Page 3 of 16
Re: Energy Dashboard (Build in)
Posted: Thursday 13 June 2024 11:08
by Kedi
Love the new integrated custom icons. Nice job, tnx. :D
Posted: Thursday 13 June 2024 12:31
by McMelloW
Great job with the use of custom icons. Looks very good.
Some points on how the custom icons behave in my configuration. The default icons, like temperature are not changed to the icon.
One of the widgets shows heating on or of. This has a custom icon in color (On) and gray (Off) It only shows the On icon in both situations.
The dashboard looks great, thanks for your work.
Posted: Thursday 13 June 2024 13:48
by gizmocuz
HansieNL wrote: Tuesday 11 June 2024 12:35
gizmocuz wrote: Tuesday 11 June 2024 9:40 New beta version (16055)
On the download website the version is 2024.3.16055 ?? Should this not be 2024.4.16055?
Same for stable version.
Thanks for spotting, fixed!
Posted: Thursday 13 June 2024 13:49
by gizmocuz
hjzwiers wrote: Thursday 13 June 2024 10:24 I like the introduction of an energy board!
I have the solaredge modbustcp installed.
Only my total solar production I have calculated from the inverter + battery:
solar = inverter + to_battery
home = solar - (export - import) - to_battery
When I fill the values in the settings sheet the battery displays well, but the and the home values which are calculated by domoticz are too low, it ignores the Solar total value that I calculate.
I check these values with the solaredge monitor (have installed batter + in and export meter)
You don't need to calculate anything. You need to supply the current solar Watt value, and the battery Watt value, and the actual grid value (and battery SOC
You can use a Shelly EM (per phase) to measure them if you don't have these values via a API
Posted: Thursday 13 June 2024 14:42
by rezzalex
gizmocuz wrote: Tuesday 11 June 2024 17:51 @rezzalex, This might have to be done in the plugin... On a Victron system, when you set the setpoint to 1000 Watt it takes 1000 Watt from the Grid. When you set the Setpoint to -1000 Watt, it returns to the Grid.
Is this with the build in Enphase hardware?
It is also mentioned in the enphase code:
The current power charging/discharging the battery, in watts. Positive values indicate charging, negative values indicate discharging.
But I don't see the value being used.. There is a Watt sensor being made, but this holds the total charge of the battery
The value 'real_power_w' is not send to Domoticz which should contain the setpoint (current power)
Best to open an issue on github or send me a message on slack
Continuing the discussion here, for historical conversation purpose : https://github.com/domoticz/domoticz/issues/5798
Posted: Friday 14 June 2024 9:31
by gizmocuz
McMelloW wrote: Thursday 13 June 2024 12:31 Great job with the use of custom icons. Looks very good.
In the current beta I added support for more (default/custom) icons, and basic on/off icon support.
Posted: Friday 14 June 2024 13:11
by McMelloW
gizmocuz wrote: Friday 14 June 2024 9:31 In the current beta I added support for more (default/custom) icons, and basic on/off icon support.
Thanks gizmocuz, this looks great.
Posted: Saturday 15 June 2024 14:47
by akamming
Just updated to latest version. Everything is showing correctly, however I just noticed the cost of energy and gas remains zero
The energy prices are filled in in the settings. Anyone has a hint how to fix?
Posted: Sunday 16 June 2024 8:19
by gizmocuz
@akamming, best to read through this topic.
Depending on the settings (are you using 'internal' or did you specify devices), make sure if you specify devices for your prices, that they do not have a timeout
Did you wait a few hours?
Posted: Sunday 16 June 2024 9:36
by akamming
tx @gizmocuz
I read this entire thread, but can't seem to find the answer. Also don't know what you mean by "Internal or specify devices", can find a setting like that.
hope you can give me some clue how to fix...
Posted: Sunday 16 June 2024 10:11
by FireWizard
Hi @akamming,
Did you configure "Internal(meter settings) in the tab meters/counters under Dynamic prices?
Posted: Sunday 16 June 2024 11:03
by akamming
Nope. That setting is set to "Niet actief" (since i don't have dynamic prices in my contract)
Posted: Sunday 16 June 2024 11:16
by FireWizard
Hi, @akamming,
Then, that is your issue.
Change that setting to Internal (meter settings).
It might look confusing, as you configure "static" prices in a field indicated as "Dynamic prices", but it is the way to do it.
Posted: Sunday 16 June 2024 12:35
by akamming
Ok just made the change. Hopefully the other reports are then also still ok
For now I still see 0 on the cost of the energie dashboard. But maybe have to wait a few hrs…
Posted: Sunday 16 June 2024 12:45
by gizmocuz
I will change it to "(Dynamic) Price calculation" ... maybe that sounds more logical
Posted: Sunday 16 June 2024 13:48
by FireWizard
Hello @gizmocuz,
Probably a good idea, it might prevent confusion.
@akamming,
Indeed you should wait . it will show values after some hours.
Posted: Sunday 16 June 2024 18:00
by gizmocuz
Done, new beta. Also a new option to tell how the P1 Electricity report should be displayed (like now/before = High/Low Tariff , or in a simple way (only usage/return.. handy when you have a dynamic energy contract and there is no high/low anymore)
It now also uses the real (dynamic) price when available
Posted: Sunday 16 June 2024 18:15
by HvdW
How do we download it?
Automagic or install a new domoticz beta version.
Posted: Monday 17 June 2024 8:05
by akamming
FireWizard wrote: Sunday 16 June 2024 13:48 Hello @gizmocuz,
@akamming,
Yesterday after a few hrs, the cost for electricity started appearing. Gas remained zero (but i had to watch soccer instead of fixing domoticz ;-) ), so did not bother to put it on the forum yesterday
but now when i wanted to troubleshoot i see that as of this morning i now also see the cost of gas, by the amount it started calculating as of 0.00, so apparently a wait till overnight was needed to make the cost appear
tx for the help
Posted: Monday 17 June 2024 8:48
by akamming
gizmocuz wrote: Sunday 16 June 2024 12:45 I will change it to "(Dynamic) Price calculation" ... maybe that sounds more logical
question, why is the option there? You could also assume that when "not active" is selected, automatically "internal" is assumed...
