Page 3 of 4
Re: Netatmo thermostat support
Posted: Wednesday 04 April 2018 22:15
by Jazzle
Anyone reading this has managed to get a Vaillant vSmart (rebranded NetAtmo thermostat) working in Domoticz?
Posted: Sunday 13 May 2018 19:34
by pipiche
Just to let you know that Netatmo Valves are available on Beta from version #9433 or higher
Posted: Sunday 03 June 2018 1:53
by NeoMod
deejc wrote: Thursday 03 March 2016 11:54
I set mine (in hardware) if no response in 15 minutes it restarts the worker
Thank you! I know it's an old post but indeed this simple trick solved my problem.
Posted: Sunday 03 June 2018 17:54
by pipiche
You right. I made a 15' timeout as well, as I was loosing connectivity !
Posted: Sunday 09 September 2018 16:52
by xavierlp
Hello pipiche
I've got 2 Netatmo vannes, and I'd like to know how you can see it?
I'm using stable version V4.97
Thanks a lot
Posted: Sunday 09 September 2018 17:58
by pipiche
YOu might have to delete the Netamo Hardwar from Domoticz and add it again
Posted: Wednesday 07 November 2018 20:51
by BazsoDombiAndras
Hello Guys!
I have recently re-built my Domoticz server from zero because the old one had lots and lots of reliability problems. In the new Domoticz server running the latest version I have noticed a few good and bad changes about the Netatmo thermostat (compared to how it worked in the old version):
Good:
- There is individual support for every room controlled by Netatmo thermostat and/or smart radiator valves
Bad:
- All the Netatmo thermostat devices in Domoticz fail to refresh for many hours and then they refresh and then they don't get refreshed for many hours again. There's something wrong here... And I see that this problem has been reported in this thread by several users 3 years ago already. Yes, sure, we can set a data timeout, but that's a workaround, not a fix... any chance this will be fixed?
- In the old version there used to be also a switch showing the state of the main thermostat (basically the state of the boiler)(ON/OFF). I can't find that in the new version
- There is an "Away" switch for each individual room. That's not how it works in Netatmo. In Netatmo there is one global away switch. Even in Domoticz all the away switches for all rooms are somehow tied together. If you modify the state of one of them, all the others automatically get the same state. So I don't see why there are many of them...
Posted: Friday 11 January 2019 21:22
by pozidz
Hi there,
BazsoDombiAndras wrote: Wednesday 07 November 2018 20:51
Bad:
Did this happened before too?
Do Neatmo APP get properly updated?
Regards.
Pozidz
Posted: Saturday 12 January 2019 9:38
by BazsoDombiAndras
This only happens with the new version of Domoticz. Yes, the Netatmo app refreshes properly. The problem seems to be in Domoticz.
Posted: Sunday 13 January 2019 15:53
by jorijnsmit
Does Domoticz support Netatmo's valves directly or is there always a need for the Netatmo's Relay as well?
I guess the valves do not communicate over Wi-Fi directly but will always need the Relay in order to be controlled and read out correctly. Is this true?
Posted: Sunday 13 January 2019 18:32
by BazsoDombiAndras
The Netatmo system needs either a main thermostat or a boiler controller module, the valves do not work independently, they communicate over radio waves through some proprietary protocol, not WiFi. Only the main thermostat or the boiler controller module use WiFi.
Posted: Tuesday 10 September 2019 15:54
by yannig
get some synchronization problem with Healthy Home Coach since July, see the following post here :
https://www.domoticz.com/forum/viewtopi ... 67#p223667
Posted: Thursday 09 January 2020 16:34
by fabd
Hello
Up for the thread.
I have last domoticz version (beta) and after removing the netatmo hardware and create a new one, i don't have my valve in new device.
Only thermostat and weather station.
How to get the valve ?
thanks
Posted: Sunday 05 April 2020 21:31
by albamatti
Hi there,
I followed these instructions to get my Netatmo Valves visible.
https://www.domoticz.com/wiki/Netatmo.
Without any succes. I'm using Version 2020.1 (March 22th 2020) on a RPI4.
It is possible to get my weatherstation-data into Domoticz. Anyone succeded in adding Netatmo Valves?
Posted: Tuesday 24 November 2020 10:56
by fabd
Hello
UP for the topik
One year have past; Still the same problem. I have the latest production version
comment mettre un site en ligne gratuitement
After creating a new worker, i only see Thermostat and temperature sensor. I don't have my 7 valves
Even if i change manually the set point temperature on some valve, the discovered item remain the same.
Why ?
Posted: Friday 08 January 2021 12:39
by Sylar6725
I have the same issue.
I have open a issue on github (
https://github.com/domoticz/domoticz/issues/4402) but no anwser.
Maybe someone who have this problem can add a comment. Maybe I didn't explain myself correctly (i'm french).
Posted: Saturday 06 February 2021 20:49
by albamatti
I am having the same issue!
Posted: Saturday 08 January 2022 13:41
by homeJLB
I believe there is a new API from Netatmo
with differend types;
NETYPE_WEATHER_STATION
NETYPE_HOMECOACH
NETYPE_ENERGY
NETYPE_SECURITY
Not sure the plugin can use all the types
Posted: Thursday 03 March 2022 3:09
by Sylar6725
Good news
The Netatmo plugin has been fixed (
https://github.com/domoticz/domoticz/pull/5174)
You need to install the beta version to have the fix
After that, you just have to authorize the detection of new devices, go to the hardware page, select the netatmo plugin and just click on modify.
Now the valves and thermostat are available in the devices
Make sure you have a backup in case the beta doesn't work properly.
No problem in my case
Posted: Monday 14 March 2022 21:14
by zicht
dear
version 2022.1 14279
Netatmo coach (air quality sensor)
Netatmo correct detected on enabling hardware.
"Netatmo has found no devices" error after 10 minutes and keeps repeating on HW interval,
2022-03-14 21:27:23.533 Status: Netatmo: No Weather Station devices found...
The values are not updated correctly, especialy CO2
Work around : set timeout on hardware tap on 10 minutes.
Status: Netatmo: Worker started...
This way the HW is restarted and values are captured as on initial detection
Br
