MySensors - Gateway to Domoticz
- blackdog65
Re: MySensors - Gateway to Domoticz
Does anyone use MYSController?
I have it running under Wine on Linux Mint (Domoticz master) with no problems.
I have a serial gateway that will report to Domoticz on my Mint PC. This works fine and MSController connects fine. When I tried to move my gateway to a remote installation of Domoticz on a Raspberry Pi (same network) MSController cannot see it if I try to connect by TCP. I hope it's just something silly like port no. or something, but any ideas?
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
- blackdog65
Ah... a little help from the developer... install ser2net and edit the conf file to pipe it across
it was actually a lot easier than it sounds and now I can debug MySensors from any pc on my network
Big thanks to Tekka
Big thanks to Tekka
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
- bjornhallberg
- Domoticz version: Beta?
Any way to get the battery readings to work? I only have the voltage divider (and code) on some of my sensor nodes but it seems the data is getting mixed up when read by Domoticz? I.e. sensors are getting the battery readings of other sensors. Sensors that never report a value get a value anyway.
Fantastic to finally have MySensors and Domoticz working together btw!
Hendrik
I had the same, its in the log, but no new devicedeennoo wrote:Hello,
i try to get Pulsesensor for water and power, using the usb gateway
got this log on domoticz :
2015-02-15 21:55:57.848 MySensors: Node: 69, Sketch Name: Water Meter
but nothing gones on unused device (of course accpet new is active).
I made a temp/hum sensor who works very well.
Any one got an idea ?
do you have this working yet??
CubieTruck with Domoticz
RfxTrx 433Mhz Usb, Rfx Sensor, Z-Wave
Slave Raspberry Pi with Domoticz, Piface, P1 usb
ThinkPad
Maybe a dumb question, but how do i get the MySensor stuff added in Domoticz?
I have a working setup (gateway + 1 node) lying on my desk. I can read it fine with 'MYSController' in Windows (nice tool btw!) but now want to add it to Domoticz.
Do i add it under Setup > Hardware as a new device or so? I don't see any 'MySensors' device there (v2.2284 on my NAS).
ThinkPad
Thanks, already thought that. Not sure if i want to do that on my NAS as i prefer a stable and reliable system.
I have a Pi lying around, will try it there, thanks. I can then add the MySensors stuff like i said? Under setup > hardware ?
ThinkPad
Got it working
Quite a nice project, MySensors.
Very easy to build some sensors!
But a weird thing, i have 2x DS18B20 connected to my node, But only one of them is seen by Domoticz (only one device created)....
If i read the gateway with the MYSController i can see that two temperatures are updated every time.
So some translation MySensors <> Domoticz needs to be worked on.
Built the bh1750 lux sensor. Its registered in domoticz log as lux (unkown). Theres is no device listed in devicelist either.
- gizmocuz
If the log says something like
(MySensors) Lux (Unknown)
this means, it is added internally, and you should be able to find it in the devices tab.
If it is not there, make sure 'accept new hardware' is enabled in the settings
- gizmocuz
Should be fixed in the latest betaThinkPad wrote:Got it working
- gizmocuz
This type of sensor is not yet supported yet.Hendrik wrote:I had the same, its in the log, but no new devicedeennoo wrote:Hello,
Could you PM me your sketch ?
gizmocuz wrote:If the log says something like
I got it in the dveice tab no, but it does not update Lux value. Its static on 1000 Lux
I found the error.
Domoticz add 1 zero on every reading. 10 lux in the arduino log is 100 in domoticz. And domoticz readings dont go higher than 1000 lux.
ThinkPad
I have installed v2.2329 on the Pi, but unfortunately still only one temperaturesensor is shown under devices and in the log.gizmocuz wrote:Should be fixed in the latest betaThinkPad wrote:Got it working
- gizmocuz
Please try with the below sketch:ThinkPad wrote:I have installed v2.2329 on the Pi, but unfortunately still only one temperaturesensor is shown under devices and in the log.gizmocuz wrote:Should be fixed in the latest betaThinkPad wrote:Got it working
#include <SPI.h>
#include <MySensor.h>
#define TEMP1_CHILD_ID 0
#define TEMP2_CHILD_ID 1
#define TEMP3_CHILD_ID 2
#define SLEEP_TIME 30000
#define SN "Multi temp test"
#define SV "1.1"
MySensor gw;
MyMessage temp1Msg(TEMP1_CHILD_ID, V_TEMP);
MyMessage temp2Msg(TEMP2_CHILD_ID, V_TEMP);
MyMessage temp3Msg(TEMP3_CHILD_ID, V_TEMP);
void setup()
gw.begin(NULL, AUTO, false);
// Send the Sketch Version Information to the Gateway
gw.sendSketchInfo(SN, SV);
gw.present(TEMP1_CHILD_ID, S_TEMP);
gw.present(TEMP2_CHILD_ID, S_TEMP);
gw.present(TEMP3_CHILD_ID, S_TEMP);
void loop()
// Process incoming messages
gw.process();
float temperature_1 = 19.5;
float temperature_2 = 23.4;
float temperature_3 = 4.8;
Serial.print("Temperature_1 = ");
Serial.println(temperature_1);
Serial.print("Temperature_2 = ");
Serial.println(temperature_2);
Serial.print("Temperature_3 = ");
Serial.println(temperature_3);
gw.send(temp1Msg.set(temperature_1,2));
gw.send(temp2Msg.set(temperature_2,2));
gw.send(temp3Msg.set(temperature_3,2));
//Sleep
gw.sleep(SLEEP_TIME);
ThinkPad
I'm sorry, i responded too fast i think. The second temperature sensor just popped up under devices
Just had to wait some longer i think?
Nice
Now on to the watermeter sketch: http://www.mysensors.org/build/pulse_water , been wanting that for a long time. Can i help in some way? Providing some testdata or so?
Nice
- gizmocuz
Working on it as we speak....ThinkPad wrote:I'm sorry, i responded too fast i think. The second temperature sensor just popped up under devicesJust had to wait some longer i think?
Nice
The pulsemeter (water) example on the mysensors website has a serious bug!
If the requested value (VAR_1) is not received from the main software (domoticz in my case), then it will send requests as fast as it can, endlessly
Anyway, i am trying to create a new sample, and implementation... can take some time
ThinkPad
I think i am already seeing that. Connected 'MYSController' to the Ethernet gateway i made, and i see the application constantly scrolling, only thing it displays is:
RECV REQ VAR1
Nice, looking forward to it! Let us know if we can help in any way
RECV REQ VAR1
