..'')
	if(uservariables['VarScheduledDays'] == 1) then
	commandArray['Variable:VarScheduledDays']= '0'
-- Scheduled Months
then
		print(os.date("-- Irrigatie ==> [Rooster] - Vandaag is het en dag in %B, en jouw ingeroosterde voorkeurs irrigatie maand"))
		print(os.date("-- Irrigation ==> [Scheduled Months] - Today is a day in %B, and is scheduled for irrigation"))
		print('-- Irrigatie ==> [Rooster] - Ingeroosterde maanden: '..VarMonth1..'  '..VarMonth2..'  '..VarMonth3..'  '..VarMonth4..'  '..VarMonth5..'  '..VarMonth6..'  '..VarMonth7..' '..VarMonth8..' '..VarMonth9..' '..VarMonth10..' '..VarMonth11..' '..VarMonth12..'')
		print('-- Irrigation ==> [Scheduled Months] - Scheduled months: '..VarMonth1..'  '..VarMonth2..'  '..VarMonth3..'  '..VarMonth4..'  '..VarMonth5..'  '..VarMonth6..'  '..VarMonth7..' '..VarMonth8..' '..VarMonth9..' '..VarMonth10..' '..VarMonth11..' '..VarMonth12..'')
	if(uservariables['VarScheduledMonths'] == 0) then
	commandArray['Variable:VarScheduledMonths']= '1'
			print(os.date("-- Irrigatie ==> [Maand Rooster] - Vandaag is het een dag in %B, en is NIET jouw ingeroosterde voorkeurs irrigatie maand"))
			print(os.date("-- Irrigation ==> [Scheduled Months] - Today is a day in %B, and isn't scheduled for irrigation"))
		print('-- Irrigation ==> [Scheduled Months] - Scheduled months are: '..VarMonth1..'  '..VarMonth2..'  '..VarMonth3..'  '..VarMonth4..'  '..VarMonth5..'  '..VarMonth6..'  '..VarMonth7..' '..VarMonth8..' '..VarMonth9..' '..VarMonth10..' '..VarMonth11..' '..VarMonth12..'')
	if(uservariables['VarScheduledMonths'] == 1) then
	commandArray['Variable:VarScheduledMonths']= '0'
-- Scheduled Day Time
if (timeofday['Daytime']) and (time.hour < 12)
then
		if  (uservariables['VarScheduledTODcurrent'] ~= 0) then
				commandArray['Variable:VarScheduledTODcurrent']= '0'
elseif (timeofday['Daytime']) and (time.hour >= 12)
then
		if (uservariables['VarScheduledTODcurrent'] ~= 1) then
			commandArray['Variable:VarScheduledTODcurrent']= '1'
elseif (timeofday['Nighttime']) and (time.hour < 22)
then
		if (uservariables['VarScheduledTODcurrent'] ~= 2) then
			commandArray['Variable:VarScheduledTODcurrent']= '2'
elseif (timeofday['Nighttime']) and (time.hour >= 22)
then
		if (uservariables['VarScheduledTODcurrent'] ~= 3) then
			commandArray['Variable:VarScheduledTODcurrent']= '3'
then
if (uservariables['VarScheduledTODcurrent']) == tonumber (VarTimeOfDay) then
		print("-- Irrigatie ==> [Rooster] - Huidige dagdeel komt overeen met jouw voorkeurs dagdeel")
		print("-- Irrigation ==> [Scheduled Time] - Time of the Day matches your desired scheduled TimeOfTheDay")
	if (uservariables['VarScheduledTOD']) == 0 then
	commandArray['Variable:VarScheduledTOD']= '1'
		print("-- Irrigatie ==> [Rooster] - Huidige dagdeel komt NIET overeen met jouw voorkeurs dagdeel")
		print("-- Irrigation ==> [Scheduled Time] - Time of the Day doesn't match your desired scheduled TimeOfTheDay")
	if (uservariables['VarScheduledTOD']) == 1 then
	commandArray['Variable:VarScheduledTOD']= '0'
-- Irrigation Program
if (uservariables['VarScheduledTOD'] == 1
	and uservariables['VarScheduledMonths'] == 1
	and uservariables['VarScheduledDays'] == 1
	and uservariables['VarMoistHumCon'] == 1
	and uservariables['VarMoistTempCon'] == 1
	and uservariables['VarBuienRadarCon'] == 1
	and uservariables['VarWeatherCon'] == 1
	and uservariables['VarMoistOnline'] == 1
	and uservariables['VarMoistOnlineHum'] == 1
	and uservariables['VarMoistLastSeen'] == 1
	and uservariables['VarProgramStopHum'] == 0
	and uservariables['VarManOverride'] == 0
	and uservariables['VarProgramHasRun'] == 0
	and uservariables['VarFollowsProgram'] == 0
	and uservariables['VarProgram'] == 0
	and otherdevices[VarIsPump] == 'Off')
then
commandArray['Variable:VarProgram']= '1'
then
local VarIsCounter = 'VarMaxRunTime'
local VarMax = VarMaxRunTime * -1
	print('-- Irrigatie [PROGRAMMA]')
    print('-- Irrigation [PROGRAM]')
