Page 3 of 19
Re: Satel Integra (Security System) with ethernet module
Posted: Friday 11 September 2015 10:07
by fantom
Ok. I check how it works.
Question : where did you get this green icon ? is changing its color when violated zone? ?
Fantom
ps. I see, that this code, must be this same as in settings panel. So I can't do it that way as you showed.
Posted: Friday 11 September 2015 11:17
by proohu01
I know it is not possible the way I showed. But I ment something 'like' that.
The icon is a custom icon I downloaded somewhere on the Internet. Yes it changes color when the state changes. I my case it is gray when disarmed and green when armed. The screenshot is from a PiFace input that is also connected to my Satel. That is the way I used to connect to my Satel before you came along
PS. You know that you can use custom icons for switches in Domoticz by using the "custom icons" from the menu right?
Posted: Friday 11 September 2015 11:38
by fantom
Yes. I know.
But if you want use custom icon for satel module for zones, you must use 3 states:
xxx_0 - normal
xxx_3 - violate
xxx_4 - alarm.
Fantom
Posted: Friday 11 September 2015 12:26
by proohu01
Yes, but not for switching it on or off. It is armed or disarmed.
Posted: Friday 11 September 2015 12:59
by fantom
Yes. Not for arming but .... maybe i add more option for it (for example 'mode' from 0 to 3).
Or i replace one "arm" switch by four switches (one for each mode)
Fantom
Posted: Saturday 12 September 2015 9:13
by fantom
Today I did support for alert icon on devices tab. Now will be correct colors icons.
Fantom
Posted: Sunday 13 September 2015 11:20
by tcviper
Ok, since there is almost no info posted here on how to use/install this Satel integration I wanted to ask a few questions:
What is the default port for this connection (7094?) and what password should be set? The one from a user? the master one or another??
Posted: Sunday 13 September 2015 12:22
by fantom
I don't know how you set port in ETHM1 - but default is 7094
Password (user code) needed only for arming/disarming now. This is code (for one user) which you use on security keyboard for arming/disarming.
Let me know how the tests. In the logs you have information about connecting, errors, etc.
The newest version with many my changes for Integra is 2.3011
Fantom
Posted: Sunday 13 September 2015 17:12
by tcviper
Could it be that you can only connect the Integra to one Domotica system? We also have it connected to our Fibaro HC2. Or should it be possible to add it to both at the same time?
2015-09-13 17:13:16.033 Satel Integra: Create instance
2015-09-13 17:13:16.034 Satel Integra: connected to 192.168.1.xx:7094
2015-09-13 17:13:16.035 Satel Integra: busy
2015-09-13 17:13:16.035 Error: Satel Integra: Get info about Integra is failed
Posted: Sunday 13 September 2015 20:51
by fantom
ETHM1 accepts only one connection
Fantom
Posted: Sunday 13 September 2015 20:57
by tcviper
To bad
Posted: Friday 25 September 2015 20:00
by rdebruijn
Hi, I recently bought an Integra 32 with ETHM1-PLUS, and your plugin/code works like a charm! I know it's also possible with the FIbaro to use Z-wave sensors as sensors for the Integra. Will this be also implemented in Domoticz plugin? Would be perfect if we can use other sensors in Domoticz as input for zones on Integra.
Posted: Friday 25 September 2015 21:13
by fantom
I don't know how working Fibaro with Integra. Do You give me a more information ?
Fantom
Posted: Monday 28 September 2015 23:10
by rdebruijn
On this page it is described at bullet "3)"
Unfortunately it is in Dutch however i think Google translate can make it well readable.
Basically it describes that with the Fibaro home center integration for Satel alarm panels,
The z-wave sensors connected to Fibaro HC can be used as sensors in the Satel,
And the Satel sensor states can be shown and used in Homecenter.
So this last part you already accomplished (show Satel sensor status in Domoticz) but I'm eager to know
if the use of sensors in Domoticz as sensors for the Satel panel
would be possible
http://www.robbshop.nl/over-z-wave/z-wa ... integratie
Posted: Tuesday 29 September 2015 8:05
by proohu01
Hi, rdebruijn,
As far as I'm aware, of all the home automation protocols and device types out there, Satel is only able to communicate with KNX bus directly. The Satel is not able to communicate with zwave devices and visa versa. However, if you put a homeautomation gateway in the middle (such as a Fibaro Homecenter or Domoticz or etc etc) you can probably create some additional functionality.
I think what you are looking for is a way to trigger input zones or output zones on the Satel from within Domoticz right? That should be possible and would actually be very nice to have.
Posted: Tuesday 29 September 2015 19:42
by rdebruijn
Hi proohu01, fantom,
Yes proohu01 this is exactly what i mean. Would be a very nice feature, and this also how the integration with Fibaro Homecenter is described. To use Z-wave devices via the home-automation gateway (in this case Domoticz) to trigger input or output zones for the Satel alarm system.
Posted: Tuesday 29 September 2015 20:26
by fantom
I do not understand anything.
Please, teel me what You want, and I will develop this
Fantom
Posted: Thursday 01 October 2015 9:28
by proohu01
fantom wrote:I do not understand anything.
Fantom
Fantom,
In the first post, I supplied a link to the technical ETHM-1 document. On page 7, the section "Part 2 - INTEGRA control" describes that you can also change the output state on/off (0x88 and 0x89) and trigger alarms. It would be nice to have this intergrated into Domoticz.
This way, you can use
any domotica event (not only Fibaro zwave devices) to trigger an alarm or change the state of one of the Satel outputs.
Posted: Thursday 01 October 2015 9:59
by fantom
Hmmm, I think that understand what you say, but this functionality exists in module Satel for domoticz now.
For this moment module can :
1) add to domoticz zones with name from Integra - alert type
2) add to domoticz outputs with name from Integra - switch type (and text type for not switchable outputs)
3) add to domoticz device "Arm" - switch type
4) add to domoticz device "alarm" - alert type
3) read zones states
4) read output states
5) read alarm state
6) read arm state
7) switch arm/disarm
8) switch outputs to on/off
9) read temperatures from ATD100 (only beta now)
In plans : reading events from Integra
Fantom
Posted: Friday 02 October 2015 13:31
by proohu01
I don't see any switch capable devices except for the ARM/DISARM switch. How would I be able to switch an output?
- satel_domoticz.png (72.77 KiB) Viewed 5982 times
