Compatible Smoke detectors
jono
Re: Compatible Smoke detectors
Post by jono »
markk wrote: Thursday 15 January 2015 13:49 I've got two of these linked and working well. I can activate them from Domoticz and have set notifications so I get alerted if they go off.
http://www.amazon.co.uk/gp/product/B00A ... ge_o02_s00
Hi mark ,
I’m looking for a couple smoke detectors that’s easy to set up and test You link no longer working
What type did you use
Thanks in advance
Jon
markk
Post by markk »
sion
Post by sion »
markk wrote: Thursday 28 December 2017 14:56 Hi Jon. These are the ones: https://www.ebay.co.uk/i/371945202188?c ... 3083842978
i have 3 of these working well enough. they link well, and can activate from domoticz and get notifications etc, but have found they eat through batteries. How have you found them?
Is anyone else using any different ones?
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
mayyam
Domoticz version: 4.11333
Post by mayyam »
Hi, how You menage to pair it with Domoticz?
I pressed Learn Light/Switch then pressed TEST button on Smoke Detector. Domoticz asked what type i want to have, i chose Smoke Detector.
Now when i press TEST button my SMOKE switch is going ON and that's ok.
But what i have to do to make him cry? ;) When i press that virtual switch (SMOKE) nothing happens. The only reaction i can get is when i put the Smoke Detector in LEARN mode and press my virtual switch (SMOKE), then Detector beeps few times and going out from learning mode.
What i'm, doing wrong here?
_______________
- Dell FX-160 / Ubuntu 16.04
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
elythomaslumber
Domoticz version: 2023.1
Post by elythomaslumber »
Does anyone know if those are compatible to RFXCom?
https://www.smartwares.shop/smartwares- ... 5rf-2.html
Currently they very cheap: https://www.pollin.de/p/funk-rauchmelde ... eck-580627 They are compatible to RM175
aleph0
Domoticz version: 11838
Post by aleph0 »
Hi !
I'm using those ones :https://www.aliexpress.com/item/Free-Sh ... 30727.html There are very sensitive to smoke, very loud and compatible with RFXCom. 1 way only, we can't trigger the alarm from domoticz
b_weijenberg
Post by b_weijenberg »
The RM174 is received by the RFXtrx433E with Ext2 firmware and ARC enabled.
RFX-433, RFX-433EMC, RFX-868
sion
Post by sion »
mayyam wrote: Friday 09 February 2018 10:36 Hi, how You menage to pair it with Domoticz?
I didn’t press the learn light switch.
I had accept new hardware on.
Pressed the test button on the Alarm.
Then went to devices, and found it there - then added from there.
If I press the button in domoticz it will Set it off.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
sincze
Domoticz version: 2024.4
Post by sincze »
Installed these: Flamingo FA21RF as described here.
viewtopic.php?t=6653#p195569
Compatible with RFLINK. :D
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