if otherdevices[VitManOverride]  == 'On' and uservariables['VarManOverride'] == 0
	then
	commandArray['Variable:VarManOverride']= '1'
elseif otherdevices[VitManOverride]  == 'On' and uservariables['VarManOverride'] == 1 and uservariables['VarMaxRunTime'] ~= VarMax
	then
	commandArray['Variable:VarMaxRunTime']=tostring(VarMax)
	commandArray['Variable:VarProgram']= '0'
	commandArray[VarIsPump]='Off'
elseif otherdevices[VitManOverride]  == 'Off' and uservariables['VarManOverride'] == 1
	then
	commandArray['Variable:VarManOverride']= '0'
function info(msg)
		print('-- Irrigatie ==> [Programma] - ' .. msg)
		print('-- Irrigation ==> [Program] - ' .. msg)
function may_update(is_irrigate)
	counter = tonumber(uservariables[VarIsCounter])
	if is_irrigate and uservariables['VarManOverride'] == 0 and counter >= 0 then
	elseif not is_irrigate and uservariables['VarManOverride'] == 0 and counter <= 0 then
		counter = math.max(VarMaxRunTime * -1, counter - 1)
	if uservariables['VarManOverride'] == 0 then
		counter = 0
		commandArray['Variable:' .. VarIsCounter]=tostring(counter)
	result = false
	if is_irrigate and counter >= 1 then
		result = true
	elseif not is_irrigate and math.abs(counter) >= VarMaxRunTime then
		result = true
	return result
function on_off(is_irrigate)
	update_allowed = may_update(is_irrigate)
		info('Pomp Status [' .. otherdevices[VarIsPump] .. ']')
		info('Pump State [' .. otherdevices[VarIsPump] .. ']')
		if otherdevices[VarIsPump] == 'Off'
			and uservariables['VarProgram'] == 1
			and is_irrigate then
 			commandArray[VarIsPump]='On'
		elseif (otherdevices[VarIsPump] == 'On'
				and not is_irrigate) then
function is_VarProgram_aan()
	result = false
	result = (uservariables['VarProgram'] == 1)
    return result
	on_off(is_VarProgram_aan())
if (uservariables['VarScheduledTOD']) == 0 and (uservariables['VarProgramHasRun']) == 1
	then
	commandArray['Variable:VarProgramStopHum']= '0'
-- Irrigation Program manual or automatic check
if uservariables['VarMaxRunTime'] >= 0 and otherdevices[VarIsPump] == 'Off'
then
if otherdevices[VarIsPump] == 'On' and uservariables['VarFollowsProgram'] == 0
then
		print('-- Irrigatie ==> [Programma] - Irrigatie programma manueel gestart')
		print('-- Irrigation ==> [Program] - Irrigation program started manually')
-- Irrigation Program Max Run Time Remaining
if uservariables['VarMaxRunTime'] <= 0 and otherdevices[VarIsPump] == 'On' and uservariables['VarFollowsProgram'] == 1
then
VarRemaining_counter = uservariables['VarMaxRunTime']
VarRemaining = VarRemaining_counter + VarMaxRunTime -1
		print('-- Irrigatie ==> [Programma] - [' .. VarRemaining .. '] minuten resterend totdat programma word beeindigd')
		print('-- Irrigation ==> [Program] - [' .. VarRemaining .. '] minutes remaining until irrigation will stop')
-- Stop Irrigation when Moist Humidity has reached your desired humidity
if (uservariables['VarFollowsProgram']) == 1 and (uservariables['VarProgramStopHum']) == 0
	and smoistsensorHumidity >= tonumber (VarTarHum)
then
	commandArray['Variable:VarProgramStopHum']= '1'
if (uservariables['VarFollowsProgram']) == 1 and (uservariables['VarProgramStopHum']) == 1
then
if uservariables['VarProgramHasRun'] == 1
	then
		print('-- Irrigatie ==> [Programma] - Irrigatie programma heeft vandaag al geirrigeerd, Grondvochtigheid target is behaalt')
		print('-- Irrigatie ==> [Programma] - Programma word op de eerst volgende irrigatie dag herstart')
		print('-- Irrigation ==> [Program] - Irrigation program already irrigated today and soil humidity reached target')
		print('-- Irrigation ==> [Program] - Program will reactivated on the next scheduled irrigation day')
-- Irrigation Program Stop Information
	then
		print('-- Irrigatie ==> [Programma] - Irrigatie programma heeft vandaag al geirrigeerd, Grondvochtigheid target is NIET behaalt')
		print('-- Irrigation ==> [Program] - Irrigation program already irrigated today but soil humidity didnt reached target')
