Page 3 of 3
Re: Compatible Smoke detectors
Posted: Wednesday 27 December 2017 11:28
by jono
Hi mark ,
I’m looking for a couple smoke detectors that’s easy to set up and test You link no longer working
What type did you use
Thanks in advance
Jon
Posted: Thursday 28 December 2017 14:56
by markk
Posted: Wednesday 10 January 2018 22:34
by sion
i have 3 of these working well enough. they link well, and can activate from domoticz and get notifications etc, but have found they eat through batteries. How have you found them?
Is anyone else using any different ones?
Posted: Friday 09 February 2018 10:36
by mayyam
Hi, how You menage to pair it with Domoticz?
I pressed Learn Light/Switch then pressed TEST button on Smoke Detector. Domoticz asked what type i want to have, i chose Smoke Detector.
Now when i press TEST button my SMOKE switch is going ON and that's ok.
But what i have to do to make him cry?
When i press that virtual switch (SMOKE) nothing happens. The only reaction i can get is when i put the Smoke Detector in LEARN mode and press my virtual switch (SMOKE), then Detector beeps few times and going out from learning mode.
What i'm, doing wrong here?
Posted: Friday 09 February 2018 11:02
by elythomaslumber
Does anyone know if those are compatible to RFXCom?
https://www.smartwares.shop/smartwares- ... 5rf-2.html
Currently they very cheap:
https://www.pollin.de/p/funk-rauchmelde ... eck-580627 They are compatible to RM175
Posted: Friday 09 February 2018 11:57
by aleph0
Hi !
I'm using those ones :
https://www.aliexpress.com/item/Free-Sh ... 30727.html There are very sensitive to smoke, very loud and compatible with RFXCom. 1 way only, we can't trigger the alarm from domoticz
Posted: Friday 09 February 2018 15:38
by b_weijenberg
The RM174 is received by the RFXtrx433E with Ext2 firmware and ARC enabled.
Posted: Sunday 22 April 2018 2:00
by sion
mayyam wrote: Friday 09 February 2018 10:36
I didn’t press the learn light switch.
I had accept new hardware on.
Pressed the test button on the Alarm.
Then went to devices, and found it there - then added from there.
If I press the button in domoticz it will Set it off.
Posted: Saturday 27 October 2018 14:46
by sincze
Installed these: Flamingo
FA21RF as described here.
viewtopic.php?t=6653#p195569
Compatible with RFLINK.