if uservariables['VarProgramHasRun'] == 0 and uservariables['VarProgram'] == 0 and uservariables['VarManOverride'] == 0 and otherdevices[VarIsPump] == 'Off'
	then
		print('-- Irrigatie ==> [Programma] - Irrigatie programma standby, en word hervat als alle condities inorde zijn')
		print('-- Irrigation ==> [Program] - Irrigation program standby, awaiting for all conditions to be okay')
if uservariables['VarManOverride'] == 1 and otherdevices[VarIsPump] == 'Off'
	then
		print('-- Irrigatie ==> [Programma] - Irrigatie programma manueel gestopt')
		print('-- Irrigation ==> [Program] - Irrigation program Stopped, Manual Override')
Dutch Log:
Dutch Log
Dutch Log
English Log:
English Log
English Log
Setup:
- DS923+ Docker
Siewert308SW
Version 0.8
- Added validate check for switches and uservariables
- Fixed some misspelling (Do you find more misspellings, please let me know
- Added Max MoisSensor Last Seen option
   @since: 2015-07-12
Credits:
The Hardware i use:
Siewert Lameijer
Necessities:
Changelog:
Version 0.7
Version 0.7
Version 0.6
Version 0.5
Version 0.4
Version 0.3
- Clean some code
Version 0.2
Version 0.1
-- Settings Begin
local logging = 2
local wind = 'Wind'
local uv = 'UV'
local RainMax = '0'
local UVMax = '6'
-- Last Seen Max time in seconds for when the program will halt
local VarMoistLastSeen = 600
local VarTarHum = '70'
local VarMinHum = '45'
-- Scheduled Days
-- Scheduled Months
-- Settings End
-- Irrigation Program Variables Check
-- Error logging.
function error(msg)
function validate()
result = true
-- Switches and Devices Error logging.
	if not otherdevices[VarIsPump] then
		error('Device [' .. VarIsPump .. '] doesnt exist.')
			result = false
	if not otherdevices[VitManOverride] then
		error('Device [' .. VitManOverride .. '] doesnt exist.')
				result = false
	if not otherdevices[weatherstation] then
		error('Device [' .. weatherstation .. '] doesnt exist.')
				result = false
	if not otherdevices[wind] then
		error('Device [' .. wind .. '] doesnt exist.')
				result = false
	if not otherdevices[rain] then
		error('Device [' .. rain .. '] doesnt exist.')
				result = false
		error('Device [' .. uv .. '] doesnt exist.')
				result = false
	if not otherdevices[MoistSensor] then
		error('Device [' .. MoistSensor .. '] doesnt exist.')
				result = false
-- User Variables Error logging.
	if not uservariables['VarBuienRadarCon'] then
		error('User Variable [ VarBuienRadarCon ] doesnt exist.')
		result = false
	if not uservariables['VarFollowsProgram'] then
		error('User Variable [ VarFollowsProgram  ] doesnt exist.')
		result = false
	if not uservariables['VarManOverride'] then
		error('User Variable [ VarManOverride  ] doesnt exist.')
		result = false
	if not uservariables['VarMaxRunTime'] then
		error('User Variable [ VarMaxRunTime  ] doesnt exist.')
		result = false
	if not uservariables['VarMoistHumCon'] then
		error('User Variable [ VarMoistHumCon  ] doesnt exist.')
		result = false
	if not uservariables['VarMoistLastSeen'] then
		error('User Variable [ VarMoistLastSeen  ] doesnt exist.')
    	result = false
	if not uservariables['VarMoistOnline'] then
		error('User Variable [ VarMoistOnline  ] doesnt exist.')
		result = false
	if not uservariables['VarMoistOnlineHum'] then
		error('User Variable [ VarMoistOnlineHum  ] doesnt exist.')
		result = false
	if not uservariables['VarMoistTempCon'] then
		error('User Variable [ VarMoistTempCon  ] doesnt exist.')
		result = false
	if not uservariables['VarProgram'] then
		error('User Variable [ VarProgram  ] doesnt exist.')
		result = false
	if not uservariables['VarProgramHasRun'] then
		error('User Variable [ VarProgramHasRun  ] doesnt exist.')
		result = false
	if not uservariables['VarProgramStopHum'] then
		error('User Variable [ VarProgramStopHum  ] doesnt exist.')
		result = false
	if not uservariables['VarScheduledDays'] then
		error('User Variable [ VarScheduledDays  ] doesnt exist.')
		result = false
	if not uservariables['VarScheduledMonths'] then
		error('User Variable [ VarScheduledMonths  ] doesnt exist.')
		result = false
	if not uservariables['VarScheduledTOD'] then
		error('User Variable [ VarScheduledTOD  ] doesnt exist.')
			result = false
	if not uservariables['VarScheduledTODcurrent'] then
		error('User Variable [ VarScheduledTODcurrent  ] doesnt exist.')
		result = false
	if not uservariables['VarWeatherCon'] then
		error('User Variable [ VarWeatherCon  ] doesnt exist.')
		result = false
return result
-- END Irrigation Program Variables Check
if validate() then
-- Windmeter data:
-- Rainmeter data:
-- UV data:
then
    totalrain = 0
    rainlines = 0
       while true do
       file:close()
       return(averagerain)
       minutes=120
          verw = 3
          verw = 2
then
then
t1 = os.time()
if (Moist > VarMoistLastSeen) then
print('--')
	print('--')
	print('--')
	then
-- Scheduled Months
then
then
then
then
then
then
then
then
	then
	then
	then
function info(msg)
		counter = 0
	result = false
		result = true
		result = true
	return result
	result = false
    return result
	then
then
then
then
then
then
	then
	then
	then
	then
Setup:
- DS923+ Docker
Siewert308SW
V1.0 of the script has been released and opened a new topic for this script only.
viewtopic.php?f=38&t=7290
Setup:
- DS923+ Docker
epierre
Post by epierre »
So bad I've not been able to follow this post...
Is there a way to make it work outside of netherland (without buienradar) ? does forecast.io would provide the same rain forecast ?
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
zicht
Domoticz version: 2023.1+
Post by zicht »
How is the heat dissipation with your systems ?
I have a 220V washing machine valve installed, but i reduced the water pressure significant by a pressure reducer to make it more workable and dose the amount of water spilled. However the valve seems to become very warm (HOT!) now....
I am just curious if you have the same effects ?
I love your work in this project !
ThinkPad
Post by ThinkPad »
Washingmachine valve is not built to operate long times. Maybe being activate for a minute or so (to fill the drum) and then off for a while.
You could have a look for some butterfly valve or magnet valve. Keyword for having it active for a while is 'duty cycle', look it up so you know what to look for :)
epierre
Post by epierre »
Water valves are "normally off", it means the solenoïd is pushed down by a spring, and when there is a current delivered, the solenoid goes in open mode. Thus it avoid electricity linked water leaks (remember that the pressure must be compensated by the spring while it is off !).
In my garden the valves heat when they are in use which is normal for there is dissipation, nothing is wrong on this.
ThinkPad
Post by ThinkPad »
Ok, but don't you think there is a difference between a washingmachine valve and a valve meant for irrigation purposes?
I think there is (different coil or something).
epierre
Post by epierre »
ThinkPad wrote:Ok, but don't you think there is a difference between a washingmachine valve and a valve meant for irrigation purposes?
from the picture I see at the beginning no, there is a body and a top, the top holds the spring and the solenoïd it pushes in the bottom.
the washing machine valve has the same design issues that a water gardening one, have water only when needed and never leak in between, for domestic use pressure is between 3-6 bars max 10, in industrial irrigation it can be much more...
heat is not an issue if you water for some minutes, just do not control your inhouse water system with it always on ;-) it is not the same use ;-)
there are quater turn valves if you want to cut your domestic water in case you find a leak, but usually there is a servo motor and this is much more expensive.
blackdog65
Just a quick note...
I've been having problems with pressure loss through the washing machine valves so I bought one of these
http://www.ebay.co.uk/itm/321813372024? ... EBIDX%3AIT
It fits straight onto a standard radiator TRV body. When energized it takes about 20-30 secs to open and the same to close but the flow looks good in preliminary testing.
If it's all good I'll make up a little 4 port manifold with these on and give it a try :D
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
curious
Re: [DIY] Garden irrigation and learning project
Post by curious »
@siewert.
I am not allowed to send you a private message because I just joined this forum for a few days.
The photos seems to be removed from your own server/site? Is there a way to publish them again ?
Allthough I am living not far from Zoutkamp I don't want to go and stare in your garden. :)
BarryT
Domoticz version: 2024.3
Post by BarryT »
i'm getting these errors, any idea?
2016-04-24 12:44:00.437 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_irrigatie2.lua: /home/pi/domoticz/scripts/lua/script_time_irrigatie2.lua:334: attempt to index field '?' (a nil value)
2016-04-24 12:44:00.454 Error: EventSystem: in /home/pi/domoticz/scripts/lua/--script_time_irrigatie.lua: /home/pi/domoticz/scripts/lua/--script_time_irrigatie.lua:291: attempt to concatenate global 'VarIsPump' (a nil value)
*Edit, its working allready :)
